When I posted my last blurb, I had not had the wheels aligned after the suspension changeover (as recommended). I did that and got new tires (which I needed) and the car is now stable and rides well with the Bilstein shocks. As for the Electronic Stability Control System (ESP), I don't know whether it is working or not - the dash light comes on and goes off within 2 seconds during start as it should, and I have never seen it on any other time, so I assume it is active (because the manual says the light will come on if it isn't). But pressing the ESP button on the dashboard has no effect (no light), so that's puzzling. I have had no more stability problems, so I am happy with the changeover so far - BUT would like to know for sure what the status of the ESP is.
Has anyone got any feedback on these?
http://www.arnottindustries.com/part_AUDI_Air_Suspension_Parts_yid17_pid124_gid5- 29.html
Do not buy an allroad to turn it into an A6, it is not practical.
BTW I have a 2002 allroad, replaced the bags once in 2005 and never again had a problem.
Bwilly.
Knowing the issues associted with this model....I negotiated with the dealer to have (one of the bags had failed with the previous owner prior to trade-in) the other front bag replaced as welll. I added 2 additional years of warranty to the 2 years already on the vehicle (Audi certified). I verified with Audi that the air bags and the ECM (auto leveling control module) are covered under the warranty.
I have had the vehicle for 2 months without any trouble at all. Once a week I excercise the system - top heith to lowest height.
Do you still have these for sale?
dan
Any suggestions? And i hear that a control module needs to be programed after installation.
The dealer charged me $500 for a hose two years ago(the part was $10). That was the last time I used a dealer...
Anyway I think you should go to an Autozone for a free scan and let us know what you find...
As of yesterday car is now on level 4 and it1s staying there.No droping,no noise...could it be that is just a wire as you say or some check valve???
Art 65
I replaced my front bags in November 2009 with Arnott bags - my compressor is just now starting to not come on constantly ...so sounds like my Audi mechanic was right. That'll be the last time I stray from him in order to save a couple hundred $$
As far as Arnott goes - I think they're great. Their customer service is fantastic and the air-bags also come with a lifetime warranty. Something you wont get from Audi - even when you're spending $1000-$1200 per installed bag.
When/if I have to replace my rear bags I'll definitely get the rear Arnott Gen 2's.
After reading these posts, I'm leaning more and more to just putting in the Arnott front air shocks, although if I have to get into the compressor at some point, it sounds like every bit the nightmare I'm reading about with the coil spring conversion. This would pertain to the conversion's resultant ESP issues, check engine light, spongy handling, etc.
My 2002 2.7 has 175,000 miles. It has been a joy and I plan on keeping it through thick and thin. I must say though, this air suspension vs. coil springs has me pulling my hair out because it seems they are equally troubling for many of you, regardless of your choice?
The passenger airspring leaked on my 2001 allroad. It got replaced with OEM parts for ~$1,200 total. As soon as the passenger side airspring go replaced, the driver side showed similiar issue of lowering over night. Shop suggested to replace that one as well. The allroad has now 108k miles. Airsprings were replaced 4 times(!) with OEM parts already and I am hesitant to replace with OEM parts yet again. I am thinking of replacing both front airsprings(even though only one is apparently leaking) with either Arnott generation I or generation II. I just signed up to this forum and I am eager to hear suggestions. The car is 10 years old but I love it and would like to keep it. Thank you!
john
I've read through the last 3 screens of posts on this thread and am thinking I will order the Arnott Gen-II bags for my 2003 Allroad. First, I would like to confirm (to the extent possible) there is nothing else wrong with my suspension. My LF bag went flat today (car obviously low on that corner). My Ride Height warning light is flashing and my low-level indicator is flashing. I do not hear the compressor running constantly so I assume the car is smart enough to turn off the compressor when one bag has a leak.
I reside 60+ miles from the nearest shop that can read the error code (my generic reader only does engine codes). My questions are:
(1) What is the likelihood of something else (bad control module, broken wire, leaking air hose, etc) causing only the LF suspension to be riding low?
(2)Hhow specific are the OBD error codes for the suspension and would it be a mistake to proceed with replacement of the front air springs without first having the OBD codes checked?
BTW, there is an excellent step-by-step guide to replacement of the front air springs on Audiction.com
Thanks for any help!
How do you do that? Do I need tools, jack up the front?
I've had a lot of problems with this "gorgeous lady", (kidding with my wife i tell her that allroad is my lover, eh, eh).
I would sugest that you replace any leacky airbag as soon as possible because delaying things will only make it worse. I've ruined my front ones two months ago, but since i had another problem, (expensive engine trouble), i waited until now to place the new airbags. Result: 2 new front bags, driver rear bag and a fried ECU.
I'm putting the oem ones in the back, they're the same price as arnotts. Be carefull with the air gen II Vag com programing because the arnott bags make the van higher than the oem ones. So if you put the front ones, the allroad will be higher in the front. Audiworld forum has a good tutorial on how you do it. Look for allroad vag com suspension.
If you still want to give it a try it is fairly easy: Jack the front of the car (remember to put the car suspension in "jack mode"), remove the air line from the top of the air spring, and squirt the Slime into the spring. Refer to the excellent photos at the link to the step-by-step for spring replacement in my first post.
BTW, I did replace my springs with the Arnott Gen-II springs. It was easier than doing the brake pads - requiring about 3 hrs labor.
Good Luck!
The dealer here in San Jose CA charges for labour $175/h and they say it's 2h work per wheel. What do you think, does it really take 2h for a pro car mechanic in shop?
I've also got conflicting comments about wheel alignment, some shops say a wheel alignment is needed ($165), some say not necessary. Any advice on if wheel alignment is a must after replacing the air bag?
I also live in San Francisco and am the owner of a '04 4.2 Allroad with 108,000 miles on the odometer. I love the car and hope to keep it for many more years. Do you know of a good independent mechanic that would be willing to take care of my car (the suspension squeeks and sighs) on a long term basis? I am older, 63, and do not have the time or the skills to work on these newer cars. Thanks in advance.
They even installed my ARnott coil suspension and took out my air suspension.
Did you conclude that the $2.00 seal solved the problem? It is something I would like to try based on the problems I'm having. If it worked for you can you tell me how to get to it to replace it and what the part number was so I can order them. Thanks.
I have an '04 with 99,500 miles on it and 13 months ago I experienced a LF leaking air bladder. I used 8 ounces of slime and the leak was sealed and functional until yesterday. I got 13 months and 18,000 miles of extra life for the cost of a $10.00 bottle of Slime.
Yesterday I tried repeating the slime solution to no avail. My experience was that the entire front end (both driver and passenger side) went beyond lowest position even though only the LF was leaking. I'm told that they will move in tandem even the one that is not leaking.
I know that Audi recommends replacing both but I've not heard a compelling argument for doing so. As your post said, Audi did not do it in pairs. My non-dealer Audi shop will use the OEM part ($750.00 plus labor) and I will then see if there is any change in handling. If so then I will also do the second one.
A possible source of my problem may have been that the local Jiffy Lube did not lock the suspension before lifting. This is known to cause problems with the air suspension. I've since turned over all my maintenance including oil changes to my local Audi shop.
My plans are to keep this car for another 100K miles, it is a tremendous vehicle that impresses me everyday with the way it runs and handles and I just have to swallow hard when the maintenance bills come calling.
