Pontiac Grand Prix Electrical/Lighting
I have a question about the Daytime Running Lights. Aside from turning them off manually every time you start the car is there anyway to turn them off permenantly? :confuse:
If there is not a way to turn them off permenantly does anyone know (I haven't checked yet) if you can get different color bulbs? There is something about deep yellow running lights on my black GXP that doesn't look right. Maybe if they were clear or even like that blue looking xenon light?
Any help would be appreciated! THANKS!
Frank
Frank
My current problem is that occasionally the car will not shift into Park. Sometimes if I just keep shifting all the way down and back up, it will eventually go into Park, although usually with some resistance. Last night I had to drive it around the block, and then I was able to get it into Park but with more than a little resistance.
A couple of months ago, I experienced the "stuck key" problem: the ignition would not turn all the way to the "off" position, and the key would be stuck in the ignition. Left key in overnight and it ran down the battery. Took it in for repair in December, and they said the solenoid on the shifter was defective and they had to replace the whole shifter (cost me about $400).
Anyone else experienced similar problems, or have any suggestions on what could be causing the shifting problem?
The headlights on a GXP burn four when lit and are very bright. They also have a good upper cutoff. If you buy the cheap high power blue blue lights you will have difficulty seeing in fog or rain - snow conditions. If you need something brighter try HIR lights which are special and very bright. :shades:
Does anyone know if Pontiac is really going to change the name to G8? Now that i'm thinking about it more, it may make pontiac sound more "cool" but it could reduce the resale calues of these Grand Prix's Already made. Pontiac has had a decently long heritage with this name, meybe it should stick? :confuse:
This is nothing more than speculation, ' course.
Well, if the light sensor is covered, it'll be interpreted as no daylight, therefore the lights would obviously come on.
Besides, the light sensor is also used by the auto AC to compensate for direct sunlight, if the GP ever got an auto AC like other GM models...
WRT DRL, AFAIK, it can only be disabled by the dealer, but you'll have a hard time finding one willing to do it. The lawyers told them not to... :P
HTH
Mine does not. Very steady image - even over very degraded road surfaces.
- Ray
Wanting the new C6 HUD, now . .
Head Gasket
Very expensive fix for the warranty co. I think it was $2700 or so to fix an oil leak. Less than a year later, it's leaking again, and now out of warranty.
Power steering pump
Yep, went out, fixed the pump and the whinning noise is gone.
Power Window Motors
Both window motors have been replaced. Now the driver side is "sometimes" not working again.
Blower fan
As everyone else is seeing, works on high and nothing else. Until it didn't work at all. Thanks to several folks on this group I bought a new relay and changed it myself. Now the fan is working fine.
My newest BIG PROBLEM
I suspect this is some kind of electrical short, but have no idea where to start.
First time this happened was a couple weeks ago. I got in the car to start it and turned the key, and there was nothing. No clicking, or cranking or sound of any kind. In fact the entire electrical system is off, no overhead lights or door alarm or anything. And I couldn't take my key out of the ignition either. Then, all of a sudden after 5 minutes or so everything came back on. So I turned the key and it started and ran fine. This has been progressively getting worst until today, when it was really bad. TO date, this has happened probably 8-10 times, but today the electrical didn't want to come back. When it finally did it was like the car was possessed. The interior lights were flashing; the RPM gauge was flying back and forth (car not running yet) dings, beeps, and buzzes everywhere... Then I started it, put it in drive and after traveling a couple feet, everything on the dash clicked a couple times and the car died. This was the first time it had actually stopped while driving. It finally started again, and I drove home. Now I'm not sure what to do.
Is there anyone at all that has seen this or knows what to look for???
Thanks so much... AC
What if you only turn on lights and A/C and try to accelerate fast? Is all the power there?
How long has this been going on? It's not typical for an alternator to get weak and stay weak for long periods. If it's dying, it should die totally in a couple hundred miles or less.
I assume no "battery" or red charge light is glowing on your dashboard?
My current issues are with other electrical aspects of the car that I've been dealing with, but am now making an attempt to find a solution to. All around the same time, the digital clock/radio display went out (I can only read it when the sun is shining on it..oddly enough), the windshield wipers halt in "midwipe" (and I have to turn them off and on several times before they land back under the hood), my speedometer has taken on the intermittent function of my windshield wipers, and when it's not working, my odometer ceases to function...also the cruise control ceases to function periodically. I have noticed a few of the disruption in functions occur when I hit a bump in the road..like the speedometer, odometer, and cruise control. Anyway, I was just curious if these problems were indicative of some specific common problem and if so, is there a solution on the side of inexpensive?
X_it
Also, when I meet w- him I'm going to replace the tranny fluid and check for metal shavings in the pan-(if there is the car is in bad shape) due to the shifting thing. Again, if anyone knows something about this please let me know!!
(thx for the good luck comment)
At least its warm out now!--wait, where do you live? I'm in central Minnesota
Mentioned your problem to my Father in law who is a retired part rep. for GM and he was convinced it was a "blower regulator" i believe thats what he said. but that's just based on a common replacement part in grand prix.
well, now that i've confused you royally, i hope this helps !!!
everything was unhooked leaving the lower "pivot" bolt loose, I then realized it has a spring holding tension on the alternator. If I pull the final bolt, how do you "set" the spring to replace the alternator. Any help or links to information or repair sights would be a huge help.
Does anyone know how to replace them or if they can even be replaced?
IDEA TRYING GETTING THE IGNITION SWITCH WIRES REPLACE ABOUT 100.00 BUT THEY CONTROL ALL WHAT YOUR SAYING IT WORKED FOR ME.
rearview mirror, then stopped working altogether. The passenger's side works. It's a 2007 and it shouldn't have problems yet. Did I kill it?
I'm not much of a car guy - is there any chance this is something I can repair myself, and assuming it's going to take a trip to the dealership does anyone have an guess as to what it might cost?
