A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
My tires generally will lose grip long before the tread is gone. Perhaps I push my cars harder than the average driver, but for the price of tires, I keep mine 30-40k or 3 years or until I can feel the grip being lost. I drive the same roads day in and day out. If I feel myself losing traction on a particular turn, I can pretty much bank on the fact that I need tires and it's usually long before the tread is gone.
-mike
Motorsports and Tuning Host
On a more practical level, a good driver adjusts their driving styles and expectations, given the plethora of variables. So for example, I would do your SAME roads in anyone of 5 cars....
For example if I'm taking a particular exit ramp at 55 normally and then for 3 or 4 days I notice I can only take it at 45, all other variables being the same, I can pretty confidently say it's my tires causing the issue and it might be time to replace them. Being a race car driver, I drive very consistently, as anyone who races knows that it's not a single lap that tells the tale of a winning race, it is the driver who can consistently turn decent lap times that wins. So I carry this over to my daily driving routine as well.
-mike
You just said it yourself, race car tires don't have tread. So therefore, the tires get more slippery due to the compound of the tires deteriorating. It absolutely has nothing to do with tread, since, as you stated, race car tires don't have tread in the first place.
Tire compound and age notwithstanding, pathstar is still correct:
On dry road worn tires actually have better grip than new tires. Only when the tread is needed (on slippery surfaces) is it better.
Most of us aren't driving our cars like race cars and several of us here are talking about maneuvers like racing type driving.
I'll say that a person atuned to their car's behavior as tires wear, will determine that deeper treads on front may help them more; others may want the deeper treads on the back and assume the modifications to their driving style that shallower front treads mandate. I.e., I'm driving on tires with 4 years of age and about 30% of their tread depth. They have become noisier on certain textured concrete because of same. I am vacillating among putting on new Harmony tires and doing two only or doing none before out first summer trip of 350 miles early June. I accept that radical lane changes in rain won't be as grippy and that slowing down at the least amount of water on the road will be necessary if I continue with these tires and a partially worn tread> I have the deepest on the front.
Correct but then saying that a bald bias ply tire or a non-rubber tire with no treads would also be correct. It's just not a fact that is relavent in any tire discussion as the heat build up of a tire with no treads would destroy the tire and leave you in a far worse spot.
So if you want to talk about 1 particular aspect in a vacum including a CLEAN road etc. You are correct. This would be akin to saying a super narrow tire gets better gas milage than a "normal" tire. Which in a vacum is correct, however in the real practical world isn't a consideration.
-mike
Small price to pay to be safe. I not only follow this routine on my "performance" daily driver (Legacy GT Wagon) and my race-prepped car (94 Legacy Turbo) but also on my tow vehicle (04 Armada) and my trailers (Flatbed car hauler and triple axle boat trailer).
-mike
Funny thing is that when she has a tire issue, like this past December when she ran over a huge piece of metal which obliterated the tire and cracked an alloy rim, I get the phone call to drop what I was doing and take care of the problem. She just wanted to replace the destroyed tire and the other worn one on the same axle, but since the other 2 had only about 3k miles left according to the tire guy, I just purchased all four. I still got grief about waiting the 3 extra months to purchase the other 2, but we were already there and I knew I'd have that peace of mind with all the tires being the same brand and same tread.
The Sandman
-mike
1. Tread less tires on public streets/highways are illegal. (I'm sure someone may find an exception to this, but why?)
2. Slick tires may have more traction on dry pavement. Does that mean that the driver will only drive on dry pavement? (no rain in sight)
3. Once tread less or slick, I can imagine that tire wear will increase. How does one determine how long to long to drive on this type of tire.
4. Someone mentioned the expense of replacing tires to early. Early replacement is surely less expensive than replacing them to late. What happens when the accident investigator determines that "bald" "slick" "tread less" tires were a contributing factor to the accident? Can the driver receive a citation? Can the insurance company use this "failure to maintain minimum safety standards" or some similar term as a good reason to cancel the policy holder?
Yes these do exist, "DOT Race Tires" which essentially are race tire slicks with 2-grooves down the middle of the tire. But as you said you don't want to drive on them in Rain, Snow, Cold or and this is a big or, any kind of dirt, pebbles, or "road grime"
They are DOT Legal in name alone.
-mike
With that in mind, it's pretty much all about tread depth. Tread compound, whether hard or soft, is almost immaterial.
-mike
I still vote for the rear... (or from the rear?..lol)
-mike
Here's more fuel for the fire:
RR in bald tires is better than unworn tires, so the heat build up would be less.
Ok you are right, let's all ride around on bald tires. Whatever floats your boat.
-mike
At any rate, as the tread wears, you usually end up with more rubber on the road, hence more traction, except on slippery surfaces, and excluding ice, where more rubber actually equates to better traction. Better traction is due to the tread usually being wider the closer to the tire base you get. Tires are made this way to reduce "tread squirm". On a new tire, tread squirm can reduce traction as well. It can also result in tire heating. See below re racing on street tires.
Now some of you have alluded to "harder rubber". This is usually caused by heat cycling/aging. It is another matter entirely from tread "wear", but I suppose it should be taken into account.
It's true "racing tires" loose traction as they wear. It's not true street tires do. In fact, in racing classes that require street tires, the tires are usually shaved to reduce the tread to the minimum specified in the rules. Street tires loose traction only when they harden or you wear through the "good" compound rubber. This is a complex subject and I would grant Paisan some street tires will loose traction as the tread wears, but in my experience, most do not, again, on dry roads.
This is obviously a popular topic, judging by how many posts have been made.
I would attribute part of the perception to imprecision in written conversation. So as a result of wear, I do not think the "hard rubber" perception is as much as the rubber actually gets harder, but that there is actually PHYSICALLY LESS rubber!!!. An easy example: new tires starts out at between 10-14/32nds. Closer to legally bald (2/32nds) there is between 8-12/32nds LESS rubber.
While I agree somewhat with what you are saying, in racing what actually happens is that DOT Legal Race tires with an R-compound but treads will be shaved to the min depth allowed. The compound on these tires is still setup for racing and the heat buildup involved. My experience on-track with street tires is that tires which are more worn will heat up and lose traction quicker than new street tires. Here is an example, Watkins Glen International Raceway. My racecar was setup the same, similar weather, etc. In the spring, we went out with new high performance street tires on the car and after say 10-12 laps the tires would begin to get squirely and overheated. Same car setup in the fall, same weather, now with fairly used street tires but not bald ones, we could only get 5-6 laps out of them before they got squirely. We were also running similar lap times as well so we weren't pushing them any harder in the fall as opposed to the spring.
Now was this a result of the heat cycles on the tires or the lack of tread on them? I would argue that it doesn't matter because the lack of tread is inherintly going to go hand in hand with more heat cycles.
-mike
Put on Falken 512 last spring, and after 5,000 miles, the outer edges were worn. I know they wear quickly, but this is ridiculous. I kept inflated 2 lbs over recommended, and check of alignment says all is OK. My winters are not exhibiting such wear, nor did my Potenza's.
I'm getting credit for the Falkens, but I have to use it towards Goodyear, Falken or Dunlop. Nothing with Dunlop really excites me. So I have it down to either another set of Falkens or switching to the new Responsedge. The Goodyears will run be an extra $65 a pop.
Any thoughts?
-mike
Krzys
Krzys
Take them with a grain of salt. I found a few on there with excellent ratings that were actually prety poor tires. Often times folks get a new set of tires and they are better than their outgoing tires with 60,000 miles on them simply because they are new and get a false positive rating.
-mike
I second that finding about TireRack reviews. They didn't like some of the tires I was checking. Turns out they are excellent tires.
Within a reasonable range of the placard pressure, the risk is fairly low, but the further you get away the placard pressure, the risk rises fairly rapidly.
If you couple that with the fact that the first 5 psi over the placard has a larger effect on RR than the next 5 psi - then anything over that has a decreasing effect.
Besides, there is a good reason why tire manufacturers put a maximum pressure on the sidewall. This is all about risk. I would hate it if someone were to experience an impact failure at high speed and lose their life, just in the interests of saving a few bucks in fuel.
Funny!
Oh, and they're getting above 70 MPG, some way above. Just don't get caught behind one of these guys. They tend to drive slow most of the time.
Please don't judge all Prius owners by these guys actions. Most drive the cars "normally" and get 45 - 50 MPG avg or so.
Based on a half year of owner reports it appears that with the Prius, anyway, a tire that has good traction and feels in control will get poorer mileage than a tire most of us would get rid of due to poor traction. The Integrities are a good example. Poor in rain, lowsy in snow/ice. Not even confidence inspiring on dry roads, but good fuel economy. They are in constant search of LRR tires (low running resistance) - but ones that have some traction.
I think we need some more info.
Has the alignment been checked? If so, were the values "in spec" or right on nominal? Most factory alignment tolerances are too wide. Plus it is possible for a vehicle to leave the factory with misalignment.
Did you rotate your tires regularly? Front tires on a FWD wear 2 1/2 times faster than the rears. Plus certain driving conditions can cause the front tires to wear the shoulders more rapidly than the centers.
What was the wear pattern? One sided wear, center wear, etc?
What about inflation pressure? Low pressure can cause tires to wear prematurely.
How many miles do you get from a set. And why are we talking about 4th and 5th? Shouldn't we be talking about 3rd and 4th?
All these will help diagnose what may be going on.
Plus how many
* The new vehicle weighs more. It is surpising how much weight can be added between model years in what appears to be identical vehicles.
* The new vehicle has a "tighter" engine and the fuel economy will improve as the engine loosens up.
But since this is a Tire forum, I'll talk about those.
* New tires have higher RR and worn tires, even if they are otherwise identical.
* OE tires tend to have lower RR values than replacement market tires.
* I noticed that a 2006 DTS came with 2 possible tires - a 17" S rated and an 18" H rated, where the 2004 Deville only lists a 16" S rated. Larger diameter rims weigh more and will consume more fuel, plus higher speed rated tires will consume more fuel.
So to directly answer your question, yes, more tread and wider tires will be part of the answer, but I suspect it isn't as much as you think.
And you should be prepared to take another hit when you buy replacement tires.
If you increase the wheel size (say 15" to 17") the wheel gets heavier, generally. But if you keep the overall diameter the same by going to a lower profile the tire gets lighter.
So as we increase wheel diameter and decrease profile do we have a "valley curve" in overall wheel+tire weight? That is, is there an "optimum" size where the combination weight is lowest? Is there any way to guesstimate where the minimum weight would be?
I'm just thinking in terms of minimum overall weight for max. performance of the suspension, and improvement in performance of the car.
I just purchased a Prius, and here in Edmonton Alberta, with six months of winter, I'll be putting "proper" all-season tires on the car this fall. Probably Nokian WRs. I'm thinking of purchasing 16" wheels for better handling (European and Japanese Prius have them), and possibly slightly wider tires, for a little more load capacity to increase safety on our pothole strewn roads. Keeping overall diameter the same, of course.
Of course, dedicated snows are the ideal and if/when I buy a RWD car more than likely I will have a set of mounted snows just waiting for December to roll around. However, I consciously choose FWD for its advantage in the white gold (snow). I'm a lifelong New Englander/skier/FWD driver. I've done quite well (until the Bridgestones that came with the TL...!) with FWD/All Season tires and, in the latter few years, assorted electronic assists (e.g. Traction Control).
So, as long as I ride FWD, I would prefer to run on one set of tires that have a decent grip in the snow (realizing full well that they are not snow tires). Hence my query.
The Continental's have indeed gotten good reviews by consumer's on The Tire Rack site. But in comparison test, other tires have outperformed overall, the Conti's are rated best in the snow by the consumers, but not tested by Tire Rack in the snow (that I've found yet). If, for example, the Kumho's are higher rated in every category (again, by the Tire Rack tests, e.g. categories including wet & dry handling, comfort, noise...) that would pertain to 95% of my driving, I would like as much real-world review of their snow capabilities as I can find.
OTOH, none of the tires I'm consiering as replacements can be worse than the Bridgestones in the snow, can they? And note, that even with the Bridgestones I have survived two winters without incident due to winter driving skills, FWD, electronic aids and luck. Note that when it's time to head to the mountains of Northern N.E. the TL stays home...!
Thanks for the reply, I've heard nothing but good stuff re: Blizzaks.
If you're riding the Conti's, how are they as far as noise and ride comfort. Wet/dry grip?
My local tire shop pushes Toyos and frowned when I mentioned Kumhos (they don't sell 'em, could be why!?). Given the Kumho Ecsta ASX write up on Tire Rack, and consumer reviews, they sound like a bargain...
You started down the path, but didn't complete the journey.
If the rims are larger diameter, then the difference in weight will be - all other things being equal, which they usually aren't - the difference in circumference plus the difference in the "spider".
For the tire, the difference would be the 2 sidewalls.
So guess what happens to the weight? Larger diameter rims (and tires) will always weigh more - all other things being equal - and this doesn't count that the tire (and rim) needs to be wider in order for the load carrying capacity to be the same.
So to answer your question - there isn't an optimum value except to say that smaller diameter rims would weigh less.
And I think you'll find that if you change the rim diameter and keep the overall diameter the same, the load carrying capacity is also the same, even though the width of the tire changes.
