I would fight with GM on this. Mileage isn't the cause of the RKE/FOB problem and it's widespread across the entire model line as well as a few other GMs. Threaten to contact the Better Business Bureau if you don't get any satisfaction and use this forum as evidence if you can't find anything from GM.
I would be careful about buying replacement parts on Ebay. It looks like the fix is a redesigned FOB, not just a new one.
I had the same issue with the remote range but since then i have had the new antenae and both fobs replaced but not the receiver. It is an improvement but I still don't think the range is as good as it should be. I don't recall the receiver being part of the fix. Could you please correct me if I am wrong. Hope to hear your reply.
Did you get the new FOBs and antenna as well?
Yes, fobs 1st, then antennea and finally the reciever. I just read in another forum that the new fobs have stars imprinted on the back, mine do.
Ya, for me too now...!! It's almost like these new fob transmitters are the higher powered versions. :surprise: Most likely though, it's a combination of all new replacment parts here. Well, I tell 'ya, it's certainly a great feeling to finally have everything in good working order.
Enjoy your ride.....
Frank
Thanks to all,
Ron
Her are the part numbers from my invoices:
#15912860 transmitters
#25837954 antennea cable
#25808837 receiver
The only other technical item on the invoice is "Reprogram receiver through TIS2000", I have no idea what TIS2000 would be.
I hope don't have to "fight" with your dealership to get this done. I had no problem or resistance at all.
Good luck though,
Bob
Bob,
I hope not as well but the last time I got the attitude that they knew better than I what was wrong. Of course, once I picked up the car, I noticed it was exactly the same as always. I half expected them to blame my window tinting but they didn't. I think I get some resistance because I didn't buy the car there. I don't think that should make a difference but maybe it did.
Thanks for the input. I'll take those part numbers with me.
Later,
Ron
MY APPOLOGIES FOR TAKING SO LONG TO GET BACK TO YOU ON THIS ONE!!
Fobs (transmitters) GM # 15912860
Coax cable Anenna GM # 25837954
Receiver Module GM # 15946938
You will notice that I have a different GM receiver Number to Spinner's...???
Not sure why at this point...All is still working perfectly for me and it's been about 5-6 Days.Good luck and let us know how you make out.
Frank
Hopefully that difference in part numbers doesn't mean one of you will have problems agin. Hopefully, there are just more than one new part number. I'll let you know how mine turns out.
Later,
Ron
Gee....I sure hope all our problems are gone for good..!! ...I looked both numbers up on GM parts direct and they are definately both for keyless entry Receivers.I wonder why the two. Anyway, I e-mailed gm parts direct about this and i will let you know what they say....
Frank
Anyway, although it wasn't a great distance away, I was able to unlock my car holding my fob behind a truck body a couple of cars away. Opened right up! I usually couldn't get it to open 10 feet away pointing it directly at the car.
Well, I'm still waiting for the guys at GM Parts Direct to get back to me as to why my keyless entry receiver part number (15946938) is different than Spinners (25808837) So, I got a little impatient, and called my local GM dealership for an answer. They said that his (Spinners) is the later version. oh no !!....Just great !! I really didn't want to hear this !! Well, cross your fingers for me, I hope this doesn't come back to bite me in the backside. Again , everything is still working great so far......
Frank
You're the man! I'm going to try to ensure I get the latest part numbers in mine now that I know. If they refuse to hook me up, I'll just wait a while and see if their inventory runs out. Of course, with my luck, YOUR part number will be the quality one and the newer will fail in my car.
If any of you are willing to do some long range testing with your cars, maybe in a large parking lot (Walmart) to get a good idea of range...by parking spaces....from the side and front and back...that would be great. No special trips, just the next time you happen to be out. I've noticed with my limited range now, sometimes extra cars in the lot decrease my consistency...sometimes range.
Good luck!
Ron
I had my 06 SS into the dealer late last week and the service dept looked at my RKE system. The only problem I'm having is low range on the remote start, but everything else works great. The service manager told me that the SS (at least mine) is not included in his TSB's as having these problems and he thinks mine has the latest coax antenna. I told him, I bought my SS last July, and the TSB came out in the fall, so I think he is wrong on that. In my argument to him, whether it does have the latest antenna or RCDLR or not is illrelevant since the range is bad and in my opinion needs to be repaired. My question is.....Have any of you fellow 2006 SS owners had your repairs made and carried out under warranty? Again he thinks the SS is not part of the program! :confuse:
Here's my 2 cents.....!!!!!
Just as a review for yourself, and you may want to also give a copy of this bulletin to your GM Service Manager, please refer to post # 47 from zjim . As stated here, the poor remote range and all the other associated problems in this bulletin specifically states that coverage is for the 2006 - 2007 Chev Impala's and Monte Carlo's. There is absolutely no reference here to any specific Impala model covererage, or, for the exclusion of the SS model, for that matter of fact. Gm would have never left this fix this wide open if it was for specific models only !! The remote start runs off the same fobs( transmitters), receiver, and antenna. They are wrong ! wrong! wrong! What a bunch of MORONS here !!!....Spooler, the new coax antenna cable just came out about a week or two ago....I waited 5 months for mine !!! The bulletin states that it would be available in January 2007... well after you bought your car. Tell them that you are totally not satisfied and that you will now be getting the GM Regional Rep over their dealership involved here. Now let's see how fast they jump to your attention....!!
Let us know how you make out...
Frank
Check to see if your new fobs (transmitters)have the stars on the back cover....?? ....and, check the Gm part numbers on your invoice. Hopefully, they match the parts numbers reported for some of the fix in prevoius posts ... i.e....see the numbers that I reported for example to Ron !!
Now, you need to go to post # 47 and have another read. I believe that the TSB does not mention the receiver specifically at that time. Also, to get a good feel here, and some great history and experience, read all the posts fom #47 to the present. It will give you an idea as to what works and what doesn't work and by what was replaced and not replaced. At one point , GM informed some dealerships to change one part at a time . I'm not sure if this is still in effect today. My personal feeling is that ultimately the receiver needs to be changed.Sad to say, if you don't, it may not last !! I guess time will tell.....
Frank
I was also a little frustrated to see that they didn't add the oil change to the paperwork. Advisor forgot to put it on there and did it himself since the mechanics had already gone. Should anything happen to the engine, I wouldn't want GM to try to say it wasn't covered because I couldn't prove the oil was changed at the proper time.
Thanks for your reply! I think you are absolutely right about this. It may be hard to believe, but this Service Manager I think is a pretty good guy, and has went way out of his way to help me a time or two. So I'm going to keep after him, gently nudging him along the way. I'll do as you suggest and get a copy of zjim's #47 post to show him next time I'm there. I'm pretty confident he'll get me fixed up. I'll let you know how it comes out.
I can't imagine him thinking there is an SS specific receiver. That's about the stupidest thing I've seen on here. That's about the same as saying it has a different windshield. Maybe he was just having a bad day.
Ron
Since I work for GM in St. Catharines On., I had one of the GM engineers go into the GM website that the dealers use for TSB,s and he printed out the fix for the key Fobs. It did not mention the receiver as part of the fix, only the transmitters, cable and reprogramming. I had the fix done but as I had mentioned in the other forum to Frank, that I had the TPMS light come on twice in 2 days about 3 weeks after the fix was done. I'm not sure if there was an updated version of the fix after the one I obtained from the engineer. I will have to investigate some more when the engineer comes back from Germany. Maybe he will learn something from the Germans when he gets home and pass it along to GM..........grrrrrrrrrrrrrr.
Well you know, it doesn't surprise me in the least...After my many, Fob experiences/frustrations here, and also reading everyone elses woes along the way, (some good, but mostly all bad), I personally see the TOTAL Fix as.... 2 new Fobs, Coax antenna cable , yes the Receiver, and the additional re-programming..!! Obviously, the recever would be the most difficult( labor) and expensive part to replace for GM on a general and wide spread basis. Maybe it's one step at a time and only replace it if all else fails.... Am I being too cynical here ..??!! Ya, while the TSB does not specifically identify the receiver as such, again read
previous Post #47 where it lists about 6 items that.. " a vehicle may exhibit one or more of these following conditions"
Well, It seems that the reciever is involved in some of the problem functions here..!! Anyway, I will get off my soap box now and hope that everything works out for you soon....
Keep us posted...
Frank
I'll let you know......
Frank
Yes I was somewhat taken back. He's just mistaken. I'm going to keep on working on him, and I'll help him out and bring him his TSB's !!!
I posted the distance out of the owner's manual in here a while back. I think 197ft is correct. Of course, that's only for cars equipped with the remote start. Without the remote start, the range is much less...again, in the owner's manual but I think it's less "buried."
Awesome range, Frank. I look forward to your full report from a parking lot near you. Axle, your "sleep mode" theory is similar to what I was experiencing when testing mine. In my case, when I locked or unlocked the doors repeatedly, it would seem to freeze up temporarily and then work again. It reminded me of when my cable box gets "confused" at times and delays the commands I send to it. Maybe THAT issue is addressed with the new receiver...who knows.
Mine is inconsistent. Somedays, I can get about 75 ft out of it, others, maybe 20 ft max. Also, I noticed that USUALLY, I get better range facing the front of the car but sometimes, just as good from the back...but only sometimes. I haven't scheduled an appointment yet to have mine fixed but will soon.
Thanks all,
Ron
Ya, for sure he is mistaken here..!! :sick:
But you know, if you really like the guy and you have some sort of relationship with him, I don't blame you... this is sometimes half the battle in your favour. Again, I would show him a copy of the TSB, and also share with him some of our experiences , the good, bad and the ugly. I don't want to sound like a broken record here (remember these ?), but I still feel strongly, that the RECEIVER is part of the TOTAL fix. AND, just as a reminder, I did have EVERYTHING replaced, and all is very well still, and working as it should..!!
Oh well ...hope everything works out for you...and keep us posted..!!
Frank
Wow, I must say , I certainly am impressed at this point with this distance..!!
I'll keep you posted....
Thanks again
Frank
Yeah, here in Jersey we got about 8 inches last nite...My Impala is snuggled in the garage and will stay there for a few days!! Guess I'll use my wifes Honda today, dirty her car up!!
Thanks for your thoughts! Your parking lot testing you are doing has me thinking. If you can, would it be possible for you to range test in front of a big box store such as a WAL-MART, and then test say in an fairly empty large lot such as an office complex etc.? Here's my theory on some of this. I work with RF systems for a living, and since I believe these RKE systems operate in the 320 MHz band, I'm wondering how much RF generated interference (or noise being picked up by the RCDLR) that is being generated by all the DATA IT and RF price/inventory tagging technology in those stores. My theory is (and it's only that!) that the RCDLR may be picking up so much RF garbage being generated by external sources like the stores' IT systems, it may not be able to "hear" the RKE until it is closer to the Impala. Of course as we know a bad antenna, low power fobs, or sensitivty problems with the RCDLR will cause the same things. At work, I have access to a poratble RF spectrum analyzer, which measures power levels of RF emissions at a given frequency. When I get some time I plan on doing some measuring at known places where my Impala gets very low RKE range, such as in front of "big box retailers" and look to see if unwanted "interference" is part of the problem. Could be that the new RCDLR has better filtering to help block out all the RF crud. Or maybe the new TIS firmware they are suggesting in the TSB can re-program the filtering of the receiver. At any rate, I hope my Impala loving brothers and sisters don't slam me too hard for sharing these thoughts. These posts are a great community! I'll keep you posted!
Spooler,
I had a similar theory (although I don't have any RF training). My cars (my '06 and '02 Monte Carlo) have had range problems whenever on the air force base or my new job on the navy base. Of course, we have LOTS of RF garbage in our airwaves. I think you're onto something and have the tools to prove it. What's your car's current status? Have you had any of the RKE equipment replaced? I'm all factory fresh in that dept...all I've had so far is a reprogram of the original "junk." Keep us posted and document what you find. You can enlighten us and more importantly, your service manager. Maybe even pass it along to GM. You would think they have some big brains that would've thought about these things but it's apparent they haven't.
Later,
Ron
Hey now...careful. I like the remote because I don't have to worry about scratching my door or trunklid while fumbling with a sharp metal object. I had gotten pretty good at using my fingers as a guide but that left finger prints and smears.
Now, if only I had a way of keeping my friends from dragging their rings while opening the doors, I'd be all set. Anyone else have scratches in and around their door handles? Maybe GM should start using the rubberized paint that some cars have on the bottoms of their doors to protect the door handle area.
Have a great Saturday, all,
Ron
I have all the original RKE equipment in mine yet. I talked to my Service manger about my range problems, and he thought my SS had all the newer stuff. But i don't think so! So when I'm able (I have some medical problems right now) I'm going to try to do some experimenting with a spectrum analyzer. First I'm going to verify the frequency that the RKE fob transmits at. It should be at about 320 MHz. Then with the spectrum analyzer, I'll measure the relative power level that the spectrum analyzer sees the fob at distances say of 20' 50' 100' and then 195'. The 195' measurement would be the sensitivity bench mark of the test. With that information I'll head to some shopping centers and bigbox store lots and drive thru looking for RF interference on or near the same frequency as the fobs, and if I see interference, I could measure the relative power level, and that would tell us how much of the signal of the fobs are lost in the undesired RF noise present in the area.
You know Ron, also I'm thinking that the RCDLR antenna in the windsheild is probably very directional. Since RF at that frequency would be very sensitive to the relative position of the vehicle. So I'm betting the range (with my stock windshield antenna) would be much better to the front, somewhat less from the back, and totally bad from the sides. And I think I have noticed that the range seems very bad from the sides! The new coaxial antennas are probably more omni-directional. As soon as I'm better, I'm going to look into this! I'll keep you posted!
