Visitor Agreement.
I must say this dealer is doing his best and the overall service has been astounding.
The only other annoying "problem" is the out side temp. display always shows four to eight degrees too high. They already did the TSB becouse it was sticking on one number. Other than always subtracting five degrees....any ideas.
Have had no tranny or engine problems so far.
I will be very happy with the car when and if I can stop keeping two hands on the wheel on back roads.
Oh.....Those puncture proof Conti's do puncture with a very small nail.
Thank goodness foa great five star dealer.
the mechanic at the dealer said that i am doing well another customer only lasted till 18k, I guess he was trying to make me feel better.
Greco
:lemon: :lemon: :sick: :mad: :lemon:
No engine or tranny problems. Overall mileage with mixed driving is a bit under 16MPG.
A stranger said to me yesterday...."nice car, how do you like it?" Let me say I dont think he will be driving a 300 any day soon.
MikeSp
are you riding on continental tires ??
if so don't waste your time
have them replaced.
its not an align problem its a tire problem
prorated in canada.
let me know how you make out
manager
To me the lemon law should still be in effect, because the car was still under warranty with only 800 miles on it.. seems to me that Chrysler products arent worth the money if they wont stand behind them... sorry to hear your having to go this route.. but I wish you all the luck and a happy resolve in your favor..
MikeSp
Charger police cars and it mention that the cop cars will have a firmer steering then stock.Maybe Chrysler will read some of these messages and make some changes.As for your sunroof rattle,there is a tech bulletin for that.Its 23-002-06 Jan.06.
Check your air pressure on your tires.If you have to much you may wonder more.I have the dealer put in 36lbs in all my tires,and you get a good ride,plus more grip.Try that and see if it helps.Sometimes the dealer put to much air in.
Good Luck
I have been reluctant to complain to any dealer about the steering fearing that since the car does NOT pull to the right that I had better not have them fix something that is not broken.
IMHO, some kind of steering dampening needs to be designed for these cars -- my 300M would run rings around my 300C in terms of handling on curvy and undulating roads -- at least with it, I NEVER had to worry about which way it was going to head after hitting one of our home-grown huge Missouri chuck holes!!!!
MikeSp
I think you will get used to it after awhile.I feel more
confidence in the steering now then when I first got mine.
But it's now 27k miles into its life and I've been
driving it carefully ever since I got it. Everything
seem s fine except they had to fix the alignment a few
times ( a common issue among all 300's)when it was
less than 1000 miles and they also replaced the rear
left power window module and flushed the software.
Dealers got those issues taken care. But I was told
the camber bolt has to be replaced in order to adjust
the alignment again. And it is not covered under
warranty. I was a mechanic in the service too so I
understand how things work. In this case, it's either
the mechanic at their dealership was trying rip me off
by charging $460 to replace it, or Chrysler had a
defect bolt on this one. How can it be damaged when
this bolt sits at the center of the wheel? So I
contacted one of the warranty Rep to discuss it, but
this lady seemed know nothing about mechanical
problems and she called up the service Dept. A few
minutes later she returned to me saying that Chrysler
300's has different alignment design and it's costly
to fix the alignment issue. Then she kept on saying
the $460 job of replacing this Camber Bolt is
considered "Normal Wear and Tear". What a joke!!!
I like this car and I expected to see big panel
gaps and some issues as people stated on forums. But
now I believe why people also said "Chrysler doesn't
stand behind their products".
To those people who consider Chrysler products as
their daily drivers, be prepared to deal with quality
issues during life expectancy of their products. If
you want reliability and service, go somewhere else.
And to Mercedes Benz, they made a big mistake to
associate with Chrysler. This kind of experience truly
damage the image of a world class car manufacturer.
Mercedes should sell Chrysler, NOW!!! They don't
deserve it.
Although I did not purchase my car from them, I found that, Dick Milham Toyota has the integrity and skills to make your purchase an extremely pleasant one. I commend the manager at Dick Milham on his customer skills and his efforts to go that extra mile in making a customer happy. You will not be disappointed.
Thankfully when it cut off it happened with me driving and I have the quickness to cost it into a store front parking lot, as I was going through a light that was just turning yellow. Very Dramatic wouldn't you say, but its true...
I am lemon lawing this car that I like very much but I cant pay for something that is not one hundred percent for at least 5 years...And with gods help this will work, but I wrote this just in case someone has the same problem. :lemon: :lemon: :lemon: your out...
My 300 used to pull to the right and after a few visits to the dealer nothing changed. So after all that frustration I decided not to rotate the tires to see where the problem was. The driver side front wheel had too much toe in. I did the alignment myself and 50,000 km later with new tires there is no unusual tire wear or pulling. I didn't rotate the new tires on purpose to see if my alignment didn't simply force the car into behaving. The left front wheel was 7mm out!! Don't the dealers and Chrysler use something better than my measuring tape???
Originally, the dumbazz service manager tried to tell me that Chrysler built them to pull to the right " in case of a medical condition" if you lost control it wouldn't go into oncoming traffic.
I informed him that he already had a medical problem and suggested that he see a brain surgeon immediately. lol
