I too have little ones to taxi around. My main concern is the side impact protection, or lack or it. I just weighed the risks and the amount of time that they will spend in the Jeep and found it acceptable. At least with the higher ride height, a side collision will more likely meet with the frame rather than with the side windows (unlike my current econo-box). In either case, it will be far safer than my CJ.
You may also want to consider the effect of the wind. It was not until my kids were about 5 that they could stand the buffeting and blowing. If you do not plan to take the top off, you may want to consider the Liberty as an alternative.
As far as maintenance - my completely stock '98 has only had one non-routine maintenance problem (well 2, but I haven't bothered getting the second one fixed yet). It needed a new exhaust manifold - a common problem through '99 (I understand they redesigned the manifold for the 2000 model year). The second one is an intermittent dash gauge problem that has a TSB out on it. One of these days I'll get it taken care of, but at the moment it isn't a big deal, because it seems to happen mostly when it is cold outside. I definitely need new brake pads and rotors and an air conditioning service, but at 102,000 miles, that is to be expected, and part of routine maintenance.
I also thought the Inca gold was only available in the Rubicon but the dealer said that it is available also in the Sport. He said it is not available in the Sahara. I sure hope he is right because I like the Inca gold. He said he will call me tomorrow with my VON. I imagine when he submits the order it will be rejected if he is not right about the Inca gold. That would be very disappointing. I like different colors. When I ordered my current truck, a 99 Dakota, I ordered the yellow. I still love it but my wife still hasn't stopped complaining about my color choice. So this time I let her win on one item, the transmission. I got the automatic so I would not have to hear it again for 4 years.
quikkag,
At this point I do not plan any off-roading. We will see. I told myself that if I was getting a Wrangler I definitely wanted a lifted one. I think that really looks sharp. This will be my daily driver. It has already been ordered for 6 hours. I think this will be a long wait!
Thats pretty impressive. 102,00 miles and not much maintenance. Never had any problem with the axle seals or suspension?
So here's the repair tally for my 4.25 years of owning my 1998 Sport:
Summer 2000: Toe-in out of alignment(my own fault, received off-road): $60
Summer 2000: The intermittent gauges that Mtngal suffers from now: fixed under warranty
December 2001: New rear differential seal needed because the guys at the quick-lube goofed up the fluid change: $60
May 2002: new coil needed because Jeep kept stalling: ~$200
In addition, I've probably spent around $1000 in maintainence via oil changes (every 3K miles) and other fluids (coolant/transmission/differentials/transfer case) every 20K miles, and of course the maintainence job (new spark plugs & wires/distributor cap/fuel & air filters/tune-up) that I had done when they replaced the coil last month.
SO that's two owners' experiences with the same make & model year. The only thing that has really gotten me angry at my Jeep was the coil last month, because it did leave me stranded. I'm dreading the day the exhaust manifold starts making noises but so far I've dodged that bullet.
Tom
Have you hugged your Jeep today?
My Jeep has 18,000 miles on her now, and I have had a couple small problems that were taken care of under warranty. I am very happy with the reliability of my Jeep, but she just has 18 K miles, so I will just have to see how she does as the miles accumulate over the years.
I had a water leak that turned out to be a poor seal on the heater box where it goes through the firewall. This was fixed in one visit to the dealer.
I also had a problem with the turn signals not working, and this was taken care of with a new stalk under warranty.
Take a look at a bunch of the old posts in here, and you will see that no one is complaining about their Jeeps. Almost without exception, we are all thrilled with our Jeeps and very glad that we have them.
Tom
I have done the usual maintenance (diffys, transfer case, oil changes, plugs, air filter etc.) which does add up over time.
tluke,
Need more details. If you don't mind I am going nuts trying to save money for someday to be Jeep
Hug your Jeeps for me til I get my own
dwrangler
The TJ are just reliable as any other vehicle that is on the road. They are not like the old CJ's with oil leaks etc. By the way before the CJ owners start yelling I also have two CJ's 7
Hopefully the Cards rise from the ashes and kick some rear!
Steve
Larry
I'm from in Chicago,IL but plan on relocating to San Diego, CA. I wanted to buy a used 2000 in July and I had a few questions.
What are the major differences between the SE and the Sport?
Is the Sport worth the extra cost and poorer gas mileage? What have people been paying for 2000 Jeeps?
Do you have problems with your 2000 Jeep?
How's the drive from Chicago to California in a Jeep?
For the '03s, the biggest news is probably the 4 speed auto tranny and the option of rear disc brakes on the Sport. Of course the Rubicon gets lots of heavy duty off-road equipment. Other items I've seen mentioned are the use of the I4 from the Libby in place of the current 2.4l 4 cyl. Interior changes include slightly different seats with more travel and higher seatbacks. The soundbar has apparently been split into 2 corner "pods" that house the speakers and map lights. costcoauto.com has some of the option lists out for the '03 but they don't give any pricing on their site.
-twylie
As far as long trips in a Jeep, I haven't gone for a trip longer than 3 hours at a time. However, I was comfortable for that whole time...a lot more comfortable than in the Pontiac Sunfire I had previous to the Jeep. Hope this helps!
Jeephead
As far as maintenance goes - the Tacoma had a new radiator put in (under the extended warrantee)when it was only 18 months old and a strange tranny problem that appeared at about a year and disappeared after a week and hasn't returned. So they aren't perfect either...
Is this normal to not be included with the Jeep? I also don't have the straps to roll up the rear window (not that I would very often) - just wondering if I got jipped... Thanks in advance.
As for the straps to hold the rear window, I don't use mine since I remove the window. One option might be to unzip the sides of the rear window and see if you can secure it to the soundbar/sport bar. Maybe velcro or some snaps to hold it up under the rear of the soft top. I will say that the factory provided straps to hold down the windshield and the ones to keep the rear seat pulled forward are OK, but not that great. I bought a roll of double sided velcro and use it for securing anything that needs to be lashed down or held in place. It was cheap at Home Depot and I just cut a strip to length anytime I need to tie soemthing down. I think I've got about 4 or 5 lengths in the Jeep right now.
Check to see if the other '02 Wrangers are like this the next time you go to the dealership; maybe you can get them to take care of you if yours is "unique".
-twylie
Also been working on a NEW web site
www.geocities.com/bamatazz2001/index.html
check it out. its not perfect, but its a start.
Please post your personal web sites too.. we should link them together
HAPPY bday deb!!
congrats to all who got new jeeps or ordered theirs.. The family is growing!!
KEEP JEEPIN
BAMA!
FWIW, I see a bright red, older Wrangler every weekend going up and down my street with a bald dad in front, and a bald baby in back, both smiling!
I noticed the gearshift knob on my 5-speed has slowly rotated clockwise, so now the I-5 diagram is sideways. Has this happened to anyone else? Anyone try stylish replacement gearshift knobs like the ones in the Quadratec catalog? Since I have a Solar Yellow Jeep, I was considering one that's black and yellow. It's kinda pricey though - around $65!
yellowman
I'll only charge you $49. Please send it ASAP!
(If you unscrew it completely, and mail it to me, I'll gladly paint it yellow for you for another $15, bringing it just under your quoted price of $65.
-twylie
Thelma Jane used to get real good mileage like that too, but I took care of that by putting all that armor on her and switching her to mud tires. Also, I'm driving up to 70 MPH now, whereas I used to keep her 60 to 65 going to work and coming home. It really makes a difference if you keep the speed down just a little. That wind resistance is a killer with the poor aerodynamics of a Jeep.
Not complaining, though, cause the fun of wheelin' is worth giving up a couple miles to the gallon on gas. No excuse for the higher highway speeds, though. Ought to try slowing down again and see how much of my poorer gas mileage is related to the speed vs the armor and the mud tires.
Tom
I got it a little earlier than I expected because I realized that it was going to be really tough to get out of my Audi (A4) lease after one year. Audi wouldn't take it, and I had trouble selling it privately because the new models are out this year. I knew I wanted a TJ, so I went to the dealer and they took it as a trade-in (bill of sale, release of liability).
The next step is to say goodbye to my XJ. I have had the 87 Cherokee for 5 years and my dad bought it new in 86 - a good 16 years now
http://www.csupomona.edu/~ctgraber/xj/offroad.htm
The site is VERY outdated, but still open. I can't wait to take the TJ out there and experience the Valley all over again (and with 4WD this time!).
I was told by the dealer in Irvine that in 2006 all jeeps will have Mercedes engines! I haven't read all the posts here, but has anyone else heard about this?!
Chris
Which Jeep should I drive today?
By the way, nice Jeep.
It was supposed to ship today, so I hope to have it by early next week.
Now the sun won't be as rough on me and Ross Allen when we drive around in Thelma Jane topless (except for the satari top, of course) and doorless.
I'll try to get some pics in the photo gallery when I get the new top put on.
Tom
I have the bikini top. Our bald heads will not get blisted this way. I rains here about everyday in the afternoons. I need a good few topless days. We have our acation coming up maybe I will have some sunny days that week.
Im getting close to 10,000 miles what maintence should I do? Im gonna get the tires roatated I know. Im not for a oil change till 12,000.
Congrats to everyone who has ordered of got a new JEEP!
Keep Jeepin!
BAMA!
My wife and I went by our local Jeep Dealer here in NC, and saw a Sahara in Sienna.
My wife was prepared to not like it (For the same reasons as you...), but changed her mind when she saw it in the flesh.
The Sienna is a very dark burgundy. Definitely not red. A really attractive vehicle.
In fact, if Pam ever decides to trade in her '98 for one, she already has a name for it
(Pay attention, Tsjay!)
SCARLET SAHARA!!
Heck, it's almost worth buying just to be able to use the name!
Good luck!
Cam
I'll probably be looking at trading my current Wrangler in around the time they come out with the redesign (2006 or so - gotta get another 3 years out of my noble black steed), which should be very interesting!
Spoke on the phone to the middle son of a friend of mine last night. The kid is up in Baltimore and had just bought a black 2002 Sport yesterday. He said that he had always wanted one since the times he had played with me in my old CJ5. I think he was 6 years old back then and he is now 28. It took 22 years, but he finally swung our way. I guess it is true, kids and dogs love Jeeps.
Mtngal, checked gas prices here in central Texas. Exxon is 126.9, Chevron is 127.9, and a no name station is 131.9. Those are the regular unleaded prices, didn't bother to look at the higher octane prices.
Huckhill, how would I describe the sienna color since that is the color of my sport. For starters it is not red. Where to go from there I don't know. I think if you thought of burgundy and added a whole bunch of brown you would be close. I think it is more of a brown with some red added to it. Depending on the light the color does seem to change. The amber fire was my first choice, but they had discontinued that color so I went with the sienna. I like it.
Congrats to all the new owners and I think you will enjoy your Wranglers.
For all the potential new owners go for it, I think you will enjoy your choice.
Tsjay, you are going to be my test rat again with the new top. Been thinking about going that way, but was not sure about the no drill header. Keep us posted.
Appstate88, tell the wife that is a great name.
Still a happy camper.
My wife and I took it for a spin last night here in Columbus, Ohio and had a blast!
Thanks to ewylie for giving me some sage advice concerning my purchase. (I emailed you a couple of weeks ago.) I'm happy to become a member of the wrangler family. (I just gotta start getting used to looking for other wranglers to wave to.)
Have a good day Walt
Thanks All!
Jim
Mtngal--gas is even cheaper in San Diego than L.A. right now, which is not normally the case. Somebody's always getting ripped off somewhere by those stupid evil gas companies.
Coons10, way to go. Hope you enjoy your X. I have a sienna Sport and am very happy with the color. All I know about the no drill header is that you have to take it off to put your soft top back up. With the one that you drill, you can leave the header on and put on your soft top. The other thing I know about the no drill is I am a coward when it comes to drilling holes in my Sport.
