Visitor Agreement.
(tounge firmly planted in cheek!)
I agree with the people about the em tires. I put Kelly Chargers on this car about 3000 miles ago.... Much better tires.
This is the best car I've ever owned.
All the TSB's are making me very nervous about the reliability of this car!
Thanks Again
For future reference, I would have immediately pinged OnStar for assistance. One of the things you're paying them for is to read engine diagnostic codes and recommend remedies.
The Ford Focus has has five safety recalls. The Escape isn't doing that well either. I would recommend an Impala to anyone who asked and if I had to do it over again, I would still buy an Impala.
To put this in perspective, imagine if our car was made by Microsoft. On a weekly basis, our car would die unexpectivly and we would have to get out of the car and get back in before it started. Every so often we would have to uninstall the engine and re install it. And every year they would change the gasoline and we would have to buy a new car to use it.
today I went out to do some maintenance on my 2000 Impala and was unable to release the hood latch
it pulls back as normal but wont "pop" if you know what I mean. Has anyone experienced this and if so can someone advise me how to manually release it as easily as possible?
thanks in advance
The hood "pop" sounds like the hood and the latch need to be adjusted. Remember when closing the hood, just "dropping it from waist level is enough to close the hood properly. Anything more means you need an adjustment. The weight of the hood is more than enough force to close the hood properly.
First off, when you talk about pulling the hood release latch, I am assuming you are talking about the one inside the car. There are two latches, the one inside the car will release the hood and the second one is the backup latch that is found under the hood.
It could be that the spring that pushes up the hood is broken/missing. To open the hood, pull the latch while someone else lifts up on the hood. The hood should come up about 2-3 inches. Then release the second latch and lift up the hood. Take a look at the latch, There should be two springs. The big spring is what pushes the hood back up.
If you cannot move the hood, something serious is wrong (hood missalignment) and you gotta take it to the dealer or a body shop. If you can wait, I'll try and upload some photos this afternoon.
wwnf
Oh, Also, do I need to get new brake pads, I think I read somewhere once that you should buy new pads when you get new rotors.
What is bad about cross drilled rotors?
Keep us posted.
Ask your dealer to check the injectors, fuel pump, and fuel filter. Also, try changing the brand and grade of gasoline, and see if that does anything.
I think I've seen other people mention a similar problem. I'm wondering if it's common. Can I see a show of hands of anyone that's had problems with the power driver's seat?
I'm sure I'll be getting to know my service manager well, before the warranty runs out. I assumed as much when I bought a Chevy. That's one time I wish I was wrong.
Jon
Joe
So, we left it alone until this afternoon. While waiting for the tow truck to come, I tried to crank it up again. Got the 1/2 second run-time before it died dead again. After that, I couldn't do anything to get any life out of the car.
Sooo.. while we're waiting for a call from the dealer tomorrow, has anyone else seen this before? I skimmed the other articles, but didn't see anything quite like this experience posted here.
Here is an update on service issues with my car which seems pretty consistent with everyone elses.
1. The infamous Amp Booster......The new 103 amp booster is on order at no charge by dealer now. I didnt get much help on this one from the dealership I bought the car at but took it to another dealer and had no problems.
2. Intermediate Steering shaft began acting up at about 22000 miles and has been replaced.
3. Front Struts replaced but dont believe they were bad. I showed the mechanic commentary from this Owners club about the steering shaft but guess he thought I was not about to tell him his job. Once again, this was the dealership I purchased the car from.
4. Rotors went bad at 20000 miles and replaced.
5. Power driver seat trac a little loose. I only noticed this during acceleration or braking. The dealer has ordered a new seat adjuster for it. I gave them the posts on the seat trac problem but they dont think that was the problem in my case...I suspect they are wrong on this one.
6. The headliner is loose under the moonroof. I forgot to tell them about that one.. Ha Ha.
7. Key Fobs working intermittently... The dealership could not duplicate the problem and said the relay checked out o.k. so nothing done on this one at this time. I will replace batteries and if that doesnt work back it goes.
8. I noticed a new noise after getting the car back from the steering shaft replacement which sounds like it may be coming from the tachometer. I dont know if it is related to the shaft replacement or not.
I sure hope thats it for awhile. The engine cradle is still fine as far as I can tell. No symptoms of a weak weld as yet. Maybe I got lucky there and got one of the stronger welds on the early production cars.
If we can get all these bugs out we will probably keep this car a long time as we love the ride and nice upgrades in a fully loaded LS. My wife loves the radio controls in the steering and I love the independent climate controls. The quality of the leather is poor in my opinion and the moonroof lifting out of the roof rather than flush is too noisy because of wind resistance so I couldnt recommend that option to anyone. But for the most part as long as we can get past having so many service issues as I stated above we will be keeping this car a long time.
Again, thanks everyone for your postings as it has helped me a ton in helping the mechanics figure out what is wrong with the car.
Ever since I got the car (4/7/01), I've heard an occassional noise that sounds like a pebble smacking against the windsheild. The first few times, I thought that I just didn't see the pebble. However, since I have never seen any pebbles actually hitting the windshield, have never seen any damage to the windshield, and have heard this while driving over smooth, pebble-free roads, I'm beginning to think it may be one of those documented snap/pop noise issues.
I would appreciate it if anybody who has experienced this please describe the sound, and tell me what to look for or recommend to the service dept. when I bring it in. I have to have the driver's seat repaired next wednesday, and I'd like to kill two birds.
Geez, I hope we don't have a more serious prob. If the noise was more consistent, I'd worry. I only seem to hear it from time to time while on the E-way. Gotta be me hearing things...
RR
How are your speakers sounding, now that you've gotten the door/window fixed?
Guess what?
It is the top dashboard piece that extends the width of the dashboard and it is located at the very base of the windshield. The top dashboard has 2 pieces. The main dashboard top and the second piece that is located near the bottom of the windshield (Where your light sensor is located).
On hot days this piece may start to creak because the clips are expanding/contracting due to the intense heat. This piece is exposed completely to the light/heat. When you put slight hand pressure on top of it you might here the peeble sound.
One solution is to remove this plastic piece and put gobs of grease in the fastening clips and put it back.
That's all no fuss or mystery. Don't go crazy looking for noises in the cradle, ISS or HVAC controls because those no longer exist there...it comes from this simple top dash plastic trim.
Guys, relax ande enjoy your cars!
I already have three big scratches and 2-3 dings in my windshield already. =(
I thought I was lucky that it didn't have a crack. Now I know why...imaginary pebbles.
Garypen: The speakers are sounding great! Whatever the service dept. did seems to have made the difference and I can hear my music without any resonance. The Alpines shine. Seperate tweeters would be sweet, but I think I'll lay off of modifying her for now.
How are those JBL's?
Thank God 'Crazy' is a relative term, huh?
Later, all!
RR
New Jersey commuter (80 miles a day)
I own a new 2001 LS (1SC package) that now has 1000 miles on it. So far so good, but I'd like to know about anything to keep my eye on.
however, my dealer says that after 12000 miles it isn't a warrantied item, that it becomes a maintenance item, so he won't replace them under warranty
how did you get your rotors replaced at 20000?
