Visitor Agreement.
I thought he was sticking with the same brand and type of tire.
If so, going wider at the same height would ride the same or better, right? Going taller, he would only get a smoother (albeit less "responsive") ride, right?
Yes, it is important to watch the payload information. Also, make sure to go with the recommended pressures.
My question is: Can you look at two different tread patterns and get an idea which one is quieter? Are there visual clues that typically signify a quieter tire?
I know that big gaps can translate to better snow traction along with more noise. Circumferential grooves can mean better wet / hydroplaning traction. But I have seen some tires that have big grooves on the outside yet are described as quiet. Do we have to believe the marketing descriptions?
I was hoping for some tips to get a general feel of how tires might feel/sound.
As far as the load capacity I failed my homework assignment on that. I had looked on the Michelin chart and noticed that the 245/70 max capacity was 100 lbs greater than the 225/75 but had not look at the Goodyear which was 80 lbs greater than the 245/70 Michelin. So the way I read the Jeep manual it says the current load capacity with the OE tires is now 1150 lbs. It would then go to 830 with the 245/70 Michelins. Can't say as I like that at all but if I went with the standard 225/75 Michelins the capacity would be down to 430 which is way not acceptable. Does it sound like I ran through this correctly?
As long as you are aware of the load ratings then its not a problem for you. Just gotta be careful of overloading. Yet another by-product of the Exploder/Firestone fiasco.
I had a neighbor with a JGC who couldn't wait to remove the OE Goodyear's. Installed a set of C/T's and loved them. I'm sure you will too.
IF this number crunching is right the max load capacity of my Jeep would only be 430 lbs. So put two 215 pounders in the front seat and the vehicle is at maximum. This seems crazy to me. Either I'm way off base with these numbers or my respect for Michelin was way misfounded.
225/75-16 load rating: 1804 lbs at 35psi
245/70-16 load rating: 1904 lbs at 35psi
So my numbers are backwards. You pick up 400 lbs of payload capability with the 245 Michelin tires.
On to the Goodyear's:
225/75-16 load rating: 1984 lbs but no PSI rating (that's odd).
So, I was correct in my first post about load ratings but incorrect in my second. My apologies.
By the way, how do you judge a higher quality brand? Is it only those that spend big bucks advertising so they have to charge more for their tires? Could a company make a high quality tire and not advertise heavily or sell for a premium price?
So my question still stands: What are some visual clues that might indicate a quieter tire? I am wary of marketing descriptions and would like to add some real world experience.
Anything which doesn't have rubber pick up and then hit the pavement I'd think.
TBC purchases tires from a variety of suppliers but their biggest producer is Goodyear with over 50% of their total tires made by them.
The big issue with private-labeled tires is not the marketing but the R&D and engineering that develops them. Lots of people believe that the only diff between the big brands and the little ones is marketing but that's not always true. The big companies will always keep their best technology and production developments for themselves. Just because a Big O tire is made in a Goodyear plant does not mean its the same thing as a Goodyear tire.
I think if you look past the marketing claims you will find what makes one tire better than another. The answer to what makes a quiet tire is easy to find if you'll do the research.
Or 4 times 1904 lbs.(per tire)=7616 lbs. minus vehicle weight plus payload capacity (4072+1100)= 5172 lbs. Four Michelin CT's are rated for 7616 lbs. and your gross vehicle weight is only 5172 lbs. so the Michelins and GY's are both rated for more than your vehicle can carry so you are not giving up capacity with the Michelins.
By the way I replaced the GY Integitys on my RX300 with Michelins CT's about 5k miles ago and couldn't be happier. Much better traction and just as quiet and not as squirrelly.
best tire. I am willing to take a chance to try new tires. Some people want proven technology.I do not have a favorite brand. I might want a Dunlop allseason for my mild winter tire. I would Try the Pirelli P7 or Michelin Pilot Exalto. for summer tire.
Today I received a call from Michelin. Very nice and seemingly knowledgable guy. He explained that a year ago the rating on the Michelin Cross Terrain SUVs would have been 1984 but now is reduced to 1804, a factor of 1.1. If the Cross Terrains were used on a light truck OR passenger car they would remain at 1984 but on SUVs the load rating is reducted by a factor of 1.1. This is the practice for all tire makers and is done because tires on SUVs are subjected to more stress. He mentioned weight and driving characteristics as the reason. So according to him when you see the Goodyear tires show up as 1984 that is for light truck but when used on an SUV they would be derated to 1804.
I was impressed that Michelin called to answer my question. Daimier Chrysler on the other hand sent the following answer when I ask what the minimum tire load rating was for my vehicle.
"Your vehicle was designed to operate with the specific tires that were installed at the factory. We would not recommend that you change the tire specifications on the vehicle. Therefore, we would be unable to advise you further on your tire inquiry."
Obviously Daimier Chrysler was too lazy to look up the answer to my question.
Sounds like a little CYA happening at DCM. Their response makes sense to me as I'm sure Jeep's chassis and suspension engineers worked closely with Goodyear so the Jeep and the tires would work well together. Personally, I don't blame them for their answer, if only taken from the Explorer debacle perspective.
But its good info nonetheless.
dunlop sp a2's? are these performance tires?
WRT asking the tire maker for advice I would be wary. The best tire for you may not be one that they sell, but they would sure try.
Grand High Poobah
The Fraternal Order of Procrastinators
That is probably the concern of the vehicle maker. If they planned on the vehicle sliding rather that gripping, then at some point, with a sticker tire than what the engineers planned for, during a hard corner, the vehicle could roll.
The question is, how many lateral G's until it rolls, and can you reach that figure with the tires you are switching to?
My advice, if you are looking to improve handling, get something with a lower center of gravity
TB
With "sticky tires," onset of rollover will occur when the lateral acceleration is (L/2h)2 g's where L is the separation between the left and right tires and h is the height of the center of gravity. You can plug in the numbers!
tidester
SUVs; Aftermarket & Accessories
Assume the width of the vehicle is the value L.
To get to 1G lateral acceleration before the thing can roll, the value h has to be 1/2 L or about 36" off the ground. Since this thing has 8" of ground clearance and is about 72" tall as well.
Hmmm, I wonder where the c/g is of this vehicle?
For the earlier Explorers, the road holding index is listed as .69 to .7g's for the 2000 models.
These were Shorter than the current 2002's (67.5 vs about 72") and narrower (70.2 vs about 72")
So I really wonder if the new ones are less prone to rollover, given they are significanly taller, but not proportionally wider.
Anyway, using the formula given in the above post, and assuming 67.5 as the value for L, we can figure that the c/g of the 2000 Explorer is about 42" off the ground. Wow.
FWIW, 42" is just 6" shorter than a Miata at 48"
Ok, yeah I was bored
TB
The prices and services are all very similar. Does it matter in any other way where I purchase these tires???? All opinions welcome.
The car (and subsequently the tires) have 25K miles on them. The tread is wearing nicely, I expect another 25K miles, at least.
After reading the owner's manual, I'm wondering if I should take it to a tire dealer and have it patched instead. Any thoughts?
Has anyone moved from a touring or grand touring tire to an ultra-high performance all-season tire like the Pilot Sport A/S? How was the noise, ride, and handling? Any other comments on the Pilot Sport A/S? What about Pilot HX MXM4 vs the Pilot Sport A/S for this application?
-- Joe
Grand High Poobah
Of course, I never quite put the same amount of trust into plugged tires, figuring it must cause a little heat buildup or something. I usually keep it under a 100 mph after a plug. I also don't doubt it would slightly affect balancing.
Even at 30 mph you started to hear the tire noise. By 70 mph the steering wheel was even vibrating. Not severe like a a flat spotted tire or wayward belt but totally aggravating.
What's weird also was that rotating the tires had no effect on the noise/vibes and there was no tire cupping or tread feathering. The tread on all four tires were evenly worn. They looked perfect.
My son (principal driver) wanted to get more miles out the tires but I said no way after he took me on a highway cruise. Not only does it contibute to driver fatigue but it can't be good for the suspension and steering rack.
Went with Dunlop SP sport A2s based on tire rack survey info that in summary they are a performance tire with a quiet ride and decent light snow traction. I'm not quite convinced on the snow traction part because of the tread design but my perferred tire (Michelin X-one/plus) is not available in 215/60-15. It was immediately evident we got rid of the tire noise as we drove away from the tire store (more on store) and confirmed when we were able to get on the highway. (didn't have a chance to explore the Dunlop handling characteristics)
Got the Dunlops from Poor Freddie's in NYC (Jamaica, Queens?)for $80 apiece while passing through. That includes mounting and balancing but not tax. I figured that price (before tax) matched on-line prices when you factored in shipping plus mounting & balancing costs. Poor Freddie's is a big operation with all new Hunter balancing and alignment equipment. I'd recommend them if you live in the area. Say Hi to 'Junior' if you do.
My opinion is that they are nice LT tires for those who want a car-like ride and good 3 season traction (not the greatest tire in snow). The Michelin LTX M/S might last longer but they're more expensive. So I think the Dueler H/L is a very good value and a fine choice.
I just finished looking at options on this size tire and ended up ordering (ordered 8/13, got e-mail 8/14 they had been shipped already) Michelin LT Select tires from WalMart (245/70/16). Michelin makes X Radial LT tires sold only at Sam's Club, BJ's & Costco. Checking the specs of both of these at Michelin web site shows them to be very close to each other, but not identical and similar to the LTX MS Michelin. WalMart had these for $110.96 each. Sam's was about $123/tire. Lifetime rotation/balance, mounting, road hazard is 9.76, plus TN 9.25 sales tax should total about $528 at WalMart. WalMart has more locations than Sam's and was cheaper. ONLY drawback is they have to order them and delivery is 6-8 days.....so, if one has to be replaced, I will have to wait for delivery...both our vehicles has full size, real spares. BTW, our Grand Cherokee has Goodyear Wrangler SR/A 245/70/16 ($133 at Sam's) that have a lot of life left after 36,000 miles. I'm putting the Michelin's on my Trooper with 38,000 miles, replacing Bridgestone 684s that are not worn out, but have less tread left than the Wranglers. Plus, they have always had a little vibration at freeway speed...never been real happy with them.
Has anyone had experience with this brand?
Here's American's website: http://www.accconline.com/radials.htm
To me these tires are just like any other no-name tire brand. Some are good and some aren't.
Steve
After taking an 1100 mile trip last week I can report that the tires have met my expectations. They have very good handling, a nice ride and are very quiet. If anyone else is looking for an H-rated tire they should check these out.
http://www.tireadvisor.com
Here's an interview with the guy at Michelin who created Tire Advisor:
http://www.tirereview.com/tred6.htm
The biggest problem with plugs is that they leak. Not 100%, but often enough that they shouldn't be trusted at all!! The tire industry considers them temporary repairs. They should be replaced by a proper repair ASAP!!!
And anyone driving 100 mph on a tire that has been repaired by a plug (and doesn't know what damage is inside) is living dangerously.
A guy I have dealt with for years at a local tire/repair shop told me that plugging a tire could lead to eventual failure, allowing air or water to get into the interior and cause separation or corrosion. He said this could possibly be a reason for the dealer/manufacturer to deny warranty coverage. If you get a shop to repair the flat, there is not usually that much difference in pricing for plug vs. patch.
