is it even possible without removing the cover?
The light on the switch to put the roof down is not coming one when pressing it! (nothing happens when you press it)
I checked the main fuse's but all seem ok! Called Volvo garage but was told they need to put the car onto the computer at a cost of £100 to see what the fault is alone!
Can anyone help me with this problem or tell me where to start!
I tried taking the earth of the battery but still nothing!
Also is there a way to manually put the roof down and up? In the handbook it only tells you how to crank the roof up. BUT NOT DOWN!
Be great full if anyone could help me on this problem. Thanks
When I had to put my roof down I used the same method of cranking it just cranked it in the opposite direction. I hope you get yours working. I found a small garage that took care of me rather than the dealer. The dealers tend to over charge compared to the smaller mechanics.
Hope this helps.
I have an 04 c70 and I first noticed that that the rear window demister was not working. I have also noticed that the chime at the end of the lowering or raising of the top does not sound. Also the windows do not lower when the top starts its cycle.
From what I read on VADIS the control module is suppose to lower the windows 5cm at the begging of the cycle. Also the boot is not suppose to be able to be open via the switch (I can open it while lowering or raising the top but it does stop). Also the rear defroster is shup off when the cycle is not complete which is why I think the defroster does not work.
I have checked the fuses and they seem to be fine. I found a buzzard or Relay that reads "Audible Hood Warning Unit 8611543" I204
I am not sure if this is the relay for the chime. I tried to test it by putting power to the connectors but I did not hear a click.
Any help is greatly appreciated. Thanks..
Bob
