Visitor Agreement.
Chris
Chris
I heard recently that Toyota will up the interval for 2010 US Models to 10K. But make sure you get the notification from the Toyota dealer before you change to the 10K interval.
If Toyota in Japan gets the 10K intervals, do you think that's because of some people in the US not paying attention to oil change intervals, which can cause sludge in any car?
Very interesting, as the 2010 Camry requires 6 month/5K AND synthetic. I guess if some of those type of people ignored the maintenance schedule, the engine would be more forgiving because it's using synthetic.
If you've ever changed the oil and filter yourself and you've seen the dark black dirty color of the old oil and you've felt the weight of the sludge in the old filter (compared to the lightness of the new filter) after just 3 or 4 thousand miles, you'll think that a 5 thousand mile interval is stretching it.
Oil does several things in a car engine: it lubricates, it cools, and it cleans. It cleans by picking up tiny foreign particles and carrying them to the filter. If it can't leave them in the filter, either because they are too small or because the filter is full up, then it just carries them along indefinitely. That's dirty oil. And the better it cleans, the more dirt it carries and the less well it cools and lubricates.
It would seem that no matter how good the oil, synthentic or angelic,if you go to a 10k mile interval for changing it, you're gonna get 3K of new, pure lurication and cooling, 3K of increasingly dirty stuff, and then 4K of sheer filthy, ill-functioning, awful stuff slipsliding around inside your engine. And for what? You.ve saved, or rather put off spending, 30 bucks (half that if you DIY). And your car is worth 10 or 20 or 30 thousand dollars. Wow. No proportion there.
The single, most important, cheapest thing you can do to a Toyota to make it last 250K miles or more is to change the fluids at decent intervals. Oil at 4K or 5K at most, transmission and power steering fluid every 50K, coolant at a hundred.
Besides, don't you just feel better about your engine after you put clean oil in it? I always celebrate the occasion with a beer. Two if I DIYed it.
I once read an article in Popular Mechanics on hows they keep cabs going in New York 24/7 for hundreds of thousands of miles--they change the oil every 3K. O:kay, that was 40 years ago and oil has improve. ..So 4K or 5K.
But not 10K
You don't want to end up with a vehicle that won't run, because the wires aren't on correctly, the plug isn't gapped correctly, or you cross threaded (or stripped) the plug in the head.
You don't say which engine you have, so don't know whether you have one head or two.
If you really can't find it in the manual, then use the oil stick to help guide you. Put in 3 quarts, and then check the dipstick to see how far it is down. Keep putting in oil, 1/2 quart at a time until you get it up in range, then start the vehicle so the oil can be pumped around and fill the new oil filter up. Stop the engine, let the oil settle, and look at the dip stick again. Top the oil off.
Any good quality oil will do, of the correct weight (whatever that engine calls for ie. 10w30, 5w20, ???).
1. How do I turn this off?
2. Is there a way I can re-set this so that it comes on every 10,000 miles instead of every 5,000?
Going from memory..... with the engine running, push the odometer to the trip B setting, then turn the engine off. Next while depressing and holding the odometer reset in, turn the key to the on position but do not start. You'll see the bars count down 54321, and then it's reset.
Something like that. Going from memory and don't have my system handy, but the manual documents exactly how to reset it.
sorry to jump to subject to subject... .
its about my catalytic converter (front). i dont have one, instead i have a regular straight piping that was welded by a private mechanic. my original cat. converter was damaged (had a hole?) and made noises when i accelerated. at that time i didnt know that was a bad idea, its a bad idea right? my friends are telling me it wont pass a smog test. but when the mechanic was done welding, their were no noises, car ran smooth than ever. my next smog test is about to come and i dont to fail it. what should i do? thank you.
(I'm surprised a mechanic welded that in for you.
If it was my vehicle, I wouldn't do anything until they flunked me (or not). If they flunk it, they'll probably give you some amount of time to get it fixed (as per the laws). You can do planning now (and save your money up), waiting for them to flunk you. Then you can decide whether you are going to throw additional money at the vehicle, given it's high age and mileage.............or get another vehicle. If they don't flunk you, you're good to go.
what do you guys think about this cat.? hopefully that darn mechanic would weld this on for me for free since what he did.
yeah true i dont really want to make any major repairs to this car anymore. that is why im wondering if i would get in any kind of trouble if i sold it "as-is".
Assuming it wasn't dripping with oil prior to you changing it, then most likely one of a couple things are wrong:
- you didn't tighten up the oil filter enough, and it's leaking oil under pressure, or
- you tightened up the filter too much and squished the gasket out, or
- you didn't make sure the old oil filter gasket came off with the old oil filter, and installing the new oil filter and gasket has squished out the old, or
- you didn't tighten the pan drain plug, or
- you stripped the pan drain plug by tightening too much.
two questions
1) the 'handle' inside the door seem to be made of two separate piece of material, and there is a gap between them, so if I hold the handle tight it feels like it pinches or squeezes my hand or finger, this is really annoying to me. I look at all four doors, and the 'handle' all seem to have a small gap.. does you camry do that???
2) when is a good time to do first oil change, should I wait till 5000 miles or is it better earlier during break in of the vehicle?
For 2) Keep the oil in for 5K miles, and I think with the synthetic oil Toyota now requires for '10 and later 4-cylinder models, you can actually go one year or 10K miles, whichever comes first, between future oil changes.
mechanically i have no complaints, the engine is strong and smooth and car drives like a luxury car, but Toyota could have done a much better job not cutting corners here and there in the cabin. Another thing I don't like like some people are saying the seats are too thin, even my 2000 solara has a a more thickly padded seat.
is it common for a new car to need alignment?
also, seems the steering wheel feels a bit light and vague, instead of centered on the road it feels like it likes to wander if there is slight uneveness on the road, and constantly needs some minor adjustment. do I need to take it back for another alignment or is this just how camry drives?
for the oil changed, I will follow the owner manual and change at the dealer..
However, if I try to tilt the back part of the seat up, the front part of the seat moves up with it, almost like I'm just ajusting the seat height??
Does you camry do this?? I can't seem to adjust the seat to a comfortable position, my 2000 Toyota Solara doesn't have this issue and has more thick padding for the seats - I agree with some people the newer camry seat is not comfortable for long trips..
Dealer notes indicates it pulls left or right depending on which side the tire/wheels are on, does that mean the tires are defective? Also is T0.7 too much for the TOE adjustment?
Dealer Notes:
"pulls to the right preliminary check & Road test, pulls to the right, T0.6, switch front tire/wheel & road test, pulls left to T0.5, reverse the front one side tire T0.7, steering wheel off center, check front wheel alignment T1.2, adjust front wheel alignment, adjust FT TOE T0.7"
Just a reference point. Last month I just checked my brakes on my 2007LE, daughter who is primary driver said she heard a squeak. The rear pads were worn down (to the warning sensor), fronts were fine had lots of pad left on them. The rear pads were $23 for the rear set, and $5 for a quart of brake fluid (I flushed and replaced all the fluid in the system). That's $30 in parts, and I would guess 1.5 - 2.0 hours of my time including the time to get the parts from autoparts store. Rotors were fine, didn't need to take them off.
I don't know the labor or parts rates in your area of the country.
If your vehicle really does need the rotors cut and new brake pads on all fours, then I guess that's probably a reasonable price. Most places have the package deal which pretty much is an easy way of giving you an estimate, whether you actually need all of that or not. Also makes sure you have a complete job, and won't have to come back for any re-do.
Just giving you a DIY reference point (not counting the jacks and tools already had).
But of course while I had the tires off, checked everything else over, scrubbed/washed the rims and tires real good of brake dust, and rotated the tires putting them back on. So got a couple other things done while doing the brake job.
