Ford Expedition
1181921232434
  • davantdavant Member Posts: 294
    Joe#,
    Our electronic doober is off between one and one-and-a-half MPG compared to the reality of miles traveled divided by gallons to refill. Being the avid post surfer that I am (not as good as Steve but I use other sources too) it appears not everyone has this problem. Those that do seem to be pretty consistent with about a 1 MPG error. With variables like pumps used, how you top-off, grade/brand of fuel, and most of all driving style, I recommend you remain objective until you determine MPG yourself and compare it to the Message Center. Congrats on the upcoming purchase, you'll love it, promise!
    P.S.-Why bother with GPS? It's Texas, everyone's friendly and you can see forever so you can't get lost.
  • kamrikamri Member Posts: 2
    I saw a post from Davant in regards to software fix for the mirrors. Does anyone have specifics? My mirrors, most often the passenger side, will lose its setting after initial entry with fob or when shifting from reverse.
    My dealer has ordered a new mirror. I believe this will not be the fix. My guess is IC or module related. Any body with similar issues?
    Kamri (not Camry?),
    I know you were asking the masses (other than me) but I was in for mirror service last week. They told me about the upcoming software or new control module release, they weren't sure which it was going to be. They said the main reason for this update was that mirrors can bang stops because some drivers set them pointed pretty low and the reverse command exceeds physical limits. Our mirror, yours, and alot of others seem to have a problem a little bit different than that. Ours won't tilt down if you back up more than once. Sometimes it waits 10 or so seconds before tilting down on the right side. To me this seems to be a servo voltage command problem or a weak ground. Unfortunately our dealer won't take any action until the TSB is fielded. We also need a new right mirror as the glass jiggles at highway speeds but they wouldn't even fix that right now. Something about being advised by mother Ford not to replace mirrors for uncommanded behavior.
    Hang in there, I'll be one of the first to let folks know what I find our or when it's released.
    Davant
    No not Camry, although my parents have one with 250k+ and still running strong.
    Actually, I was hoping you would reply since I saw you post regarding the mirrors. It sounds like my prob is a little different than yours. Mine tilt done fine in reverse, but do not go to their original setting. It will just keep on going till it can't go further (pointing up in the sky). One night my wife accused me of cutting someone off. I know I checked in mirror before changing lanes, but I didn't realize that it was shooting straight up in the sky. Now I'm cognizant to check mirror adjustment at all times. Occasionally when using the fob to enter the vehicle, the mirror will pull all the way in. It appears to loose its memory. I'm betting on the control module. The dealer wants to replace the mirror (on order) but I'm convinced that won't be the fix.
    Kamri,
    We also have an '02 Camry and it takes good pitchurs, drives nice too.
    At least our mirrors behave to the point of keeping us safe in traffic. Obviously your vehicle is fascinated with astronomy or perhaps is summoning the mother ship. They say each has it's own personality, now I believe it. Until the TSB is released you can always disable the reverse tilt-down mirror feature in the Message Center Setup without disabling the Back-up Aid. That way you can still hear the beeps without hearing horns too. Keep in touch!
  • joe78733joe78733 Member Posts: 4
    davant, Thanks for the info on the MPG error. As for the Nav system, of course the folks are friendly in Texas, but I'm a gadget guy and I just wanted one. I came close to not getting the Expo. because it looks like such a poor Nav system, compared to the many good ones that are out there. Hopefully after I get it, it will turn out better than the very poor demo the sales guy tried to do. Really excited about getting back to the Expo. Had a 97 for three years, switched to a Lincolin LS in 2000 and going back in 03. Take care...
  • kkkkkkkkkkkk Member Posts: 2
    The 18 MPG driving I refer to includes 230 miles of I94 driving at 65miles per hour-no stops, cruise control set at 65 miles an hour and roughly 50 miles through small towns, country driving where the speed limit in the country is 55 mph. My XLT does not have a message center. As I mentioned, I calculate the mileage by hand every time I fill up.My travels are in Wisconsin (280 mile one way)so it is not completely flat country. My previous Expedition with the 4.6L engine 4x4 would also get the same 18 MPG under exactly the same conditions.The 4.6 engine would get 1 more mpg though in combo city/highwway driving than the 5.4L.
  • czerwinskiczerwinski Member Posts: 7
    I am purchasing an '03 Expy in the next couple of months. I prefer the 6 disc CD changer option and extra power, but need to have a casstte player. Does Ford have a factory installed tape player to go along with the CD changer system, or am I stuck with the single CD/tape player combo?
  • expy02expy02 Member Posts: 23
    Davant
    You can't have my boat! But it's 27 degrees as I type this, Spring can't arrive too soon!
    As for the towing mileage with my '02 5.4 4WD Expy, I mainly do short trips, rarely over 40 MPH. I would expect it to get around 13-14 MPG on the highway. The Expy replaced my Grand Cherokee Ltd with a 318, it averaged 6-8 MPG towing the boat on the same route. I have seen 17 MPG highway mileage but it drops to 16 MPG as soon as you hit 70.
  • jrc346jrc346 Member Posts: 337
    Yeah it's true. I have get a very solid 18MPG on the expressway. My mileage in town however is a very dismal 8-9 MPG. My conditions were in warmer weather, on I75 going 68 MPH for about 100 miles then switching to a two lane road for another 125 Miles going 60-65 MPH (225 mile total trip). I take this route often to our vacation home and average pretty much around 18 MPG. This is NOT using the computer. However the computer has been pretty close numerous times. Lately though I have been using the cruise and this has lowered my MPG to the high 16's on that same route.
    I do have a problem that just cropped up. The two last times I have opened up my OIL cap there has been an oil sludge build up. This has gotten me nervous as I know that this can cause engine damage. I am going to replace my PCV valve and hope that remedies the problem.
    Something that I forgot to mention is that I do have a K&N Filter Charger and I do use Mobil1 Synthetic Oil. This may or may not contribute to the good MPG's as I bought my Expy used with the current air filter and oil I use.
  • caroline913caroline913 Member Posts: 5
    This is in regard to my previous posts #1016 & 1019. I have filed the Lemon Law with this state
    for the malfunction of my 2003 Expedition and on Friday the dealer completed the last chance at fixing my seat motor problem. That was 1/17/03.
    Today is Monday 1/20/03. I drove it around 150 miles and it broke again! This time they can have it back, I'm sick of wasting my time, not to mention the money I spent. It appears to me, and I told the service department this, when I use the heated seat button the power seat stops moving soon after. The service advisor said it could not be electrical because it is all one unit. That doesn't even make sense to me. I was also reminded that 4 other Expeditions had this problem, but he never told me what happened to them. Sorry to bring down the board, but I want
    to know how I can be the ONLY one with this problem.The mirror problem, I also have, is suppose to have a recall by spring, their words about it. No repair available now. Hope none of you experience any of this, and remember
    I'm a Ford fan. Had a 97 Exp and bought my son a 2001 King Ranch.
  • zman3zman3 Member Posts: 857
    18 on the freeway and 8-9 around town? Wow!!
    Regarding the cruise: I always assumed cruise would give better mileage. Guess not??
    Has your mileage dropped much since it has gotten cold? I've only had mine since mid October. I am hoping, but not expecting, better mileage next summer.
    ...but I want to know how I can be the ONLY one with this problem.
    You are almost certainly not the only one. It is quite possible that none of the others who post here and represent a small fraction of all Expedition owners have experienced the same problem.
    Good luck!
  • brads03expybrads03expy Member Posts: 12
    Have an '03 Expy 4X4 5.4L engine. 2,800 miles
    Trip to Illinois:
    Friday night driving 76 MPH with cruise set, 3 adults, 1 infant, 2 dogs loaded to the gills, small crosswind, 6 Degrees outside, 15.1 MPG.
    Trip back on Monday:
    Even more loaded (late Christmas with wifes family, our son made out like a bandit!) 35 to 65 degrees outside, small tall wind, got 17.28 MPG (280 miles 16.2 gallons) 2 lane roads for 80 miles at 68 MPH, then 76 MPH for 200 miles. I was impressed.
    I have been getting about 15-16 MPG driving back and forth to work @75% highway.
    I have an XLT so no fuzzy math here, all done the old fashioned way (manually).
    My mileage does get worse in the winter. I can't say whether its that I am using the cruise more often or that it's the cold weather that has brought my mileage down. I am not in anyway complaining though. I originally thought that cruise would get the best mileage as well. I have found though that I can modulate better for hills and such. So instead of the Expy dropping a gear I use the hill that I go down to gain speed then use that speed to get up the next. Kind of tedious I guess. Not so much a big deal though when you are the only one on the road. Other things that I have done to get better gas mileage is make sure that my tires are up to pressure (something that many people ignore during the winter months) and I also try to let off the gas farther back from stop signs and lights. This helps extend brake life and seems to do alot for mileage as well. I think it's conglomeration of all of these tips that I have picked up over the years that gives me such good mileage...at least on the expressway/open road.
  • alwaysfordsalwaysfords Member Posts: 210
    Fuel additives in the winter also decrease mileage. I don't know how far reaching the additives are, but I know they are in all the gas in the Northeast.
  • mirthlessmirthless Member Posts: 1
    I am looking to purchase a 2003 expy. I intend to use this vehicle for offroad and horse trailer towing. Do I gain towing capacity by purchasing the 5.4 instead of the 4.6? Do I gain towing capacity by purchasing the 4x4 instead of the 4x2?
    Post #
    1037 - kkkkkkk - 18 MPG, wow, I believe you, just can't duplicate it with our 5.4L 2WD EB no matter what, sounds like others can though.
    1038 - c'ski - No cassette player available with the 6 CD. You may want to ask the dealer if they can install an 8-track with Quadraphonic sound (only those over 40 get this).
    1039 - Expy02 - OK, If I can't HAVE your boat maybe it could come visit as it too needs a vacation. It's just 5 minutes to the beach and it was 70 degrees today, reconsider? I might try my MPG test again just below 70. I'll enjoy doing 69 in a 70, first time since high school.
    1040/1042/1046 - jrc/zman - 8 MPG city, 18 highway? Are you racing or just heavy footed for heaven sakes? I thought it might be just the gas but not with 10 MPG diff C/H. As 'Z' said tires and looking ahead matter alot.
    1041 - Caroline - Your loss is their pain at last. Getting another one, what's next?
    1043 - tidester (host) - Good point! Maybe all the others are in the shop so they don't have time to post?
    1045 - Brads - Similar loads, trips, results here. Was that you in front of us?
    1047 - Al'Ford - Even though it's not that cold down here I think we get 'Yankee' gas as our mileage is steadily declining, at 7.5K miles I'm still using reg oil & Amoco.
    1048 - Mirthless - Maximum towing capacity of 8,900 lbs comes from the 4x2 5.4L combination. 4x4 5.4=8,650lbs, 4.6L 4x2=5,750lbs, 4.6 4x4=6,050lbs. It's on page 15 of the glitzy brochure or you can get it via this Adobe link: http://www.fordvehicles.com/images/suvs/brochures/EPD03_brochure.- - - pdf
    Thanks to all who put up with me, Happy Fording!
  • bodymanbodyman Member Posts: 23
    I have not had a chance to drive my 2WD '02 in snow yet, and I am wondering how well they perform. In the past, my full size station wagons were the best cars I drove in snow. My Expy has General tires and does not have the limited slip rear end. How is traction and road holding in curves? Thanks, all!
    2WD without limited slip - this definately isn't a snow going buggy. Most years in NC how much snow do you get?
    We get very little near the coast, some winters we don't get any. When we do, it is rarely more than 4"-5". That's why I did not get 4WD.
    I am more concerned with the back end breaking loose in curves. I realize each vehicle has it's limits, and traction is also relative to tire design.
    This my first SUV, and I just wondered if 2WD sucked on snowy or icy roads.
    I've never driven the 2WD so I can't comment on that - I'd just call in sick and snooze on the couch on the snowy days! It probably acts an awful lot like a pickup - real light in the back. It isn't something a few tubes of sand can't fix though. I used to put sand in my Wrangler even though it was 4WD. It really made it sit down into the mush nicely.
  • tonyd39tonyd39 Member Posts: 12
    Three 2003 XLT 4x4 Questions:
    A.) I'm considering the purchase of a new 2003 XLT that looks to have been manufactured in the July/August 2002 time frame. Does anyone know if any changes have been made to XLT models that are more recently made (i.e. December 2002 or January 2003). Or are/were there any problems with the initial 03's manufactured during the Summer of 2002?
    B.) The XLT i'm looking at is a 4x4 with the 5.4 engine. It has the AdvanceTrack option, and side curtains with the rollover sensors. What does everyone think about these two options? Are they worth it? What is the advantage to using AdvanceTrack if you have auto 4x4? Does AdvanceTrack effect gas mileage.
    (C.) Lastly anyone know of any safety issues with the side curtain airbags with young kids sitting in the 2nd row seats?
    I bought a 2003 that was made in July too! I know that they have deleted the underhood light, 3 of the side scuff plates, spare is a steel wheel instead of the aluminum one. These changes happened at the end of 2002. Saw these changes at Blueovalnews.com (search for Expedition).
    I have the side curtain airbags and know that in the sales brochure it has a picture of them. It looks like airbags are curtains and come down and protect the side glass areas. They don't fire into the passengers space like you would at first think an airbag would do. They stay inflated up to 6 seconds. I have an infant and have zero concerns about this!
    I didn't want Advance Trak because you get open differenials instead of the standard limited slip ones. Also it is expensive and is something else that could go wrong, especially since that technology on the Expy is so new. No gas milage differences.
    I will add one comment on the AdvanceTrac.
    I have an 03 Expy with that feature. We have not had any serious snow storms here in Minneapolis yet, but we have had snow. I have taken the vehicle out to a parking lot to play with the AdvanceTrac feature and I think it is pretty damn sweet. It won't overcome the laws of physics but I had a heck of a time getting the vehicle to break loose during turns and evasive maneuvers. I am very happy we got it.
    I don't do a lot of off-roading so I don't miss the LSD. The open differential with the Advance Trac has an electronic traction control feature to it that basically serves the same function as the LSD. Read the following link:
    http://www.fordtruckworld.com/news/2003expy-dirt.asp
    If you don't live in a snowy area I'm not sure AdvanceTrac would have as many benefits. It would still help in dry conditions but you would really have to be in a world of hurt for it to kick in, IMHO.
    Tony-D,
    I see you did the dual post thing, I addressed pricing in the other one. The side airbags have no proven utility but peace of mind. The feds haven't tested them but we all agree you'll be glad you have them when called upon. In theory the bags sound great but all passengers in our vehicle will be belted in at all times. The 2/3 coverage they provide the second row will probably protect them from some glass, lose objects, and pad flailing limbs. Those seated in the third row get a great view of side, passenger, and drivers airbags inflating (depending on direction & speed or impact) but no airbag (unless mother-in-law is seated there). The other more interesting features to me are the pre-tensioners that suck up seatbelt slack, and the staggered airbag deployment force based on seat postion, weight, etc.
  • powertrippowertrip Member Posts: 3
    I am currently looking at purchasing a 03 EB 4x2 5.4L with power 3rd seat, 2nd row captain chairs, and a sunroof. I was wondering what would be a good deal on this vehicle OTD? Any other options (Advancetrac, etc) do people find they really like or wish they would have gotten after owning for a while. Looks like invoice in my region (NE FL) is $36K according to Edmunds.
    I have been reading about the problems with the new model and wonder if anyone has positive or negative feedback about buying the vehicle due to these specific problems(mirrors, seats, whining, etc.).
    Finally, I am also looking at the Sequoia. The biggest difference to me I guess is the price for the Toyota but they last and have good resale values. I have almost ruled out the Tahoe due to the 3rd seat configuration and archaic looking dash. It does have a lot of bells and whistles but that is about it and most I can deal without I think.
    All comments and feedback is appreciated. I want to make an informed decision when I buy. Right now, I really like the Exp and especially the price I think I should be able to get it for opposed to my other favorite(Sequoia).
    Anybody know if Ford will up the rebate and/or continue with the dealer incentive($500 ends 1-31)? I found out Tahoe's rebate is going to $2500 from $2k on Feb. 1st.
    Could someone tell me exactly what all an out-the-door price should include and specifically if it includes taxes when it is talked about?
    You are in the same situation I was this past fall. I really liked both the Sequoia and the Expedition. I was looking at a 4x4 LTD Sequoia and a 4x4 Eddie Bauer Expedition. I picked the Expedition and here is why:
    1) I bought the Expy for $100 over invoice with an additional $1K rebate. The Sequoia would have cost me somewhere between $3K and $4K more for a comparable vehicle.
    2) With my insurance company, which I've had for 22 years (and I'm only 38), the Sequoia was $500 more per year to insure. I don't think most companies penalize you that much for the Sequoia but mine does. I wasn't about to switch agents just for a vehicle. He provides great customer service and I have never had an issue with a claim. This was probably the single biggest factor in my decision. I am certain the Sequoia will hold its value better, but the $3K+ difference in purchase price added to the additional $3500 over 7 years it would have cost to insure was just too much of a bump for me.
    3) Like I alluded to above, I am a buy 'em and hold 'em type. If I got rid of the vehicle after two years I think the Toyota would have been a better buy, but in the long term (7 years or so)I think the depreciation will be less of a factor. I'm sure the Toyota will still be worth more, but I think there will be less of a gap.
    4) I figure I can buy a Ford extended warranty for less that $2K if I decide I might need it. I can have bumper to bumper coverage for 100K miles, which is better than the Toyota factory warranty.
    5) We actually did like the Expy almost as much as the Toyota. I think it has better features, like the power third row. The reliability was the only potential downside.
    6) Our Expy has had less than stellar reliability so far. There are some owners who haven't been back to the dealer yet, but I am not one of them. I've had a couple of rattles, the front end growl, the mirror issue, and now my rear differential is leaking. I don't think the mirrors on the Sequoia tilt down, so I could always disable the feature on the Expy, but I do like it so we leave it on. It will be at the dealer today as a matter of fact for the differential.
    7) We owned a 95 Explorer before the Expy. It had quite a few issues during the 3/36 warranty. It was in the shop probably 6-10 times. Nothing major that left us stranded, but more than enough to be a hassle. However, we got all of the bugs worked out during that period and other than routine maintenance, the only money I put into it was a new thermostat. It was 7.5 years old and had 85K miles.
    8) I do have the AdvanceTrac and love it so far. One big concern I had with the Sequoia was the over active traction control or stability control system where some people were left stranded in an intersection with no power due to the hyper sensitive system. That sounds truly spooky.
    9) One final note. Everyone's mileage seems to vary. Every vehicle is different. My friend who owns a 4x4 Sequoia claims to get 16 mpg in combined driving. That seems pretty good compared to the average. Our Expy only gets about 12-13 mpg which sounds slightly lower than the average Expy. I didn't buy the vehicle for the mileage, but I do think that it is the single most disappointing aspect of the vehicle. I was hoping to squeak out at least 14 mpg.
    Hopefully my ramblings help a little bit.
    Karl
    Powertrip, to me, out the door pricing means the price it takes for me to "legally" drive off the dealer lot.
    That means the sales price, taxes and all licensing fees have been paid so all I have left to do is wait for my plates to arrive in the mail and notify my insurance carrier that I've gotten a different/additional car.
    Anyone think of any other gotchas? Rebates in the mail?
  • wkohlerwkohler Member Posts: 74
    First, Steve's right; OTD should cover everything to drive off the lot. Rebates normally go to the dealer unless other arrangements have been made between the dealer and the buyer.
    Second, I must have an early Eddie Bauer Expedition as I've noticed I have all the "extra" stuff; i.e.; light under the hood, scuff plates, center A/C vent, trailer hitch plug, etc. So far (1800 miles), the vehicle has not been a problem; no issue with leaks, mirrors, funny noises, etc.
    Third: I'd like to say that after 5 suburbans, this is my first Ford experience. Why did I but a Ford? Just wanted something different for a change I guess. I do find some things that I just need to get used to: You can't "mix" the ceiling and floor outlets for the rear HVAC system on the Ford, I prefer the outside air temp (OAT) and compass readouts in the rear view mirror, there is no "neutral" position for the 4X4 system; and,you have to manually turn off the 4 wheel drive system when turning off the vehicle. I'm used to the suburban "resetting" to 2 wheel drive when the ignition is turned off. The turn signal, wiper, high beam stalk is managed differently on the Ford.
    Please don't take these as dislikes or Ford bashing. I do like the Expedition, but just need to become more familiar with Ford's interpetation of system controls.
    Bottom line? So far a great vehicle! Hope the "honeymoon" continues.
    OK ... now my dealer has a demo XLT 4x4 Premium with 5k miles with the 4.6L engine, leather, moonroof, 6-CD, reverse sensor, safety canopy, and DVD. They are offering this at a cost of approx $ 1,100 below invoice. The questions now are (a) is the demo pricing fair, and (b) is the XLT premium with the features above a better vehicle then the XLT 4x4 Popular with 5.4L, AdvanceTrac, Captains cloth, safety canopy, and 6-CD. I do not do a lot of hauling as the XLT will be used by the wife. Is the 5.4L and the AdvandTrack worth passing up to get the demo XLT premium with the leather, moonroof, and DVD, reverse sensor, canopy, etc?
    Tony,
    Demo price seems fair, see the other board for more on driving/choice/price. I like the leather but not the little engine that could. There's really no 'better' to it, they're both mighty-fine SUV's. Drive them both, not only with the sales person but on your own for an hour or so. Run an errand, drive like you do everyday. If you don't mind the demo and can live with the revier 4.6 go for it. 75% of folks get the 5.4, mileage is only 1 MPG diff and $700. Pssst, EB is sweet...
    As Steve said, OTD is just that, everything to get the keys and wave bye-bye without blue lights behind you. You'll have to pay $740 destination fee but that's in the sticker. I think all dealers charge 'administrative fees' for every vehicle sold that range from about $150-500 (pre-printed on the Purchase Order). I've found over the last 5 cars or so that they're generally unavoidable so don't ask they be, "thrown in to seal the deal". The only other 'gotchas' I know of are the paint & fabric protection that's usually pushed at point of sale, it's bad juju. I wasn't offered an extended warranty (probably would have bought the 6yr/100K mile Ford ESP if I was) but typically one is offered. If it isn't Ford it's a big profit item and may or may not be a good company, do homework ahead of time. Beware of the finance officer genie, he/she claims to grant your wish but has mystical powers. In other words, know your financing options or go through your own institution or you could be putting a percent or more back in the dealers wallet if you 'renegotiate' terms with that, "I can't believe I just bought it" gleam in your eye.
    Sometimes your salesperson doesn't quite understand the meaning of an "out the door" price!
    New Car Buyer Proves The Importance Of Getting It In Writing (WABC NY)
    The link in 1066 describes illegal action on the part of the dealership. The customer had a signed contract legally binding for a certain price. Although you sign a statement to reconcile errors it may or may not include a gross price adjustment. Legally the dealer, or any vendor, can't charge your credit card without consent, that part isn't up to a judge.
    Just trying to help and not scare the crap out of everyone who drives away happy. Writing does matter...
  • radiogeekradiogeek Member Posts: 9
    On a similar note as the postings about a written contract, my suggestion is when shopping for a car--bring a calculator!!
    I shopped on-line last summer looking for a 2002 Expy. with the features I wanted. I found a few locally. I first tried Thomas Ford in Beverly, Mass. What a joke. First, the truck's running board was damaged--like it'd scraped driving it too close to the door pulling it into or out of the showroom. When I pointed that out, the salesman didn't even acknowledge the damage was there. Didn't want to even hear it!!! As for the price: they'd come down on the 42K sticker to somewhere around 35K. I was interested (pending fixing the damage). Interested, that is UNTIL he kept giving me monthly payment quotes (with the promoted 0.0% financing) that would EQUAL the 42K sticker. It was like they thought I was so stupid I couldn't do basic math. When I brought attention to the fact the monthly payments equaled exactly the 42 sticker price, "That's the best we can do."
    I walked out. (Fortunately, as a radio DJ, I enjoyed bashing them the next few shifts I had!)
    In any event, before signing the contract, double-check their figures and math.
    (Side note: I closed a deal on a Expt at Rodman Ford in Foxboro, Mass. and it was much easier to deal with them than Thomas)
  • ranwin33ranwin33 Member Posts: 10
    I own a 4x2 with the limited slip rear end. It's lousy in snow, on ice and even when the pavement is simply damp. I am sure quite a bit of this is due to the rear wheel drive and my being used to front wheel drive vehicles, although I've now owned my Expy for nearly 2 years.
    I would say this, had I known it was going to behave so poorly I would have opted for the 4x4. Adding 200 pounds of weight in the rear end helps a little. See my post 688 from March 02.
  • efeatherstonefeatherston Member Posts: 1
    I just discovered this board and found this note. We are close to filing lemon law on our 2003 EB due to the climate controlled seats. The heat has not worked correctly since we got it, going from burning hot to shutting itself off and not coming back on unless you shut the car off. The dealership had the car 4 times now since Sept and replaced everything on the seats. The dealer told me the engineer has told him of 113 similar cases so far.
    So Caroline913, if it helps, there are others experiencing the problem.
  • delta8delta8 Member Posts: 1
    We just bought an 03 EB in Dec. and the DVD will not load up. We took it back to the dealer who removed it and is sending it in for repair. Has anyone else had problems with their system? Also, I thought the system was supposed to come with wireless headphones, but the dealer said the wireless headphones aren't being produced until later in the year. Does anyone know if and when wireless headphones will be available?
  • clpurnellclpurnell Member Posts: 1,083
    last year (before thanksgiving) I got a quote on an expy eb 4x2 5.4l With roof and DVD. Sticker was 41k+ There offer was 33160. I would say a good deal would be invoice - rebates here in texas that is 2k so 34k with no more than 36.5k otd seeing as taxes are 6.25% here
  • mlm4mlm4 Member Posts: 401
    A few weeks ago I rented a 4x4 '03 Expedition XLT with about 2500 miles on it from Hertz. I actually reserved an Explorer, thinking it would be nice to have 4WD in Boston in January, if needed. When I arrived at my #1 Club Gold space I found an Expy there. My first thought was, "I don't know if I want such a huge vehicle for driving the streets of Boston." But having already driven an Explorer I thought I would give the Expy a try, partially because I was also planning to drive to Cape Cod and Maine over a three-day period.
    Overall, over the 500-plus miles of driving I really liked the new Expedition. I neglected to check which motor it had, but I think it was the 5.4 (since I hear the 4.6 is wimpy). It was comfortable, quiet and smooth and was easy to handle despite it's size. Although the track is only about an inch wider than my '99 Tahoe, it feels much wider than that. I was able to negotiate the narrow streets of Boston, but I wouldn't recommend it for people not used to driving big trucks. Parking requires care and patience. Seats were comfy, driving position was good once I got the adjustable pedals all the way back, and the manual climate controls were touchy but we were able to stay comfortable with an occassional tweak of the temp knob. Fit and finish were good (by Ford standards). Visibility was good, except that I find Ford places the inside rear-view mirror much lower on the windshield (on all their vehicles) than GM does, which obstructs more of my view (being 6'2"). Gas mileage was around 15 mpg (mostly highway miles). My 5.7L V8 Tahoe gets just under 16 city, and just under 18 highway.
    OK, now for the critical review:
    Tailgate is huge, and requires lots of space behind the truck to open it.
    Compass and outside temp readouts not visible to other passengers.
    No front dual-zone climate control available (not counting the rear seat controls).
    I noticed a grinding noise from the front axle. I grazed through the board and found some mentions of it and a TSB, but didn't see any follow-ups. Seems like a common problem?
    Hard to get in and out without either stepping on the running board or grazing my pant legs on it. Being tall, I don't usually use the step.
    Not that a rental would have this, but Ford doesn't offer a satellite radio option on any Expy.
    Dash vent bezels felt cheap when rotated.
    Large side mirrors are nice, but when frozen with a small amount of ice are immobile. No power fold feature.
    Anyway, even though functionally it is a great truck, I can't help think that there are some key luxury features (such as the dual-zone climate controls and satellite radio) that GM offers on it's trucks missing from the Expy.
    Well the wife won out. Decided to go with the dealer demo 2003 XLT premium with the 4.6L engine with leather, 6-CD, moonroof, safety canopy, and reverse sense. The demo price with Ford rebates just seemed to good to pass up. I just hope I dont regret the smaller engine and that I didn't go with the other XLT with less features but the bigger 5.4L engine. I guess time will tell.
    I just purchased a new 2003 XLT. My question centers around the proper useage of the 2nd row and 3rd row seat belts. My kids will be sitting in these seats. When they put on their seatbelts should they pull them out all the way and then let the seatbelts themselves retract to where it is tight around them, OR should they just buckle the seatbelt and rely on the seatbelt to auto-tighten in the event of a suddent stop or force. I guess in other words what is the proper use of the seat belts.
    Mlm4,
    Glad you liked it. Put your feet up and relax, this could take awhile. I'd like to point out a few things, mostly opinion mind you, but some based on facts you may not be aware of.
    If it didn't feel 'revy' it was probably the 5.4L and your MPG matches up. I do agree it's a big beast but I feel, as I think you do, that handling inspires confidence as it doesn't drive like a nearly 3-ton vehicle. Large but not cumbersome, a fluid balance of nimble versus stable if you will. Steering is top-notch because one of the 100+ improvements for '03 was rack & pinion, not like your Tahoe or previous Expies that have recirculating ball (which way did the road go?). The hood was raised 4" which may exaggerate the feeling that the rear view mirror was lowered. Based on a buddies '02 side-by-side it didn't change but an inch or so. I'm the same height as you and agree, it can obstruct, but at 5,700 pounds, how bad could it hurt...us, LOL? Not that you would find one as a rental but the Eddie Bauer offers digital set & forget temp controls and mirror/seat/pedal memory for two drivers.
    I drove all the GM/Chevy's (except Caddi) before buying an Expie 4x2 Eddie-B with 5.4L. I like the higher torque and (albeit slightly lower) HP at useable/comfy RPM's Ford offers. Not that specs matter that much but compare the RPM's required at peak HP and torque for GM motors versus Ford. GM wins the peak spec race but not the torque one, and at what RPM? Will you rev that high without being laughed at by every other driver? Ford has it where it counts, towing and going with ease under 2,500 RPM's in day to day driving. Not a speed buggy, but strong and capable.
    I agree the tailgate is a whopper when open. I suggest folks who park with the rear close the garage door opening put some cushy weather-stripping on the frame/molding so the paint isn't damaged. I caught this early enough to prevent damage, I hope others do too.
    I never thought we needed a heads up display visible to all occupants showing the time/temp/drivers BP but hey, there's always next year, Ford engineers might be reading this. Driver/passenger dual zone controls (except front back as you mentioned) are there but are cleverly disguised as vent open/close controls, or you can argue over who owns the single knob, archaic but effective. I can't help but wonder how the Amish feel about this?
    There are others who have the 4WD grinding TSB and are satisfied it's fixed, look for that at blueovalnews.com forums if you can't find it here. I adopted a left foot step-board-swing in and hop-out to avoid the dirty pants or scraped legs. Sat-radio? Not anytime soon as Ford still hasn't mastered GPS, one thing at a time, LOL. Side mirrors have deicers, at least our EB does, Navi offers power fold mirrors this year, maybe Expie in '04. I think Lincoln needed that, power running boards, and power tailgate, (maybe a power back-scratcher) to justify the price (Expie x1.3).
    Both GM and Ford build great SUV's as does Toyota/Lexus (^$), and by this time next year maybe Nissan (Titan-in-law). I think Ford is king for now and selling an extended length and 24v power plant equipped model would keep them on the throne. Despite the many features and upgrades GM/Chevy offers, they've become 'stale' (dashboard, antiquated steering) and have resorted to infini-gizmos in an effort to wow & woo buyers. Remember, beneath every silky adorned GM/Chevy full size SUV exterior lies a live axle and leaf springs. I challenge every prospective GM/Chevy buyer to try this test. Drive on a road festooned with small potholes (alternate sides work best) at various speeds short of airborne/warp. Then try the same road in an Expie since they all have Independent Rear Suspension. Now tell me that you like GM/Chevy better! You won't be able too as you'll still be spitting out expensive dental work from round one. Thanks for your patience and postings!
    Tony,
    Have all occupants buckle up normally. Don't extend the belts fully so they ratchet while retracting unless you are using a child seat that permanently mounts to the vehicle. Trust Ford's system to do it's job , it's been tested. If you feel like you want to push the envelope securely belt in yourself in plus sack(s) of dog food in rows 2 and/or 3 and do a 15 MPH brake check, you'll sleep better.
    Congrats on the new Expie, you done good. Keep in touch.
    Dave -
    Thanks for your thoughts on the Expedition. I agree that one of the big advantages of this truck over the GM products is the IRS, and I took notice of the great ride with my rental. I'm sure in time GM will do the same -- GM and Ford seem to leap-frog each other with their designs.
    It may sound petty to complain about lack of dual-zone climate control, but the Amish are not paying $35-40k for their buggies either. I have dual-zone in my Bonneville, and my experience is that female body temperatures are always way above or below my (male) temp, so on long trips to keep everyone happy, dual-zone is a great thing to have. Considering that it is now available on the Navigator, why not the Expedition, which is a great long-trip vehicle and has no bargain-basement price either. Just an example. At these prices, I guess I'm just a bit fussy.
    Mlm4,
    You're not fussy, you just want everything I want too without having to buy a Navigator. I enjoy hearing about experiences and trying to understand others points of view, thanks for sharing. I've done alot of homework and hope some of it has value to prospective buyers or at least makes a few people smile.
    At least the Expie's optional temp controlled seats give each front passenger a choice to heat or freeze from the bottom up. Reading other posts, even that takes a few minutes to kick in (I think I divorced the frozen bottom one already though).
    I smell a rework from GM soon or they could start lagging. If they're both not careful the next frog leaping could really be a Nissan Unicorn.
    Cheers!
    I just noticed on the XLT i purchased that two of the tires (one front and one rear) seem to have a "bump" in the rubber on the sidewalls. By bumps I mean that if you rub your hand along the sidewall you can feel a "mound" and visibly see this as well. It's not exactly a bubble but it doesn't appear to be normal. Can somone explain what this is, what the cause is, and if this is something I should addres with the dealership. Could it be caused by overinflation and/or hitting a pot hole?
    Depends on what you mean by bump. I had "mold" marks on my Kirkland/Costco tires a few years ago. They were noticable from certain angles but had no effect on the tire. They looked and felt like "waves."
    Since you have the same bump on two of the tires, I'm guessing that this is all it is.
