Steve
David
I have not done all of the service as recommended by the manual. However, I do everything myself. My vehicle will be coming up on 50k in a month or so. I will be doing everything as mentioned in the above posts at that time if I have not already performed the task. Please email me at chad.knott@kolbfasteners.com. if you need assistance in regard to this maintenance. I live in Gainesville, Georgia.
Is this the same in other states?
BTW, my Isuzu dealer charges about $350 on "special" (every other month).
-mike
Keep in mind that you may or may not have extended-life coolant installed. If you have "old" coolant, the manufacturer recommends changes every 2 yrs/30k miles. Brake fluid should be flushed every two years as well because it tends to absorb moisture.
If you read this board often, you will find that fluid change intervals are hallowed ground. Some will swear that you never should change fluids; others replace their oil every 2000 miles. It's personal preference in many cases.
Tom
John
I don't think my dad has ever had brake fluid changed/flushed/etc. in his 35 years of vehicle ownership.
-mike
I find that the fluid in the reservoir usually looks fine. Whether it has picked up water and compromised its effectiveness/made it much more corrosive I don't know. The fluid at the brakes is certainly darker looking for the first couple of pumps.
Granted, this may be overkill especially if you don't keep your vehicles all that long and/or you have to pay to get the work done. I plan to keep my Trooper for 10+ years. I am willing to spend a couple a bucks and take 45 minutes every couple of years to flush them.
I have had good experience with only one dealer in Maryland. Criswell in Annapolis. I just bought new 02 LS and got a great deal. Was looking for used 99 to 01 LS and the dealer in Silver Spring kept switching trucks and prices. Stuff like yes we have an 2000 LS 4WD I'd get there and it would be 2WD or sorry it's only an S model but it is 4WD. When I asked about new they went right to LS at $33K and not willing to negotiate price. Criswell, said used LS' are near impossible to find and asked if they could come close would I look at new. Asked for best price Manager came back with hard number said try to beat at any dealer. No one in MD, DE, Southern PA or Northern VA came close. Most offered the $5k rebate but that was all.
Need to take in for fix on Drivers Seat and Drivers mirror. Will post experience.
As an overview, I almost empty the reservoir first with an old turkey baster being careful not to let air into lines. I then fill with new fluid. Then I go to a wheel and open and close the bleeder while my helper pushes, holds and releases the brake pedal. I do this until the fluid is clean. Of course you have to be careful to refill the reservoir lest you let air into the system and have to start over. Also, having a hose on the bleeder outlet and directing that into a clear bottle is also a good idea. This keeps brake fluid from flowing everywhere, lets you see what is going on, and can keep air from being sucked back in.
No doubt there is a good writeup somewhere on the net. Just be careful to get the ABS precautions correct as I guess you could mess up some sensor and/or get fluid squirting out under high pressure. Also, the wheel bleeding order is important in order to get all the old fluid out.
http://66.216.68.23/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=86&t=000267&p=
Flushing the system is as simple as bleeding it. This is even more imperative on ABS-equipped vehicles because that gunk in the system can lodge in the valves of the ABS unit. In fact, when changing brake pads on an ABS-equipped vehicle, it is generally recommended that you not force the old fluid back through the lines and ABS unit, but rather crack the bleeder screw on the caliper to let fluid out as you compress the caliper piston.
Tom
These sort of maintenance items are way beyond my skill and comfort level, so I would need to have a shop do the work.
What's a ballpark price for something like this? Having never paid for this work to be done, I have no idea.
If you're curious about the details of my experience I'd be happy to email you, or I could post a toned-down version here. I still have all the email correspondence from the dealer and my detailed notes. I never contacted American Isuzu or the Better Business Bureau. I'm very disappointed in myself for not doing that, because it was the right thing to do.
I've read the thread on it here the last couple days and a lot of good information has already been explained. I for one believe that bleeding the brake system is a SMART thing to do. I don't think it needs to be done more routinely that about every 50K miles though. That's about the timeframe I generally do mine. Each time, I've seen a somewhat darkened color fluid come out at first and then it clears up with 8-10 pumps of the brake pedal. The key is to purge enough fluid to get all of it out of the wheel cylinders where it's been exposed to heat produced during braking. This will extend the life of the elastomers (seals) in the system.
Happy Trooping !!! ;->
Anybody have an opinion about whether or not this might be an economical upgrade for my 1999?
Jim
-mike
The Silver is mine, the Blue is SBCooke's.
More pics at http://isuzu-suvs.com/events
-mike
I learned from Sean's mistake! Easy on the gas, gently through the water
I should get one eventually.
-mike
When the change was made to climate control, was the fan blower improved at all?
Our '98 has 50K miles and runs flawlessly, but I'm getting apprehensive about another Arizona summer in the Trooper. We have very dark tint and use a sun shade, but the a/c doesn't cut it here. The a/c shops say it's running fine. If I were to buy a newer Trooper I'd rather do it now than try to sell ours when the temperature is 110 degrees here!
tidester
SUVs
I learned too, I go around until I get a snorkel.
I have a 56K at home, pics are no problem.
-mike
Trooper Length 187.8
HummerH2 Length 189.8
Trooper Width 72.2
HummerH2 Width 81.2
Trooper Height 72.2
HummerH2 Height 77.8
Trooper Weight 4455 lbs.
HummerH2 Weight 6400 lbs.
Trooper Turning Circle 38 ft
HummerH2 Turning Circle 44 ft
Why is the Duramax Diesel not standard equipment on the HummerH2? It sure is heavy enough for it.
http://www.hummer.com/html/h2_specs_features.html#dimensions
56K Modems. I had a Motorola 56K modem with hardware controller chip on board that usually downloaded at 3K/sec or so. I upgraded the computer to a P4 1.5GHz and reluctantly installed one of those $17 software winmodems, now it downloads much faster 5K to 7K and up because the P4 is fast and the modem software does a much better job using compression. So, if you have a slow hardware modem in a fast GHz PC then try out a cheap software modem <$20 and see if it is not a lot faster.
How many Trooper owners would buy a $50K HummerH2 if it had the Isuzu Duramax Diesel and got 20mpg?
Oh well at least we know.
The Assender may get a duramax option, hopefully, since it will have a V8 option.
-mike
I agree, a page with engine, axle, gear and other technical information similar to this would be a a good add-on to any isuzu page.
-mike
Steve
Maybe edmunds should have a "you don't know nothin'" forum, and all those "issues" can be taken up there?
