Stories from the Sales Frontlines
1199219931995199719982003
    @sterlingdog said:
    Chalk me up for the cheapo blue, 2 blade Gillette razors also. Get them at Costco. Change every weekend. Too hard to shave my upper lip with those 5 bladers !!
    2013 LX 570 2016 LS 460
    edited June 2014
    @sterlingdog said:
    "Too hard to shave my upper lip with those 5 bladers !!"
    I used the complimentary Fusion razor I received from Gillette this morning for the first time (been using Mach III's for years) and found I got a closer shave. You are right, Richard, shaving the upper lip and below the nose is difficult, but if you are careful, it works fine.
    If I can get 25% more shaves out of this new Fusion than I got out of the Mach III, it would be a break-even point in terms of cost. But the shave seems to be much smoother.
  • stickguystickguy Member Posts: 53,847
    wait, you guys are both retired. Why are you even bothering to shave at all? :D
    Stick, you're not alone on the electric shaver. I buy a Norelco or Remington triple at about 8 month intervals buying on sale and storing the next one for later. At $28 not worth it to replace blades. Just toss it. Last one (mistake) was corded. Oops, now I check for cordless.
  • driver100driver100 Member Posts: 32,639
    edited June 2014
    @oldfarmer50 said: I buy the Bic disposables. 99 cents for ten. Gives a close enough shave for my purposes and you get about 6 shaves out of each
    @sterlingdog said:You're exactly right oldfarmer
    99 cents for 10! Using the driver income averaging schedule it works out to 10 cents a blade.....6 shaves to a blade, or 2 cents a shave.
    My Mach 3's cost about $3 a blade, divided by 14 shaves is 22 cents a shave.
    Oldfarmer, I think you have found a way for me to save hundreds of dollars a year!
    Maybe they are manscaping!!
    Eeeewwwwww!!!!!
    @mako1a said:I buy a Norelco or Remington triple at about 8 month intervals buying on sale and storing the next one for later. At $28 not worth it to replace blades
    Wait, this is even better, 240 shaves for $28! That's 12 cents a shave, better than my Mach 3 (20 cents) but not as good as oldfarmer 2 cents).
    driver, don't forget, with the blades you have to add in the cost of shaving cream.
    @driver100 said:
    If that safety device made it so you lived in a bad accident you would be glad you got it.
    Most, if not all, of the safety devices designed to make you survive an accident have been in cars for some time now. The items mentioned on this thread (backup cameras, blind spot monitors, lane change warnings and the like) are more in tune to preventing the accident than surviving one. That and they seem to replace the attentiveness, alertness and skill of the driver.
    edited June 2014
    Don't you mean shave hundreds of dollars a year off your grooming expenses?
    @snakeweasel said:
    "That and they seem to replace the attentiveness, alertness and skill of the driver."
    With older drivers along with teenagers, these safety features are important. However, the "beeps, buzzes, chimes and flashing lights" can be more of a distraction than an aid in the case of the older drivers.
    Of all the safety features available, the back-up camera and front and rear parking sensors are very important to older drivers. Also, lane departure and blind spot warnings are also important.
    edited June 2014
    If GM is bad you should try American Airlines some time. AA has to be the most poorly run airline in America.
    I have been sitting at JFK since 3:00 PM. It is now 8:00 PM. Lord knows when we'll get to Puerto Rico.
  • imidazol97imidazol97 Member Posts: 27,730
    Richard,
    Has your AC been working correctly since the FL store serviced it?
  • oldfarmer50oldfarmer50 Member Posts: 24,426
    I'm already half way there with a full beard. I just shave under my chin and a few other strategic spots to ward off the a Grizzly Adams look. In a few years when I retire I may adopt the full Sachquach look.
    @oldfarmer50‌ said:
    "I just shave under my chin and a few other strategic spots to ward off the a Grizzly Adams look."
    Just be careful with that razor on those "strategic spots" OF!!!
    @robr2 said:
    manscaping
    I should do that. I tell people that my hair didn't fall out, it fell in and just came out in other spots. :'(
  • ab348ab348 Member Posts: 20,487
    Now that I'm retired I didn't shave yesterday. Felt grubby, so shave and shower today, much better.
    @stickguy said:, don't forget, with the blades you have to add in the cost of shaving cream.
    I thought it would balance out.....shaving cream and pre-shave and after shave lotions for electric (power mower).
    edited June 2014
    Actually I use shampoo/body wash to shave in the shower. I figured out long ago the shave cream was a gel so it would hold moisture and its detergents would break through the oils on the beard to allow the water to soften the hair. All that's needed is time for the detergent to breakdown the oils on the hair.
    Somehow I'm thinking this is too much information!
    @imidazol97 said:
    (He could be correct :) )
    @imidazol97 said:
    Actually I use shampoo/body wash to shave in the shower. I figured out long ago the shave cream was a gel so it would hold moisture and its detergents would break through the oils on the beard to allow the water to soften the hair. All it needs is time.
    Sounds like another macscaper.....
    I thought manscaping was only for the young guys......
    @driver100 said:
    The big cost of shaving with a blade is the hot water.
    Yes, it is possible to shave your upper lip with a 5 blade razor, but it is sort of like eating spaghetti with a spoon. You can do it, but it is messy and awkward. :'(
    @houdini1 said:
    "Yes, it is possible to shave your upper lip with a 5 blade razor, but it is sort of like eating spaghetti with a spoon. You can do it, but it is messy and awkward. "
    I never said it was easy - if you take your time, it's a no-brainer. I like this Fusion better than my Mach 3!
    @imidazol97 said:Somehow I'm thinking this is too much information!
    I never thought about it that much....detergent vs foam vs gel etc. I just buy what I always did and I don't worry about it. Like I say, one blade lasts 2 weeks at 22 cents a shave....I am worth it damn it!
    @houdini1 said:The big cost of shaving with a blade is the hot water.
    OMG...I am not going to calculate that one. If it bothers you try cold water.
    I think a Mach 3 has better handling and is more nimble than a Fusion for rounding curves and for getting the feel of the beard.
    I own both but really prefer the Mach 3.
    @driver100 said:
    It doesn't bother me...just trying to further your education.
    @driver100 said:
    I think a Mach 3 has better handling and is more nimble than a Fusion for rounding curves and for getting the feel of the beard. I own both but really prefer the Mach 3.
    But the Mach 3 doesn't handle as well in snow due to rear wheel drive.
    edited June 2014
    Reply question
    Sometimes when I reply to a post by clicking on "quote" it will show the body of the post I am replying to and sometimes it won't. Is there some way I can chose?
    just delete the block you don't want. And if you don't want it in blue, just delete the > at the beginning of the line.
    It worked this time to include the post but many times the post does not show up at all when I click "quote". Maybe it is just a glitch with my computer or browser (chrome).
    Sometimes if there is a quote in the post to be Quoted, the non quote, new portion will be included in the new box. Sometimes just the greater than sign and the at sign plus name of the poster.
    Washington Post Story...
    The Arctic Ocean is warming up, icebergs are growing scarcer and in some places the seals are finding the water too hot, according to a report to the Commerce Dept. yesterday from the Consulate at Bergen, Norway.
    Reports from fisherman, seal hunters, and explorers, all point to a radical change in climate conditions and hitherto unheard of temperatures in the Arctic Zone. Exploration expeditions report that hardly any ice has been met with as far north as 81 degrees 29 minutes.
    Soundings from a depth of 3100 meters showed the Gulf Stream still very warm. Great masses of ice have been replaced by moraines of earth and stones, while well known glaciers have completely disappeared. Within a very few years it is predicted that the sea levels will rise so high that many coastal cities will be uninhabitable.
    This report was from November 2, 1922, as reported by the AP and published in the Washington Post...91 years ago.
    I'm still busy worrying about the global ice age returning that they promised in the 70s and the Jimmy Carter era.
    @imidazol97 said:
    I think this sometimes happens when the quote you're trying to quote also has a quote in it... like Imidazol's post I'm replying to. He quoted houdini1 in his post, then added text. Then I hit quote on imidazol's post, and I got zippo. I'm thinking there's a personal setting that fixes that, but I'll try it first so I don't give out bad info.
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    @Kirstie_H said:
    Nope, my idea didn't work. I'll try to remember to mention that issue to see if there's a fix for that.
    Review your vehicle
    edited June 2014
    @imidazol97 said:
    This is the only Mach 3 I'd use.
    mustang mach 3
    http://themustangsource.com/concept/mach3/mach3_6.jpg
    edited June 2014
    Please make a note that sometimes if there is a quote AND new text in someone's post, the new text in the OP's post will copy the new text into the Quote box and sometimes it won't. E.g., when I replied to Houdini's post earlier, his new text showed up in the box; the quote he had did not carry in. But I couldn't get that to happen again. It won't work now when I'm trying to quote your post.
    I originally had highlighted the new text in Houdini's post intending to paste it into the new Quote box. But his new text had already copied in.
    @imidazol97 said:I originally had highlighted the new text in Houdini's post intending to paste it into the new Quote box. But his new text had already copied in.
    Sometimes it quotes the whole message, sometimes nothing. This time I pasted the part of the quote I wanted. But, with my new tablet copying and pasting is not easy, so I'll just have to do what I can when I take it to the UK in 2 weeks. Or, maybe Kirstie will have it fixed by then! :D
  • sterlingdogsterlingdog Member Posts: 6,984
    Good point. I actually shave every other day now, unless we're going some where special such as a concert, meeting, etc. Since my beard is so white now, the second day hardly shows anything at all.
    Richard
    @imidazol97 said:
    Richard,
    It seems to be working fine. Thanks for asking.
    Richard
    @imidazol97 said:
    I also shave in the shower using the body wash. As you say, all you need is for the oils to break down, which they can do while I'm bathing.
    Richard
    @driver100 said:
    Try cold water?! NEVER! I had to do that once during a hurricane power outage that lasted a week. I must have cut myself in a dozen places.
    Richard
    @Kirstie_H said:
    I've noticed something interesting. When I hit "quote", everyone's post will reappear with the exception of Driver's. His post never reappears. I wonder why.
    Richard
    @sterlingdog said:
    Richard
    Weird. Your post didn't reappear either.
    Richard
  • graphicguygraphicguy Member Posts: 14,199
    @driver100 said:
    Barbasol....but that's only because I can't find Noxema shave cream anymore.
    Richard
    Hate,.....Hate......HATE....cold showers. Last time I had one was 3-4 years ago. A hurricane (you read that right....a HURRICANE) that blew through Cincinnati shut off my power and hot water heater for 5 days.
    I was worred my manhood would never return.
  • laurasdadalaurasdada Member Posts: 5,248
    @graphicguy said:
    Everytime I see/hear Noxema shave cream, I instantly picture the commercial with Joe Willie Namath and the beautiful blond. "Take it off. Take it all off."
    edited June 2014
    @graphicguy said:
    ...can't find Noxzema shave cream anymore.
    It's available on Amazon.com in various flavors as well as regular.
