Does this problem also occur with the 6 cyl versions ?
Could this be a fix?
I called and opened a new case after getting charged $400 for the right rear caliper failing (out of basic warranty now). The phone Representative just repeated over and over the fact that the car is out of warranty. This is highly disappointing in my opinion, since there's a safety concern here that is clearly not a wear and tear issue.
Between me and my wife, we drove about 10 different makes and models, never had we any issues with the breaking system on any of them.
I will look into further actions - has anyone here contacted any of the people who filed the class action-suit?
In my case I had one pad on right rear wear out prematurely. Took it to my own mechanic after crooks at Hyundai would not apply warranty. He put in new pads, same problem, replaced caliper, same problem.
Then showed him post #245 So read that guys - you have to either grind the pads or the area they fit in which is too tight of a fit. So then they slide better. He did that for no extra charge and so far so good.
I am guessing it would be hard to get a dealer to "customize" like that because it would be admitting that the design is bad and bring down the whole pack of lies we are getting.
#1 Issue is poor design which "sticks" exacerbated by weather. Look at the posts they are almost all in the North. No way I wore them out naturally. It was one pad on one side of rear brakes. So at least for most cases all the posts about new materials and modern cars using rear brakes more and size of pads are wrong.
I have purchased my last Hyundai!
I sent the following message to Hyundai’s Consumer Affairs Department:
On June 24, I needed to have my 2010 Sonata repaired by your dealership in Streetsboro Ohio. At issue was a grinding, squealing noise coming from both my rear brakes. About 3 weeks prior to this service visit, I removed one of the rear wheels & noticed that one of the pads was excessively worn & the other one hardly used even though my mileage was at that time under 18k. While I am not a trained auto mechanic, I have worked on my cars for over 40 years & am familiar enough to recognize that poor design caused the premature wearing of the pads & subsequent damage to both rear rotors. My last 4 cars have had disc brakes & I have ALWAYS received over 60 to 70+ thousand miles on a set of brakes. The service cost for the repair was $421.25 + tax. The Service Consultant advised me that it was not covered under warranty even when I showed her the notice that Hyundai is facing a class action lawsuit in NY for the same issue & that there were numerous complaints concerning the same problem from Ohio customers as well. I do not feel that I should have to pay for faulty designs & the obvious problem caused by that design. $421.25 plus tax may not sound like a lot of money but to a person on a fixed income it is! It is my hope that Hyundai will do the right thing & refund my $421.25 plus tax as soon as possible. Thank you for assistance in this matter.
I received the following response:
Thank you for contacting Hyundai Motor America. We are sorry to learn of the difficulty you have experienced with your brakes; however, we appreciate the opportunity to clarify warranty coverage for your 2010 Sonata.
The brake pads in your Sonata is covered under the New Vehicle Limited Warranty (NVLW) for a period of 1 years from the date of original retail delivery or the date of first use (DFU) or 12,000 miles, whichever occurs first.
The rotors in your Sonata is covered under the New Vehicle Limited Warranty (NVLW) for a period of 5 years from the date of original retail delivery or the date of first use (DFU) or 60,000 miles, whichever occurs first except if the rotor is damaged by brake pad wear.
This warranty covers defects in factory parts or workmanship only, as determined by an authorized Hyundai dealership. Additional warranty information may be found in your Owner's Handbook.
We apologize for any disappointment or inconvenience this may cause, however, based on the time and mileage of your Sonata, this warranty has lapsed and will no longer cover the cost of any needed repairs to the brake pad or rotor.
For repairs that are no longer covered under warranty, we still recommend having them completed by an authorized Hyundai dealership. Our factory-trained technicians are the best-trained and most-qualified to repair your Sonata to our specifications.
We have documented your comments. Your case number xxxxxxx can be referenced if we can provide further assistance.
Thank you for contacting Hyundai Motor America and for being a valued member of our Hyundai family.
When I resent a questioning response to their response, I received another “parrot message” saying their decision is final & “Hyundai Motor America thanks you for your time, and for your business.”
Yup they gave me the business alright!!!!!!!!!!!
