Chevrolet Impala: Problems & Solutions
It sounds like symptoms of the Intermediate Steering Shaft problem...
Your problem is the first time I heard about as far as the 2001 Impala is concerned. Have you had the dealer go over it?
Have you noticed if your braking performance has diminished?
Also remember that the Impala LS has a stiffer tuned suspension called "Ride and handling" so you tend to feel and hear more of the suspension in comparison to a softer tuned car, like the Impala base sedan.
Anyhow, have the dealer check your front end with a fine tooth comb to make sure that nothing has gone or will go south down there. Please keep us posted and welcome to the club of Impala owners
00-07-30-014 Delayed Shifting
01-08-50-008 Power Seat Track
I dropped my car off this morning for both those things, and I want to be able to ask them if they tried so and so, IF they tell me they couldn't find anything.
Your transmission problem is unusual, so you need to get it checked by the dealer. The Transmission's valve body could be suspect, but they need to run a full diagnostic before arriving to a more definite conclusion.
Your electrical Gremlin is weird, never heard of it on any Impala. Have it checked, sounds like a computer fluke, which I hope it is.
I have OnStar but here in FL we don't have the personal calling service yet, so I can't comment on it.
Do you have a Lemon? Maybe, but give the dealer a chance to take care of your issues.
I have a 2001 Impala LS with a build date of 4/2001. 6K miles and zero problems.
Don't let your friends and family put you down for your choice. Cars are complicated pieces of engineering, built by humans and prone to failure. Even the vaunted Honda Accord has a ton of annoying problems with transmission, fuel sending units, interior rattles and so on. Go and take a look at the maintenance and repair forum and soon you'll discover that your problems are not that bad and that all cars do have their issues from time to time.
I used to drive Hondas and Acuras for 12 straight years, and the Impala if not equal is better relibility wise than any of my past 6 Accords and 2 Acuras. The Impalas is a great car, give it a chance before you sound off the fire alarm bell.
Good luck!
they have tried to put me into smaller cars but as soon as I get in and tell them about the former smoker smells in the car I get switched to a larger vehicle. This has been a big improvement over the last experience so I'll hold off my judgment. Why should we have to fight for good service? I'll never understand it. The leather seat had a
small tear behind the cover that fits over the side panel of the drivers seat. I can't really say that the tare came first or that the loose cover/panel thing is what made the leather get caught on clothing or something -it was too far back to be from normal jackets or jean studs to catch on it. Replaced under warranty so I'll not gripe about it for now. Happy motoring!
That's my guess.
I gotta say, though, not one single problem in our CL.
KarenS
Owner's Clubs
To me after owning Honda products from 1989 to 2000, I think that the new products are no match to the Hondas built in the late 1980's and early 1990's. My sister's '99 Honda Accord LX has had chronic front brake problems. It went back to the dealer yesterday for the 5th time in less than 3 months. Her 1996 Accord never exhibited these problems and none of my '89, '90 and '94 Accords did either. My '95 Integra had great brakes but I did have problems with the brakes on my 97 2.5TL.
Like I said, zero problems on mine. No wobbly seat. No late shifts. No uneven idle. No hesitation. No intermittant auto door locks. No poor radio reception. No extremely slow-acting rear defroster. I can't say that about my Impala, whom I affectionately named "my car" or "that silver Impala over there".
Between the Impala and the CL, it's the CL that has been "like a rock". Ironic, isn't it?
The Impala is still a great car. Quite solid. Good looking. Pretty comfortable. I've just had more problems with it than my CL. (I suppose "one" problem would have been more than the CL)
BTW, could you email me? I'd like to ask you a question about your experience with your 2000 LS. Thanks.
I know AllData has the full guys for a fee, but they don't have 'em for the 00-02 Impala.
Also, I don't think there should be a fee at all. I think they should be made public for free. It should be the right of car owners to see what defects and fixes the manufacturers have been discovering about their cars.
There is a discussion in M&R, Technical Service Bulletins that may be of interest to you. 0patience has previously posted detailed TSBs.
KarenS
Owner's Clubs
Edmunds.com Maintenance Guide
This way will spawn a new browser window.
Let me know if you still have any difficulty.
KarenS
Owner's Clubs
Brake noise is caused by a "slip stick" vibration of brake components. If the noise persists, a brake dampening compound may be applied to the back of each pad. Use Permatex Disc Brake #126hb, or equivalent. Also, clean and lubricate all metal-to-metal contact areas between pads, pad guides, caliper and knuckles with a thin layer of high temperature silicon grease. This allow parts to slide freely and not vibrate when moving relative to each other.
Garage just applied the dampening compound. The can indicated that a variance of just .0005 can cause vibration noise. The dampening compound was sprayed on the backs of the brake pads, allowed to set up for 10 minutes, and then pads reinstalled. So far so good!
What's the build date of your car?
I've accepted the DRL's, despite the fact that I dont totally agree with the premise of them making the car safer, and I actually have really gotten to like the automatic headlights, but I really do NOT want the interior lights blinding me the moment i turn off the key and take it out of the ignition.
Anyone ever tried to disable this or asked the dealer about turning this one "feature" off????
Of course, it can put the kabosh on those driveway make-out sessions while her daddy is peering out through the curtains. Try leaving the key in the ignition. ;-)
But seriously, it's far from blinding. You must be forgetting to remove the night vision goggles before removing the key.
I have checked the connections and they all appear to be tight, are there and TSB's or known fixes for this?
cheap insurance is right!
RR
