Highlander Hybrid Tire/Wheel Questions
Does anyone have a good recommendation for Snow/Winter tires that they have run on their HH?
I live in Calgary and need a tire more suitable to Icy and Snow conditions.
Nokian is hard to find in the US and I cannot find the exact size for the HH: 225/65-17. They do have 235/65-17 that supposedly will fit the HH. A tight fit for the rear wheel well but should do OK.
Please let us know what you decide to buy.
I mounted this size in the Nokian WR (winter rated all season), and they are fine. I have the nav system so had to do a recalibration per the manual.
Thanks for confirming it!!!
How does the WR work in snow and ice? Do you feel confident with it in such conditions?
Cal
Don't know, first hand , yet. Canadian Driver rates them very well, in this regard. Of course, dedicated snow tires would be better, but by all reports, these do very well. I have 10k miles on them so far,and no apparant wear. I'm in the mtns of w. NC, so we get a fair amount of snow. This winter will tell the tale. :confuse:
I am unsure about a bigger tire as last winter the rear wheel wells were getting packed with snow in several snow storms here. I am worried about that causing problems, however, availability of 225 65 R17 tires seems to be low.
This a useful tire size comparison calculator.
As to a European tire mfg making winter tires,; many serious winter tires are sourced from Europe. Nokians are from Finland, and the Finns certainly know about winter.
We are narrowing it all down to Hakka SUV and WR SUV, now we just need to decide on wheels, something simple and strong.
Regardless of what our car manufacturers say, regardless of what magical snow tires (even studded tires) we all have on our HH, by CA laws, all cars entering chain-control areas MUST carry chains in the trunk ready for use. No chains, no passage.
CA DOT GOV site specically points out that there are chain devices for tight clearance vehicles (like the HH).
Now back to regularly scheduled Snow Tires programming........ :shades:
And, they sometimes don't even bother to check, but they will ask, or the signs will state you must carry them.....
Should you get stuck, or become involved in an accident, they will check. And I doubt if anyone not from California can imagine the fine. $1000+ :surprise:
Also known as cables. Does the owner's manual give instruction on snow cables (type S, probably), and how to install them?
If you plan to install only over the front drive wheels (HH is really FWD), then a normal full-coverage chain will work. If you want to install over all four tires, then you will need to get something special for the rear tires. CA Dept. of Transportation FAQ said something about Spike Spyder and I checked their site. It supposedly covers the outer half to outer two-third of the tires only. May be it will work.
My gut feel is that a real top-notch set of four snow tires on the HH will cover most Winter conditions leaving the chains only for the worst or the most severe conditions. In such severe conditions, it may be better to stay off the road. So may be a pair of chains over the front tires will satisfy the CA requirement and still get us through most Winter driving.
We will get snow treads this year. It just makes driving in the Sierras a lot simpler and a lot sure footed too. Snow treads, chains in front (or rear) and VDIM, we are ready!
Thanks again and thanks to everyone who clarified this chain usage issue.
If your HH has 4WDi, it will be worthwhile to have Snow treads on all four wheels. This can keep you moving in conditions that stop other less well-equipped cars. This capability is priceless when it is dark, there is a snow storm and you are miles from home. I have had too many of those when we lived in Michigan.
All safety systems rely on some traction on some of the tires to function. So if there is no traction, there is nothing the on-board safety systems can do. If the HH has traction in the front only, then the rear can still slip and slide in a worst case scenario. Ideally, the Traction Control can handle that if it can find traction in one of the rear tires. But if you hit a patch of ice and the rear tires completely lose traction, the front will try to go where you steer but the rear may wag. So it is safest to have snow treads on all four.
Research says they are some of the best snow tires on the market for a light truck.
Only downside was cost. Was thinking of Michelin Latitude X-Ice since they were not XL rated and hence were 70 Cdn $ cheaper. Unfortunately not in stock at the time with no ETA as well. So went with the Nokian's. Mounted them on Core Racing Evo-7's which were also on sale.
Nothing would prevent me from recommending these snow tires to anyone who experiences real winter.
Safe winter driving to you all.
We watched our friend drove/slid his 4WD SUV off a road in the Sierra exactly for this reason. He has never driven a real 4x4 and had no experience with limitation of 4WD. At the time, he had no true snow (only M/S junk) tires and refused chains. He has since taken a course out in Hollister Hills and became a relatively safe driver.
Please slow down in our HH, have fun on the slope, get great MPG and get home safely in one piece this winter!
1. The following link takes you to Goodyear's "rating" page so you can see how the tire comapres against others.
http://www.goodyeartires.com/goodyeartireselector/results_tire.jsp?mrktarea=Pass- - - enger
2. Note the Integrity is a Minivan tire, *not* a SUV tire. I personally find it a soft, squishy cheap tire that hampers the handling characteristics of the HH but that is just my personal beef with this tire, you need not agree.
3. The Integrity on our HH never last till Winter of 2006. We lost one to sidewall puncture in the Fall of 05 and replaced all four tires with another tire with thicker sidewall. The Integrity has a one-ply sidewall, really really lousy for a 2-ton SUV.
We used Goodyear Regatta 2 tires on our minivan. This is the tire just above the Integrity on the Goodyear Tire Rating page. You will notice Goodyear ranks Regatta 2 *BETTER* than Integrity.
We took our Sienna minivan (with Regatta 2 tires) to the Sierra on ski trips countless times. The tires did well on plowed road and did fine at low speed in fresh snow to about 2 inches thick and in packed snow of about 2 inches thick. It went through thick (6 inch plus) slush in Yosemite Valley OK as well. We only put on chains when chain control is imposed and we never had trouble with these tires in the mountains in winter. We make about 4 to 6 trips into the Sierras every Winter so we have some experience with Winter driving conditions.
I am NOT recommending the Regatta 2 because it is a van tire. If you decide to change tires, please consider SUV tires. If you get snow tires, it will be even safer in winter condition.
We are ordering the Hakka 2 snow tires for our 4WDi HH for added Winter driving safety.
After a long freeway drive, we had one tire at 32.5 while the rest were at 38.5 and nothing on-board alerted us to this problem. Can't blame the car, it does not have any sensor in the wheels.
Looks like time to shop for and install our own tire monitors. Has anyone done this and if you did, can you please share your experience?
From the research I've done on tpm's, the main thing is to make sure the tires are still balanced after installation. The type that screw on the stem can leak on you, so make sure you install them properly.
TPMS is a good investment. Even the cheapy standard version in our Sienna has helped us several times by providing early warning of tire problems. The last time the warning lamp came ON, my whole family was traveling and we were able to pull off the freeway and reached a gas station in time before both left-side tires went completely flat. We had hit something on the freeway that slashed the sidewall of both tires. The Sienna was so quiet, and the suspension system so cushy, we had heard nothing and felt nothing. If not for the warning lamp, we might have kept driving farther and at higher speed than we should under those conditions.
Old fashion gauges are still useful but TPMS can be a real-time life-saver.
Cheers
Pat
60% of miles are Arizona highway - posted speed limit 75 MPH.
30% city traffic
10% gravel/sandy roads
No plans for snow driving, but concerned about water traction (for "rainy" season).
My choices are:
Bridgestone Deuler Alenza
Goodyear Fortera
Michelin Cross Terrain
Joe
Does anyone know of a source for inexpensive steel wheels to fit the HH?
Any thoughts on the 17" replacing the 19". I understand that total width and diameter are the crucial measurements, but is there any problem with brake clearance?
Further checking from other dealers seems to indicate that there are no snow tires from any manufacturer in 19" 55 series.
"Bridgestone Blizzak DM-Z3 (Light Truck/SUV Studless Ice & Snow) Warranty Rating 3
* Size: 245/55QR19
* Blackwall
* QR Speed Rated
* Price: $155.00 (each)
* Estimated Availability:
In Stock
255/50R19XL
The overall diameter is only .6" less. A comparison can be made at:
http://www.miata.net/garage/tirecalc.html
The WR is an all season tire with the snowflake, which denotes severe winter duty. I've had a set on my 06 HH for 30k mi and they still have lots of miles left and have performed great in snow. The Nokian site for the WR is:
http://www.nokiantires.com/en/tire_wr_suv.aspx
BTW; Nokians are made in Finland; they know about winter driving - they are a little hard to find, and they are not cheap.
