$25k for this vehicle seems pretty good. Just thought I'd post it as a reference point for people considering new '02 Troopers.
However, the non-dipstick design is just sheer stupidity on behalf of Isuzu. I suspect that entry of water, dust and other contaminants that can be encountered while off-roading may be the reason for this design. But I think it would be preferable to have a dipstick with a sealing/locking tube arrangement.
wishnhigh1 "Nissan Patrol" Sep 15, 2002 1:34pm
Steve
-mike
And I wasn't giving Tidester a hard time in my earlier post. He's just unbelievably efficient. Mispell that name and BAM! He's there.
-mike
Speaking of which are you gonna come this saturday?
-mike
tidester
SUVs; Aftermarket & Accessories
Newbies seem to go to the main Isuzu board (/WebX?ed_displayMakeModelRelatedDiscussions@@.ee9204a!make=Isuzu&model=All) and make entire new discussion topics rather than posting in existing topics. For example, do we really need an "1994 Isuzu Amigo Won't Run" discussion board or one only for "towing a 4 -4 Pickup Manual Trans"? Clearly these should have been posted on existing boards. While not yet a big deal, it is certainly possible for the system to be much less readable if everyone just creates a new board whenever they feel like it.
Generally, when a redundant topic is created we will request that the author repost his/her message in the existing discussion and mark the "new" topic as read only.
tidester
I am quite happy with it. Got it for about 22.5K almost a year ago.
Improved gas mileage on the 99' by using a higher Octane fuel. It surprised me, but it seems to be real. I'll report more as time goes by. I went to 91 Octane from 87 Octane.
I did, I just added the alternate spelling of Ascendor to my dictionary!
-mike
-mike
I though run 4/3 on stock setup with the ranchos and now that I have stiffere front T-bars and OME springs in the rear I run it at 3/3
-mike
Want to put aftermarket CD/Receiver in place of factory Cassette/Receiver but there was some issue with the two antenna leads with the '02 in-glass antenna system. Can anyone give some info on what's necessary to install an aftermarket system considering the 2 antenna leads specifically, and any advice in general (ease of installation - DIN I would hope - and so on.) Also, I think the 4" and 6.5" factory speakers need to go.
I NEED A DIPSTICK!!!!
There, got that off my chest now.
We loaded his 4600lb+ truck onto the 2100lb uhaul and headed home. The Trooper towed it well in "3" and even turned 10.5mpg @ 55-60mph. I wouldn't want to do it all the time but luckily we retrieved him.
-mike
I am trying to work out Saturday...but I am about 50 delta to go.
-mike
The sub under the rear seat in the hidden compartment (as seen on Paisan's site) I doubt would work well. Atleast as a sub. There is no air in the box for the sub to work with (which is important for sub box design). Then the speakers would function as regular mid's or high's, but would be blocked by the seat. I don't think it's a good idea/design, but that's just my opinion.
The rear diff has obvious drain/fill plugs. You will need the limited slip additive, 4 oz. tube available at most any auto parts store.
The front diff has a disguised drain plug, it is the cover hold-down bolt at about 5 o'clock on the diff. The fill plug is on the other side IIRC and is obvious.
You will want to get one of the cheap hand pumps at the parts store to get the diff fluid into the fill holes.
Oh, and do it while it is warm. Diff fluid doesn't drain or pump worth a damn when it is cold out.
Steve
Steve
Steve
IIRC, a 50,000km service doesn't include a bearing repack and the dealer has already told me that it is $180AUS for the service, with the auto service being another $130AUS.
I've decided to go with a tranny service because on weekdays it is only doing 14kms per day in short repeated trips. In other words, doesn't get a chance to get to operating temperature too often.
Question on the maintenance. Did you perform the oil changes or was it left to the dealer? If it was the latter, then you also have recourse on that servicing dealer.
Hopefully this all blows over quickly for you, and you can get on with enjoying what otherwise should be quite a fine vehicle.
Dave called me today and said that he was driving it and all the warning lights popped on, but it still ran OK. Dave said he took it to his mechanic and the guy said that the "Relay switch from the alternator went out and that it would run fine. However the blowers will not work, for the A/C or heat" The entire alternator would have to be replaced because of this switch...Has anyone else heard or dealt with this?
I just want to make sure if I put a new alternator on it that it will be fine. Dave said he would drop the price down to $4400 because of the problem (which I think is a good deal). I really like the truck and want it but I don't want to make a mistake that I will regret. I would love some feedback on the situation...Anyone know what a new alternator runs?
-mike
My guess is the seller may not want to fix the problem - on an older vehicle that's not worth a whole lot, he probably just wants to be rid of it. I just sold a 95 Ford Contour tonight. The AC didn't work and the ABS warning light was on. I just didn't feel like fixing these expensive problems before selling. I was up front about it - could have pulled the ABS fuse and kept quiet, but that's not me. Anyway, the seller bought the car at face value.
Haven't heard of any trend toward crankshaft bearing trouble before.
