Visitor Agreement.
other trailering news
george7
The ammount you can tow also depends on what is loaded in the truck, If you are planing on taking the family, fully loaded SUV, and a 5,600 lbs trailer, you are runing very close, if not on the line. If you were plaining on a weekend out at the lake, give your wife the keys to the other car and load that one with the kids and provisions for the trip. Try to keep the LC as light as possible, exclusion of the 3rd row seats might be a good weight saving solution too. If you are in the LC with one other person, with the 5,600lbs trailer, you are within the rate, given 375lbs for driver and passenger, and around 250 for spares, tools and what ever else you might need. that puts the load around 6000 lbs. when the boat is gassed up your rear suspension will be close to bottem, and may hit the bumpstops if driven over mild bumps. Im sure 6500 is a soft limit, ALTHOUGH I HAVE NEVER TESTED IT, but the trailer hitch is a class IV which is the highest for SUV, they range in classes and thats how we get the 6500 LBS limit, the next class is the V class and it ranges upwards of 6500 lbs (cattle movers) I would be extreamly carefull in driving with 6800 lbs. You must know your machine, check the temp gagues constantly (may be worth while to get a trany temp gague instaled, i have one and it has helped me know when to back off when towing) Check oil, brakes, lights, chains,knowing your tyre pressure is a must. check out some of the towing fourms if you have any more questions related with what to bring and how to manuver the rig under load.
Thanks for your input. I agree the hitch is solid class 4. and on the Tacoma is rated for 7500#. Must be that with the additional vechicle weight in the LC keeps the trailered weight down. I expected to be at the limit and had airspring installed to help with ride control (and lights out of the tree tops!). Good point on 3rd row seats - good place to lose 140#.
I will be pulling a Fastload 2624T trailer with a 25' center console fishing boat. I have been able to determine is the 5th circuit is to the backup lights, not sure about the trailer brake lockout while reversing. The factory connector is 4 pin, so I am hoping the controller will accomodate. Most of my towing will be around the NE coast, so hope to keep it mostly level. If I was heading into mountains I would definetly go for the tranny temp, but as I will sticking to flat land and infrequent long hauls will try to go without. I have some reading up to do on tire rating and pressure recommentations - I think my factory tires are D load rated (2600#), which should be adequate, but will require pressuring up the tire. I have trailered before with another vechicle, smaller load, so know the mechanics. But as the load gets high, time to double check everthing. Thanks again.
Just for reference the retail price (which, don't worry I would'nt touch with a ten foot pole) was $55,000. It is very clean, has the usual features incl. nav.
Within 2 weeks of the purchase I had both exhaust minifolds replaced due to cracks. They were covered under the wrap around warranty, not the basic warranty that comes with the certification. I have no doubt that they were cracked when I purchased the vehicle, and the selling dealer told me there was nothing wrong when I brought the truck back to be repaired. I had to take it to another dealer to have it fixed.
The truck has been great up until 3 days ago. The torque converter locked up and took out the transmission. The milage is about 73K. The new transmission is covered under the normal certification warranty.
Without the benefit of talking to a previous owner, I would have never purchase any used 35K vehicle with no long term warranty from a dealer before. The certified vehicle program is what sold me, and I am glad that I purchased it.
Needless to say, if I were you I would buy a certified car and seriously consider the wrap around coverage.
Also, does anyone here have any thoughts on the Lexus LX vs. Land Cruiser debate? I know it's subjective, but what ARE the differences? Wood trim? Sound insulation?
Did they say what the availability is for a 2005 right now, and in what part of the country are you located?
There are a few other discussions I think that are dedicated to the LC/LX comparison issue. I've never read them; I guess I'm just not a Lexus kind of guy.
Thanks everyone for the feedback on Toyota Certified.
My LC has developed a wind noise that comes through the passenger side dash vent near the window. The noise doesn't come through any of the other vents. Any thoughts on what could be causing this? How is this vent connected to the outside ( the noise starts at about 50 MPH and changes depending on speed and outside wind).
Now I'm trying to decide between the TLC and another Lexus GX470.
I can't keep the vibration/wobble out of the steering of my 03 LC. I rotate and it gets worse. I've had it back at the tire place upteen times looking at rotation, balance, everything to figure out why I can't get a smooth ride out of the tires. This has been an issue for the last 20k miles or so.
Is my problem the tires? They are the tires I bought the vehicle with--Goodyear Grandtreks. I have 18" Foose wheels. I have 34k miles on these tires.
I'm tempted to go buy new tires even though I don't quite need them yet, but do you think that will solve my problem? I do rotate every oil change.
Any opinions??
Like you, everything checks out fine...
The last time I rotated, the vibration was so violent it was like one of those foot massager deals at the fair! My arms were flying around everywhere. I took it back and said you have to put the tires back the way they were!
I was really hoping to get rid of this problem once and for all! The guys at the shop are sick of me already.
Does this make sense? I searched the board, and I couldn't find any previous posts about problems with frozen pistons. This is a '00 LC with 63k miles. Also, I had no braking problems whatsoever when the wear indicators started to go off.
I really have no reason to doubt the mechanic, seems like an honest enough guy. But I figured it's still worth checking in the with board if any of this sounds odd to anybody and if there are any suggestions on how to verify what they're telling me. Thanks!
Though I've had this problem too, mine was strictly a balance issue.
The frozen piston/brake caliper is not uncommon and can cause the uneven pad wear. You can rebuild the caliper if you're inclined to do it--which is cheaper than buying a new one.
Finally, re: the lower on one side issue--I'd still recommend adjusting your torsion bar up on the low side. I'm sure the dealer would do this for you.
HTH
The vibration does go away at about 70+ mph. The wheels and tires were on the vehicle when I purchased it. The problem wasn't immediate--it didn't develop until I had 10-20k miles on the car.
I posted my question on another forum here on edmunds and someone wrote back that the Nissan Pathfinder had the similar problem we are having and they were able to fix it by finding someone with a Hunter 9000 Road Force Balancing machine to balance the tires. I looked up on www.hunter.com and found who in my area had the machine and it's the shop I've been taking the LC to all along. So I guess that puts me at square one again.
I hope you are right too. I am waiting to replace my M-Class with a LC. It'll be great if Toyota threw in a V8 with cylinder shut off technlolgy with 300HP and about 20 mpg
The GX is nicer(better interior, quieter, better audio system, handles better), the TLC is a hair bigger (more hip room, and shoulder room although the GX has more headroom/legroom). Don't forget about warranty length and service pluses like loaners.
I wouldn't worry about the TLC makeover pending. It may actually turn out that the current is a classic and the new model isn't as well accepted, just like the BMW 5 series makeover.
You can't go wrong with either, it's just a matter of cash and personal preference. I still can't decide. But if I didn't already have a GX, it would be a no brainer, the GX delivers much more for less money.
