Toyota is not standing by its customers and quality! I am a loyal customer with 3 Toyotas, most recently a 2012 Camry Hybrid in Sept 2012. My older Sienna has a minor annoying door noise issue and I asked for Toyota goodwill assistance.Louis Carrillo from Toyota Corporate just gave me a very cold reply that they denied my plead - very disappointed! Probably no Toyota for the next car! Buyer beware!
I got quotes from $150 to $3000 - so be aware. I was told by all body shops that this is a very common problems so pervasive on Sienna 2004-2007 (or so).
Some said this can be a safety hazard if the door problem is severe since the door may fall off.
Write on Toyota Facebook page and vent your frustrations.
Hope this info helps.
How did I get it fixed for free? I have a very bad temper... I am a man and I did a scene, describing real loud their car as being more unreliable than a Government Motor car. I was so loud that the showroom buyers came to see what was happening at the service desk! This is when the owner of the dealership rushed in to ask what was happening (never saw that guy before), they looked into their computer system and then told me that this was covered by a "special warranty" valid forever!
The above means three things:
- First, this is what you call a "hidden warranty", used only when a very angry customer (check!) shows up.
- Second, Toyota knows this is a defect resulting from their manufacturing process.
- Three, the same will happen to you passenger's door eventually... It is just a matter of opening/closing frequency.
The repair done was the welding solution in the dealer's body shop, as I understand it they had to dismantle the door and they also had to paint the hinge section since welding will make the paint bubble up.
Hope this helps.
I'm in need of your solution also. How do I get it?
What is your ebay address?
See if you can get the dealer to find the recall notice and replace the shocks.
Thank you very much.
Not the most sophisticated drawing, but after comparing the basic construction of my older Subaru to the Toyota, I'm left scratching my head. Why did Toyota take something so simple and basic as a bolt-on cup, and add an intermediate plate held on with a single spot weld on each side?? An age old bulletproof design compromised by a flimsy piece of sheet metal. More cost, more complexity, and unfit to perform the job long term.
Hmmm... having problems posting a drawing directly, but the link seems to work.
http://i1060.photobucket.com/albums/t456/Fibber2/Toyota%20Repair%20Misc/DoorChec- - k.- jpg
http://i1317.photobucket.com/albums/t631/dude65401/siennadoor1_zpsfb8b7d4a.jpg
http://i1317.photobucket.com/albums/t631/dude65401/siennadoor2_zps0ade6e9c.jpg
Tools used were drill with 3/16" bit and one slightly smaller for the screws, a ratchet with 10mm, 12mm sockets and 10mm and 12mm box end wrenches, as well as phillips and regular screw driver. I also had to use some electrical tape to reattach wiring to guides in the door.
PS - If you have the popping noise, I wouls suggest you at least unfasten the door opening limiter until you get it fixed. Each time the door pops it is doing a little more damage to the plate.
PPS - Make sure your window is in the up position before you take the door off. Otherwise you couldn't get to the area where you need to work.
I guess I'm one of the lucky ones. My 2004 weld didn't break until 2013. I'm not looking forward to dealing with the dealership on this repair. I've always heard that you shouldn't buy a first-model-year vehicle but it looks like it wouldn't have mattered in the case of the Sienna. I see a lot of the same problem for many years after 2004. We've had plenty of other first-model-year type problems with the Sienna, mainly associated with the doors, all five of them. It may be time to simply trade the vehicle in. I'm not going to spend a lot of time arguing with them over this though. Life's too short. I'll just carry my business elsewhere. Nissan is manufactured locally and all the other manufacturers will happy to sell us a car. Besides, the best value is a used car. I can probably get one of those for about twice what one door repair on the Sienna runs.
Sorry, Toyota.
I just bought a 2006 Sienna, the seller told me there was noise at the driver door which this model has at about 80/90K miles, but it just cost about $300.00 to fix. I believed him so I bought it. but today when I asked a technician to check the door, he said it's door welding defect and will cost about $500.00; since it a welding defect, why Toyota does not do recall? we should ask our attorney to help us, Toyota should take this responsibility! who will be with me to have a try?
There we go! They finally upgraded the software to allow easy photo posting. The design (IMHO) is flawed, and relies on a simple spot weld to hold the cup in place. Why not simply bolt it directly to the door as has been done for years quite successfully?
The failure is expensive and annoying, but unlikely to be life-threatening or vehicle disabling and thus not recall worthy. Best of luck with your lawsuit.
'Ask Toyota' RE: Toyota Case #1504281240 [Incident: 150428-000163] 9:52 AM 32 KB
Dear Mr. Spencer
Thanks for the reply and clarification of Toyota’s unwarranted view of the effectiveness of its “extensive” reliability testing procedures. After researching the many, many reports of the door stop mechanism failures (e.g., see Ref 1 below), it is apparent to me that your 2 year warranty extension beyond your standard 3 year warranty is irrelevant for owners who have experienced the failure, who do not drive over 20,000 miles per year.
From the many complaints (e.g., see Ref 1), it appears that this design flaw in 592,000 vehicles should be corrected by a full “recall”. Replacement of the door and/or welding may be ineffective, and is not even “required” to fix this problem.
There are several self-fixes offered on U-Tube which would not require more than 3 man-hours labor, and less than $10 of materials. Toyota Dealers could provide local sub-contractors (body shops and/or repair garages) with a detailed service bulletin such as provided by Ref. 2 to provide this fix for a few hundred $. I think this would be a far better public relations action by Toyota, than their current one which is evidently to just allow the vehicles and/or their 1st owners to simply “die” off.
Short of that I’m sure that there are many current owners who will never buy another Toyota, and will spread the word to their friends and prospective public domain auto-quality review organizations, dealer BBB ratings services and state licensing departments. A class action suit should also be considered because too many owners of these models of low mileage, well-cared-for vehicles, are out there who have or “will” experience this problem.
And again, I recommend that Toyota Engineering needs to significantly improve their component reliability testing management and procedures on new designs.
Regards and Good Luck in your Career,
Fred C. DeMetz, Sr.
Ref 1: http://forums.edmunds.com/discussion/10450/toyota/sienna/question-on-tsb-toyota-sienna-door-welds-causing-clicking
Ref 2:
Mike65401
http://i1317.photobucket.com/albjms/t631/dude65401/sicnnadoor1_zspfb8b7d4a.jpg
http://i1317.photobucket.com/albjms/t631/dud65401/siennadoor2_zps0ade6e9c.jpg
Sent: Friday, May 01, 2015 3:07 PM
To: fred@soundpathtech.com
Subject: Re: Toyota Case #1504281240 [Incident: 150428-000163]
Recently you contacted Toyota. Below is a summary of your contact message and our response.
Thank you for allowing us to be of service to you.
Subject
Discussion Thread
Response Via Email (Jay Spencer) 05/01/2015 03:07 PM
Mr. Demetz,
Thank you for your follow-up email and your reflections on this specific situation.
The failure rate for the door check is proprietary information and not something that we would be able to offer. Obviously a trend was seen early on which caused the warranty enhancement to be issued but the actual number of repairs is not available.
You can be assured that Toyota does extensive testing of all aspects of our vehicles both for safety and longevity. Owner experience and consumer perception also play a role in our ongoing efforts to build the best vehicles. Contacts like yours are integral to this process, because there is no better source than a Toyota owner who takes the time to tell us like it is.
Thank you again for your honest feedback. It is made available for review by our product planning and engineering teams.
Respectfully,
Jay Spencer
Toyota Customer Experience Center
Customer By Email (FRED DEMETZ) 04/28/2015 10:00 PM
Dear Mr. Jay Spencer,
The other aspect of the referenced Incident, is I’d be interested to know how many similar door failure mechanisms in the 592,000 vehicles during the production run from 2004 to 2007 have been reported?
If this failure is as common as it appears to be, it means Toyota has not done enough reliability testing on vehicle prototypes. In my area of Southern California I have witnessed the testing of full-scale airline aircraft doors latching mechanisms, repeated thousands of times in facilities which specialize in reliability testing. Has Toyota done this type of testing on the Sienna Doors?
The reason many people buy Toyotas is their legendary quality and reliability. To build and sell over half a million $40,000 vehicles whose doors will fail “under light usage”, and require an expensive repair, long before the rest of the vehicle goes 100,000 miles, suggests to me that Toyota needs to get some good reliability engineers who know FEA metal fatigue analysis of spot welded panels, and know how to test the design before production.
Toyota’s adding 2 years or 100,000 miles to the 3 year/36,000mi warranty is nice, but not good enough. Assuming quality automatic welding equipment was used for consistent results, all these doors are doomed to failure, it’s just a matter of reaching the number of cycles until failure. In my case it was about 10 years x 200 days use/year x 10 cycles/day = 20,000 cycles in about 66,000 road miles driven on dry, sunny California freeways.
Fred C. DeMetz
Ph.D., Mechanical Engineering
Sent: Tuesday, April 28, 2015 10:53 AM
Response Via Email (Jay Spencer) 04/28/2015 10:53 AM
Mr. Demetz,
I apologize again for the concern you are experiencing with the front door check on your 2005 Sienna.
As we discussed, Toyota did issue a customer support program in November 2007 which extended the warranty coverage for the driver's front door check from 3 years or 36,000 miles whichever comes first to 5 years or 100,000 miles whichever comes first. The date of first use on your vehicle was November 17, 2005, so the warranty coverage ended on November 17, 2010.
Please find enclosed a copy of the Technical Service Bulletin that details the suggested repair for the door check if it is not cracked or split.
Your case is documented at our National Headquarters under file #1504281240. If you have any further questions, please contact us at 800-331-4331. Our hours of operation are 5:00 AM to 6:00 PM Monday through Friday and 7:00 AM to 4:00 PM Saturday, Pacific Time.
Sincerely,
Jay Spencer
[---001:003298:02144---]
Another issue I have experienced, which I would consider a true safety issue is the Vehicle Skid Control mechanism engages in turns and on winding road (even lightly winding), This has caused many scares for me. The review of the logfile by the Toyota certified mechanic didn't reveal anything, i should also mention that my can has never been in any accident/impact situation.
The only way Toyota would pay any attention to this matter is if the owners who are experiencing these issue call them to express their concerns.
