Haven't seen a TLX in the wild and after a year finally found one of these....I don't care care what the reviews say acura needs a win- the ILX clearly isn't it - nor is this -
The most interesting thing about that photo is .... you're listening to Rihanna?
I must be getting old.....
hahaha
I know it's early, but the numbers suggest Acura has a hit on their hands with. They want to sell 44K of them over 12 mos. They are on track to sell 50K to 60K (probably closer to 50K once the initial flurry slows down).
Something for everyone....4 cyl with DCT, and all wheel steer or 6 cyl. with SH AWD if you want it. As good in the tech dept as anything else on the road, and probably better than most. Performance that's competitive. Value equation that is probably best in class.
Plus, they're about darn near impossible to break, they last a long time, and they don't cost much to maintain or operate.
That's a winner to me.
@ TLX talk- one thing that acura has been missing in sedans - more then anything is LOoks. You can talk about go fast spoilers or whatever BUT reason last TL failed - and make no mistake it did fail (along with RL) is looks.
@stickguy - agree - my point was more directed at TL- as you stated I also think the RL was fine in looks. Nothing flashy but hard to buy that when you can pay similar for E class(thus the fail). The new rLx again looks fine but at that range it's tough when you look at comps- haven't seen a TLX yet and won't comment.
http://www.acura.com/PressReleases.aspx
"High strength steel uses include:
UISBOR – USIBOR is a boron-alloyed steel with an aluminum-silicon coating that protects against oxidation during the heating, forming and hardening process. This high-strength hot-stamp steel is used for the TLX's door opening rings, for 5% of the unit body. (See Safety section for more information.)
980 grade HSS – Used in certain key structural points such as the front edges of the door sills, and in the A-pillars and B-pillars, for 2% of the unit body.
780 grade HSS – Used for most structural load paths for ACE™, including the side sills and forward spars of unit body, for 2% of the unit body.
590 grade HSS – Used for the front frame spars, floor and roof supports, for 35% of the unit body...
Magnesium Steering Hanger Beam
Located behind the instrument panel, a 3-piece magnesium steering-hanger beam replaces the 26-piece aluminum and steel unit in the previous TL model. Its purpose is as a structural attachment point for the steering column, pedals and instrument panel, as well as a structural element that helps the passenger cabin retain its shape in certain collisions. This single robust magnesium component makes up 2-percent of the TLX's body weight...."
they had a couple of black ones on the apron (did not scope out due to pouring rain). But, there was a graphite lustre (same color as my RDX) in the showroom. a V6 FWD. Overall, very nice. Loved the looks. Even the front end was sharp, particularly the headlights. Beak did not offend. the rest of the car had enough curves and design points to be interesting, without feeling overwrought.
Interior, very nice. pretty much shares the dash with the MDX it seems (the RDX and ILX are close to each other too). Well done. Nice, clean dash and very "Acuraish" super duper comfy seats. back seat to me was fine. I am 6' with a long torso, and had no problem with leg or head room. Might not be quite as big as the Legacy we drove, but plenty of space for 4 adults. Trunk was acceptable.
not a huge car, but certainly seemed to fit the entry level luxury profile. Performance? Well, the V6 is going to be fast, just based on how fast my RDX is, and the TLX s/b lighter and has more gears.
oh, the "shifter" gizmo on the V6 was a bit odd. Simple to use, but just strange. Did not get a chance to see a 4 cyl which has a normal gear shift.
I plan to drive a 4 cyl base car if they have one available in the next week or 2 when I go back down.
my one big peeve? They pulled a Hyundai and deleted the spare tire. No run flats (a good thing) but just a can of fix a flat, and a cheap pump. I just refuse to own a car that has no back up plan for a bad tire. Did not explore/question if you could just take out the foam tray under the trunk floor and put a donut in there. Heck, the Legacy not only had a tire, it was on a matching alloy wheel! and per the salesman, was rated for 200 miles.
In short, I was particularly underwhelmed by this car. This is coming from somebody who currently drives an '05 TL and previously had a 6 cylinder Audi A4.
The BMW was black and is gorgeous outside. I was a bit surprised at how low the roof is on this car - definitely not a lot of headroom.
Since it's a rental, I'll grant that this was probably a downmarket trim level vehicle. The seats were black and I'm not sure if they were leather or leatherette - I suspect the vinyl as they didn't have a leather smell. The seat bottoms were very flat with almost no bolstering. In general, although the car did have nav, I didn't feel the interior was very upmarket. Seemed pretty middling to me - not as cheap as entry-level cars, but certainly not luxe, either. The trunk is large laterally but is shallow.
The automated nanny behavior had me screaming thoughts of repair costs had I owned this car. The electronic shifter seemed more gimmicky than useful. The auto-engine shutoff was exactly as has been described here - unrefined and jerky on restart. Yes, you can disable it but you need to do that every time you get back in the car.
I thought the steering was a bit numb and vague on-center. The ride was decent but not that quiet. The engine was refined for a 4 but not all that smooth to me. I didn't push the car as I was in traffic, but this car firmly convinced me that I didn't want to pay north of $40K for a 3-series.
I appreciated the reviews from others here as well and did some research on the TLX. Sounds good but haven't seen one live.
I've been pricing the 335is used. I'd never go for the 328 or lower. The 2 series is too small for me and the premium for new 335's are too dear for my aching college-ravished bank account!
While Acura isn't immune to trying to get people to pay more for leather, all but the base TLX's have leather....and it is a very nice leather....soft, high quality. MB tries to push their vinyl to be as good as leather. From what I can tell, they seem to do a good marketing job on that front.
Was in Costco last night. They always seem to have BMWs in the front as an enticement to use their car buying service. They had a 435i xDrive with the M Sport package....dark metallic grey with red leather interior. It was equipped exactly the way I'd want it. Very nice. But, as I suspected, it was knocking on the door of $60K. For $60K I could negotiate a new Corvette plus a Spark for daily driving duties.
The Costco by us will either have two Mazada's or one MB sitting outside, never a BMW.
On the BMW front, they have recalled i3's for airbags, X5's for latches and 3 series, X1, Z4 and X3 all for brake issues. Porsche Macans have already been recalled. Some GLK350 have been recalled. Even 918 Spiders have been recalled.
The green has disappeared from their online configurator. It was $595, though. I'm almost certain of it.
There's a lot of this going on.
I think trying to row your way thru 7 forward speeds would be very confusing and really a bit annoying but then again I'm a bit old-fashioned and for most cars I think six speeds is one too many.
Who says you have to go thru all 7 speeds each time? 6 was a nice number in my VW GTi but I can count on one hand the times I went into 5th and not straight to 6th. I get what you are saying
I love the car. It is amazingly fun to drive and flog around turns at extremely high rates of speed. I feel like I have double the power and control with Quattro and the 3.0 vs. my old FWD 2.0T.
I did find one issue, I'm getting into the music file market (still a CD guy), and I like high resolution "HD" music files... like FLAC, but Audi doesn't support anything but MP3 and AAC (the two worst for sound quality). The manual says up to 320 bit rates but in my testing only 256 will work, at least in AAC.
Using ITunes to turn a CD into AIFF, AAC, ALAC, WAV I found only 256 AAC to work. (avoided MP3 all together but that works too; though I didn't test 320 bit rate MP3 yet).
Shame on Audi for not being up to date with FLAC support in a 2014 car. I even have the Bang & Olufsen upgraded sound system, so you'd think they'd support modern quality.
In regards to sound quality, and this subject has been beaten to death on the forums like Car Audio also people like Harry Kimura (he lives in San Diego and is the grand father of the modern day aftermarket sound competition) if you truly want sound quality in your S4 then contact usdaudio.com/ they are the only people who I would allow to touch my car. Sound Quality comes at a price, and that weigh and space. So if you could get your FLAC files to work, they wouldn't sound all that much different especially driving down the road. If you think your S4 is quite now, you should hear what 200lbs of sound deadening will do to your car. But then it comes at a price, added weight.. Current car audio has come a long way from the days when I work in then car audio industry... But they are far off from having a complete sound quality atmosphere in which you would hear the true difference, also if you want SQ, just use a CD...
If so, please post your driving impressions -- the TLX seems to be getting less than stellar reviews from the likes of Automobile, C&D, MotorTrend & R&T. Funny thing, to me at least, Acura put the transmission that the paid car reviewers seem positive about in the 4-cylinder rather than in the high contented, big motor, SH-AWD version.
The TLX 8-speed dual clutch (but with torque converter -- a rarity) transmission in the 4 is everyone's darlin'. Then the review turns ugly by suggesting that the 9-speed V6 just feels [essentially] fat, sluggish (due to its apparent porky-ness) and a lot less fun.
On the other hand, the new C-Class is lauded as a baby S class.
Who's driven these here? Tell me more, tell me more -- in many ways, your opinions are the ones that matter most.
Not too long back, I took out a new S6 and was smitten by the intoxicating power of the thing, as well as its ability to blend sportiness and luxury into one sweet, sophisticated and sporty package.
Another month, about, has passed with my S4 -- now at 17,300 miles.
And, while I am certain another wild drive in an S6 would have me again tumescent with desire for this $80K super-sedan, it's just too damn fat, too big in the overall scheme of things. What would be really to my tastes, with the benefit of hindsight now, would be a slightly larger S4 -- add about an inch or so to the wheelbase, make it another 3 or 4 db quieter and put the SQ5 engine in it (for the added torque, natch). Open it up just a smidge in size and power -- 333HP and 325 ft/lbs just are about at a point in the marketplace to require a bit of a bump northward.
Here we sit with no new 4's coming until 2016 MY and, if history repeats, no new S4 for at least another year (or two) beyond that.
Now, if someone wanted to provide me with a new S6 for a couple of years at no charge, well, you can be certain I would not re-gift it.
My comments pertaining to my opinion that the S4 will certainly require a power boost to remain competitive are a good example of "situational velocitization". That is what used to feel really quick and fast, well, feels simply "normal" these days.
The only cure for this velocitization is to get an A4 2.0T loaner for a day or two, so I can essentially push my quickness and speed reset button, for there is surely no lack of quickness or speed in my S4 -- I've just gotten used to it so much I take it for granted.
Drive it like you live.
If my assumption on that matter is correct, perhaps AoA will lobby for whatever the next lower HP (below 400) is but press for more readily available torque. Economy and emissions, too, would have to be a consideration, no?
The current 3.0T in the S4 puts out a conservative 333HP and 325 pound feet. The beefed up version in the SQ5 adds 21HP (taking it to 354) and 21 pound feet (getting us to 346). The crank is a heavier duty part than in the S4 iteration and apparently the SQ5 engine is "strong enough" to be cranked to another like increase without breaking much, if any, of a sweat.
A new model S4 with 375HP and 367 pound feet might just be the Goldilocks answer (at least in the US). This would leave plenty of "headroom" for either a blown V8 or an even more tightly tuned V6 (T) to be fitted into an RS4 model. Indeed, based on what is easily do-able these days with plain ol' "normal" forced induction (super or turbo), twin-charging (super AND turbo) or other, "compound induction" derivatives, I wouldn't be shocked to "hear-tell" of an S4 with a 4 cylinder engine of some-kind or another, putting out an easy-peasy 350HP with gobs of low end torque, either.
Program note:
For reasons that would require at least two more paragraphs, I will tell you that I was cruising along at about 67 MPH on I-71 N (north of the I-275 interchange this Saturday PM last). I had the "need" to "punch it" -- and for the count of 1, 2, 3 floored the S4, cleared the incident, glanced at my digital read-out and found it reading 100. Under the circumstances (light traffic, four lanes heading north, etc), I was simply able to coast down to a relatively legal 68 without the need for the dampers. I realize the S6 seemed to do this exact same thing in what I "recall" as 1,2,3 -- the difference is that the S6 did so with practically zero drama. The S4 made all kinds of fun sounds as it made the jump to light speed.
Newer S4's will, due to market conditions, surely come with more grunt than current versions, but for the life of me, I find it difficult to imagine ever being able (or rarely so) to use such power.
1,2,3 -- the thing is like a freakin' sling-shot.
Dizzy with the rush of speed, I leave you saying "Drive it like you live"!
An article on the BMW 320i from our friends at Consumer Reports.
