-June 2024 Special Lease Deals-
When the car is running and the Passlock system becomes tripped it isn't supposed to shut down, it's supposed to just let you know by illuminating the security indicator in the cluster.
On top of this problem, I have a water pump problem, which has been repalced but there is a loud abnoxious noise now and cant figure out what is causing the noise. Any suggestions???? My radio also locks up and I will go four to five days without a radio and then it will just finally turn back on. I can't believe that there are this many people with the same problems, and GM will not do a recall.
Count me in on lawsuit against GM. :mad:
Over the past year I have had the passlock problems a few times. It is always when the weather is hot and humid. Never when it is cold.
I had a look for the yellow wire and that is when i realized there was alot of wires and connectors that were probably left over from the remote start. There is a little box and I am guessing maybe it was left when the remote start was disconnected (bypass maybe?) There are three wires coming down that i am thinking might be an extension on the passlock wires (black, yellow and yellow/black). The wire go into this little box. Yellow is labeled as going to the ignition switch. The yellow/black goes to the BCM and the black is ground.
Would cutting (or un-splicing) either the yellow or yellow/black be the same as cutting the yellow wire up top that requires the radio removal?
What is this black box for? If it is a bypass, why does it not bypass? Has a few wires:
- icn switch
- bcn
- ground
- 12v power
- starter
- activation
- bulb check
- ign input
Below are a few pics of this black box, wires coming down, unused connectors. If someone could have a look and tell me what this stuff is, i'd be so thankful.
http://img380.imageshack.us/my.php?image=img0121fl7.jpg
http://img59.imageshack.us/my.php?image=img0119pu3.jpg
http://img59.imageshack.us/my.php?image=img0118kf9.jpg
http://img59.imageshack.us/my.php?image=img0117ys1.jpg
I removed the entire ignition switch from the vehicle.
Took it apart to get to the electrical contacts inside the plastic housing .it just snaps apart.
The electrical contacts were very diry .so I cleaned them.
I also noted that each set of contacts has a leaf-type spring that pushes on the rear contact. One spring was firmly crimped in place.
The other was just sitting in place but looked like it had never been crimped so I think it was not doing much good. I used a pair of pliers to crimp it tight.
I reassembled it and have not had a problem since.
Previously, I had the passlock problem quit often ..particularly on damp days.
This also solved my SERVICE VEHICLE SOON light problem. I had not bee able to find any burned-out bulbs .but cleaning the ignition switch solved it.
I was also having problems with the dash lights not always coming on when the ignition key was turned ..in fact this was the problem that drove me to disassemble the ignition switch ..but it is now solved.
I had previously looked at the BCM & PCM but they were good no dampness or corrosion.
The engine also fires up much quicker.
I just want to have the security light off and the door chime be normal. Please help. I don't care what wire I have to cut or what I have to clean, but I don't want to spend any money on this. thank you so much.
As for the light staying on, come on, guys: Let's read the directions. We've piled so many e-mails in here that even I've forgotten precisely where they are -- somewhere back about page six or seven or so -- and I wrote some of them!
As previously stated, when one cuts out the security system by (1) starting the car, (2) cutting the data wire, and (3) splicing in the toggle switch in the open (off) position, the anti-theft security light will come on and stay on -- that's your indicator that the anti-theft system is disabled. You can't have your cake and eat it too -- if you want to opt out of passlock, you must accept that you'll be driving around with the red light on. It's no big deal -- I ignore it other than to make certain I lock the car and pocket the keys when I park it. And who's going to steal a '97 Pontiac with dead air conditioning in a tropical town full of new Cadillacs and BMWs anyway?
I've been reading this forum all summer and have learned lots of things, I thank everyone who has contributed to this post.
Jeremy
At this time all I need to do is disable the chime - by any means available.
and have the security light not on, again - any way I can.
Please help me do this. I would be grateful.
The ten minute thing no longer works either. I justwant to know if anyone has any other ideas.
Froglover: The first thing to make certain is whether your toggle was left in the "on" position (contacts closed) when you quit for the day. If so, you in effect have reconnected the wire and re-enabled PassLock. This also happens if you turn the toggle on after you turn off the ignition. The toggle is used solely for those times when the battery has to be changed. Disconnecting the battery also can re-enable PassLock, in which case, if the data wire isn't reconnected, the car won't start at all (query: How's your battery? How are the cable connections?).
Make certain you know which toggle position is "on," which "off." Since it's free, the next thing to try (if the car won't start at all) is to turn the toggle "on" (contacts closed) and try the "wait ten minutes" trick. If that works, WHILE THE ENGINE'S STILL RUNNING, turn the toggle off. You then should be good to go PROVIDED YOU DON'T AGAIN TURN THE TOGGLE ON.
After that, you just have to track the problem down: Passlock working (or disengaged) -- check; battery connections clean -- check; battery holding a charge -- check; injectors working -- check; fuel pump working -- check; &c. Also, when was the last time you had the car tuned? Often, the coil package in a Pontiac has to be replaced at tune-up time. Until I did that, my car still wouldn't start either.
Also, I'm moving across country NEXT FRIDAY and was planning on taking this car- should I be worried with this damned security light on? Please, someone help!
:confuse:
Tell me what happens from the start.
When I had a passlock problem the light would be blinking when I tryed to start the car, the car wouldn't turn over, nothing happened. I turned it on and waited the ten min. when the light went out I started the car. When ever I was driving the car and the security light would come on I knew the next time I would have problems starting the car. Your problem doesn't sound like a passlock problem, it's more then likly a fuel pump thinking, find the fuel pump connecter at the fuel tank and run a wire from the battery to the power side of the pump and see if the pump comes on, if not then replace the pump. I'm not saying that you don't have a passlock problem, I'm saying your car isn't starting this time because of something other then passlock.
Grand Am Passlock Security Fix
Please.... everyone.... this tutorial will fix ONLY problems that have to do with malfunctions of the PASSLOCK(tm) security system on the Grand Am, and many Alero's. It WILL NOT fix problems with the fuel injectors, starter motor, battery, or other items which will also cause your car not to start. If you try to start your car, and the "Security" light comes on and flashes, then read my article. If that is not what is happening, don't bother.
Dick Berger
Retired GM Proving Ground Engineer
A few months ago it started becoming harder to start, then on occation when I was driving it would completley shut down. It has continually gotten worse!!! i have had my independant replace the Ignition module and some sensor (sorry, I will have to check my bill, cant remember what it was) only to be at a loss. Honestly, my mechanic seemed rather embarresed but could not find what the problem was. I then phoned GM and they told me it sounded like the pass lock and so I took it in. After 6 hours of being there (1.7 hours diagnostic) they were able to tell me that it may be the fuel pump or fuel pressure switch but would need more time. I was frusterated and said forget and went to pick up the car. After reading many posts on this website and many others, I decided to test fate and had my independant mechanic change the ignition cylinder which as we all know housed the passlock. STILL DIDN"T WORK!!!! However, a day after it was changed I tried to see if my remote starter would still work, it cranked but wouldn't catch. went to start my car and for the first time got the security light on my dashboard which I had to wait the 10 minutes to reset. Also since then when the car stalls the Service Engine, Battery and Oil lights now come on.
My remote start used to be one of the ways I would be able to start it when it didn't want to start, but over the past month it would start it fine and then as soon as I went to put the car in reverse or drive it would die. Now the remote doesn't start but I really dont care about that. This car came with an aftermarket remote keyless entry and remote start, could this be potentially the problem? I am ready to sell the car but scared that it might be difficult considering it is so problematic, never know when this will happen. My biggest fear is the stalling, today it happened on a bridge, very frightning.
I am at a loss. Should I consider the battery cables or battery or even spark plugs. What about the fuel filter, had it changed a few months back, could it possibly not be on right or letting air in, or can that happen. Or, has anyone ever experienced a bad connection somewhere else that I might want to consider. PLEASE HELP.
I believe your problem is in one of these connectors that lose it's signal and shuts the engine off, your major ones are the cam, crank sencer, power pack/ coil connector, TPI or TPS. and Distributor, the distributor connection is what keeps your fuel pump going, with out its signal the fuel pump shuts off. Also have your independent check the connections to your PCM, ECM or what ever they want to call it.
Keep us informed as to what you find
It really sucks because this was my first sporty car purchase and I love it, but I am so scared to keep it even if I can fix it as it seems to have so many issues that arise with this car! :confuse:
Thank you for your message.
Let us know what you find out.
Unfortunately for you, there is more wrong with your car than the security system, possibly bad ignition system, bad injectors, or a bad Body Control Module.
You could try the modification suggested in Post #394, which would certainly eliminate the security system from your possible culprits, but that leaves several other possible causes for your problem, and tripower1 is likely right about it not getting fuel.
Dick B.
http://www.passlock2.com/
Thanks for any and all advice and information in advance to this post and my previous one where I posted before signing my name.
Danny Moses
Yorktown, VA
2002 Impala Security light came on while running for the first time today...and I know what is in my future and am trying to be proactive for once.
It is normal for the Service Engine, Battery, and Oil Lights to come on when the vehicle stalls. It happens every time I stall mine by letting the clutch out too fast.
Dick
