The XM info is great - I think we'll enjoy it more than we know.
XM & Sirius Satellite Radio
Rock 'n Roll!
We had the '01 pewter and now that we have the '03 dark green/ I am in scratch obsess mode since scratches will show much more. I've parked away from people, I've been ever so careful AND my 3 year old LOVELY daughter today had a rock in her hand while I was loading our dogs into the car after a walk. She decided to draw a few nice, big circles on the drivers side/passenger door where she sits! Can't even describe my emotions at that moment. Not a pleasant moment for either one of us. I'm told that it's a "clear coat" scratch and can be buffed out which is being done tomorrow morning. We've had it 3 days! Oh the joys of parenting.
We're in Stamford - we got our Suburban at Karl Chevrolet in New Canaan. Nice, family-owned place. Didn't have to fill out any paper work - Mike just took some basic info and did everything for us.
I am thinking about it and it seems fairly easy to install.
I am not sure if it will void the warranty.
In order to shift the transmission, the brake must be pressed.
The owner of a new '03 Z71 complained that when the key was in the accessory position, the transmission lever could be shifted without first pressing the brake pedal.
I also own an '03 Z71 and tried to duplicate his claim. When I put the key in the accessory position ONLY, I was able to shift the transmission lever into any gear without applying the break first.
I tried the key in other positions and the safety interlock worked.
The next time I have it at the dealer for service, I will log my complaint.
Any of you with children should be extremely careful and check your vehicles for this defect.
Can someone please tell me who qualifies for the tax write off if used as a buisness vehicle. I was told by someone that all vehicles weighing > 6000 pounds can be taken off as a buisness expense the very year in which the vehicle is bought. Is this true. Where can I find out about it ?? Thanx
A suburban/Tahoe have a gross vehicle weight of over 6000 lbs (meaning a fully loaded truck weighs over 6000 lbs). This vehicle can get accelerated depreciation over a standard car.
There is a new temprary tax credit that applies to vehicles weighing over 6000 lbs (not gross vehicle weight). These may be able to be written off in 1 year.
I do tow a trailer, and sometimes I load it with a lot of wood or brick, but I could easily confine myself to the weight limits recommended for half-ton, so my question really is on durability. Thanks for any comments.
Also, I would appreciate any comments on pricing--how much above dealer invoice or below sticker at this time of year (Sept 19,2003) for the 2003 models.
That is what I am hoping to do w/ my new 03 Z71 burb.
You should be able to negotiate a deal allowing for a price around invoice, allowing a $500 buffer either above or below depending on your market.
Now is a great time to buy with all of the rebates/incentives offered as well as the low rate financing.
With respect to the 1500 vs. the 2500, I don't know about the 2500 series lasting longer because most of the drivetrain component are similar or often the same.
With the 2500 series, a larger engine with more torque and hp is available for towing if you feel you will be hauling heavy loads over 8500 pounds. You also get upgraded drive axles etc.
If only towing occassionaly, the 1500 should serve you fine. (A judgement call)
Just some pricing advice...
Make sure you know the actual invoice price on the vehicle you are looking at and not an inflated figure provided by the dealer.
Did my first oil change @ 600 miles. Opted for Mobil-1 10W5 super syn and also Mobil-1 oil filter (M-107). I noticed ample metal dust on the magnetic tip of the oil drain plug.
The oil change was a breeze other than a small accidental spill. Underestimated the initial burst of the oil after the plug was removed. Replacing filter was a joy - it is conveniently placed next to the drain plug. I poured 6 quart of Mobil-1 10w5 and it took every drop of it.
I'm just curious to know if other people with similar models have the same problem I do.
Just turned 1200 miles and plan on changing the oil too.
Other than the safety interlock for the transmission, everything has been fine.
How about license plate lights? Is there anybody with one not working?
If not, what changers have others successfully added (preferably controlled by head unit).
John
This is how I would decide; If you are going to tow a trailer, and the loaded trailer weight is approx 75% of your GVWR, go for the 3/4 ton. You won't be sorry, and you'll be groaning and wishing for a 3/4 ton when you go up those hills a towing. We took our 5100 lb (empty) Hi-Lo from KC, MO to Yellowstone National Park, and our brakes started to smoke coming outta Cody,WY due to 8% grade! Yes, I know trailer brakes help out, and I've got electric, BUT that put a BIG!!! strain on the '99 burb. I would go for the 3/4 ton, with 8.1 and 4.10 gears. For mileage improvements, I suggest a K/N air filter, and a Banks PowerPack/Stinger System. Durability wise, the 3/4 ton have heavier duty components,so they won't wear out as fast. The 5.0 with Quadrasteer I would stay away from until the bugs are worked out. Besides, when towing inthe mtns. there ain't no such thing as enough power
03-07-30-007 (APR 03) A/T - Apparent Delayed Gear Engagement .I got a 2003 Suburban all wheel drive and sometimes it feels like your in neutral until the tranny kicks into gear .I want to know the whole problem and fix BEFORE i go to the dealer so they can't give me one of the famous "Tech unable to verify" excuses.
Any thoughts on pricing?
Any thoughts on reputable companies?
Are the XM, DVD, Stereo covered?
Check with Warranty Direct (warrantydirect.com) for an extended warranty. The coverage for our DXL was quite comparable to the coverage offered by the dealer but for alot less money. However, I don't think they cover the DVD entertainment systems. Quotes are available online. The only other company we checked with was Mercury, but the coverage from Mercury was not nearly as thorough.
http://www.consumeraffairs.com/news03/natl_warranty.html
http://abclocal.go.com/wabc/news/7onyourside/wabc_7side_081803nat- lwarranty.html
glsable
glsable
BEFORE YOU PURCHASE A NEW 2003/2004 SUBURBAN, PLEASE READ!!!
I purchased my Suburban only one (1) month ago. I loved it for the first four (4) days, until the irritating noise from the A/C started in the dash. I have taken it in for three (3) separate service attempts to fix this noise. At all three (3) attempts, I had Service Managers, A/C Techs and other GM/Chevrolet employees admit to me that the noise I am hearing is caused by a GM Design Flaw in the A/C unit in all 2003/
2004 Chevrolet Suburbans and GM has no Service Bulletins issued to advised the Service Departments how to fix the noise and to basically live with it.
Disgusted I then contacted my dealership to see how to rectify this issue. My dealership advised GM/Chevrolet has a "BuyBack" program for those customers that are not happy with the purchase of their new vehicle. (WHAT A JOKE!!!!)
Feeling that I have been ripped off and knowing the Lemon Law, I proceeded to contact the 800# GM/Chevrolet Customer Service number and report the issue with my new Suburban. Customer Service issued me a case number, contacted my Dealership, spoke with the Service Department Manager, who advised the Customer Service Representative that they had researched how to fix the noise and have a couple of solutions they would like to try in an attempt to fix the noise.
I then took my Suburban back to the Service Department (this being the 3rd attempt). Noise was not fixed. Service A/C Tech. admitted to me he heard the noise in the dash and can't fix it. He even admitted to me that he has other 2003 Suburbans being serviced with the customers having the same complaint of a loud noise coming from the dash when the A/C is on.
Fed up, I contacted my GM/Chevrolet Service Representative via their 800#, advised her the noise was still not fixed, advised her of the names of Service Managers and A/C Techs that have admitted to me that there's a design flaw and no service bulletins to fix it and I want my vehicle bought back by GM because I know I could NOT live with driving a new vehicle that was making this irritating noise and knowing GM was getting by with it. She advised me the next step was to have the Area GM Representative review my file, speak with my Dealership and the Service Department to see why this A/C noise couldn't be fixed. She also advised me that if he determined the noise couldn't be fixed, he would advised GM that the vehicle should be bought back. They would be back in touch with me within 48hrs (business). (It ended up being 5 business days before they got back with me).
During this waiting time period, to make my purchasing experience even more irritating, my engine light came. I took my Suburban back to the Service Department (4th visit to the Service Department) to have this issue looked at. Service Department advised me it was a computer chip.
Five days later I heard back from my GM/Chevrolet Customer Service Rep. advising me that she had spoken with my Area Representative. Area Representative advised her that the noise I am hearing from the A/C is a NORMAL noise in all 2003/2004 Suburbans and Tahoes and that since my issue is not a MECHANICAL ISSUE, I really shouldn't be complaining. What, I should just accept this irritating noise, are they crazy???? I just spent $37K on a car that I get aggravated with when I drive it?? Yeah, right!! I don’t think so.
For this reason, I am posting this message, in an attempt to let other future customers be aware of this design flaw and no fix solution concerning the 2003/2004 Suburbans. GM knows there's a design flaw and continues to sell these vehicles. If anything good comes out of my terrible experience is that I make anybody looking to buy a Suburban be aware of this issue and drive it for at least four (4) days. Good luck and beware.
KITCHENS: What is the monthy XM fee? And was I right about the sign on fee or not? Thanks for the heads up on signing up for automatic payment to waive fee for invoice payment.
As to charges, there was no setup charge that you talked about (I think you said $300). First three months were free. After that, it is $9.95/month.
I liked it so much that my wife bought me an after-market XM at Best Buy for my car. Not as slick as the integrated unit in her Burb, but still nice. Also, on second, third, etc. XM radios in the same name, the charge is $6.95 (still $9.95 on the first one) a month.
I just bought an 04 Volvo and can't believe they don't offer XM. I can still use my after-market, but I was hoping to have an integrated one.
Go for it, they are great!
I believe Ford/Lincoln/Mercury products use Sirius Radio and not XM.
I've seen a few ads showing Saab offers XM radio. I know Saab is owned by GM now. Honda also offers XM radio as well.
Hearing your story is starting to make me think maybe there is something to these instances... if it happens again, I think I'll taker 'er in and have them look it over.
I personally would definitely get leather with kids. It cleans up much easier and can be repaired more easily if damaged. The comfort of the upper trim GM vehicles with the power 2 way lumbar support is different than the lower level trim vehicles. Make sure you try the seats with and without the power lumbar for comfort.
I got a seat cover for the middle row seat (the primary seat used by the kids) to help protect the leather. So far (almost 3 years) it was worked well and is easily washable
