Visitor Agreement.
No, you should not. That would violate the Forum's Terms of Use.
"You agree that, except with Edmunds.com's prior consent, you will not (either in your Postings or in your profile) solicit or promote any products or services, self-promote, or implore readers to take actions that are intended to further a personal purpose."
If you have any further questions feel free to contact me by email.
I guess most of the folks who love their cars are violating this part of it as I know more than one person who feels their car is their personal purpose! hah ahahahahaha
j/k
-mike
It did get some responses. The discussion has been very dead lately, and I miss it being active.
Thank You
And that is precisely why your post is still there!
Replacing original tires this week will probably go with BStones again. 74K of all highway driving is the best thing in the world. Other then minor issue with TOD sensor, replaced under warranty, and the overhead light switch on driverside broke. I have had no problems.
-mike
Interesting on my ongoing TOD issue...the other night when it was raining my 4wd kicked in. I the transfer case was binding, I was in a parking lot. I had to stop and turn off the engine and turn it back on? I guess the short is underneath the truck. I am 1/2 way there.
I've seen where some engines split the EGR passage to each individual cylinder while others just dump the single passage around the throttle body.
Has anyone removed the upper intake plenum or traced the EGR passages?
Oh well, I found the end of the EGR tube is behind the throttle body. So, it's just a single tube. Should be able to open the throttle body, stick a long brush down the tube and clean the carbon gunk w/o pulling the top intake plenum off.
Could certainly be a bad or dirty spark plug(s). When was the last time they were changed?
With the symptoms you describe and having 134,000miles could also be fuel delivery; fuel filter, fuel pump, plugged or bad fuel injectors, or crud in the fuel tank.
Dirty intake plenum, plugged air filter, PCV valve, EGR - many things. If the 95 has a TPS or throttle-position sensor, these are often the cause of drivability problems.
Because it idles fine, I would less suspect electrical.
If you have plug wires (don't know if the 95 had wires or has the coil packs directly over the plug) - check them, can certainly cause the symptoms you describe. If you have the coil packs, it could be bad coil packs. If you have a distributor - check the coil, distributor cap, rotor, etc...
Could even be bad gas, if this is on the same tank of fuel.
1995 was the changeover year for OBD1 to OBD2. Maybe there is a fault but it may not throw the check engine light. You may try going to an autoparts store like Autozone and see if they can pull a trouble code for you.
I believe the lifter clicking issue may be fixed (helped) by using 0-30w Synthetic oil for several oil changes. Cleans the lifter passages. If you search this forum or one of the Isuzu Owner Club forums on the issue of lifters you should find quite a few hits on the subject. You may also ask in the main forums under maintenance or the like on your hesitation question.
With the oil "leak" you may check to see if it is actually leaking anywhere. There is also an issue with Troopers of plugged PCV valves contributing to oil burning. EGR is also an issue. You can also search in these forums for this issue too.
On Nov 08, 2004 you said your Trooper had the following codes:P0137, P0157,and P1171. I have a 99 Trooper with the same three codes Lets see... the dealer has replace the 2 rear O2 sensors (twice), fuel filters, fuel pressure regulator, fuel pump,PCM, and EGR service has been performed all within the last 6 months. Vehicle currently has 118,000 miles and runs very well especially after the fuel pump change. Please Respond! :confuse:
I have a check engine light issue. I have a "01 Trooper & bought it brand new in 2001. So far it has been flawless, 28000miles & no problems whatsoever. The "check engine" light came on like 2 1/2 weeks ago, i took it to the dealer who recommended cleaning out the intakes (carbon deposit crap), cleaning the injectors, new fuel filter & adjusting the throttle. after almost $400 i thought my prob was fixed, didn't consider it that bad considering all i had spent money wise last 4yrs was cost of fluid changes. Well, the CE light came back on like 5 days ago, after which my wife filled up the gas tank & it want away afetr a few hours. So i thought it might be a loose fuel cap. The light is back on again today. Any suggestions as to what might be the cause, i hate to have to take it back to the dealer only to get ripped again. do you think it might be a faulty gas cap, or fuel line issue? any help on this would be appreciated. thanks!
I own a 1993 Trooper LS 4wd with 170,000 km (100,000 miles). About a year ago my truck started to bog out when I accelerated. I did a major tune up. I changed: EGR valve, IAC motor, throttle sensor, O2 sensor, cat convertor, plugs and wires. This did not help my problem. My truck eventually came to the point where it was flooding itself. Last week I paid a GM dealer $2300 CDN to change my 6 fuel injectors because they were leaking. I got in my truck and when I started it, it was running rough. After it warmed up it was running not bad. Today I was on the highway and my check engine light came on. I came to a stop light and the check engine light went off and then back on again when I accelerated. When I put it to the floor the truck bogs and putters and I have black smoke coming out the exhaust. Ive been having that problem since the truck started acting up last year. I am so frustrated and im sick of paying people to tell me they have no clue whats wrong with it. I need help! Thank you for your responses.
Your black smoke means the engine is getting fuel, but not enough air. Is your air cleaner clean? Are the air passages clean? Is the intake to the air cleaner box clear? Is the intake staying in cold engine mode and resticting the air? Do you have the snorkel kit and a bird nest in it?
Maybe too much fuel? Are you getting terrible MPG even when it is running OK?
Maybe air intake valves sticking and not opening up enough? Has this engine been overheated or run out of oil?
Does it bog evenly on all cylinders? Just one side? Just one cylinder?
Is your radiator fluid level changing too?
It could be a lack of spark so that the cylinders don't all fire. Is your battery fully charged? Are the ignition coils in good shape providing lively sparks at all cylinders?
Once you find your problem and fix it, especially if it is ignition trouble, and you are buying wires and plugs again anyway, have a look at this web page: http://www.directhits.com. I had a set of directhits on my 1995 Trooper, they were a very big help for towing and the engine was more peppy and maybe a slight improvement in MPG in normal driving. The directhits are worth their cost (about $20/cyl) just for the quicker engine response. I am not selling anything, just telling a tale of my pleasant experience with a good money back guaranteed product. I had directhits in for 75000 miles. Towing a 4000# trailer went from 9.9mpg to 11.2mpg and after directhits it ran smoothly on cruise control while towing vs. hunting for gears before.
All of my air passages are clean as far as a I know. I will double check all of them tomorrow morning. How would I know if the intake was staying in cold engine mode and do you think that would cause the check engine light to come on? I do not have a snorkel kit or a bird nest, I dont even know what those are! When I drive the vehicle there is a strong smell of fuel all the time and my mpg is crap. The engine has never overheated or ran out of oil, although when the check engine light first came on i added oil and it went off for a few months. Id have to find out about the cylinders bogging evenly tomorrow so I cant answer that right now. Rad fluid is fine, battery is ok, I have a large stereo system but a good interstate battery. Im thinking if it was the ignition coils then it would drive like that all the time not just when I step on the gas.
I really appreciate you helping me, I like the directhits but I cannot afford them. Thank you for your help!
Check engine light could be from the oxygen sensor(s) telling you the engine is not burning all the fuel so the amount of oxygen is not correct.
Can you take it someplace like an autoparts store and have them read the check engine code for you? I think the 1993 Trooper would have a standard ODB1 computer interface (1996 and later are required to have ODB2). There is an adapter available to connect your personal computer or PDA to an ODB1 or 2 interface, don't know the cost or source.
I cleaned the EGR and the stalling problem is gone! People in this forum saved me $1200
Sometimes, the CEL is still on and off. But the stalling problem never happened. The gas mileage is still poor (as usual) about 15MPG or less. The idle speed is kind of high recently. Maybe I need to get a new EGR.
I may change my job next month and the new commute is about 35 miles one-way. This will kill me given the gas price here. My gas bill will be $250 a month. Getting a new car? New car payment + gas will surely > $250/month. Plus Trooper really gives me a great view in traffic.
Now I need to get new brake pads for the rear brakes. The car is 87K miles and it is still the original. Do you guys have any suggestion? Tirerack.com sell brake pads. Is it worth to get hand dirty to install them by oneself?
Chad
Our questions:
A) How much does this vehicle weigh?
...and a more subjective question:
C) If you didn't care about the engine or 4 wheel drive, and the priorities were light weight (assuming a "glider" w/no engine), a manual tranny, general robustness/quality, and affordability/value, what years/models of Trooper would you be looking at?
...and one more question that we hope won't be taken as heretical (we LOVE our Trooper, honest!):
D) How much does the 4-wheel drive system weigh, and is it integral to the drive train or removable?
Once more, thanks in advance!
- P&C
MODERATOR /ADMINISTRATOR
Review your vehicle
I went back to the dealership where I got my injectors replaced and the mechanic that did the operation went over a few things. He tested the EGR and it was fine. He then hooked up a reader to the O2 sensor and the pressure seemed to be OK, it wasnt great but it was adequate. Becasue the truck was flooding itself he determined it may be build up in the cat convertor thats casuing the bogging. I have yet to remove it but I will if I dont figure this out in the next 7 days. As far as the CEL is concerned I found out how read the flash codes. I have located the white 3 pin connector under the dash. I was told to jump A to C and read the codes from the panel where the CEL is located. DOES ANYBODY KNOW THE EXACT PROCEDURE TO JUMP THE CONNECTOR? What do I use to jump it?
And is it possible to manually check if the coolant temp sensor is working, and if so where is it located and what do I do????? Thank you to whomever wants to share some inside information to a hurting trooper owner!!!
Signed,
Desperate.
I realized that you have to let the 12 code flash 3 times before you get the juicy codes!
I got a 32 and a 44.
Can anyone tell me what these codes mean for a 1993 Isuzu Trooper LS ?
Also, I have an option to buy an extended warranty on this car from Guardian Warranty Corporation. Any feedback pro or con (pardon the pun) on this outfit?
Since my original post, I've discovered that our '91 SE weighs about 3700 lbs. Anyone care to hazard a ballpark idea how much the 2.8L V6 weighs? Also, just as a reality check - how does the Trooper compare to other SUV's in terms of weight - is it comparable? Heavier? Lighter?
I'm also still trying to find out if it's feasible to convert a 4WD - and if so, how much weight might be saved by doing so.
Thanks again to bsmart1 or anyone else who can help me out!
I just landed myself a 2000 Trooper, love it so far. That being said, I'm not the most tech savvy gal on the block. My keyless entry was working fine until I locked the doors from the inside lock/unlock switch on my out of the car. When I returned, I tried to unlock the doors with keyless remote thing and the horn beeped a couple of times and wouldn't unlock unless I did it manually. Now I can't get the unlock or lock to work from the remote and I have to do it all manually (the horror). How can I get it back to normal? There aren't any answers in the owner's manual. Thanks for any help!
Rachel
What do you mean "glider" will your lightweight Trooper project go airborne?
