I've done a search, but I wanted to make sure I have this right. I have a 1998 Trooper S, 4wd SOTF variety. I am about to buy Old Man Emu SHocks, and my mechanic tells me that the N15/N65 part number designations are for either 1997 and prior Troopers and/or a generic shock number, so...What I want to know is, which goes where, N15 = front? N65 = rear? and they do in fact work on a 1998, right? And these "expedition" springs...they can't find them. Are they the heavy duty ones? Stiff?
Thanks in advance,
Jim
http://www.arbusa.com/old_man_emu_suspension.htm
More:
http://www.rocky-road.com/trooper.html
http://www.drivetrain.com/EMU/emutrooper/emutrooper92_02.html
http://www.expeditionswest.com/vehicles/ewvehicles/Isuzu_Trooper/
http://www.4by4connection.com/omesuspensions.html
I hope none of these is considered to be a competing discussion, cause if they are I'll get a note that my message didn't post, and you all won't get to check out these web pages. Do a search in your favorite search engine for "Isuzu suspension OME" or since OME is Australian "Jackaroo suspension OME" becasue down under the Trooper is really a Jackaroo.
Do not fear the medium stiff shocks are quite mild when going down the road, read about low pressure nitrochargers on the web pages above.
These are fantastic shocks...at least I have found them to be. Far better than stock.
rocky-road.com and 4x4connection.com will match prices (at least they were willing to a few years back, so call around.
Ask a Trooper mechanic and this discussion how much petrol can be tollerated in with diesel fuel. If might be OK to have a little petrol in there.
http://www.nitrotruckwheels.com/sfImages.large/78.jpg
Stock offset is about +40mm. I did find some that were +20mm. The Nitro's are 0mm. I went with 16/8 and 255/70-16 and Toyo Open Country ATs. Good treadwear rating of 500/a/b, so we'll see. The rims and tires come right to the edge of the fender flares when looking from the top.
I was concerned that the lack of offset would push the tires out too far, but it looks and handles fine.
I almost went for 17's as I can get 245/65-17 in a traction / off-road type tread. The 255/70-16 and the 245/65-17 are right at stock diameter. I went with stock height for gearing.
I've had 265/70R16's on there since last week. I like them more and more. I have noticed that from ten feet away the G051's look like they have a sporty tread with noticeable lugs, compared to the LTX M/S that look like highway only rib tires from ten feet away.
I have become used the the feel of the new tires and I like it well enough. I still think the Revos offer better road feel and tighter handling, but I wonder if that was because my Revos were down to the wear bars and therefore had better handling because of no tread flex.
I bumped a curb while parking with the right front tire, I expected a sidewall scub, but it climbed right up the curb and rested on top. The tire tread stayed flat even though only about an inch of the tread was supporting that corner of my Trooper. I backed it off the curb just in case leaving it that way would put damaging stress on it.
The difference bewteen the Yokohama G051 255/70R16 and 265/70R16 is more than I expected. The 255 has a 41 psi rating and a higher load capacity than the 265. The extra tread width of the 265 is all in the middle section, the shoulders are the same. The 265 has a much more open lug pattern and larger lugs, which I was pleased to see since I do want to be able to go off road from time to time.
I think the G051 would work well off road except in the deep loose mud or similar. Revos would be much better off road.
I hate to say it, but I might just keep the Yokohama G051 for the distance. I had them installed out of curiosity to try them out at low risk with the 30 day buy back. To swap to Revos would cost me $40 a tire (because the Revos cost $40 more than G051s) x 5 tires and mounting fees and government tax differences etc... So nearly $300 to swap to Revos. Revos are the best tire I have ever used, but they got noisy at the end of their tread. The G051 are great too, and at much lower cost.
Next, I will see about getting a picture taken with a LT245/75R16 Revo tire next to a P265/70R16 G051. On paper the LT245/75 Revo is the same hight and 0.3 inches narrower in tread than the P265/70 G051. The LT Revo has more tread depth and runs 50 psi which would be great for off road and towing respectively.
You could also ask an eBay seller if they will share the instructions with you.
For instance:
http://www.keylessride.com/order/programming.asp
Unfortunately, that's a commercial site and you'll have to pay to get the instructions. I searched a few other forums, but came up dry.
You're welcome!
Dave
http://pg.photos.yahoo.com/ph/picktoo/album?.dir=3a6f&.src=ph&store=&prodid=&.done=http%3a- //pg.photos.yahoo.com/ph/picktoo/my_photos
Internet research is a wondrous thing, indeed. With full credit to jlemond1 on another forum.
BTW, my price just went up to a DOZEN donuts!
Dave
Thoughts? opinions?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7960310746&category=337- 27&sspagename=WDVW
Common courtesy, ya' know?
Dave
My apologies,
Dave
I'm on my third Trooper. No one I know personally has had any troubles. Right now, I'm thinking of keeping the Trooper until it disintegrates. "Hopefully" I'll have no major troubles with it. Of course, I only have 25K on a 2001.
Personally, I'm in a dilemma as well. Not a big Mercedes fan but I really like a used G-wagon. Three locking differentials....
Silverghost, great find on that 94 keyfob programming. Don't even own a 94, but I copied it for my file.
de nada. I got lucky . . ..
My Trooper now makes me outrageous. It developed the following problems: (1) the engine stalls when I shift it from P to R or when my foot is off gas pedal. (2) when the engine speed reach 3000 rpm, CEL shows up, (3) after that, the engine idle speed stays at 2000 rpm level and the stall problem disappears. (4) when I disconnect battery cable and reinstall it, CEL become off and the idle speed comes back to normal. But the problem (1) happens again and new cycle begins.
I sent the car to the Bill Stillwell Isuzu in Downers Grove, IL and they told me I need a new fuel pump. Before I send the car back there again, they went out of business. So I have drive 20 miles to a Isuzu dealer at Orland Park, IL. This time, they gave me a even longer list:
(1) Fuel pressure regulator
(2) Distributor
(3) EGR service
(4) tune up
(5) throttle service
(6) Injector service
The total quote is $1290 plus tax. Ironically, I just had the 90K service and got new spark plugs and fuel injector serviced 3 months ago. I think maybe I should seek second (or third) opinion.
My fellow Trooper fans, do you guys have any idea what is the real cause of the problem?
First of all, what year is your Trooper? For what it's worth, I've never heard of a fuel pressure regulator going bad, except in an old BMW I once owned. But, assuming your Trooper even has one, it may well be a possibility.
Second, what "distributor" are they talking about? As most vehicles, Troopers haven't had an ignition distributor in years. If your dealer is referring to a fuel distributor, I seriously doubt that is the cause of your problem, assuming your Trooper even has one.
EGR service? That definitely could be your problem. Plugged EGR valves/lines (and dirty PCV valves) can create a host of problems, as documented all over this board.
Tune up? What are they including in that? Spark plugs and F/I service pretty much does it. You didn't mention who performed your tune up, or what type of spark plugs they installed, or what else they might have done. Improper plugs on many Troopers create another host of problems.
Throttle service?? I've seen other people mention that. What the H... does that mean?
Injector service?? Why?? You said you just had that done!
Get a third and fourth opinion if necessary. Sounds like they're rippin' you off. Get informed, man, and ask questions!
BTW, don't cry about having to drive 20 miles to a dealer. 20 miles doesn't even get you into town in Houston!!
When I pulled the intake hose to the throttle body on my '00, a ridge of deposits had built-up around the butterfly / throttle plate preventing it from opening fully. I was out of sensor safe carb cleaner so I repeated actuated the throttle to scrape off the deposits. If there would have been a throttle cable, I probably would have noticed the throttle sticking. The side benefit is that my slight engine ping disappeared completely over the past 6 months - which makes sense.
So far, the intake manifest gasket was changed twice (at 20K and 80K). I also had 90K service at my local mechanic. they also changed spark plugs (they claim they are platinum) and serviced fuel injector).
According to Edmunds.com, the trade in value of my car is about $4000. Yeah, I am considering get rid of this car. I don’t think it is wise to through in $1000 for the repair that cannot guaranty solving the problem. But my wife had a bumper scratch accident with the Trooper last winter, I believe, the trade-in value I get should be less than that. We just got a Toyota Sienna in December. Now my wife tries to persuade to get a Camry. As you know, Trooper owners are the people who don't want to be mainstream. But after all these troubles with this Trooper, I have to think it twice before I get a new car.
I'm not one to be mainstream by owning a '70 Rover 3500s, '75 99 Saab EMS, 2 SHO's, my current Trooper & '04 Subaru Forester XT, to name a few...
Two more weeks or so left in the 30 day "free" test drive to decide to swap these for Revos. So far, without any big plans for off-roading, I still thik I'll keep the G051's
Peter
Have the dealership check the "Mode Switch". It controls the pressure in the transfer case. When it fails, it thinks the car should be in "Low" gear. Had mine replaced a few months ago.
Also, don't be surprised if your Transfer Case is toast. Mine went out a 28000k miles. Had it teplaced under warranty and it went out again at 72000K miles. As usual, Isuzu Customer Care won't help out.
It's a shame. I thought I got a good truck for a great price.
It's time for new tires for my 1998 Trooper. I don't get offroad much, looking for a good all around tire. I did a search in the archives, but not much on brands etc. What do you all recommend for a good all around tire for the Trooper, preferably quiet on the highway.
Just a quick search on tires revealed a lot of brand, model, load range & size info. You can also search TireRack & read their reviews & road tests. There are a lot of good all around tires - some designed more for highway use, some more weighted for all-terrain, mud, or ice/snow conditions.
If you're looking for an all-season street or A/T type tires, you won't go wrong considering any of the following: B-stone Revo's or HL-D683's, Michelin LTX series or Cross Terrains, BFG A/T T/A KO's, Pirelli Scorpion's, Yoko Geo H/T or A/T, Kumho's, etc. The street patterns will generally have the lowest noise but there are several A/T brands that are also quiet with no whine (except for those with LT ratings).
You just need to decide which tire fits the parameters of your definition / needs.
Personally, another set of Revo A/T's will be mounted to my Trooper again once my current Revo's wear out (mostly highway use with some off-road duty - outstanding in dry, wet & snow conditions)...it's extremely rare that I ever go back with the same model tire.
Thanks again!
Kumho is best known for their ECSTA & VictoRacer 700 series tires. You get what you pay for (unless a brand name gets too big for itself) & the tire is the only thing between you & the road...I never skimp on the performance level I need but I do negotiate for the best value. The 798's may or may not meet your needs but I don't have any 1st hand experience with them.
They are very quiet and excellent traction on the street. Can't really break them loose in the wet. I'm confident for the type of off-road I do - down a dirt road for camping and fishing - they'll be great. Not planning any real rock crawling or mud bogging, getting too old for that. These tires replaced some Yokohama Geolander AT+IIs that I wore out in 28,000 miles. The only real downside to those tires was a tendency to wander on uneven roads. I would also say that the traction on wet roads is superior with the Toyos.
Only have 1,000 miles on them. The treadwear rating is pretty good, 500/A/B - the same as the Revos. 255/70-16, $117 per tire. Toyo offers a 500 mile/45 day tryout, so you can't really go wrong.
http://www.toyo.com/tires/tire_lines/images/opat_sm.jpg
If you want some pictures of the affected part, let me know.
Tom
my apologies, i just read right now your poster, i have sent in different forums and i got the solution of others, also is the same solution that your poster.
again my apologies and thank very much for answer my poster.
post data: you will get your donuts, good job..
