But, now I'm trying to find out the lug nut size on my Odyssey. Someone told me they were 13/16, but I know Honda is metric so that can't be right. I took out a 17mm (too small) and 19mm socket (rocks a hair when on nut). I'm thinking its 18mm.
Any thoughts on this? Don't want to strip those nuts.
all I can find on the net are the original Goodyears and I dont's want to replace with the same thing. Thanks
Tires really should be changed when ABOVE the legal minimum as 25-50% of their wet performance is gone when half worn and the hardening from continued vulcanization.
Tires in the lab are only tested to 8,000 miles!
http://www.cardecal.net/new_tires.htm
http://www.tirerack.com/tires/index.jsp
http://www.1010tires.com/
http://www.ustireoutlet.com/
http://www.tiresavings.com/
http://www.vulcantire.com/index.html
http://www.tiretrends.com/catalog2.php3
http://www.discounttiredirect.com/direct/home.jsp
I want something that will last, is of good quality, and will give me a correcting reading over and over.
http://www.valvelock.net/home.htm
"I checked with my Brother-in-law. He is a production engineer for a
company that makes those huge trash compactors that you see on the
back of trash pick-up trucks. Turns out much of his work is with
welding equipment which requires he work with pneumatic controls a
lot. He knew right away what I needed.
He bought me a high quality 4 1/2 inch round commercial type pressure
gauge (Winters Gauge #Q322 0-60PSI). He pointed out that the gauges
sold to consumers for tire gauges are class B instruments (at best)
with an accuracy 0f 3 percent full scale while the one he got me meets
ANSI/ASME Grade 1A standards (plus or minus 1 percent at any point on
the scale).
The 4 1/2 inch (compared to the 1.5 to 2 inch on tire gauges) scale is
wonderful to read. It has numerical markings every 5 pounds and the
tick marks go down to .5 pounds. The case is made out of 304 stainless
and appears to be very rugged......."
I'll be replacing some Potenza 040's on an IS300 wagon. Rims are very likely as well, as I'd like to widen the contact patch a bit.
I'll be looking at 235/40-17 up front on 17x8 SSR GT1s and 255/40-17 behind on 17x9s.
Don't have the space/time for switching to snow tires.
OEM Michelin Synchrones - Garbage in the snow. Vehicle becomes undrivable even in a dusting.
Anyone have experience with the Yokahama Geolandar H/T-S?
The next step is to swap the tires on one side. If the pull changes, then the tire that just went on the back is the culprit. If the pull doesn't change, the one still on the front is the one.
BTW, it is possible to develop a wear pattern in a tire that will cause a pull and after 15,000 miles, this is likely. You may or may not get any consideration at the dealer.
Hope this helps.
Matt
That being said, if I had to drive on I-95 down south where it is all concrete, I'd probably try the Michelin Hydroedge. Long Island and upstate NY, you'll find the Nokians on my car year round.
Michelin Symmetrys wore to the treadwear marks at 27K. Warranty to 65K. The set was rotated only 2x, and should have been rotated at least once more on an AWD. Seemed like premature wear similar to the OEM Bridgestone Duelers.
The original dealer here would not handle it. Said :"too much paperwork."
Another local dealer did. A call to Michelin took care of it, giving me almost 40% credit (much more than expected)for the worn Symmetrys towards a set of Michelin Harmonys (needs: good snow traction, all-season, good treadwear, good hydro planning resist). Michelin now has a bonded solid customer.
Some kind of real 'Customer Service' and response.
So far, the Harmonys work well on snow/ice.
Rotated at what mileages? 6, 12? 12, 24?
Just curious. Glad Michelin stands behind the
tire. I have them on LeSabre. I like my X-Ones better, but I'm concerned about long wear on the Symmetrys. I'm glad you're sharing your experiences.
Anyone want to weigh in on whether directional tires such as the GY Aquatread 3, Michelin Hydroedge or Nokian WR 2 would wear out prematurely on an AWD 1996 Subaru Legacy Outback? I noticed that the Subaru recommends front to back rotation and not cross rotation in any event.
Drive safely out there,
Matt
The Symmetrys were on an AWD 2001 Forester,5-speed.
Rotation was at 8900 then 19500 and 25500....my fault and admitted to the selling dealer and Michelin.
Tirerack's consumer reviews and ratings also show early wear.
I was still impressed with how Michelin handled the warranty---generous.
Tire rotation- I've had "directional" tires for most and just got in the habit of doing front to back anyway. Just make sure you get an alignment when you get the new tires and rotate at every oil change if possible (or at least every other pending you oil change schedule)
I had the Nokian Hak 1's on my Explorer that were awesome in the snow and was not sure if I wanted to stick with them or try the WR's. I opted for the hak 1's for the Sequoia for winter mainly because I knew how they were and if I was not happy with the WR as winter tires, I didn't want to be "stuck" with them for 50k of just winter use
I run studded Hakkas on my Mountaineer. The road noise is a little much but it turns an unsafe snow car into a safe one. In my opinion, the heavier the car, the more important the tires are.
On a ligher car like a 'Baru, I'd think the Nokian WR would be a great all season tire. I do Hakka Q's and Continentals on my VW for winter/summer and that's overkill.
My Hakka Q's worked fine after I had the brain-dead Nokian dealer remount one of the tires to make it rotate in the right direction. The morons mounted them as 3 lefts and a right. It was really noisy with one of the tires running backwards.
Either way, you and I have great winter versions of the Nokians, I think squeezedlemon would be real happy with the WR's for the weather he will in most of the time in Portland. They are a true All Weather tire.
p.s. They're forecasting ice cold for here the next couple days and about 4-6 inches of snow. I'm gonna leave the WR's on and make sure I go play before they plow! We had some black ice in the parking lot at work and I was still very impressed with how well these things grip. No problem starting or stopping while other co-workers were sliding away.
The Pilot is a performance tire. If you want sharper handling, more responsive steering, and better braking performance, its a good choice. Trade off is, of course, tire wear.
The new HyroEdge looks like a good tire and a sensible choice for cars like your Altima. Good wet weather traction and long tread life are its strengths, obviously. BTW, the 85K thing does not indicate how long the tire will last, just how long Michelin will warranty it for. Just like car batteries that say "84 months". The battery might die in 24 months but the mfr will pro rate the warranty based on the 84. Tires work pretty much the same way (see CAPEROSIER's posts about his Michelins to get an idea of how this works).
The Bridgestone is kind of in between the two Michelins. 60K treadlife warranty, a little sporty, good in the wet, a good overall choice for your needs, especially at that price. It gets my vote.
The quality in roundness and life pays off. My current XOnes are heading for 100K. They're quiet, grip great in snow without being a noisy rugged tread. I'm in Middle Ohio so snow can be a problem, but not a daily problem as in some more northern areas.
The Hydroedge apparently has replace the XOnes and the Harmony is a step down, but might be what I'd replace them with when they wear down and the car has 150K on it.
Last set of Michelins XH4s wore 110K and I replaced two so I could trade the car. The XH4 was great in snow because of the tread design and were a little hard in the rubber -- they were a high mileage highway tire.
The extra investment will pay off in the long run as long as the tire is what you need for your driving.
I checked tirerack.com's prices for the Hydroedge. They want $376 for the tires plus about $30 for shipping (and that is without installation, hazard warranty...) vs. Costco's $368 ($428 less $60 rebate) all inclusive except tax. I am not a big fan of Costco, but at least on this one, Costco has tirerack beat.
As far as the Pilot goes, I am less concerned about tread life because they will likely last the 40K or 50K miles (or less)I will put on the car in the next 5 or 6 years anyway. The better handling sounds great, but will the ride be noticeably harsher? What about rain and snow performance relative to the HydroEdge or Bridgestones?
I find the HydroEdge appealing because I live in CT and find that I end up driving in rain and snow more than ever. The cost is about $130 more than the Bridgestones. I am wondering if Michelins are worth it (since I was a kid, my father has been drilling into my head that Michelins are the best tires around) and whether this particular tire for this particular car given my needs is just overkill.
That is not true, I paid $5 S+H each tire and $10 mounting balancing and all other little things come with installation @ Cosco. So that make $15 extra.
I understant that tire to tire places have different prices. Costco didn't have my size and brand.
If you are referring to RunFlat tires. They are available and being supplied on OE some vehicles. The problem is they have limitations that many folks can't live with.
Hope this helps
The Sienna AWD owners suffer a bit of sticker shock when they have to replace a run-flat, but hopefully supply will help the prices to fall.
You're going to have to pick what's a typical day for your area and check pressures when the tires are cooled. I usually do it just at dusk. I put a pound or two extra in when I'm at the gas station, then check the tires in the evening at home. It's easy to let out a pound if I have them higher than needed.
Best gauge to use? My local tire store buys the stick kind for a dollar or so. They bring a new one into the shop, compare the two or three they use and throw out the one that's off the most.
They like the idea of replacement often rather than spending more on a fancier gauge.
