I've started to really like the exterior styling (it sort of grew on me), but I can't see spending $35K to get that cheap looking interior, especially when the same money can get me an ES300.
Also, has anyone seen what the interior changes will look like, such as will it be somewhat similar to the DTS, except on a smaller scale?
I'm hoping it's before next August 1st since GM is ending the GM Card rebate when getting a GMO/GMS discount.
I don't know how much they can upgrade an interior in one year... don't expect the basic design to change that much. The description I've heard were "improved jewelry and lighting".
I wouldn't care if they left the interior alone and just gave me more motor... and the desired wagon version.
b4z, from the pics I've seen, I like the XLR. Being as I typically like most cars more after seeing them in person, I have a feeling I'm going to love the XLR. I think we can safely say, this ain't gonna be another Allante.
It was suggested that Cadillac should replace the WHOLE car, vs. just the engine. That was the notion that I was responding to. Concern had been expressed about replacing the engine, and if the car would ever be "the same" again.
New CTS interior is going to have different door panels, a few extra pieces of trim, and a few things "touched up" a la the 2003 Escalade with its revised BVLGARI instrumentation, clock, and new steering setup. Nothing drastic, just a few changes to the general theme. The center HAL-like stack may be toned down a bit.
Olds was right on with that Lex ES comment.Being heavily based on the Camry,they had a lot left over to spend on the eye candy.
And while the ES has a lot of good qualites,I doubt few would say it is fun to drive.
Whereas the CTS,like my Catera,gives you a very roomy interior and at the same time drivind dynamics fairly BWM-like.
And I'm happy with "fairly" because I see(it was for me)the BMW 525i as the likely competor,not the 3-series. And of corse it costs a great deal more. But I thought that 325i just too small inside.
"The build and finish betrayed the still-under-refinement stage, but it's obvious this car is meant to run against something other than a Lincoln - namely Mercedes-Benz SL500 and Lexus SC 430."
All they said was the materials seemed very good. They never said the interior was as good or better than the competition.
And I won't tell your English teacher, but it's "edition", not "addition".
And it DOES look a lot like the CTS interior. The steering wheel and center stack are almost dead ringers. The material may be different but the design is almost identical. It does not look anywhere near as good as the SL500 (IMO). It's ok in a $35k CTS but not a $75K SL fighter.
I am figuring that it was a piston or ring problem which caused the cylinder walls to be damaged.
Could be that a ring was installed improperly and scored the wall beyond repair.
More than likely an assembly problem which would show up quickly, and it did.
As for the AutoWeek article: you know what I meant. I was just trying to illustrate that the XLR interior is not something straight off the CTS; it is in fact something that can run with its competition. And, anyway, didn't they say something about liking it better than the SC's interior, or something about the curves or lines?
Have a nice day...
As to "never be the same" IMO auto servicing has become very much a component repair affair. The mechcanics probably have more experience replacing entire engines than tearing one down and painstakingly replacing close-tolerance internal parts and rebuilding.
And as far as likening the current CTS mill to the Catera, this is from Automobile Magazine of September 2001:
"The 3.2-liter V-6 in the CTS is, essentially, a new engine, although it shares its DOHC, 24-valve, 54-degree included-angle architecture with the outgoing Catera's 3.0 liter unit.The cast iron block is stiffer and stronger, and there is a forged steel crank plus new cams (mainly for refinement) and a new piston crown design. A weakness of the previous engine was vibration. This has been addressed with a redesigned cam drive, a revised bracket for the power steering and air conditioner pumps, and a new more rigid cast aluminum oil pan. ..."
I know it's easy for me to say 'cause it's not my baby in the hospital... but I wouldn't let negative expectations color my perspective. I had fairly major engine work done on my Northstar Seville and everything came out fine.
But you might want to wait until 2008.
So, what's the difference if they pull the motor for a repair and put the same one back in, or put a different one in?
I think it will be just fine... but I'd be insisting on a Cadillac for a loaner.
12. LOL.
The AW article said the XLR should be faster than the SL and SC (if the caddy estimates hold up). They liked the quality of the interior materials. They didn't really comment on the design itself - interior or exterior. It was more of an article on the technology in the chassis and powertrain.
It will be interesting when they do a side by side comparison.
Pardon the interruption. Back to the CTS....
I'd be extremely upset if it was my car, but the thing to do now is to let Cadillac take care of it and pay very close attention to the results. If the car doesn't work properly and the problems can't be resolved, it'll become a lemon-law candidate. It doesn't seem justified to condemn Cadillac and the dealership before the work even begins, and I don't see any point in giving gloom-and-doom pronouncements to someone whose new engine just expired.
Good luck, typea--hope it's resolved to your satisfaction.
While not a failure, my IROC was using a quart of oil every 600 miles from new and had new valve seals installed, which didn't help. They then pulled the heads, sent them off to a machine shop and put in new valve guides. Oil consumption dropped to a quart every 4500 miles.
203,000 miles on it today and using a quart every 1000 miles.
We have many CTS owners on this thread and only one failure and I think one post about excessive oil consumption(?). Not too bad.
On the intrigue thread we had many posts about oil consumption and 1 engine replacemnet due to block porosity.
I think the CTS has a pretty good record so far.
Compare this to the Honda transmission posts and the Toyota sludge factor.
Granted they are a very small percentage of total sales.
"Back in the day," when I worked on my own and my two roommates MGB's, pulling the engine was the easy part. Fixing it was moderately harder in those days (early seventies), but a much bigger deal these days with today's anal procedures and woefully expensive parts -- has anyone on this or any other board recently purchased a gasket kit?
Didn't think so. Sounds like replacing the whole bloody thing is the right thing to do.
In Atlanta tonight, Cadillac sponsored an art exhibit of a travelling photo exposition by some of the country's leading nature photographers. The exhibit is sponsored by the Nature Conservancy, and underwritten by Merrill Lynch, Cadillac and others.
My wife and I were invited (along with a few hundred other guests) to come to the High Museum in Atlanta for the evening. My Cadillac dealership was nice enough to invite my wife and I to this event. Upon arrival, you got free valet, to where you would get the only real pitch of the evening. Next to valet was a gentleman from Cadillac's marketing group with two models, a CTS and an Escalade EXT. I thought it was interesting that they chose models that I would consider "the new Cadillac" rather than the popular Deville or slower selling Seville models.
Upon getting upstairs, Cadillac provided finger food and an open bar. Food included shrimp cocktail, chicken satay, mussels, a pork filled pastry with apricot sauce, brie, and other nick-nacks. Pretty good spread all around.
Music was provided by a 3 piece band playing what I would describe at South American tradional music from Andes peoples. I'd heard music like this before recently and it was a nice change of pace from music most of you probably listen to.
The photo collection was extraordinary. If this exhibit comes to your city, I recommend taking the time to see it. You'll enjoy the evening and your wife will appreciate a night out doing something different (I know mine did).
After looking at pictures for an hour, dessert was being served. It was mostly finger chocalate layer cakes and lemon squares, but they were all good.
Finally, at valet, I got to spend some more time with the guy from Cadillac. Since I'd already bought (but hadn't taken delivery yet) of my CTS, he didn't need to sell me. But we did discuss the success of the car, and some upcoming changes.
First, there's no real news that hasn't been discussed here already. He did confirm the DVD Navigation system and the changes for the dash panel guages. The new clock will still be analog but will be in the center console where it belongs. There was no word on V-series details. In fact, he seemed to think that the final decision of what kind of engine was going to end up in it hadn't been decided yet, which I thought was interesting. Then again, he did say that he'd tried to pump the performance group for information only to get nowhere, so take any engine talk with a grain of salt.
He was also showing pictures of the XLR and was talking about the SRX, although we didn't get into detail on either product. He did say that he thought that Cadillac had a fair amount of potential upper headroom with the new RWD Northstar engine (up to 370 HP) without resorting to superchargers.
And finally Cadillac left us with a nice parting gift. We haven't opened it yet, but I would guess it's an album of photos printed from the exhibit. All in all, this was a nice evening and certainly something different to do with my wife. The selling part was expected, but not harsh or obtrusive. It will not hurt Cadillac's mindshare to do more of these events.
of course there's always the GM faithful who think the 3800 should be in every GM car and that its the greatest thing since sliced bread.
But, for all the money spent on "reengineering the 3800 (1985, 1991, 1995) they should have been able to at least develope an overhead cam version.
I remember Buick even running a TV ad years ago touting the 3800's reliability and its "lack of sheer number of parts" compared to overhead cam engines. That's true and the 3800 is generally considered very reliable. But OHC engines have their own advantages and appeal.
I still think that GM could have spent a little development money on the Shortstar to help it meet 2003 emissions. Put that engine in the CTS and make it optional on the w body cars to spread development cost.
There was supposedly a 225 hp version of the engine with 240 lbs of torque. Nobody on this thread would have complained about power if there was a shortstar in the engine bay.
All of us wbody owners would have been pretty happy too.
I guess the only major design issue was that the shortstar was engineered for FWD and not RWD.
They can have some oil usage issues like the Northstar has but it seems to be stable.
One of the posters on edmund's reports a quart every 1500 miles. Mine used a half a quart every 3000 and then stabilized to 0 oil usage after the engine broke in.
Like all 4 valve engines it is a little soft off the line. This is why Caddy puts a 3.71 gear in the 300hp version of the Northstar. The Intrigue came with a 3.29 and a 3.05 gear.
I have the 3800 in my Impala and I prefer the Shortstar. It is smooth as glass and wants to rev.
It's kickown at 65 mph will throw you back in the seat. And it's 30 mph kickdown into first would sometimes chirp the tires.
Ah well, I'm sure the next generation of GM engines hitting the market next year will be just fine. Cadillac CTS gets one and the next generation Malibu gets a new 3.2L DOHC making around 200 hp.
Anyway, back to the CTS...
well that kills that idea. Maybe a Mazda 6, Altima, Maxima, or base 9/3......
The High Feature engine wasn't ready for the CTS in '02
And the 3.2 won't be ready for the Malibu in '04.
Is there a pattern here?
Everyone raves about the 4.5L but I heard that the 4.9L needed to be rebuilt after 90,000 miles.
