Dodge Avenger Starting and Stalling Problems
Im new to this whole forum thing and all, but as a suggestion from a dealership who is enangering me, I made an effort to come and and try to figure somthing out. I have a 98 Avenger ES Auto. I aquired the car for very cheap, and I was currentley attempting to restore it to a nice, driveable car. When I picked the car up, it had a slgitht starting problem, just wouldnt seem to get enough gas to start. Also, (the main problem) while driving, if I was to hit the gas pedal about a 1/3 of an inch to far, the car would poop. When I say poop, I mean engine bogging out, and a few awkward noises would be propelled from the engine. We have replacd numerous things, such as the fuel pumps, a couple sensors which I am not 100% sure which ones, and have also done a full tune up, including wires, plugs, cap and rotor. I have all new fluids in the car, new fuel filter and some other odds and ends. Im in desperate need of an opinion of someone, becuase obviously the mechanics at my moms work dont know the difference between there [non-permissible content removed] and a hole in the ground. The car is becoming a major inconvience, and we are looking to find the solution so it can be replaced and start being driven again. If anyone has any help, please suggest away!!!!
Russ
Then get rid of it. It's 10 years old....and it's a Dodge.
rick
it runs beautiful,then.when i pulled into the driveway it just stalled on me.checked the spark on the spark plugs and there wasnt any,so i thought the timing went.i called up a friend of mines and he told me it might be the "ASD RELAY" can someone offer some advice on where i can find this relay for a cheaper price then the rip off dealer? i can purchase online if nessary.also some advice if anyone has had this problem and if the relay might be the reason that it has stalled for no reason.
Also where is the inertia shut off switch located?
i took a spark plug and checked for spark but had none has new
pcm, camshaft sensor, and new injectors, need some advice
For 1st 6 months after all the repairs done (which were done about a yr ago) the car ran GREAT.
any help totally appreciated
can anyone tell me where fuel pump is and fuel pressure regulator. thankyou in advance for any help
Should take a compression test on the cylinders to be sure timing belt has not jumped some teeth . It should read about 170 to 185 pounds pressure dry. Wet would be 10 more pounds. How many miles on engine as I had to replace the whole distributor on my car,from Discount Murrays(cheapest source). Also the crank case sensor could be malfunctioning which is down below the battery and goes into crankcase. Goodluck
(GAME ON)
