The rear diff plug is 24 mm. The front plugs have an inverted hex head with a recessed torx, T30, I think, but it is close to being stripped. I have the Toyota Repair manuals, but haven't completely figured out how to navigate them. They need a new proof reader. Many of the cross referenced pages numbers are wrong.
Trout 14- (2980)- I haven't noticed the pressure fluctuation, but will keep an eye on it.
Oil pressure fluctation is normal as you describe. It will read a bit higher with 5w30 than 10w30.
To pump the oil in, I just use a pump I bought at the parts store. It is made to fit the one quart bottles the gear oil comes in. It was only $5 or $6. The only bad part is, it takes alot of pumps per bottle to get all the oil out.
And like Steelcruiser said: always, always take the fill plug out FIRST, then the drain plug!
My next chore will be the trans fluid, which I am going to try and change all of it by disconnecting the hose from the trans cooler and running the engine while refilling the pan (poor man's flush as one person put it). It's likely to get a little slick on my driveway again.
I try to drain tranny fluid every third oil change, in keeping with Hank's poor man's flush philosophy.
And while talking about torque specs, after some research and talking with Toy tech types, I believe that for the alloy wheels, especially the ones on the 100 series with washers for them, that wheel lug nut torque spec is 80 lbs, not 100 as shown in the manual. I believe the 100+ lbs is the steel wheel spec. I've been using this spec for about 12 years now without incident.
Any one have contrary info on this--Doug?
How much transmission fluid do you use for a flush? I figure it is somewhere between 4 and 12 quarts (the refill amount of 3.4 and the dry fill amount of ~12 qts). I read about the procedure on Amsoil.com FAQ's page.
Had to chuckle at your earlier posts on the lube oil etc going all over. You haven't lived until you've done that at least once. I remember doing it myself. What a slippery mess
I've also learned the hard way about pulling a nail out of a flat Ssssssssssssss.
Can any one help?
- Is the original mechanic correct about the tie end rods? Should I change them?
- Is there someting else I should be concern with aside from the alignment? Since I noticed there are some vibrations on the steering wheel when I drive. Could the tires be bad?
Similarly, a slight drift to one side or the other is common with the solid axle. Notice which side of the road is "crowned" when you're driving. To check this out, try driving on a road that is crowned to the left, rather than the right and see if you don't notice a similar drift to the left.
Steering wheel vibration may be due to unbalanced or unevenly worn tires. For peace of mind, you may want to consider having a Lexus/Toy dealer check your vehicle out to verify what you've been told. Other than the wheel vibration, it sounds like the Sears tech gave you good information. In re-reading your post, I noticed that you say you have to steer to the left "slightly" even after the alignment, so I think you're just experiencing the normal characteristics of a solid axle vehicle on a crowned road.
For other posters that are wondering (just as I am) about the future of the LC, thought this site might be interesting.
http://www.webwombat.com.au/motoring/news_reports/4_10_toy.htm
One more thing, the Sears technician also mentioned that the front right wheel bearings were a little loose and I should have a mechanic tighten the bearings. Is this something that might be the cause of the vibration? and Is this a less expensive than replacing with new wheel bearings?
Do you recommend I go to another mechanic for the alignment?
Thanks again for all the help.
I've provided a link that might be useful to you. It provides a general overview of the various LC/450 axle & differential components.
Hope this helps. And don't be afraid to post here. There are lots of very knowledge and helpful people here that are more than willing to share their knowledge and experience.
And thanks again in advance! This board is very helpful!
Used car warranties are more expensive and their effective dates are from the date of warranty purchase. The new car warranties are good from the date of original vehicle purchase.
Dealers are not supposed to sell used car warranties unless they sold the vehicle as a used car. Some will fudge this so they can sell them to their own customers at a later date. Any dealer can sell a new car warranty, as long as the vehicle is less than 3 years old and has less than 36K miles.
Clear as mud? Good.
I have some questions concerning the from wheel bearings. Like I said on my previous post, I recently purchase a 1997 LX450 and I have taken the car the sears auto center for a wheel alignment, after the alignment, I was told by the Sears tech, the front right wheel bearings is a little loose and I need to bring it to a mechanic to have it adjusted or tighten with a special tool.
I call several mechanics and were told different stories, two said they can adjust the bearings and two said they can not adjust the bearings on this type of car because the bearings are a "hub" design and they must be replaced.
- Can the wheel bearings be adjusted or tighten?
- Could this be the cause of some steering wheel vibration when at the speed of over 65mphor is the virbation just bad tires since I already have the tire rotated and balanced?
Thanks in advanced for all the help.
I think I'd go to a dealer and let them take a look.
Any truth to this?
Dick
Should there be any play between the wheel bearings and the tires? The Sears tech demonstrated the wheel bearing issue by placing one hand on top of the tires and the other hand on bottom and then rocking the tires back and fore to show the looseness.
Here's a link to an outline of the procedure:http://www.ih8mud.com/tech/birf-repack.html
Scroll down to "Now back to the wheel bearings..."
Any help and/or suggestions!?
My only question now is when I buy it. Seems like the going rate is $1k over invoice and it sounds like we can special order one for the same deal. Any experiences or suggestions?
I have about 7,500 miles on the Revos and can make a few comments tempered by the fact they are still newish and tires can change characteristics quite a bit as they wear.
Anyway, here is how they stand now: (If you want to save yourself some reading then settle for this summary: These tires rule.)
Quietness: At most speeds; better than the Dueler At's and the BFG AT's but about the same at the Perelli Scorpion AT's. At high speeds they are as quiet as the stock Michlein's.
Handling: At low (parking lot) speeds they are a bit loose (the same as all AT's with large outside blocks - especially when new) but at any travelling speed they handle as well at the Scorpions. A bit more understeer then the stock tires but that can be overcome by adding 2-3 lbs of air to the rear set. There is no tramlining at all and they seemed well planted on all surfaces at all speeds. At triple digit speeds in 110 degree heat they handled like passenger car tires.
Braking response: the best I have ever seen in an AT tire. On dry, wet, or dirt roads. Better than any LT tire I have ever had in the wet, in fact. This alone makes these tires a winner.
Now the good stuff - Off-road: I spent two weeks vacationing in the San Juans and drove many of the trails around Silverton, Ouray and Telluride (crossing Engineer pass, California pass, Cinnamon pass, Ophir pass, and a few other lessor known places). Thundershowers every afternoon. The only thing that stopped these tires was my own fear (that and a "navigator" threatening divorce). Axle deep mud? No problem. Deep sand and a 30+ degree incline? No problem. Rain and hail-slickend shale at 12,000 feet at a 25-30% down-grade? No problem.
Later, we went to Moab and did the Gemini Bridges trail, the Klondike Bluff Trail and a few other "intermediate" rated paths. Even when firmly resting on the skid plates these tires crawled over ledges, boulders and sand without a hitch. I think I locked the rear diff once the entire trip.
By a large margin, these are the best AT tires I've ever had.
HiC
I'm envious of your adventures. I spent the last four weeks doing a total 120,000 mile service, finally got it all done this weekend. New spark plugs, radiator flush and fill, do it yourself transmission flush, change lube in both diffs and transfer case. Amazingly, it is still running.
Now I need the tires. Are you running stock size? I was concerned about weak sidewalls on P rated tires and am planning on going with 285/75's.
Does it sound like my battery is dying or do I have another problem? I'm interested in the Optima battery. Does anyone have a recommendation?
Thanks for help.
I can not remember the website, but I purchased it from battery barn in virginia, took about 3 weeks to come in.
Roane
I check toyota.com each day - they have info on several other 2004's, but nothing on the LC.
I phoned my salesman who says the toyota reps tell him there aren't any changes for this coming year, but the car will be vastly different in 2005.
I wish someone new about the 04's! If no changes, I would just get an 03 now.
Anybody heard anything else? Bob.
Toyota Motor Sales (TMS), U.S.A., Inc., announced manufacturer's suggested retail prices (MSRP) for the 2004 Sequoia full-size sport/utility vehicle, the 4Runner mid-size SUV, the Land Cruiser full-size SUV, and the Celica sport coupe. All four vehicles go on sale at the end of August.
The legendary Land Cruiser carries over largely unchanged for 2004. Like the 4Runner, Land Cruiser's optional navigation system will now be equipped with a rear back-up camera monitoring system. The Land Cruiser will carry a base MSRP of $54,225, an increase of $270, or 0.5 percent.
Here is the article:
http://www.motortrend.com/features/news/112_news030820_toy/
I will just keep buying used 100 series for the rest of my life if this happens. I hope this does not happen but there are way to many Americans concerned with the bling, bling image and not real SUVs! Real SUVs will become a thing of the past.
fj100
ARB Winch Bumper & Warn 12,000lb
OME Lift
And a bunch of other stuff!
fj100: I'm new to Land Cruisers, but have admired them for a long time. It's a real bummer. This reminds me of how I felt when the Japanese did away with the great sport coupes some years back.
Oh well, once we get one we are going to keep it for some time. Hopefully by then Toyota will have come to its senses and will have resurrected the LC as we know it.
My salesman (25 yrs at one dealer) says Toyota is telling him that in 2005 it will be an altogether different vehicle. My bet is something like the concept machine they showed a couple of years ago. Rough and tough, wash it out with a hose kind of thing. Hummerish.
Go after a different demographic altogether (ie. younger).
Coming from a Navigator, I have no interest in the Sequoia.
Seems like it would be good to have the last model year of such a successful model run.
Good luck to all. Now, what color to get?
Bob.
If this is what the next generation looks like, it matches the description I got about 18 months ago from my local Toy GM who said he'd seen it and it looked somewhat like the current generation.
Of course this doesn't answer the question of whether or not we'll see this vehicle in the U.S.
http://www.imakenews.com/autospies/e_article000177344.cfm?x=a244v- 2K,a1chH8qW
They are finally bringing these to the states. Toyota has been offering something similiar to this in Australia for sometime.
This means any double din vehicle can have indash, cd, dvd, stereo, tv, back up camera (optional) and nav (optional). All in one. This is at the top of my xmas list.
fj100
Guess what, that picture is a picture of a Hyundai that appears to have been modified. No joke! I copied the link, but lost it. If I could find that out, why couldn't AutoSpies? Their credibility is falling quickly in my mind.
I remain optimistic that the US will get the new LC
"We thought this was funny someone photoshopped this but it’s a good effort note the third mirror on the hood.
Unfortunately, that’s not what the car will look like
But, while we wait, it’s fun to dream..."
