Pontiac Grand Am Security Passlock Problems
curlylocks1014
Member Posts: 3
just a note i was having the passlock/security lite issue @ every 4 month or so.. now it has become a daily thing! i see where there is a class action lawsuit against gm for a wiper issue for the grand ams... hmmm i think perhaps we should start one up for this passlock issue...
i just contacted pontiac if anyone would like to join in and let GM/pontiac know that this is not just an issue affecting one car please do so i think thats the only way we can get some action on this... toyota had the same problem with the prius only they cared about their buyers and recalled them..
heres the link
http://www.pontiac.com/divisional/contactus/contactus_owners.jsp
heres the link
:lemon: :mad:
The car oviously over heated from a gasket leak and thus the need for radiators and such.
Don't take cars to the dealer. I have a 2000 grand am and found all of my pronlems located on the internet and how to fix them.
I have 100k miles with problems, yes, but not real bad unless you don't fix the problem when it first arises.
I was lucky as the first one I changed was the problem.
It was very difficult to change it out. Lots of elbow grease if you know what I mean.
Security light is likely something to do with the passlock system which is behind the ignition key hole.
(PRWEB) February 21, 2005 -- If you own a 2001 Pontiac Grand Am, you'd better hope you're not stuck somewhere bad when this hits: You go to start your car, and the engine cranks, but it seems like your out of gas, and won't start. Numbers of people then have the car towed to a shop, only to find that the car easily starts after being towed, but no cause is ever found.
The problem is that the RKE (remote keyless entry) system has a defect in it that causes car not to start. As of now there is no recall on the passlock systems. As for a fix, the experts are honestly not sure.
To reset the computerized system, put key in the ignition and leave it in 'On' position for about ten minutes. Then turn it off, and try - it should start then. Warning: Continued resetting of the computer this way will eventually damage computer and will cost lots to replace/fix.
I can't think of any reason why "re-setting" the computer will cause any damage, but eventually it won't work because the root cause will completely fail, and will re-trip the passlock as soon as it re-sets and you try to start it.
The Hall effect sensor runs about $125, with labor I believe the repair costs about $375 if I remember right.
brakes and rotors
ignition (switch twice)
ignition tumbler
3 (out of 4 windows) because something was scratching them when they roll up and down
1 power window thing
alternator
serpentine belt (3 times)
fuel sending unit
water pump
and some general stuff that i consider wear and tear like tires and battery terminals
it is crazy stuff, i will definatly do more research before buying a new one which seems to be coming soon. but i keep fixing her because she is at least paid for!
This November we go out to leave on Sunday and it wouldn't start. We figured it was the same thing, we go through the security reset and nothing...except smoke - the coil pack got so hot that it cracked on the underneath side. Since we had the factory coil in the garage, we replaced it, and it ran good on Monday, Tuesday, we start it up and it's running like an old truck - ses light, trac light both on, no power - running on 2-1/2 to 4 rpms and takes forever to get enough power to hit 40mph. It's shaking and puttering. We took it to AutoZone, they read out 2 missfires - we replace the spark plugs and still no difference. Take it to a local mechanic, he says need to replace the iginition control module, coil pack and plugs - AGAIN! So,
Why would it go through 2 in this short time? The car has less than 40,000 miles. What's the deal? And why can't we find a pack/module for less than $300?? AutoZone said you can't buy one without the other and we bought it, it only had the coil - not the module with it - for $175. A local dealer can get it for $400 and a salvage yard for $100 (???) O'Reilly, who we bought the other one from now says they can't order it - only dealers can. Any ideas what's happening with the car - and these parts?
Appreciate the advise - I'm driving my husband's gas guzzling Dodge Ram!
Brian
My car has left me stranded 2 times for the security problem. The dealer said they never heard of this particular problem and for me to resolve the problem by selling the car.
They sure have confidence in their products.
Again, I woud like to get into the class action lawsuit.
Thank you,
Brian
I will do this soon.
Thank you very much for saving me $400.00 and Screwing Pontiac out of the $400.00 I almost paid them.
Thanks Again,
Brian
If I don't get stranded within a couple of days I will know it worked!
I think that's great for you but I still feel Pontiac should pay for a pourly made product. My car has been doing this for over a year. They have replaced everything. I am fixing to take them to small claims court for the money and time and anguish that I am out and have suffered. They have charged me over and over again to make repairs that obviously didn't do any good. I think everyone should stand up to Pontiac and maybe this sort of crap would stop. Best of luck,
Debbie
Good luck to everyone.
I will let you know if I get stranded again because of this JUNK.
Brian
Well to get to the Crap!!!
I am having the same problem as all of you. But I already have a remote start, just have no clue on how to use it. My wife is getting really sick of the, turn the key on for 10 minutes, then start the car. It seems to be happening more and more. Is it the Body Control module, pass lock, ignition cylinder?
John
ginkle7
I have not been stranded since I disabled passlock by cutting the yellow wire. I no longer wonder if I am going to be late getting to work because of that faulty piece of crap.
Crossing My Fingers.
Will Keep You All Updated.
Brian
Holly
All in all I want to thank you so much for this post cause even if we cut the wrong wire, we will find the real one!! And I appreciate the help you gave us!
http://www.directwholesale.net/diagrams/Images.asp?ImageID=702&link=BULLDOG
http://www.directwholesale.net/diagrams/Images.asp?ImageID=703&link=BULLDOG
http://www.directwholesale.net/diagrams/Images.asp?ImageID=704&link=BULLDOG
http://www.directwholesale.net/diagrams/Images.asp?ImageID=706&link=BULLDOG
http://www.directwholesale.net/diagrams/Images.asp?ImageID=707&link=BULLDOG
http://www.directwholesale.net/diagrams/Images.asp?ImageID=708&link=BULLDOG
