Infiniti G35 Brakes and Rotors
Ok, I'll be next:
I have a 2005 G35x
6,000 miles - Front rotors resurfaced due to severe grinding when stopping and scored rotors.
7,000 miles - Front brakes and rotors replaced as grinding continued and rotors were scored again.
10,400 miles - Front and Rear brakes and rotors replaced due to grinding and scored rotors in front and loud squeeling from the rear. Had to get regional Infiniti rep to inspect car for them to cover it. Infinti Consumer Affairs jerked me around for 2 months before the dealer helped out was able to get rep to look at car. Hats off to the dealer for this. Also told by rep that is was my driving style. Funny, I've been driving the same way for over 20 years and never had brakes wear this quickly.
22,000 miles - Front and Rear brakes replaced and all 4 rotors resurfaced. Brakes were worn down to sensors. At least this time the brakes almost lasted 12,000 miles but this is still about 1/2 as many miles as I should have gotten out of them. Dealer was able to get Infiniti to cover front brakes so I only had to pay for the rears.
Not looking forward to having to replace brakes 2 or more times in the next year and a half until my lease is up.
I have a 2005 G35x
A couple of posts had to be removed. Email me with any questions. Thanks!
2005 G35X had to have brakes & rotors replaced at 16,500 miles. The rotor replacement is what particularly galls me. And when I asked 2 technicians at Harte Infiniti about it, they both said "well, the rotors are a little thin to begin, but really it's how you drive".
Is that the standard line that everyone else is getting. Making you sound like it is somehow your fault? Do they have no integrity to mention the problems on the 03-04 models and the fact that the warranty was extended to cover rotors as a result?
Has anyone successfuly received compensation in some form for these problems on a 2005 or later model?
I have 05 Sedan and 41,000 i am still running on the original pads and rotors not problem at all just recently changed tires and the guy told me i got about 10,000 left on it, and i am not easy on my G so you guys should have dealer take care of you, that sucks.
I heard they had problems with 03 and 04 models, that is why i waited till 05 to buy it. I guess i should feel lucky
BTW, I have an '05 X with 38K miles. I'm on the original rotors, never resurfaced, but I did change the pads at around 22K miles for PBR Axxis ones to have less dust. The original pads still showed about 5mm of pad left. It was a good change for me. There is virtually no brake dust and the performance is superb for my driving style.
SA said the new pads are better than the new. Well, I don't know what better is. They do stop great. I did 'bed them in' to avoid any glazing, etc. Made a world of difference when I did have to stop quick.
Now about 1000 miles later I notice the same scoring on the rotors I saw on the old ones. Not THAT bad, not yet.
The rears are still almost like knew. He said 6 mils left on the rear pads and recommends check them again in 6 months.
When the rears go bad I will likely just put in new pads myself.
And unless the rotors are bad, just leave them as is.
When the fronts go I will get my own aftermarket rotors and pads. I think the stock are fine up to the point you have to pay for them.
I need to get new brakes and rotars for my G35 2004 Sedan. As most of you know, the brakes on these cars don't last long and Infiniti should be ashamed of itself for not taking more responsibility. Nonetheless, I need to replace them.
First question, what is the cost for a a set of four new brakes and rotors from the dealer?
Second question, can I get a better price with the same quality from another store such as Sears?
If you can find a very reputable tire/brake/alignment shop I am sure you could do better cost-wise. They will replace with an OEM or equivalent rotor, and probably give you some choice as to the type of pad you want. You may want to get some quotes against the dealership's.
Personally, not too hot on getting work done at Sears. I guess I am one of those scared off by the big service problem they had some years ago, although I never used them.
Don't know where you live, but if anywhere near the SF Bay Area you can hardly go wrong with Wheel Works. Ask friends, neighbors for referrals. An independent mechanic specializing in Nissan/Infiniti cars, another one.
Thanks for any input,
Pete
Fortunately there are less expensive and likely better alternatives the next time around. There are probably not too many 03 or 04s left that have not gone over 36K miles or 3 years, but if there are you should take advantage of it.
I think INFINITI has a ways to go if they want to play in the same league with Acura and Lexus.
Thanks Infiniti.
ofcourse, 5 months later, the "slip" light comes on and i called the dealer today. he tells me that the brakes probably need replacment. ofcourse, the car warranty ran out at 45000 miles........
Aren't they considered a wear item? :confuse:
Is this special warranty coverage to compensate for the G35x brake issues of the past?
If so, I call BS.
Do you have a slip showing you went in a few months ago?
Car is developing a new brake symptom. When I release the brakes, as at a traffic light, they grunt as they let go. Don't know how else to describe it. It's as if the calipers stick a bit when the rotors start to turn and then let go.
No other sounds or symptoms. No grinding, pulling, pulsing, squeaking, or spongy pedal.
Roll
The grunting is annoying though.
Options would be having someone look at it, or doing it yourself.
Certainly doesn't sound normal though.
Roll
The brakes in my 07 seem completely solid and stop on a dime.
I'm also seeing very little brake dust on my wheels.
I had the same concerns when I started considering the G.
After much research, I jumped on board and this has been the best car I have ever owned.
A complete joy to drive!
my issues through my states Lemon Law procedures.
The brakes are very quiet and super grabby.
Wait until your brakes are broken in and seated and see if the noise goes away.
I own a 05 G35 sedan with about 36K miles on it. My brakes
are still ok, but pretty soon I will need rear pads. If I am
not mistaken, 05 G35X has different brakes than mine. It is
possible, they wear faster than mine. If they are same as 04 G35 brakes, then you might have chance to recover some
of your cost.
Next time, do your research BEFORE signing OK to perform
any service.
good luck!
Constant heating and cooling causes that runout.
It happens to all brakes, but smaller brakes or excessive usage cause this to happen sooner.
You may want to hop into the 300C forum and ask the other owners there.
Has anyone changed G35 stock breaks with Brembo? Would dealer exchange breaks, or you had to go outside Infinity network? If not Infinity, who in Toronto (Ontario, Cnd.) can do this exchange? How much did you have to pay for this “pleasure”?
Brake jobs are actually very easy on most cars, but only if you've seen them done before.
As for parts, Brembo is a great name... but it's not necessary for the rotors.
The Brembo name shines in their calipers (the part that squeezes the brake pads onto the rotor).
You can get away with aftermarket pads and rotors, and keep the Brembo Calipers.
I swear by Bendix brand, but that's just me.
There's a lot of options for brake pads, including ceramic, which keeps the brake dust down.
The job will include unbolting 2 or so bolts which hold the caliper on to the car.
You then pop the old pads out and after removing the master cylinder cap (where the brake fluid goes), you use any c-clamp like tool to squeeze the caliper's piston back... so it's all the way into the caliper again.
Don't squeeze too fast or fluid may squirt out of the fluid reservoir.
Then you have the room to pop the new pads into the caliper, which are held in with springs...very easy.
Before bolting on the caliper with the new pads, you pull off the old rotor and the new one goes right on, over the lug nut studs.
If the rotor is stuck, tapping it with a hammer a few times usually loosens it right up.
Rust builds up in between the rotor and studs and this sometimes causes a little work getting them off.
Once the rotor is on, replace the caliper where it came from and tighten your bolts.
Make sure your brake fluid level is topped off and replace the cap.
Start the car and pump the pedal a few times so the caliper piston can seat the pads.
Be easy on your new pads for 100 or miles, allowing them to seat correctly.
Of, and when putting the tires back on, please use a torque wrench.
Over torqued lug nuts are the #1 cause of warped rotors.
-or-
Go to the shop and pay through the nose. :P
I'm in a very similar situation. I've got an 03 6MT Coupe with Brembos and 29k miles. I took it into the dealership and they told me that I need new front and rear brakes (rotors and pads). They claimed the rotors cannot be machined b/c they are so thin to begin with. The want $2600 for the full job! I then went to a local shop and they want $2800 and told me that the reason the price is so high is b/c there are no aftermarket rotors. Well that's obviously some BS.
So now I'm in the process of seeking out good aftermarket pads and rotors (is that all I need). I don't plan on doing the work myself b/c I'm not at all mechanically inclined.
I'm looking for advice now on which aftermarket rotors and pads to purchase and where to buy. I'm mostly interested in durability and less brake dust. I don't push the car very much so performance is less of a consideration. Any suggestions based on your experience?
My brother has an 04 coupe with brembos sport package as well, I believe he has the same rotors, I have to look when he gets back
I have done this dozens of times. The standard calipers in the premium G35X pkg is 14's and 22's............
