Tires, tires, tires
1115116118120121149
  • pathstar1pathstar1 Member Posts: 1,015
    Ok, your evaluation makes sense. Of course if I'm purchasing new wheels, I might be able to get lighter than stock ones, but it's hard as most manuf. don't list the weight on the charts. So I guess it's "thanks for saving me money for new wheels". ;)
    I did check the load index vs size, hence my question in that area.
    Stock wheel size is 15 X 6 JJ - stock tire size P185/65R15
    I can get stock size Nokian WR 185/65R15 with a load rating of 88H - 528 revs/km.
    I then looked at a slightly wider tire Nokian WR 205/60R15 with a load rating of 91H - 523 revs/km.
    Not much difference in dia. but higher load rating, and maybe better handling. Both have a higher load rating than the OEM tires, Goodyear Integrity 86S.
    Our local tire shops no longer like to move up in size a bit. Any reason for this? Would the 205/60R15 WRs be a reasonable change? It appears they will fit re suspension components and fenders. The European cars and the US Touring model come with 16" wheels (16 X 6 JJ) and P195/55R16 86V tires. I wanted a Touring, but it's not sold in Canada.
  • ilaveoilaveo Member Posts: 26
    There is another consideration to do with wheel diameter that you left out. The larger diameter rim's larger rotational inertia (weight further away from the center has more "leverage") requires more energy to start and stop. I have that observed cars that place more emphasis on energy efficiency like the Prius tend to have smaller diameter wheels.
    There's very little difference in the two tires sizes you mention....you'll have a .9% speedo error, meaning at 60 mph on the speedo, you will actually be doing 60.5 mph.
    Pathstar1,
    You have to be really careful where you get data from.
    For example: A P185/65R15 has a nominal diameter as set by the standards organization of 24.45" and a Load index of 86. A P195/60R15 has a nominal diameter of 24.21", and a load index of 87. A P205/60R15 is 24.69" and 90.
    The point I am trying to make is that actual tire diamensions can vary quite a bit and you have to access the source documents to be able do these comparisons correctly..
    You've also gotten tied up in the difference between US based tire standrads and European tire stadnards - which confuses things some more.
    I know that's not much help.
    Well, my diameters for the Nokian tires should be ok as I got them from a Nokian tire chart.
    I wondered if the "P" would mess things up. All stock tire specs are from the Canadian/US Prius owners manual. They have the "P" in the spec. I'll have to check the tires on the car to see if the "P" is on there too.
    The Nokian WR 185/65R15 is 24.4" dia. and the Nokian WR 205/60R15 is 24.7" dia., from their chart on Nokiantires.com, so those match your specs. I wonder if Nokian are just leaving off the "P"?
    I understand there are fine details to consider. That's why I'm starting now. I don't plan to change the tires until Fall, when I need to for our 6 month winter.
    Pathstar1,
    "......Well, my diameters for the Nokian tires should be ok as I got them from a Nokian tire chart...."
    May be I wasn't as clear as I could be. When dealing with theoretical values, you can discuss fine details. But when trying to sort out small details, using data that tire manufacturers publish may contain contradictions that can lead to confusion - and I think is happening here.
    The "equivalent" for a P185/65R15 would be a P165/60R15, not a P205/60R15.
    The European sizing standards don't call for "P"'s, and Nokian being a European based company more than likely is using the European system.
    But for practical purposes, these 2 systems result in interchangeable tires if the same "size" is used.
    In other words, it is OK to use a P185/65R15 in place of a 185/65R15 and vice versa (with a few exceptions.)
  • bremertongbremertong Member Posts: 436
    THANK YOU ALL FOR YOUR INTEREST AND ANSWERS! Some follow up information: I run the tires on 34 PSI, the tires are 17" S rated. Cadillac did some tweaks to the engine and drive train in the 2006 DTS vs 2004 Deville, this could have something to do with the fuel efficiency. The matter about engine burning in may also be a factor in that the car has less than 900 miles on it as of today. My 2004 Deville was an Enterprise lease return and never had quite the power that his car does. It has been suggested to me that the car rental companies put governors on their cars to limit performance, this might have made the 2004 more fuel efficient.
  • okko1okko1 Member Posts: 327
    not a real fan of the bridgestones that came on you car is this the first awd tl you have owned. i have a front fwd car and it has pirelli russo tires on it i am not impressed with there snow traction either. i am familiar some of the brands you have named. but having been 15 years in the business i know what was good yesterday may not be today. you might check out goodyear eagles they have always been a standard by which other tires can be compared some of the hype around these imported tires is misleading often times these tires are designed to run under very different condition than those found stateside please let me know what you do and you how rate your choice as it will help to better serve my customers thanks
  • laurasdadalaurasdada Member Posts: 5,181
    Thanks. I probably won't make a decision until the fall...
  • mrgammamrgamma Member Posts: 1
    Is there any benefit to inflating my tires with Nitrogen?
    There are some benefits to using nitrogen, but there is an awful lot of "hype".
    Benefits:
    Increased resistance to ozone degradation.
    Decreased leakage.
    "Hype":
    Better wear - This is because you lose less pressure over time, but you can get the same result by adding air when needed.
    Better fuel economy - Same logic
    If you can get it for free - great.
    But if you have to pay for it - probably not worth the price.
    Will running tires at higher pressures than the recommended
    pressures shown on the door frame of my cars shorten the life of shock absorbers and suspension. Door frame of Lincoln Towncar says 32 PSI front, 35 PSI rear, am currently running all four at 35 PSI. Cadillac DTS says 30 PSI all four tires. Seems most folks at service facilities set them at 35 PSI and tell me the tires will last longer at 35 PSI than the car manufacturers recommended pressure.
    Think it might be more expensive to run the tires at higher pressures and shorten the life of the other components. Any information on this will be appreciated.
    Operating tires are slightly higher pressures, will have little effect on a vehicle or vehicle components, except to say, the vehicle will ride slightly rougher.
    However, the benefits of longer tire wear are real and probably outweigh any negative effects there might be. Not to mention that your fuel economy will be better.
    So the net effect is that it is cheaper to run tires at higher pressures.
  • tankbeanstankbeans Member Posts: 585
    Hello everybody-
    This may sound really dumb, but at what tread depth should tires be replaced? This car, a 95 Accord, is the first I've had for more than 7 months and is the only car which I've had to think about putting tires on.
    Also what are good tires for this car? Right now it sits on Goodyear Eagle GT-HRs and it rides pretty nice. Should I just put the same tires on or are there better for about the same price.
    I've gone to the websites and just get downright confused. Once again I don't want to sound dumb or anything, just trying to figure it out.
    Thanks for any responses.
    P.S. Right now they are all sitting about 6/32 as of the last time I had my oil changed.
    Also, I am primarily looking for all-season traction, but since we have a decent amount of snow here in winter some good snow traction is also on the want list. Maybe someone could come back with tires they've had either really good luck with, recommend, or really bad luck with, stay away from.
    Again thank you for any insights. I've done the penny trick and am wholly incapable of coming to any conclusions from it. The tread goes just up to his hairline,top sliver of the forehead, when he is upside down.
  • jipsterjipster Member Posts: 6,296
    They should be replaced at 3/32 (you see the top of Lincolns head on a penny inserted into tread)... or with signs of dry rot.
    jipster's absolutely right, but I always advise 4/32nd to give you some time to shop and install and budget, etc. At 3/32 you are technically "safe" but just barely.
    In other words I'm pretty much worrying about nothing and that I should be able to wait until next spring?
    Noooo....at 6/32nd you'll wear out faster than next spring I think...I'd think Fall is about it for you. That's usually wet weather and a good time for tires and wipers and a major service.
    Actually the best is to get a caliper, (more expensive) or the el cheapo, available at WalMart tire measurment gauge. Most folks don't have a clue! So kudo's to you to even talk this way.
    Once again thank you for telling me these things. As I haven't been driving for all that long I still need to get answers from people who have been there before and have needed to replace tires. I know that my parents were never really all that good at replacing tires on time anyway.
    Do you think that I should stick with the goodyear eagles? I was kind of glancing through the discussion a little earlier and people were saying that the eagles are good tires and a basis for comparison. I know nobody can make the decision but me, but ideas and advice is always nice.
    Thank you for your time.
    OEM GY LS-H's are almost universally vilified on the VW Jetta. They are rated #3 by folks and probably only because there are only three oem tires: Michelin Continental . They are a VERY distant third place (if you know what I mean) :) most folks say oem tires per se are not the "BEST" and most folks might see 40-60k MAX.
    However, I am going on 94,000 miles and using the caliper and the el cheap tire gauge I recommended in an above post, I project a min of 100 to 125k out of these (literally third rated) tires. It probably bears mentioning while the wear is almost dead even across the tread, it has not had an alignment in 85,000 miles and indeed the aligment was only checked under the 1 year or 12,000 mile new car warranty period. So in reality, it has not had an alignment in 94,000 miles. I follow the oem recommended 10,000 mile rotation schedule, but differ in that I cross the rears, and the full sized spare has always been in the mix. I also run on a 44 psi max sidewall tire 38/36 psi. All the best to you.
    I think you could shop around and get reviews of tires on places like www.tirerack.com and come up with better choices than Goodyear Eagles.
    How expensive are the tires you just mentioned? I don't want to be a pain, but getting information is always a good thing.
    I appreciate all the time people spend answering my petty questions. It really helps a great deal. Trying to get the best price and tire so as not to wind up in a ditch or worse, smashed into a cement divider on the highway. In MN it happens more than I'd like to believe.
    Thanks for all your help. Everybody.
    You mean how much would a REALLY GOOD tire cost you, as opposed to a mediocre Goodyear Eagle? Gee, I dunno, maybe $75 bucks a pop? These would be an improvement, a better tire, but not the "best" tire you could buy, of course. Some tires cost $250 each!!!
    The best is to look up tires in YOUR size and see if it looks in the ball park for your oem size.
    You're in Minnesota? If you want -good- all season tires, I'd recommend Nokian WR. Good on warm dry summer roads, great in rain, and fine in snow and on ice. They do not wear out rapidly on warm dry roads. They're not sold by Tire Rack, so you can't use that site to compare them. Shop around, you've got time.
    I was looking for tire ratings today and found a gash about
    three inches long on a rear tire. I took the car in to a Les Schwab tire store (west coast chain) and asked them to to check. Response was looked okay in that there was no bulge in the tire or interior material showing from the gash site. While the response seemed reasonable I am not quite comfortable to just leave it at that. The surface rubber was penetrated, depth of the cut difficult to assess
    but not very deep. Was reading a tire brochure recently and it said any sidewall damage needs to have the tire replaced. I have owned this 2005 Lincoln Town Car for about a year and the gash may have been there at the time of purchase or happened recently. Any general evaluation guidelines and advice appreciated.
    sidewall injuries can be very deceptive the value of your car and safety is worth much more than the chance of the tire failing i have seen dramatic tire failure due to water infiltration which often can't be seen or detected by common means i would replace the tire
    Thanks for your reply, I was told by a tire person at Costco
    wholesale that unless I saw white substance from the inner part of the tire I should not be concerned. The car is garaged most of the time and not driven long distances in rainy weather so having the inside of the tire get water logged is possible but not to likely. My Lincoln dealer also sells tires and will have them look at it and give me another opinion and if needed replace the tire. I tend to think as you do that risking life, safety and an accident is not worth the risk. I am suspecting that this gash was on the tire when the car was purchased with 15,000 miles on it, just never noticed before. Other opinions on my question also welcome.
    Evaluating tire damage over the internet - even with the benefit of a photo - is difficult. It's a lot like doing surgery over the phone.
    Theory: Sidewalls consist of three basic parts -
    Innerliner - a thin layer of rubber on the innermost part the tire that is designed to retain the air pressure. It is made of a different type of rubber - usually a butyl - than the rest of the tire. This part of the tire must not be damaged in any way or the air will leak out - and more importantly - leak into the plies and cause a separation.
    Plies - A series of parallel cords that are the main structural element preventing the tire from exanding to the point where the rubber starts to crack from over-extention due to inflation pressure.
    Protective rubber - a relatively thick layer of abrasion resistant rubber that protects the structural elements.
    So if the cut/gash doesn't reach the plies - so far so good. The plies aren't always white. but they will always look like fabric.
    If the cut/gash is circumferential and about 1" above the rim line - even if the plies aren't exposed - this usually means impact damage and usually you can see the damage to the interior surface if you dismount the tire.
    The same is true for a circumfertial cut/gash within 1" of the tread surface. This area is sometimes called the buttress.
    If the cut/gash is radial in direction, then it is important to see how deep it is, because it is possible for the cut to miss the plies, and still be a problem. The protective rubber is generally a 1/16" to an 1/8" thick.
    The only remedy for sidewall damage is to replace the tire. Repairs in the sidewall tend to fail and they tend to fail at high speeds - very dangerous!
    Thank you very much, it may be difficult over the internet but you have done an outstanding job in my opinion! I now have a much clearer picture of the tire structure and as a result will be able to get a few more evaluations from people who work with tires such as Les Schwab, Costco, and finally my local Ford dealer who also sells tires. The tire person at Schwab said I'm okay, when I looked at the tire today after spraying and cleaning yesterday I could not see the gash but know it's still there. So far as I can tell the gash did not reach the piles but think it is part or all the way through through the rubber. After getting the two further evaluations I refer to above I will make a
    decision. There is not very much high speed driving around here in that most roads are 55 MPH speed limit with a few at 60 MPH. I tend to take a cautious approach to these safety issues so if even one of the three e valuators suggests replacing the tire I will probably replace it. Thank you very much for helping me to do the evaluation process. I will do a follow up post when I reach a final decision.
    When tire fails you may find out that 55 mph is fast enough to have problems.
    Krzys
    As previously mentioned I have now gotten the three evaluations from the three retail tire outlets. They all said new tire not needed. The last evaluation was done by
    a person with over ten years of tires sales and installation. Most convincing was, he stated that he had taken training in tires at a Michelin facility. He referred to the damage as a scratch and said that the tire would give full life if I did no further damage to the same three inch surface affected. He also said that the damage did not look like a knife cut, which of course made me feel better
    in that I live in a small town and don't want to think that I need to be concerned about leaving my car parked during the day while I do errands. I am a great believer of the unsinkable Titanic theory that almost anything is possible and even after these three evaluations that there is perhaps a small chance of a failure. I will watch it for any further detioration.
  • yurakmyurakm Member Posts: 1,345
    My car behave strange after new tires were installed two weeks ago.
    First, it became "jumpy" at highway speed. There is an impression that wheels lose contact with the pavement for split seconds.
    Second, and more important, it does not want to turn. On winding roads where I drive every day after replacing tires the car wants to leave a lane, either to shoulder / barrier, or into cars on the other lane. I have to turn the steering wheel substantially more than usually did on the same roads. I feel it at speed higher than 40 mph. At 75 mph. I have to lean and turn my upper body for remain on highway. Just dangerous.
    The new tires are Bridgestone Potenza G009, performance tires that have very good reputation. Previous tires were Potenza 950.
    My wife and I drive cars of the same make and model, Buick Regal GS. Her car still has original Goodyear Eagle LS tires, in marginal condition. We switched the cars to compare. I feel that her old tires still drive much better than my new ones. And she also confirms my impressions: said that almost hit a car on next lane today on a road turn. And the car jumps unusually on highway.
    Is it possible that a technician installed the new tires wrong, or messed up with alignment?
    The first things you should do are:
    1) Check the tire size and make sure they are the same - both within the vehicle and between vehicles - and that they are the same as what came off.
    2) Check the tire pressures. Most of what you described can be cuased by inflation pressures that are way too high. BTW the proper tire pressure is listed on your vehicle placard, provided you are using the same tire size listed there.
    3) If that doesn't change anything, try swapping tires around. First try swapping the front tires - side to side. Any changes? Then the rears. Then one side - front to back. Then the other side. All this should start to form a picture if there is a single tire that is causing all this.
    Try that and report back with the results.
    yes it is possible did you have the car aligned when you had the tires installed. it is also possible that in the process of lifting the car something was damaged. has the steering wheel changed positions at all
    Thank you very much!
    I would never think about wrong size. However, the size turned to be right, 225/60-16, the same as with original tires and with my previous tires. The tire pressure recommended by the manufacturer is 30 psi, but I usually inflate my tires a notch more, to 32 psi. Did with old tires and did it the first thing after the new tires were installed (Firestone inflated them all different, between 30 psi and 33 psi on different corners). Re-checked today: after a short 3 mile drive it reads 33 psi in all tires.
    Cannot swap wheels side to side because the G009 are directional. I am going to ask Firestone to check again the installation and especially the alignment.
    Otherwise the tires are rather nice: feel very soft, driving smooth on all the cracking and potholed local road, and are very good in rain / on wet pavements. Only two problems: imprecise when following road curves (need more steering than usual) and jumps on every small pavement imperfection. The steering problem starts at 45-50 mph, and is much more pronounced at highway speed. Bouncing is mostly on highways.
    The both problems are important to me. My daily drive is 48 miles each way, mostly on highway, but also on a winding local road where people drive at 45-50 mph. For those who knows the places: CT route 15 between exits 60 and 34, and Washington boulevard in Stamford.
    According to invoice, alignment was checked. I bought a lifetime alignment with my previous tires at Firestone, and they are checking it with every tire rotation. Firestone even provides a computer printout of the alignment each time. They caught a misalignment once and fixed it.
    However, Firestone failed to provide the printout when installed the new tires. Strange...
    I did not notice any changes in a steering wheel position. Also, the car needs more steering input to the both sides, right and left, when following road curves.
    A wild idea is a change in steering assist settings. One of three settings can be set by dealers. But I would start from re-checking alignment.
    if they give you printout for the alignment send it to me and i will review it for you. sometimes slotting of the strut bolt is needed to correct alignment this can be a little tricky to do also tread value on the new tire is high and should improve with additional heat cycles thru normal use
    Yes, it looks as the problem was with alignment. A Firestone technician either forgot to check/adjust the alignment when installed the tires, or did it wrong.
    Weekends a busy days at Firestone. It is somewhat hard to find a place on their parking, and technicians works on cars in all 9 bays. There were three service advisers and the shop manager at counter when I brought the car to them today. I just started to explain the symptoms searching for the right wording (English is my third language), when all four of them answered in chorus: "Alignment!"
    According to the computer printout of alignment made today, two parameters were out of spec: Front Right Toe was 0.22 (the normal range is 0.15 to -0.05 degrees) and Front Steer Ahead was -0.08 (the norm is -0.05 to 0.05 degrees). Adjusted to 0.01 and 0.04 respectively. Also, Front Total Toe was adjusted from 0.27 (marginal) to 0.11 (a middle of the normal range).
    I will see next week, during my long commute, if it fixed all problems. After a quick spin on highway my impression is positive already: now driving the car does not feel odd.
    good deal to much positive toe and camber tend to lend to under steer until a sudden move in the direction of steer a little negative on left and a little positive on the right with about a half degree more caster on the right should make for comfortable steer control under normal conditions.every vehicle has it's own personality you can ask the capriracer sometimes you have to try everything before you find the answer. keep on it till it's right
  • mazda6iguymazda6iguy Member Posts: 365
    My brother has a 2002 Ford Focus ZTS 4 door. The OEM tires were Firestone. It's time to get a new set of tires, and my brother tells me it will have to be Goodyear or Dunlop (he get's a special family discount because his father in law is a Goodyear retiree). Which Goodyear or Dunlop tire can anyone recommend? Size is P205-50-R16. All season tires a must. Opinions? I'm not familiar with Dunlop tires, so not sure what to reccomend.
  • mz6greyghostmz6greyghost Member Posts: 1,230
    If he's limited to Goodyear or Dunlop, then I'd recommend either the GY Eagle GT-HR or the RespondEdge. The Eagle is more of a high-performance tire, the RespondEdge more of a touring tire. I'm not a big fan of the Eagles myself, but the GT-HR isn't too bad, at least compared to the miserable Eagle LS and GA models that I've experienced.
    Thanks. The dunlop website is suggesting the Dunlop Sport SP5000. Goodyear website, like you, is suggesting the GT-HR and Responsedge. I think it will be the GT-HR he ends up with, but just for my knowledge, what other brands/tires could you suggest?
    For all-seasons, on price alone, I'd take the Kumho Ecsta AST. They're not bad for the low price. Decent wet and dry traction, but snow traction is a little low for my tastes.
    Overall, I'd pick the Bridgestone Potenza G 009. A friend of mine has them on her Jetta GLI, and short of snow tires, she claims to get excellent traction in snow, as well as great dry and wet traction. She's got close to 35K miles on them, and they still look as good as new, with a lot of usable tread left (not just legal, but actually usable, which is a big difference in my book).
    Good luck with whatever your brother decides.
    OK, tire forum guru's, need the final concensus here... Bro is going to buy tires tonight.
    I'm not a guru or anything. I just know that I have the GT-HRs on my car and they seem to be holding up fairly nicely. I'm not sure how long they've actually been on the car, but my guess would be around 40,000 because I alone have put 20,000 on them since I bought the car a little over a year ago, and it looked like they had been "broken in" when I got the car.
    They still have a decent amount of tread on them. I am planning to replace them soon, but otherwise they are good tires for me. I'm not easy on tires either. I tend to take corners a little on the fast side and drive at or above 80 a fair percentage of the time. In light snow they are pretty good, but like any other tire when there is a lot of snow on the ground all bets are off.
    Hope this helps. Just thought I'd share my experience.
    As for the LS tires which my mom has. I couldn't really say. It seems like the traction control on my mom's car goes off relatively easily even on dry pavement when there is only the smallest amount of grit. I don't know if the car is just touchy or the tires aren't gripping like they should. Well I don't want to have this go on too long. Hopefully this will help.
  • blufz1blufz1 Member Posts: 2,045
    Goodyear Assurance triple tread or Assurance comfort tread.
    Thanks, Tankbeans for your insight. Eagle GT-HR's it is...
