---Paul
As the owner of a 2005 Dodge Ram that's still under warranty (Cummins diesel 5 years/100K miles, all other systems 7 yrs/100K miles under Added Care Chrysler Service Contract [which extends the engine coverage as well to 7 years] - I'm at 49 months and 63K), my concern is not so much Obama backing the warranty... if there's no Chrysler LLC, there's no dealer network - exactly who will perform warranty repairs?
I'm really pulling for the Fiat deal.
kcram - Pickups/Wagons Host
My concern is that since oil changes are less frequent, would I be in trouble with regards to following the prescribed maintenance schedule? I am changing my synthetic at about 7500 miles even though I was told I can go to 10K miles. The last thing I want to do is void a Lifetime Powertrain Warranty.
thanks...
---Paul
I say this for two reasons:
1. You are using a non-specified oil in your vehicle ( probably a minor issue, but a point nevertheless)......
2.Because of the expense of the non-specified oil, you would understandably go further between oil changes. That's not a problem until you go beyond the maximum recommended interval. That's the problem here.........
Chrysler/Obama/Fiat ( COF Motors) ?.......will come back and say you did not follow their recommended oil change , so they could deny your claim.
Having said all this, it is a remote scenario, but it could happen, and if it did, that would more than wipe out all of the advantages of using synthetic oil on this vehicle and your next three cars for that matter.
I stuck with fossil oil and 3-4,000 mile intervals for the reasons I just gave you......
Just my opinion, Paul
Random Thought: Given the fact that Fiat should shortly have a 35% stake in Chrysler, will the winged logo on my Pacifica come in red, white, and green ?
Its going to be interesting now that Chrysler has put out the list of dealers to be axed. Sadly, the one I have been dealing with for 25+ years is on the list! I will miss them.
Anyone else in that boat (losing a dealer they really become "attached" to)?
NPR was saying Corporate was not even going to help the dealers they are axing with respect to inventory. They are leaving all the stock with the dealers for them to deal with, most likely to send to auction so they will get even less.
I will surely miss my dealer. They sold my family about 8 cars, including 2 Pacificas.
Anyone else feel the loss?
Paul
The manual states 3,000 miles between oil changes, period (regardless of oil quality). If you want to spend double or triple on oil, that's OK, but if you increase your oil change interval accordingly (to justify the cost), then you'll risk voiding the warranty.
While it's your choice: if the warranty is important (and you don't like wasting money), then stick with regular oil at the recommended interval.
If fuel economy improves, then it might help offset some cost, but would certainly fall short of justifying the expense.
I like most the parking assistant that alerts you when something is behing the vehicle and the DVD player--my daughter thinks it is amazing to be able to watch Dora in the car.
Sorry to hear about that.....are you still under a warranty ?
Congratulations on your 7 plus years.......Nice to hear from you again......I'm at 84,000 miles, with the original brakes also. Mine also looks "almost new"..........garage kept helps !
Funny, I have never had a problem (knock on wood) with the AC, and I live in steamy Houston , TX !
Mine also runs great, my repeat problem was front end clunks, but I have already chronicled on this site how I finally solved that annoyance.........
Again, b25, congratulations, and keep posting!
do you have any pictures? what is the color inside and outside? leather or cloth?
and finally where are you located... and do you honestly have any issues.. because there are several problems with pacifica especially the first ones... (2004 to 2006). thanks for your quick answer.
what do you mean? i should not consider being an used one?
I know that the contract is a negotiable item. I have called different dealers in my area and get different prices for exact same contract.
Has anyone purchased a contract from ChryslerWarrantys.com? They claim they are the real thing and are a couple hundred less than the local dealers.
Any thoughts? If anyone knows any other source for a real Chrysler Service Contract that offers a good deal, please let me know.
I am looking for the $100 deductable, Max Care, Lifetime contract. I have a 2008 AWD Pacifica.
Many thanks in advance...
---Paul in Southern NJ
You are right in wanting the real thing in an extended warranty. The question is: What is the Real Thing?
Prove me wrong, but my gut feeling is: ChrylerWarrantys.com may not be the same thing as the local dealers. They claim they are, but they are not the ones actually doing the warranty work for you, your local dealer is.
Bottom line: If you have a local Chrysler dealer that has dealt fairly with you so far, I would eat a couple of hundred dollars just to have their undivided attention when the day comes to use that extended warranty................
Good Luck,
Brooks in already hot Houston, TX................
P.S. I do not work for Chrysler or anything automotive related at all.......
I would replace your timing belt now, unless you plan on selling soon. ALL timing belts break eventually, some makes (ex: Hyundai 2.7 V6 ) recommended replacing every 60,000 miles. At 100,000 miles, you are at the end of the line. I guess you have two choices here:
1. You are keeping the Pacifica. Replace it now, knowing that it will not be breaking somewhere and leaving you on the side of the road.
2. You keep driving until the timing belt breaks, leaving you on the side of the road, incurring a towing charge, and possibly causing other damage to the engine....valves, maybe ?
1_ I bought factory Chrysler (made by Gates) timing belt since I did not want any issues. ($40 fr eBay)
2_Bought a factory Chrysler (made in Germany!) water pump for the same reason. ($40 fr eBay)
3_ “Borrowed” a loaner Radiator Pressure Tester, Chrysler Harmonic Puller (3-jaw) and Harmonic Installer from O’Reilly auto parts. Used the Pressure Tester to test the new water pump for leaks, it is sealed by an giant o-ring and did not want to find it leaking after full assembly.
The Harmonic Installer did not work due to its design. Got a 90mm long x 12mm x 1.75mm bolt and a bunch of washers from Ace Hardware for $2.80 which enabled me to install the Harmonic Balancer.
Should you not have this, the auto parts suggested a slamming the harmonic balancer back on using a piece of wood and a 10# sledge hammer (I did not try that approach)
4_ No need to take the valve covers off or disconnect the fuel line as the factory manual suggests.
5_ Do have a bottle of “white out” handy. Mark the old belt & drive cogs on the 2 cams and at the crank. Then transfer the marks to the new belt. Makes the install/timing a snap. (One cam did snap out of position after the belt was removed, but was easy to rotate back into position w/ a wrench.)
You CAN use the breaker bar on the harmonic balancer bolt to rotate (slowly) the crankshaft to TDC position.
6_I used a small tow chain w/ hook to keep the harmonic balancer from turning when I torqued it with the ½” drive breaker bar. (I did not have any air impact tools.)
6 a_Use of a floor jack to support the engine is kind of optional. It is mostly used to maintain the engine in a position such that it can be most easily worked on. At times you may feel the need for any extra ¼” of horizontal clearance, this can be obtained by using a short (3-4’ long) 2x4 board as a “pry bar” to pry the engine block towards the drivers side of the engine compartment.
7_ Have a 3/8” x ¼” drive adapter handy and a full set of 3/8” and ¼” metric sockets handy. As well as the ½” drive metric socket for the harmonic balancer (think it was 17 or 19mm do not remember precise head size, but it had a smaller head size than I expected).
8_ Do have some metric Torx head 3/8” drive sockets handy and some Vice Grips pliers. (there is 1 Torx screw on the timing belt cover)
9_ One of the most difficult steps for me was getting the power steering pump bolts back on. Was almost impossible. Wound up having to remove the radiator fan assembly such that I could push the steering pump back in position. (There is a timing cover bolt BEHIND the steering pump. I DID NOT put this timing cover bolt back in upon reassembly since I would never want to have to remove the steering pump again.) Now is the time to replace the factory installed Lower Radiator hose if you haven’t already.
9.a_ Re-installing the serpentine accessory belt can be difficult. I used the clips to hold it in place. I used a 1” wide ratchet “tie down strap” to pull a 12” crescent wrench attached to the tensioner to “rotate” the serpentine tensioner back. The ratchet drive strap held the tensioner back well and the belt went on without too much fighting.
9b_ I used some large “paper clamps” from the office supply store to “clip” the timing belt and serpentine belt on the drive pulleys during the install. Made things much easier.
10_ After 118,000 miles the Timing Belt still looked mighty good. But of course should it have broken the engine would be toast. Also replaced the serpentine accessory drive belt with a new Gates micro-V belt.
11_Total wrenching time for me on this job was sixteen (16) hours. (this includes time going back to auto parts store twice and replacing ALL the radiator and heater hoses)
p.s., my car has sucked since I bought it.
The one original key-fob combo that I have is broken where it would attach to a key chain. I'm afraid that it will be lost since its not attached to anything. I see that Dorman has key-fob repair kits, but its not the right shape/size for the Pacifica key.
Does anyone know how to repair the key with buttons so that it will attach to a keychain again?
I feel your pain on the broken key fob......the same thing happened to me. I ended up getting a new one from the dealer, if you have two keys, you can program another , cheaper one from ebay yourself........
The broken one lives on as a valet /car repair key .....usually, they just tape a number on it and use it that way..............I figure if they lose it, they will owe me a new one..........but it has never happened.
The key fob was a flimsy design, no doubt.........
If you have 2 working keys you can program a third key yourself (keys with fob or without) Most of the sellers on Ebay will send you the instructions on how to program the keys.
Also on Ebay they sell just the shell for the fob combo.
Hope this helped.
Two weeks later it is doing it again, is this something I can access fairly easily myself. Which side is this connector on in relation to the drivers side.
Any help in this matter would be greatly appreciated. Hot in Texas.
I considered using the synsethic oil, but Chrysler does not allow for extended intervals beyone the normal mileage in either schedule A or B. By the way no one can qualify for schedule A. Read the requirements for schedule A and see there is no way for anyone that drives any where to meet Chryslers requirements. Any thoughts on this ?
farout
---Paul
farout
I change it at about 7500-8000 miles as opposed to their suggested 15000. The key here is to use a quality oil filter.
--Paul
