Mercedes-Benz C-Class Maintenance and Repair
...that I have to wait at least two more months before mine gets here! Who knows if I'll even have a job by then?
1. Rearmost muffler heat shield rattles when door, hood or hatch closes.
1a. Heat shield hold down bolt loose, dealer retorqued bolt.
2. When manual seats are brought forward, carpet mats catch on seat sliders, rolling over and goughing out the foam backing and leaving grease marks on top of carpet mat.
2a. MBZ regional rep verified with 3 other like vehicles, he will relate to MBZ, they will notify dealer when a resolution is available so a warranty repair can be scheduled.
3. Aluminum trim in console is mismounted, about a quarter of an inch high on right side, near cupholder door.
3a. Service advisor pushed down hard on trim, it popped down into place and stayed.
4. Rear hatch rubbing body opening at bottom outside corners, leaving abrasion marks in paint on hatch and top of bumper.
4a. MBZ regional rep verified with 3 other like vehicles, he will relate to MBZ, they will notify dealer when a resolution is available so a warranty repair can be scheduled.
5. Front grill top mounting bolts loose.
5a. Service advisor tightened bolts.
6. Windows down feature with electronic key, need to be within 2 feet of car receptor to make windows operate.
6a. No resolution yet, dealer could not verify until I picked up car and demonstrated problem to him. While pointing key at receptor in door handle, locking/unlocking works fine, window up/down feature only works sporadically. Same results with either key, windows feature will always work when very close to car, but intermittenly when further away. Service advisor will check with tech and call me.
7. Rattle in passenger door.
7a. Dealer tech lubed/adjusted side panel by glovebox.
8. Tires have 37 lbs of pressure all around from dealer.
8a. I haven't adjusted tire pressure yet, 32 lbs all around seems to be the accepted norm in my area. Mercedes recommends 28 lbs in front and 32 lbs in rear, but says additional psi is ok.
2002 C230K Hatchback Coupe, Alabaster White with Oyster Cloth interior, 6 Speed manual trans, Bose Stereo and 6 CD Changer.
I'm flip flopping between the RSX type S, the Saab 9-3 SE and the C230. The baby benz sure has some nice safety features. But how do you all deal with no rear wiper? I'd be at a serious loss in my Integra right now without one.
Seems odd, no? Anybody have some clues?
DT
I can't comment on whether it's a problem in the snow, since we had none in Jersey this winter (sure, no snow right after I decide to get steel rims and snow tires - go figure!). But I haven't really felt the need for one at all.
I know that you didn't ask, but I'll give you my reasons why I picked the ccoupe over the other two anyway: the rsx has virtually no back seat, esp. headroom. The Saab's pedal placement is odd, and the colors really suck the past two years as they limit the choices in prep for the new 9-3. Also, both are fwd with fewer safety features. Finally, my color (Orion blue) is just too good to pass up. Good luck with the choices! Enjoy the test drives.
I live and work in areas that have lots of valleys. I almost have no reception to any FM radio stations.
w1pat@yahoo.com
1998 C230
1. Rough engine. Bothered me a little at 1st, but then got used to it and am happy now. Just didnt have that throaty rumble that I thought a car like this should have. Engine is supposed to be very reliable though and so thats good.
2. Opening windows, etc with keys. Yes, its a problem, but I don't realy do it, so it hasn't bothered me too much. After reading your comments, realize it wasn't just my imagination and that you have to hold the key close to use this function. If this is the case, what's the use of the function anyway? Hope MB gets this fixed.
3. Have the sport package and have noticed quite a bit of wear on the tires. Don't think I'll get more than 12000 miles on these (Michilin zr rated). Have gotten varying answers from the dealer, but this is what I've found out and what I'm going to do. The Mich's I've got on the car right now are the summer sport tires. They only have a treadwear rating of ~ 200. This is very low. Combine this with the car's heavy weight ~4000 lbs (thats alot for sch a small car) and its no wonder the things wear out quick. So, Michilin makes an all season YR rated tire that has a treadwear rating of ~400. 1st, I've driven this car in snow once and its an experence I don't want to hacve again. Rear wheel drive, wide tires, lots of power, look out. 2nd these YR rated tires are still low profile, etc, etc, so the look will be the same. 3rd, I don't think I'll sacrifice so much in handleing.
Anyway, jyst some issues I've had. Hope this helps
Revka
Hatchbacks & Wagons Host
Noise...from the engine... If it is a 2002, that supercharger does make noise when first started. Get used to it. If it is a 2003, with the loss of one horsepower and a significantly smaller engine ( 1.8 ) have the dealer check the balance shafts.
Let me know if this helps.
I purchased the car from new; it now has 8,000 miles on the clock. Due to my frustration I have given the car back to the dealer and they are giving me a new 2003 model, unfortunately I have to pay in an additional $ 4,000.00.
It seems as if most of you are extremely happy with your cars, so this gives me faith that my new one will give me years of trouble free motoring, I would love to hear your comments on the problems I have had.
Here they are, remember this is a new car.
EPS failed
ABS failed
BAS Failed
The boot has to be slammed to get it to close
Starter motor replaced
Ventilation control knob ceased
Sunroof wind deflector jammed.
Ineffective air conditioner
Doors unlock whilst driving
Occasionally when pulling off the engine idles roughly, as if it’s operating on one cylinder, pressing the accelerator has no effect, the engine works fine after turning it off and on again
Seatbelt sensors failed to detect the passenger was not wearing their belt.
The worst problem must be the constant rattles that emulate from the sunroof and the hatch back where the drawstrings attach to (Please e mail me if you have managed to solve these problems)
Fortunately after reading your comments it seems as if there are many happy customers out there hopefully my second Coupe will be better please feel free to e mail me on Berrill@iafrica.com with your comments
Insofar as diagnosing the problems, the most common theme is electrical/electronics. Its not really normal for so many subsystems to fail independently, so I'd suspect it to be something more basic. For example, a bad alternator could be putting out "dirty" power which then fries the other sytsems.
-hh
Hope this helps you.
I've had my '00 C230 for almost 3 years and did not know this. Thanks very much!!
- Paul
I'm just wondering if any body else has had this problem. Are they telling me the truth??
Btw, some auto parts stores (like AutoZone) will pull the codes for free and decipher why the check engine light is on.
For more discussion on warning light & trouble codes, check out this discussion. "Check Engine" light. Also, here's another discussion that you may find helpful: MB C-Class Owners: Care & Maintenance Good luck.
Revka
Host of Hatchbacks & Wagons
Revka
My A/C blower broke this past March. When I picked the car up at closing time, I drove off the lot and realize about 3 miles down that heat still wasn't working. This happened to be a Friday, so I had to go the weekend driving in Chicago winter weather with steam coming from my mouth - it looked like I was smoking a cigarette. When I brought the car back on MOnday, they simply said - Oh we just happened to get a defective blower.....never said sorry. What are the chances of a year and half old car having the blower break the first time, but then have the replacement be defective? Sounds like bull.
The car seems to have no acceleration at times. I can have the gas pedal floor when accelerating at a stop light and also when merging onto an expressway - yet the car has absolutely no pick up. It is very moody- sometime drives great, then other times I can feel every gear change while driving and it has no pick up. The dealer tells me I probably just bought bad gas or didn't buy 93 octane. I have never put anything BUT 93 octane in my car and I buy my gas from Mobil all the time - sometimes shell - nothing else.
The breaks have to be 'cleaned' every six months because the special breaking system gets a build up of 'break dust'?????? Has anyone else been told this? I've brought the car in 2 times because the car wasn't stopping very good and seems to be slipping. This is how they responded. They when I called another Mercedes dealer, they said they have never heard of this.
Last week I had it in for repairs. The sunroof wouldn't open. The dealer told me it was an electronic problem.
If anyone has had similar issues- I would like to pursue a lemon law case for the engine issue. My car has 20,000 miles and is 2 years old now.
I think my starter motor needs to be replaced. As the weather is getting chillier my car is starting its morning 'stalls' at startup. This only happens when the weather is colder than 60F. When I back out of the driveway it shakes and sputters. Then as soon as I put it in foward drive -its fine. It does idle very rough and sometime sounds like its running on diesel. I know something is majorly wrong but Mercedes is going to try to string me along until my warranty expires. They keep saying their computer diagnostics can't replicate the problem.
Last week my sunroof wouldn't open....they said it was an electrical problem and had to fix.
My a/c is very moody. Some days doesn't seem to blow cold air at all. Sometimes when I need the heat, the car bearly heats up.
About 5 months ago the blower broke and had to be replaced. I think its on its way to breaking again. How did you get them to admit the air was ineffective?
I also notice that the car sometimes seems to be running on one cylinder. Sometimes it has great pick up and drives great, then other times I have it floored and it barely picks up. Is this what you experienced?
How did you get them to give you the new car? I just want to get rid of this piece of junk. My next car is going to be Japanese.
Any insight you could provide would be most helpful and appreciated.
Stephanie
stephaniepavisic@yahoo.com
The '98 was the second year of the new automatic, and the first year in our market for the new V6 - there are some things you need to look at, and they are well summarized in this thread.
PS: the MB 24hour service was helpful in suggesting that the ESP must be turned off, or the tires will not turn if slipping. When ESP the is on, and you are at slippery start up, you can forget about going anywhere.
I have done this on my c-coupe and I am very pleased with the results.
JR
