Visitor Agreement.
I said they were not appropriate for road/only."
The "A" in "AT" means "A"ll. ALL TERRAIN. The poll was looking for a tire good for 90% road, 10% off road. What is so hard about that?
"AT tires are for road/off road mixed use, not road/only use."
So far, so good.
"Yes, you could use them but they would be a poor choice. Are you disagreeing with this?"
I think AT would be a good choice for the 90% on, 10% off road the poll was about.
"Point is, most SUV owners don't have "off roading" as a requirement, so they don't need A/T tires...how many SUVs come equipped with them?"
That might have been YOUR point, but not that of the poll or me. You can't change the equation half way through.
Sounds like a good choice. I was looking at those also. Also comparing to the Dunlop SPA2 things. I think I might go with the Dunlop because a local place will price match and they carry those, but not the other. I'll just bring in a TireRack printout.
Not so. When you said a tire good for 90% road 10% off road was good for your "typical SUV owner", you made it your point. But this is not productive (deja vu ;-) ), so I'll drop it.
The Sandman :-)
A front wheel drive car will exacerbate a toe in/toe out problem because the front tires are sorta twisting to propel the car forward. Suspension wear increases as well.
Where on the tire did the excessive wear show, inside edge or outside?
Here's an excellent article on alignment that might help shed some light on your problems. At least next time you're at the tire shop you can "habla" on the same level as the techs. http://www.mtdealer.com/ph_alignment_2002.cfm
Have you checked to make sure the roads you are testing on don't have ruts or crowns? That was where I really noticed it the most.
The rest was liveable for me.
Oh another thing about my Firehawks. I was skeptical at first after all that Firestone tire hoopla with the Explorers. The tire shop (makes sense to me) pointed out that this would be a good time to buy their tires since they're currently under the microscope. Have a good day..
Thanks again
Ken
http://www.garbee.net/~cabell/tirechoices.htm
http://www.garbee.net/~cabell/photos5.htm
"The XLs are 10.9" wide and are 38.7" tall"
"XZLs are a great tire for someone that want s an aggressive mud tire that doesn't howl excessively on the highway, and that wears slower than the XL."
"The 9.00R16 XZL is 36.5" tall and 10.3" wide"
"A program by Michelin for MVPA members to purchase military specification tires from their local dealers at discounted prices is described on the Michelin Tire page."
http://www.garbee.net/~cabell/michelintires.htm
And those old Dodge Power Wagons are awesome!
Did you miss this part: "XZLs are a great tire for someone that wants an aggressive mud tire that doesn't howl excessively on the highway, and that wears slower than the XL."
These are not exclusively offroad tires. HOWEVER, these are a little bit of a specialty item. They are more applicable to nostalgic trucks and SUV's than for more current SUV's, which are much better served by something like the BFG AT's.
That's not what bretfraz said...he said:
For those looking for info on what to use for off-roading...
This is the point I was making (or close enough, anyway).
A tire that is "not exclusively off road" is not the same as a "tire meant for on-road use".
The point is that the only reasons to buy an SUV tire that is good for "on-road" AND "off road" use is a) you do some off roading or b) you want to look like you do.
If you only use your SUV on road (most SUver's, IMO), there's no practical reason to buy a tire that is good for part-time off road use.
'For those looking for info on what to use for off-roading...'"
A tire that is "not exclusively off road" is not the same as a "tire meant for on-road use"."
Yes. It may not be for JUST on road use, but it is intended as a compromise, to give up some trail capabilities for on road manners.
"The point is that the only reasons to buy an SUV tire that is good for "on-road" AND "off road" use is a) you do some off roading or b) you want to look like you do."
OK, so what's YOUR point?
"If you only use your SUV on road (most SUver's, IMO), there's no practical reason to buy a tire that is good for part-time off road use."
For that matter, what is the practical reason to buy an SUV then? (IMO means "In My (your) Opinion", right? Then it is just that, your opinion. I don't see the reasoning in buying an SUV if you don't use it as such. You might as well just get a car, truck, or van then.
Don't take this the wrong way, but that's obvious. That statement doesn't address anything I said.
The only reason to buy a tire that is a compromise between on and off road use is if you do some off roading. Therefore, only those looking for info on what to use for off-roading (what bretfraz said) would be interested in those tires.
That's my point.
There's a different forum for that question. It's off topic here, and irrelevant to what we're discussing. 90% of SUVs never go off road and all of those need tires. Which means they probably do not need a tire that is a compromise between on and off road.
Was there a question in there? ;-)
Me neither.
In any case, I think most folks looking for SUV tires need tires that are exclusively on-road. Yes, that's my opinion, maybe I'm wrong.
BTW, I've looked back in this topic for a discussion of on-road SUV tires and didn't find any (I didn't check all posts), maybe I'll keep lurking until it swings onto that topic again.
Good day.
You mean car tires? Why not just buy a car?
I repeat. 90% of SUVs never go off road. At all. Car manufacturers admit this. I don't know what your point is in not accepting this, but it's true.
There are both good and bad reasons (IMO) to buy an SUV and not use it to go off road, but that discussion is OT here. In any case, the reasoning is beside the point...those SUVs need tires and not off road tires.
tidester
SUVs; Aftermarket & Accessories
Actually, sometimes the message gets lost.
And I appreciate your support.
and
http://www.high-tec-retreading.com/diamond.html
testimonials:
http://www.high-tec-retreading.com/testimonials.html
sizes and prices:
http://www.high-tec-retreading.com/sizes.html
TRAIL MASTER A/T
The Trail MAster A/T provides excellent rideability. This tire is a perfect blend of ice biting traction and quiet comfortable performance. For front and rear axel applications.
http://www.greendiamondna.com/products2.HTML#
Nokian.
these look like they might actually give it a run for the money, for a LOT LESS money!
ed
Tahnks in advance.
The Nokians I have are not all-season, they are snow & mud tires. They do generate more noise than summer tires, but due to the curved-v arrangement of the lugs, they aren't as noisy as any snow tires I've had in the past.
The ride and handling are maybe 95% as good as summer or all-season tires. No difference in fuel economy that I could notice.
P.S. Etires.com sells a number of different brands of tires and they call the NRW "the best tire we sell".
But I guess my new hobbies have worked out for me pretty well.
Though I do miss chatting with you folks. The other day I had some Pilot XGT-H4s put on my Jetta at Sam's club. I tipped the guy $10 and a Gatorade and he still screwed up the balancing. He thought the weights were marked in hundreths of an ounce when they were actually in grams, and he obviously didn't check his work with a re-spin. So after a wobbly ride halfway home and a U-turn I got to waste the rest of my afternoon waiting for them to re-balance my wheels. It just goes to show no matter how nicely you treat the "technicians" in your quest for professional service, sometimes it's like trying to draw water from a rock.
Well my wife is yelling that she wants to use the phone--yes, I have one of those old-fashioned 56K modems--so I better sign off before she comes in and sees that I'm on "that tire site" again and walks out on me.
I wish you all the best in your search for traction, longevity and good handling. GO MICHELIN!
--Chris Meixell
1stLt USMC
Naval Aviator #26719
Steve
- - Bret - -
Although we don't always agree, I respect you a lot Bretfraz. You've corrected me or informed me on things I did not know numerous times.
Just thought I'd take that moment. Now back to our regular programming.
Does anyone know if these tires are distributed in the US? They were in the process of getting their DOT approval.
Grand High Poobah
The Fraternal Order of Procrastinators
The original web site referenced shows them all.
Nobody on the DOT part of this original question?
