Anyone else had this problem? Should we take it back to the dealer?
Chilin 12
Thks,
Russ
Can you tell me what if any text is displayed on the Avalon's info screen when using this device? Will you be able to see track or artist name? Thanks so much.
I have already run the head cleaner to no avail.
2 questions:
a) Is this a correctable problem, or there is a need to replace the whole audio system?
b) Which manual describes the receiver/CD changer removal?
Alberto
and how the heck would I go about getting the CD player OUT of my dash???
1. Am contemplating either buying an i-pod direct hookup -OR- a double din aftermarket. Will either of these improve the sound quality through the stock JBL set up?
2. And possibly the more difficult question... I have seen the mounting bracket for the double din application, I can not find ANYWHERE if someone makes a wood grain look. I really like the wood grain look of the dash and would like to keep the flow clean. Or.. If someone could provide a picture of what the standard black looks like installed I would really appreciate a view.
Thank you in advance for any suggestions/guidance you can provide.
Is the CD you're trying to load or play one that you burned yourself?
MODERATOR /ADMINISTRATOR
Review your vehicle
Can also try holding down the eject button for a few seconds to see if that forces an eject.
I sent mine to Simply Speakers in Florida. After installing my refreshed speaker.
I discovered sometime between I removed speaker and re-installed someone has relieved me from my wiring harness to the Woofer. Plug was definitely there when I removed speaker as it was functioning just the "rattle that everyone experiences. My question does this harness run straight to the amp under the seat or does it have a break at some point prior to amp?
Any ideas as to where I might purchase said part? And finally what type of connectors are used on each end? Any help is very much appreciated.
