http://web.ntown.net/%7Erhmelton/42loveaffair.htm
Also. What size ratchet do you need to take doors off. Been working on that too..
But..the biggest pain was inastalling the Bikini top. That was tough..
ANON..thanks for the links..
DWRANGLER.. hang in there gal..
i believe the saleman will deal with ya..
how are gonna finace it?
KEEP JEEPIN
BAMA
move factory mirrors using ____ bracket:
aftermarket 2nd set of mirrors:
homemade mirror mount:
alternatively:
don't take doors off:
doors off, no mirrors:
The guy I talked to said that I shouldn't worry about it and that he, personally, would not stop anyone for no side mirrors.
Tom
Have you hugged your Jeep today?
I strongly recommend a boxed end 13 MM wrench for loosening the nuts, and that you go real easy. A slip of the wrench could mean a scratch in your paint job.
Also, once the nuts are off and you start lifting the doors off, GO SLOW AND COME STRAIGHT UP! You have exposed some threads by taking those nuts off, and they will certainly do a job on your paint, if you let them touch the Jeep as they come off.
Be prepared for a heavy load, too. Those puppies weigh a ton!
Good luck, Bama.
Tom
Just wondering who does which regarding doors/mirrors:
move factory mirrors using ____ bracket: (0)
aftermarket 2nd set of mirrors (leave originals on door when taking it off): (0)
homemade mirror mount: (0)
don't take doors off: (1) mtngal,
doors off, no mirrors: (2) godducks, tsjay
Well gotta run for now
Hug your Jeeps for me
dwrangler
doors off, no mirrors: (3) godducks, tsjay, twylie
-twylie
doors off tomorrow hopefully..
Looks like we have a rain free weekend.
Thanx tsjay...
I remembered you posted that a while back..
I didnt feel like searching for it..
dwrangeler..maybe u should check out the banks yourself 1st..to make sure. I dont really think you can get a good auto loan that matches chrysler.
KEEP JEEPIN
BAMA
Leases won't work for me. I put too many miles on a vehicle, and that wouldn't be so bad if I bought the car out. The one lease I looked at was for 4 years, and the amount owing at the end of it meant that I would have to finance it as a used car for another 3 years. I'd end up paying for it for 7 years. Not a good idea! Edmunds has an excellent article about leasing, both pros and cons. Just a personal thing - if you can possibly do it, go for buying it on a 5 year note. That's what I did. It's worked great for the Wrangler, but not for the Tacoma (which depreciates faster than I'm paying it off).
I think that California requires a driver side mirror, so I would have to put mirrors on if I took off the doors.
A question to those who are doorless and have checked into it - in the Army there was a strap across the door area as a (minimal) safety thing. Do any states require something like that when you go doorless?
Mtngal--Cali does require side mirrors if the vehicle is registered in the state; otherwise, it just needs a regular rear-view. Judging from all the doorless & side-mirror-less Jeeps I see around San Diego I don't believe it's a very heavily enforced law.
aftermarket 2nd set of mirrors (leave originals on door when taking it off): (1) cklausing
I use the quadratec quick-mirror on the driver-side, nothing on the passenger side. Took all of about 10 minutes to add on the mount, and attaching/detaching the mirror as needed takes only a couple of seconds. Figure that is easy enough, and I like having a driver-side mirror.
chad
and repost for the ext guy or gal)
don't take doors off: (2) mtngal, jptj
The process of buying a new vehicle is kind of like making sausage isn't it?
A couple of pieces of advice on financing, some of which I learned through bitter experience...
1-Already have a loan lined up when you go in to negotiate. It doesn't mean you can't work out a good finance deal with the dealer, but it gives you an option. The dealerships make lots of money on the financing, so make them work for your business! I agree with goducks1, Credit Unions are a good place to start to look for financing...
2-Negotiate your price first, then negotiate your financing. Leasing is an alternative way to finance...
A lot of people lease because the "monthly payments are right...",and don't even look at the final purchase price. Dealerships, of course, love that!
I go with mtngal and ducks in that I, personally, prefer to get a straight loan. Fewer variables at the beginning and end of the loan, and at the end the Wrangler is mine!!
Good Luck and I'm enjoying hearing your progress through the process!
Cam
here it is:
(from here on in, add yourselves... just copy this and the following text, modify your number, add your name, and repost for the next jeeper)
doors off, no mirrors: (4) godducks, tsjay, twylie, markwarren66
move factory mirrors using Steel Horse (or Sun Performance, I don't have the package) bracket: (1) madman
Since I have to drive on base everyday, I figured I better have the mirrors. Here in Tampa, it's been raining everyday, so the top and doors are back on, but I did not put the nuts back on the door hinges, and I left the mirrors on the windshield.
The Torx is a T-40 on the windshield mount, and as tsjay said, a 13mm on the door hinge. I did not worry about stripping the nut, as it is not noticeable anyway (and I didn't put them back on anyway). I was careful so as not to scratch the paint on the body though. And the full doors are HEAVY for thier size. Not too bad lifting them off by myself, but then I had to carry them up 3 flights of stairs to my apartment.
Hope this helps.
madman
Question, are most of the nuts metric or standard or a good combination of both? Maybe they are from Kentucky:-)
I went cheap and bought a small plastic food storage container and put some basic tools in it. I went with standard ratcheting box end wrenches (not sockets) instead of metric.
Do I need a combination of both standard and metric? Just don't have much room for lots of tools since I am keeping them between the drivers seat and the flipped up rear seat.
Guess I can always use a pair of pliers:-)
It almost sounds like it could be an ad for one of those "do everything" wrenches.
(These used to be called VISE GRIPS!)
I'm telling ya, vice grips, duct tape, and WD40 will take you a long long ways.
here it is:
move factory mirrors using ____ bracket: (1)madman390[Steel Horse/Sun]
Tom
The aftermarket stuff like the overhead CB rack and the rocker guards have had english size nuts and bolts.
Tom
here it is:
don't take doors off: (3) mtngal, jptj, appstate88
If you are working in a cramped space you do a little better with the ratchet.
Yea, I have the duct tape and vise grips already, no WD40. Got a small roll of 14 gauge wire (rated at 200 pounds) which can come in handy also. Never know when you might knock off a piece that you need:)
Still a happy camper.
I got a little chilly this AM on the way to work, and I should have worn a jacket. I thought about it, but decided not to.
Took Thelma to a Sonic Drive In at lunch and had my regular lunch buddy with me. My buddy, whose office is just across the hall from mine, is really getting Wrangler fever. I let him drive Thelma to the Dairy Queen afer we finished eating at the Sonic. He just kept going on and on about how well Thelma rode and handled.
The temperature was just a little over 80° today, and the humidity was fairly low. Just perfect weather.
I LOVE MY JEEP!
TomHave you hugged your Jeep today?
appstat88-Cam glad to hear you find my quest for my own Jeep to be entertaining
Question...if I could get canyons, would bigger tires fit on them ok if I got bigger tires later? That's if I can really afford to get canyons in the first place
Talk about torture...you all know how I've flip flopped between red and sienna with tan interior and tan hard top...well I've seen both colors several times...it's a conspiracy...yeah that's it...a conspiracy to drive me crazy til I get a Jeep of my very own
dwrangler
I like the sienna better than the red, but I'm influenced by my other half who, when anyone asks him what color he prefers, answers "not red."
I agree with what most others (appstate88, goducks, mtngal) are saying about leasing vs. buying. I think that in some cases with many cars, it's very similar - ASSUMING you're going to stay within the mileage limit and you're going to keep relatively good care of the car (I still personally prefer buying, but that's just me). With a JEEP, however, I think there's a distinct advantage to purchasing, for the simple reason that Jeeps have one of, if not THE, highest resale value of any vehicle out there. That means that if you can put a decent amount down up front (I think I put about $5,000 down) and you can handle the monthly payments then go for the purchase, because when it's paid off you'll be able to sell your Jeep for around $10,000 (assuming it's in good condition) so you'll be able to buy your next Jeep for that much less - that means lower monthly payments and/or a shorter loan term on your NEXT Jeep - notice how I assume your next vehicle will be a Jeep ;-)
I also TOTALLY agree with the philosophy of going in with a loan set up from somewhere else (bank, credit union, etc.) . Even if you don't actually have a loan offer in place but you know you can get one - do NOT allow the financing to become part of the negotiation. Also do not allow a trade-in vehicle to be part of the negotiation. You want to JUST be negotiating on the price of the vehicle so they can't confuse you with the other two aspects.
yellowman
here it is:
move factory mirrors using ____ bracket: (1)(madman390[Steel Horse)
don't take doors off: (4) mtngal, jptj, appstate88,BamaTazz
doors off, no mirrors: (5) godducks, tsjay, twylie, markwarren66,BamaTazz
Gonna drive around tomorrow..
Tazz looks great..with bikini top & no doors.
Those doors werent that heavy. You do have to lift straight up. & I didnt scratch anything.
This is GREAT..
hey tom
I LOVE MY JEEP TOO
Keep Jeepin
Bama
Tom
http://bbb.quadratec.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=28;t=002311
Personally, I don't like the look, but it should give you an idea of what others are doing.
Hope this helps.
madman
Spent almost 2 hours driving around topless & doorless today. It was GREAT!! Had to come back home to "put" TAZZ back together.
JEEPS ARE GREAT!!
Hey, Tomorrow is my wedding anniversary..
To the greatst lady in the world. 7 years and counting.
KEEP JEEPIN
BAMA
I am still a happy camper.
Yep, topless and doorless is the ultimate in Jeepin'. I even went wheelin' yesterday topless and doorless.
Tom
Look at the time on those two messages.
Steve
Hope you make it many, many more!
(My husband and I will be celebrating our 21st July 3).
The Wrangler we were negotiating for is patriot blue with tan soft top and interior and full doors. I'd really prefer white with tan, and half doors. The salesman told me that the plastic on the half doors where the window piece slides in eventually crack and that the zippers eventually wear out. In spite of his argument, I don't think he swayed me from wanting half-doors. I think I'm also willing to let them try to bring in a white Wrangler that fits the bill rather than drive the patriot blue off the lot, though that is a nice color. I'm still concerned about the blue being too dark considering the long summer heat here in Houston.
I'm not at all unhappy with the Trib, so I don't have to deal. It's just that I really want a Wrangler, and with the 7 year/100,000 mile powertrain warranty along with the current 3.9% financing rate, it's either buy now or wait at least a year.
Chapter two to follow....
Larry
PS: bamatazz, Happy Anniversary!
I've had three coworkers that have sold thier cars to CarMax/Autonation in the past. For a late model, popular vehicle, they got what I thought was a very fair offer in the deal.
For anyone looking at Wranglers, I think the 7/100 pledge they have going on is a great deal. Normally, an add-on powertrain warranty would run about $700 to cover the same stuff. I'm sure this stuff is negotiable, but with the financing thrown in as well, it makes the Jeep experience that much more attractive financially!
-twylie
Let me ask you, now that we're into the summer, how do you configure your Wrangler? Sides off? Top off? All enclosed and a/c cranked? Thanks in advance.
Larry
With the soft upper doors, bikini, windjammer, and duster, any rain that does make it in while parked will collect in the rear floorboard and can be drained out and I can pull the carpet. I've only had to do this once so far. Flipping the seats forward in this config will keep them dry. I will sometimes get some drips around the corners of the bikini into the cab, but it's pretty minimal.
http://www.ewylie.com/images/jeep/wjam1.JPG
http://www.ewylie.com/images/jeep/wjam2.JPG
I have to spend my working hours inside A/C buildings, so I like to get some fresh air any chance I get.
If the day is going to be really hot, I'll put the bikini/duster on and run the air while I'm stopped to help cool off. The half doors let a bunch of air in and the bikini will keep you from baking.
My wife is convinced that the jeep is a 1:1 scale model. She says I'm like a kid when I get to "configure" it for its next mission!
-twylie
Tom
I wish you the very best of luck in getting the right Jeep at the right price. I strongly suggest that you hold out for the color and the options that you really want, even if the deal might not be quite as good as that for another Jeep.
What's a few hundred bucks compared to what you will be spending anyway? If this Jeep will have to be yours for a long time, then you really want to be sure that you are getting just what you want.
I am a good example. I am still in love with my Jeep after 18 months. I'm almost as excited about her as when I first got her. BUT... I got exactly what I wanted. Thelma Jane was a factory order, so I just told them everything I wanted on her.
Good luck! KEEP US POSTED! You know how excited I get when someone gets a new Jeep!!!
Tom
-twylie
Tom
P.S. Do they make garage lift kits?
