Visitor Agreement.
Likewise, don't try to clean your keyboard in this manner until you've turned off your computer!
tidester
SUVs
How many miles is she driving every 2-3 days?
Obviously, 1.5 qts oil consumption every 200-300 miles is way too much for any vehicle, even the 3.2L and 3.5L Troopers, which are well-known to burn more oil than most people are comfortable with.
Is this an April Fool's joke?
I personally, while I really enjoy my Trooper, was interested in the concept of the Trailblazer EXT/ Ascender vehicle. As a result, I must admit that I have been following the Trailblazer/Envoy/Bravada forum. If you follow the posts you will see a number of things:
1) Reference to links that state that all extended vehicles will get the ALUMINUM 5.3L V8 as an option.
2) Repetitive problems with steel sleeves dropping out of the cylinder walls of the ALUMINUM block.
3) Repetitive gas mileage complaints (11-14 mpg) with the 4.2L inline six.
4) Repetitive problems with mirrors automatically changing positions while driving(they call this "wandering" mirrors)
5) Repetitive paint chipping problems around the vehicle, but primarily around the license plate.
6) Repetitive problems with the fan clutch "sticking" on the engine driven fan causing poor engine performance.
7) Repetitive problems with a front axle seal causing a "squeal" at highway speeds.
8) Repetitive problems with excessive wind noise at highway speeds.
9) Numerous dealer complaints, but then these are typical.
Folks, I was able to come up with this list just by memory without referencing their forum. Please see for yourself. To be honest, I have been and was hoping that I would see the problems go away, but they just haven't so far. Therefore, I believe that the Ascender will carry many of these same problems. Based on my automotive engineering experience, these type of problems are both design and execution(manufacturing) problems.
Perhaps, if the aluminum 5.3 V8 can be built correctly, I'll put this engine in my Trooper along with the third seats from Australia and will be as close as I can get.
3 & 6 are the same I think, most get pretty good mileage IIRC
4 is a problem
5 is mainly around the plate, but that sucks
7 I'm not sure on
8 Yeah, they can't figure out what way to put on the roof racks :-)
9 I haven't heard too much about this while reading the board.
Don't get me wrong. I am not trying to knock the vehicle, but I have been disappointed with the nature of "repetitive" problems. I have only owned GM trucks prior to my Trooper. My father has had five suburbans and will drive nothing-else.
From what I have read, the gas mileage issue has been the result of potentially two different problems, high transmission shift points, and the sticking clutch fan.
The axle seal problem has been the result of poorly install axles seals on the front differential housing on 4wd models.
I have read that the wind noise problems have resulted from the incorrectly installed luggage racks, and from poorly manufactured rearview mirrors. Some of the folks still complaining despite repair/replacement/reinstallation of mirrors and racks.
Anyway, I am still hoping that GM is able to eliminate these first/second model year blues by this Fall.
Back to Troopers!
-mike
Perhaps GM figures the Chevy & GM versions will sell anyway (lots of die-hard American brand buyers and/or captive buyers who get the GM discount), and the Isuzu version will need something special to attract customers?
-mike
Thanks for the response. No joke, The trooper has 55000 miles on it,she is driving app.50-60 miles a day at this time.
Marty
I noticed the discussion about oil usage. My 3.5 V6 burns no oil whatsoever and now has 43,000km (about 26,000 miles)on the clock. Is this something that starts with more mileage, or have you always seen this?
S a v v a s
1. What are the differences between '98 and '99?
2. What are the differences between the '02 and the old ones?
I read that in '00 grade logic was added to the trans, and powertrain warranty was added at 120,000 miles. Also, the grill seems to be different on the '02 vs. the '98. Any other major/minor changes?
Thanks a lot,
Chris Kmiec
The Toyota./Chevrolet "Toylet" Prism is a Toyota rebadged as a Chevy and the controls in the Toylet are GM style while the Toyota Corrola version gets Japanese controls like the Camry.
My 1995 Trooper controls are more like Camry than GM. Dashboard look and feel might be a slight Ascender advantage for some people. I have not seen the dash of the Ascender so I do not know if it is different.
Escalade:
Overboosted steering, lethargic almost scary brake pedal, GM should be ashamed they put Drums on the rear. I felt like I was riding on it, not in it. At 5' 6" I felt like I was swallowed up in the seat (no short jokes folks!). I did like the psuedo wood steering wheel though. Exterior fit and finish was pretty good, interior typical GM.
Doors were outrageously heavy.
The only real bright spot was the haull [non-permissible content removed] V8. Oh yeah, and did I mention the psuedo wood wheel, I liked that.
Expedition:
Power Steering and brakes were better. I actually preferred the ride to the Escalade too. Inside and out my opinion was rather low quality materials, although the price tag is not too high for such an immense vehicle. Again the V8 hauls [non-permissible content removed]. Doors also quite heavy.
Overall, the Japanese fit and finish of my ole' Trooper is better than the Ford all around and better than the Escalade in the dash area.
The Trooper brakes and steering give a much better feel, and I prefer the suspension ride as well.
The 1998 Troopers with Performance Package did not include fog lights. I'm pretty sure the 1999 did.
Personally, I like the front end of the 1998-1999 better than the 2000+.
Isuzu added an automatic climate control system sometime around the 2000 model year. I don't know if it's much better.
There's not much to differentiate the 1999 from 1998.
You'll get the 10yr/120k powertrain warranty only if you are the original owner, and this warranty wasn't available until 2000, if I remember correctly. All subsequent owners are covered 5yrs/60k miles.
99: All AT equipped vehicles got TOD
00: Grade Logic Tranny, Automatic Temp Controls, Nomenclature changed from Perfromance and Luxo to LS and Limited, Moonmist added as color, clear rear turn signals, mesh-rims, slightly different grille, 10/120 warranty std to original owner, drive by wire added
01: Extra electric fan added in front of A/C radiator, Anniversary Edition with Nagamichi Stereo and leather added to the LS trim level
02: Rear power outlet added (IIRC), TOD dropped from the S models with AT, price increase, Nagamichi stereo added to Limited trim level
I think that is all I can think of for now.
-mike
-mike
My dash and plastic trim resemble a 78 Datsun! However, for I like it and for my use it is great, very durable, solid as a rock. Not one rattle inside.
01: No recall on the fuel lines IIRC.
02: No recall on the fuel lines IIRC.
-mike
-mike
Thank You
-mike
-mike
-mike
It is unlikely that we will see full production vehicles with steer-by-wire or brake-by-wire in the near future. Europe has legislation preventing their introduction, and Australia is following the same line.
The logic is that steering and brakes are too critical for safety, to depend on an electricity supply being always available.
-mike
Mike ... what is grade logic? And while we are at it, what's IIRC?
Grade Logic: Basically what it does is if you are completely off the gas pedal on a downhill slope, it will automatically downshift you to a lower gear (usually 4th to 3rd) to provide engine braking. If you are on the gas at all it will keep it in 4th. That is tied in with the Drive-by-wire I'm assuming so that it knows if you are on or off the gas pedal. It works quite nicely, I love it when I'm towing I can just let off the gas and it will downshift to provide that much needed engine braking on long downslopes with a trailer.
-mike
The trooper was purchased this past Oct. with 44000 miles on it,it now has app.55000 miles. At this time the oil consumption is 1-3 qt s. of oil per 3 days with app.300 additional miles. no leaks no sign of burning from the exhaust. SOMEONE HELP! :-(
Marty
If not, then it has to be losing the oil somewhere. If there is no visible external leaks, then there may be an internal one. Have a look at your other fluid levels, particularly transmission and coolant. If they are too high, and/or the fluid looks contaminated, you have found the problem.
In Australia, Holden recommends a 20W-50 oil. When I do a change, I look for an oil that is thinner viscosity cold, but the same viscosity hot. So generally, a 15W-50 or a 10W-50. And like I said before, absolutely zero oil loss.
Good luck,
Savvas
Is the automatic climate control any good? My wife's car has it and it is great, sort of set it and forget it. But I've driven some cars that had horrible climate control. I guess my question is - is it worth trying to get a '00?
So, it's burning, going into the cooling system, going into the transmission, or going onto the ground. I suppose it is possible that it is being ejected only under pressure onto the ground and so you are not noticing it when the car is not running...
There is an outfit in Australia that supplies custom made performance kits for Isuzu V6 models. The kit provides a real increase of 10% in both power and torque, at the driving wheels.
The kit is quite simple, and is just a new mandrel bent stainless steel sports exhaust system (from engine to tailpipe), and a reusable air filter. More performance increase can be had by modifications to the airbox. There are some Jackaroos getting around with up to 180kw in power, compared to the standard 158kw.
The principal of the company that makes this kit, is Bruce Garland. Four time winner of the Australian Safari in a Jackaroo/Trooper, and winner of the last Round Australia Rally. Again in a Jackaroo/Trooper. His race V6 is rumoured to belt out around 250kw (or 337 hp) and can achieve over 230km/h (or 140mph)in offroad racing. He knows Troopers better than anyone.
If you're interested, the details are on -
http://www.grt.au.nu/Pro/faq.html
S a v v a s
-mike
Bottom line - a very nice vehicle, but for me I couldn't see 25K difference between the Trooper and the TLC. I've read several times that owners who had both vehicles felt the Trooper was 4/5 of a Land Cruiser at half the price. I had the same impression after my limited test drive.
Things I definitely like better about the Trooper include - much better visibility, more airy interior, a better seating position, and better mirrors. I'm also a real fan of the TOD system.
Some other things I noticed - the TLC has less body lean in the corners but it does lean noticably. The V8 seems a little stronger than the V6 in the Trooper, but much of that extra power is somewhat offset by the heavier wt of the TLC. Would be nicer for towing though. My Trooper has a more nose dive when braking than the TLC. The TLC seemed a little quieter on the road but the steering was a little twitchy for me.
From my limited test drive I found the TLC to be
a solid SUV, certainly a world class contender. I'd be happy to own one, but the practical side of me can't see paying that much for what to me would be a marginal gain in performance and functionality. I was pleasantly surprised to find to find the Trooper more than held it's own when being compared to what is arguably the best SUV in the world. I really expected that there would be more difference in the two vehicles, that the TLC would really stand out. Surprisingly, I finished my test drive feeling even better about being a Trooper owner.
Has anyone else compared the TLC / Trooper lately? I'd be interested in hearing your impressions.
-mike
And updated in the gallery too
-mike
A loaded Trooper at a real-world price of $32k would get you about 90% of what an LC offers at $20k more.
The Land Cruise "is nice" but new Troopers (Made in Japan) at $7-8K discount are so much nicer! 17K miles on our 01 LS TOD now - how sweet it is. Wih 5-20 Mobil 1 I use maybe 1 quart every 5k miles - which is when I change it anyway. 18 MPG hiway/16.1 MPG in town - and thats good to normal for any of the truck based SUV's with a 6 cylinder and auto transmission.
I have the automatic climate control - and its nice - but it would be the last item I would be concerned about if I was looking at a new or used one. You still turn a nob to turn it on and you still slide the other nob to set the temp. Also, when you just want heat that pesky air conditioner light stays on - meaning you are turning the compressor even if you don't need it - so I manually turn it off.
The biggest issue with the Trooper is suspension, suspension, suspension. Gas shocks, polyurethane bushings do wonders. But the beefier rear springs I've seen talked about on this post would be good too - adds stability to heavy rear loads and I bet it minimizes nose dive while braking.
-mike
-mike
Thanks for sending the pictures of 3rd row seats to Mike. Jealousy doesn't adequately describe the feeling.
Mike,
Thanks for posting my Jeep pics (you didn't need to) and for posting the pics of the 3rd row seats.
You guys need to check out the Isuzu Ascender comments made by all the TB/Envoy/Bravada owners in their forum. They are ticked!
Picture this:
1) Purchase 2003 Isuzu Ascender with 5.3 V8, 4.10 gears.
2) Go to GMpartsdirect.com and purchase 6.0L rods and crankshaft, fuel injectors, and computer.
3) Exchange and install these components into the 5.3 V8.
4) Purchase 3" suspension lift.
5) Purchase 305/70/17 tires.
6) Purchase ARB air lockers front and rear.
7) Install ARB Bull bar with Warn/Ramsey winch.
Would that be so bad?
I was wondering whether the third seats from a Tahoe would fit within the fender wells of a Trooper?
Chad
"I have just bought a Trailblazer LTZ. So far I am very happy with it with one exception. When I fold down the rear seat I have to move the driver seat forward in order to put the seat down. I have to move forward about three inches which makes for an uncomfortable ride. Then when I take the key out and the seat moves back it gets jammed agains the back seat. also the back seat doesnt fold flat. I this the way its supposed to be? I cant believe they designed the truck this way. The only way I can put the rear seat down is to move my seat almost all the way forward. I'm 6'2, makes driving a little difficut and unsafe."
That is a BIG deal to me, as I am 6'3". I guess the TB/Env/Brav/Asc won't be MY next vehicle.
-mike
