Mazda MPV Electrical System/Lights
 questionmark
                    Member Posts: 3
questionmark
                    Member Posts: 3
                    Hi, i'm new here. I just want to ask a question
I bought a 2002 Mazda MPV LX. The previous owner drives around 3000 miles per month, so the van has very high milage (146000 miles)
I found out the "check engine" alert is light.
I talked to the mechanic and I was told it was just the sensor's problem, no big deal. Can anyone tell me is it true? How to solve the problem? :confuse:
  :confuse:
 :confuse:
  :confuse:                0
Maybe someone who has replaced one of these sensors on an MPV can reply and give you more details. Personally, I would not mess with it and would take it to the dealer (the fact my 2002 MPV has a bumper-to-bumper warranty with 0 deductible until 2011 is a big factor there).
I haven't had to use it yet, and I hope I don't have to, but I figure one problem with the powertrain (which seems pretty common in the MPVs) will more than pay for the warranty.
We just hit 20k in our 2004 MPV LX(bought in July 2004) I believe our dealer said we had 1,000 miles before manufacturer warranty ran out to extend warranty. Can't really decide to go for the extended warranty or not. I think if the warranty was extended at the price that Toyota Siennas warranties go for, around $800 7yr/70k/0 deduc...it would make the decision a lot easier.
I haven't really read that many complaints about problems with the MPV's powertrain. The ones I have read are usually dealing with the transmission shifting hard and reflash not working. I haven't read many that the transmission had failed or needed to be rebuilt/ replaced. The Ford Duratec 3.0 engine...can't recall any complaints(on reliability).
there are too many things that could go wrong to even guess what the issue could or how much it costs. Once you get the code, others can help determine what is wrong.
Even with no noticeable problems, your engine and emissions equipment may be getting damaged by ignoring the CEL for 2 years. You should get it checked out by a dealer or reputable shop. Don't ignore the CEL, if anything at least find out the code and search the 'net, but don't ignore it for 2 years!
-Brian
The second part...should I just go to Firestone and ask them to replace all the large hoses that are related to air flow? Or, is it narrowed down to a hose or two and I should just do it myself? What do you think? I have to buy a Hanes for it, or Chiltons...don't have an engine diagram to show where the right hoses are.
If you know that is only one or two hoses, and where they are, can you help me?
Thank you very much.
http://imazda.com/forums/archive/index.php?t-8035.html
We had been advised that our insurance might cover this, and after contacting them were told they would cover the repair as well as a rental. They contacted the car rental place and authorized the rental, but have since said they wouldn't cover either one. Does anybody have any advice?
Thanks!!
2) I have what appears to be a factory sticker that says "CODE ALARM" on both front door windows. Is that a stock Mazda alarm system? I bought the MPV used and didn't get any key fobs with it so I'm not even sure if it has keyless entry.
-Brian
Please reply to Jay pgarescleaning@aol.com
Please keep the conversation here so everyone can benefit. Thanks!
Steve, visiting host
I have not posted in a bit about MY problems - latest is the CHECK ENGINE light coming on again! Two times in the past 2 weeks - once for a misfire on #4 plug. Took to my trusty local service person who said it may get moisture in the coil assembly due to a bad rubber seal? We decided against doing anything, resetting the light and it seems fine now. It did stumble for one day but finally dried out I guess. Ugh! This has happened off and on since I got this unit new in 2003. It usually happens in a heavy rain where all of a sudden the engine will start stumbling until it dries out again. Great Mazda design I guess??
Second Check Eng. Light came on again - this time due to a "Random Misfire". Could not pinpoint which location it was though. This rig is a bundle of puzzles and mysteries for sure. When it runs it is sweet yet - after 122K miles!! When it starts acting weird, I get nervous and think I'm on borrowed time!
Anyone else out there have this stuff happen to you? Anyone still have their MPV after this many miles??? I think I'm getting to be in no man's land now!! Many of the people who use to post here are long gone now due to selling off these puppies!
Thanks, TCC
A lot joined the MPV Club and still own their MPV's.
I'm selling as soon as this latest issue is resolved.
cheers, BK
It's a 2002 MPV LX, original owner, about 70k miles.
Got a Mazda MPV 2003, 2ltr Deisel. Have had since 04. Problems.
Electrics, driver window stuck down, had motor ,regulator and control unit replaced window now fine £700 later. However cental locking system had been playing up before this , key fob no longer works despite battery change, F passenger door lock dodgy, alarm goes off 90% of time on unlocking front doors, is only fine from rear. Mechanic had reckoned control unit replacement would possibly help but it didn't. Any ideas?
Also excessive engine oil usage ,1 ltr per week approx. alot of smoke discharge from exhaust white and black on starting& acceleration. This despite oil & filter changes and additives to oil and fuel. No leak. ?
#1 #2 #3
Then the next 3, which are easy to get to, are in the front towards the radiator.
#4 #5 #6
May check the coil and plug in cylinder 4 since it's easy to get to ( a couple of bolts), though I can of doubt it would go bad so early. Throttle body may need direct contact cleaning.
I replaced the new #4coil which I put and swaped with the old one for checking that I had last year. I drove the van and light came back again. I also checked the #4plug which by looking at it just burning fuel right like the other cylinders(no carbon on it, same gap, no debbrie). I use one fuel injector cleaner once a month(Lucas) since this problem. I changed my air filter last year and cleaned throtle body last year. After all this supported information what would be your suggestion?
I get a lot of my informtion from the mpvclub.com.
These are the codes. I have just now changed my #4 cylinder new plug and new coil. I have also used a whole bottle of Mass air Flow cleaner, through air filter, in running engine condition, but the dilemma is still there. Earlier it was flashing but now it is still.
Please need expert advise.
I have a quick question. I have MAZDA MPV 2002 with 83K on it and I need service plan on it. I never had warranty on it and the van is in excelent shape for last five years and I want to keep it but I need protection for unforseen expenses. Do you know any company or dealer who offers service or maintenace plan for it.
I will be looking for your response.
Thank you much.
I replaced the new #4coil which I put and swaped with the old one for checking purpose that I had last year. I drove the van and light came back again. I also checked the #4plug which by looking at it just burning fuel right like the other cylinders(no carbon on it, same gap, no debris), I put new one anyway. I use one fuel injector cleaner once a month(Lucas) since this problem. I changed my air filter last year and cleaned throtle body last month. I have just changed O2 Bank 1 Circuit 1. I have thoroughly cleaned the coil conductor and rubber for #4 for moister, in case if there is any. After all this supported information what would beyour suggestion?
Can anyone help point me in the right direction? My 2003 MPV shut off while driving the highway. It wouldn't start, and when you turn the ignition key on the horn and flashers come on, (I did not even install an anti theft alarm). I found that the engine fuse blows as soon as you turn the ignition on as well. It will not make a connection to a code reader (probably because of the blown fuse). Also I have been reading about the immobilizer, can anyone tell me where to find that. Any ideas would be greatly appreciated. Thanks in advance
Brian
http://mazdaforum.com/forum/showthread.php?t=7959
This is a great forum and I have been able to get very valuable tips on our Mazda 2003 MPV in the past. Now we have a weird problem:
Whenever the parking break is engaged, the "parking break" sign lights up on the dashboard. In addition, the "door open" sign also lights up on the dashboard and all the interior lights are on (even with all the doors closed!!). When the parking break is disengaged, the "parking break" and the "door open" signs go off in the dashboard and the interior light turn off as well.
Looks like there is a short somewhere in the system. Can someone please help me about the possible causes?
Sri.
