Visitor Agreement.
Comfort treads can easily do a 4/5 tire cross rotation also.
I suspect TR would suggest 195/55-15" for your car. I've had good results from Blizzaks that are narrower/taller than regular tires on skinnier steel rims (205/65-15 vs 225/55-16)
195/55 r15 are too small and leaves you with little choices in winter tires
Typical passenger car tires have a maximum load at 35 psi. Past interpretations of US regulations meant that 35 psi was what was supposed to be stamped on the sidewall. In the past few years there has been some re-evaluation of this, as well as some standardiztion between TRA and ETRTO.
What has come out is that tires that used to be stamped 35 psi max can now be stamped 44 psi. This really isn't a technical change (this has always been an acceptable practice from a technical point of view), it's just a different way of reading the regulation.
Most of the tire manufacturers decided to change the stamping as they changed molds. Michelin, however, either didn't react very quickly, or has chosen not to adopt this standard. This doesn't mean you can't inflate your Michelins to 44 psi - it means they are probably viewing the regulation a bit differently than everyone else. (Sounds like the French, doesn't it?)
Hope this helps.
it varies by like 3/4 inch out of 8 inchs in the standard camry size based on my parking lot measurenments.
More smoke and mirrors by the tire people.
Michelin told me tire width on the ground was not required by the government therefore they would not release it. go figure.
I checked on the Goodyear web site and - for my tires (Goodyear Eagle RS-A 205 50 17) they say I should cross the tires on the drive wheels. Which would mean I move the front tires to the back on the same side, and cross the rear tires to the other side of the car.
Anyone have any input -
Follow owners manual or tire manufacture advise?
I am assuming the Mazda III is a front engine/wheel drive?! If so it might be VERY similar to the OEM recommended rotation for VW Jetta (TDI) in my case. In the case of the Jetta (TDI) and Honda Civic, the static weight distribution is 60/40. So all things being equal which would tend to wear more? Front or rear?
I took exception to the VW OEM recommendations and do a five tire cross rotation.
I did this due to a number of factors:
1. 5 full sized tires/wheels
2. technical data that hints at different wear rates
3 longitudinal data that confirms it
4. more even and hopefully longer wear from tires. 125,333 miles projected, but extreme happiness with 85-95k.
On the VW Jetta in order of most to least wear : 1. RF 2. LF 3. RR 4. LF 5. spare (actually no wear but you get the picture) I keep records to serve as another data point for those folks (and others who are interested) who have posted their results (on another web site) whose write ups were helpful to me in my decision making.
The technical side is:
1. 5 tires each (at 10k rotation intervals) serve at the RF (and all positions also) as opposed to the oem recommendation of MAX of 2 (front to rear rear to front same side will = 2 tires) . So while the wear characteristic is the same it is spread over 5 tires vs 2
2 Cross rotation tends to more evenly wear the side to side "set" that a tire can take
3. Since we already understand the front to rear and vice versa condition, I skipped over this.
So in your Mazda III, if you decide to go with a cross rotation with 4 tires, cross the REARS because the rears wear least and you want to put the least worn tires in the position of most wear, i.e. RF. So on YOUR front engine rear wheel drive the dynamics are (different)and opposite of the front engine front wheel drive.
So at 47,000 miles on OEM GY LS-H tires, the measured remaining tread is 7/32 in for discussion sake.a tad more than 6.5 to 7.5/32's is the range) Since the tires started with 10/32- 7/32= 3/32 wear or consumed/47,000= 15,667 miles per 1/32. So projected consumption if I take it to 2/32 in = 8/32 x 15,667= 125,333 miles. The truth be told I'd be thrilled to get 85-95k!
The only problem - it is a lot more of a pain to cross rotate - I can Jack up one side of the car and lift both front and rear off the ground at the same time. If I cross I need to figure out how to put jack stands under a Mazda3.
The number of miles you are getting from a set of tires is fantastic - My Goodyears started out at 11/32 - after 10K they are down to between 6 and 7 (32nds) at this rate I will be lucky to see much over 20K. I normally replace at around 3/32 -
In fact, the shorter sidewalls and wider tread on the larger 18” wheels will probably significantly reduce ride quality and increase noise. Should I demand the smaller size wheel or is the difference not that noticeable? Surely, this car does not need a W speed rated tire.
My impression is the trend towards bigger wheels is driven mostly by looks not performance.
The H rated tires are at 130 mph. The problem will be you will not have to go too long or to far at 130 mph to get BUSTED!! So unless you routinely take it to the track, or God forbid street race, W rated tires (168 mph) might be almost total overkill.
I'll bet the 17" wheels won't fit, as brakes are usually enlarged at the same time.
And the speed rating? These vehicles are sold worldwide, so while the US can't go that fast, there are parts of the world that can! And more capability always equals more safety.
Since on the Lexus, one or the other is/will come standard, you can almost rest assured that either combo has been engineered for the parameters of the car. So if you indeed do have a choice (all things being equal) the smaller wheel/tire will probably offer better ride comfort. I have already mentioned that the larger tire will most likely cost MORE.
Of course, heaven help you if you do any damage to your wheels! Oem Lexus wheels are BIG bucks! Also since there is SO much aftermarket choice in wheels, you might want to make sure if you select aftermarket stuff, know the logistics behind repair and replacement.
here my driver profile:
I'm in Canada, province of Quebec where the roads are bad...
I am not an agressive drive
typically on highway I do 120 Km
20 miles a day max
I expect my tires to last 60,000KM or less, I don't mind.
BETTER RIDE COMFORT , actually LOWER NOISE COMFORT is more like it...
I don't know what my tires are and I HATE the noise they make.
the tread noise is very important for me. a little tread noise will drive me crazy
My car is not modified.
So what do you think I should buy for summer and winter tires?
anybody has some good internet links to views objective reviews about tire noise...?
TIA
stef, montreal.
The Danger of Dubs (Inside Line)
Next question. I was going to try the Bridgestone Turanza LH V rated tire as a good compromise between high performance and grand touring tire but apparently they don't offer a 245/40/17 or 245/45/17. Both MBZ rep and my independent mechanic recommend Michelin Pilot Sport A/S tires. They got good reviews on Tirerack but I would hate to shell out that much money and feel like I am riding on rocks.
Any advice would be appreciated.
If you can go 225/45-17 all the way around (should be okay, if you get all the same size wheels), there are a lot more choices... I don't even think you can get the Turanzas in both of those sizes...
I don't think you can go taller..
I have also put 56,000 miles on the GY Eagle F1 Supercars and 12,000 miles on Toyo Proxes T1's.(265-40-17, 295-35-18) So in your sizes I would say also the GY Eagle F1 D-3's are another great tire.
I really like the Toyo's for the balance between dry and wet handling. The Toyo's are much smoother than the Supercars but give up a little in dry traction. I would say the Supercars have absolutely fantastic dry grip, but will probably feel like riding on rocks to you.
1. Tirerack recommends Bridgestone Potenza G009. Are they great tires for these conditions? I can't go wrong with the price, and I'm leaning toward them at this point...
2. Does anyone (besides Goodyear) carry 185/60-15s? I'm looking toward name brands, and NOT Futura or Republic etc.
3. Any other Neon drivers out there with this predicament? What did you do?
http://www.michelinman.com/assets/pdfs/doc_harmony.pdf
I put those on my car and they are great in water and in snow (Ohio).
The price was good. There's a comparable tire Destiny at Tire Discounters and similar tire Agility at Sears. The Harmony had one step higher snow rating on Michelin's site.
I had SH-30 with my 98 Malibu, for about 33k miles. Great tires for dry pavement and outstanding for wet. Sporty. Do not hydroplane.
However, the tires were so-so in snow. Especially after 20k or 25k miles, with 6/32" of tread left.
I live and work in Connecticut, 2-6 miles from the Long Island Sound. Hilly terrains, winding roads, but not cold. Few snow on roads, but when it snows, the snow is very wet, heavy, and sticky. In addition, it melts and slips on warmer pavements. Very different from upper NY.
There is no sense to buy winter tires in our places. However, a lot of people who lives 50 miles farther from the ocean, in Northern CT, buys winter tires. Probably, even more sense to do it in the upper NY.
Nokian all-season tires from Finland are very popular in Scandinavia and Russia. Have a reputation to be as good in snow as winter tires. Personally, I have no experience with them.
http://www.nokiantires.com/newsite/tires_popup.cfm?id=6
I ditched two tires last month and got two with great tread for snow; that backs are 30%. I should have changed all 4 tires.
"If you are planning to replace tires before they are turning bald, it is usually possible to wait for a big sale and to buy a new set of tires at great discount, up to 25% ("one tire is free when you are buying 4"). On the other hand, if you are trying to milk the last 25% of tread, you finish up paying full price, or got smaller discount, if you are lucky. In result tires cost you the same, per mile, but during the last 25% of time are much worse."
Yeah, I did exactly that! I had 3/32 left on an SUV that I had just gone up to and came back from a record snowstorm and snow accumulations in the mountains. (Reno, NV) Absolutely positively no loss of traction!! I probably could have easily gone another half year, but they had a 60-70 dollar rebate off normally low prices, so I took the plunge!!
http://www.tirerack.com/tires/tests/bfg_gforce_sport.jsp
My wife and I decided to go with all-seasons, instead of high-performance tires, due to the fact that she'll only have that car for another 3 years (about 40-42k miles), and we DON'T want to buy another set. I checked into the Nokians at a couple of local dealers, and was blown away at the price! I'm sure they are great all-seasons, but they were a little too pricey for my wife's taste, and I couldn't talk her into them.
I then found the Michelin Harmonys at tirerack.com, and was impressed with the ratings and comments by others on their site. Both our previous cars had Michelins, and my current snow tires are Pilot Alpin PA2s (GREAT snow tire for my Mazda 6S, BTW) so I went with them, and saved a few bucks at tirerack compared to the local shops.
I'll let you know how they are when she gets them mounted and I get to drive it. Anything has got to be better than the Goodyear Eagle LS. They barely lasted 15K miles, and they are terrible in the rain and snow, no traction AT ALL!
http://autoshow.msn.com/as/article.aspx?xml=Michelin&shw=auto- show2005&src=autoshow2005Coverage
Pretty cool, huh?
Krzys
Just be extra careful, until the tires get warmed up (5-10 miles)..Once they warm up, you should be fine.. You'll still be safer than the other 80% of the public that are driving on worn and under-inflated tires...
Congratulations on the car.. I'm guessing that is the 3.0 with the sport package?
regards,
kyfdx
Yes. I probably only have 3 weeks or so where I will need to dodge the weather. Next year my son is off to college and I will have Grand Prix to drive in the winter while the Z4 sits in the garage. Thank you for all of your help in the various threads where you post.
Beating off the challenge from similar products from Michelin, Toyo, Yokohama and Pirelli, the V70A was given top marks for its uncompromising sports-orientated performance. The AUTO BILD testers praised the tyre for its excellent lateral and directional stability as well as its dry braking ability.
AUTO BILD is one of Germany's leading motoring magazines with a readership in excess of three million.
Nominated as the control tyre for several production car race series, the KUMHO V70A is available in some 27 sizes from 13" to 18" and in a choice of compounds.
Commenting on KUMHO's success, European motorsport manager Steve Thompson said: "The V70A is one of the most versatile tyres in our range and can be used for anything from tarmac rallying to hill climbing. This win proves what we have been saying for some time: the V70A is the ideal tyre for the serious track day enthusiast."
Click on the magazine image to download a pdf of the article (5.2MB)
Myself I'll stick with quality in the tires over advertising and car mags recommendations. You don't know how many percs are given at trade shows to gain those recommendations.
I don't drive my Buicks in competition much anymore so I really don't know how the quality compares, but I do know Michelin has given me round tires that stay round after 20K miles and don't need rebalancing often. Michelin has given me long life 100K on 80K tires (XH4s, XOnes). I stick with what works.
If I did drive much more aggressively in a sporty car, perhaps the grip factor in extreme driving would make a difference. But I couldn't get my new Harmonys to break loose on a typical dry snow in quick movements. Another good choice--for me and mine, IMHO.
Your free to get what you like of course but I'm just curious.
I've used 4 sets of Kuhmos on my cars and my son's cars, with the only negative being a little tire noise that developed after 20k miles on a set of 712s.
I have a brand new set of 285/60-18 Kuhmo STX truck tires in my garage to go with the OZ Nova ST wheels I just bought - they'll me mounted on my Dakota Quad Cab 4x4 tomorrow.
Michelins, I suppose, are the hallmark of tires, but 2 reasons keep me from buying them - Kuhmos and Dunlops are usually half the price, and I'll never buy anything made by a French company again as long as I live.
They have plants in the US building tires.
That's the same response I got about buying foreign brand cars from the foreign brand car group. When I commented that the profits (after all offshore billing and no tax states games) go to a foreign country, I was told they have salesmen, suppliers, haulers, dealerships with workers here, all making the money from selling them. I guess the same would go for Michelin.
Actually, I feel uncomfortable about French and Germans (and Russians). But Michelin tires are so long-lasting and true that I have to overlook that part. (I'm going to check the sidewall of my Harmonys for the plant code to see where they're built.)
I respect that other people have other tires that have served them well. I've found the Symmetry Michelins on the new LeSabre aren't lasting nearly as well as I'd expect (80000 mi.); otherwiese I've had good service from perhaps 44-52 Michelins I've bought since they had tubes in them in 1967.
