Visitor Agreement.
-mike
-mike
Brian
Thanks for any help!
I'll try to make this short...My wife and I traded in our 2001 Grand Caravan for a 2002 Black LS trooper. The van served us well although the Tranny was already having issues. We've wanted a Trooper for sometime but the van was cheaper in 2001. So..here we are happy as can be wishin'we could have done this earlier!!! We got a 2WD LS Black with all the goodies except leather. The dealer was Leith Isuzu in Fayettewille N.C. Our Sales guy was Rick McKee...Let me tell ya...these guys were ABSOLUTLEY great!!! No pressure, no hassle, and $7000 OFF MSRP! They took care of most of our negetive equity! I've been following this board for two years and am now darn excited to be part of it!!!!
Kdub
Personally I prefer the look of the side steps. To me, they're less bulky than running boards and they feel sturdier too.
You could buy something heavier duty than the Isuzu brand stuff, probably at similar cost. paisan and others will surely give you some advice on those choices.
My guess is that your one tire with the sidewall ribs is simply from a different production run with either the "old" or the "new and improved" styling.
Ideally all your tires should have the same diameter for the TOD to work properly. In your case your front tires have equal diameters. Your rears also have equal diameters. However the rears being newer are slightly larger than the fronts. No doubt this is not ideal but much better than having different diameter tires on the same driveline. My guess is that you will be ok but keep an ear out for unusual noises.
FWIW I would have put the newer tires on the front as the fronts tend to wear faster what with the extra wear involved in turning and stresses from alignment irregularities. That way the front to rear differential in diameters would shrink with time rather than grow.
Just my $.02 and I am no tire expert so YMMV.
265s will fit on or offroad w/o a problem. I know guys running 275-70s on stock suspensions.
Rodeo rims 16" will fit fine and have the proper offset for the Trooper.
-mike
BTW, what does a set of 684's go for?
Hasn't Chrysler figured out what is wrong with their transmissions yet?
-mike
You can get comparison numbers on TireRack.com.
Please tell me the disadvantages.
Thank You
BoxTrooper
-mike
And to Kdub58 - would recommend you spring for some gas shocks - the improvement is well worth the money - and for for very few dollars get the front/rear polyurethane bushing from JC Whitney and stick them on - easy to do yourself. Enjoy a fine vehicle.
-mike
Try adding your own rating...they are swayed easily, something rated 7.2 can be moved to a 9 by someone adding there own numbers a few times in a row.
-mike
While it's trying to eject, take *another* CD and insert it, trying to get it "over" (or, depending on how the disc is jammed, "under") the jammed CD. Only insert the CD about an inch or inch and a half. Pull the CD out, trying to use enough friction that the disc jammed "on the bottom" will start to move with the CD you inserted. One of two things should happen: it'll get popped out by the ejection mechanism, or it should appear "far enough" out to pull the jammed disc out with your fingers.
I think the fuse trick will only work for the single-disc, texas, not the changer. I've had a few discs with particularly "slippery" labels jam in the changer, the trick above will always get them out.
Anyone using other external providers for extended warranties?
Generally I shy away from these packages, but it might not be a bad idea worth considering.
I own a '99...yea I should have waited to buy the '2000....
-Uni
I do not have any idea of your situation but I would if I could take a look at trading or better yet find a Trooper at a dealership that understood the need to sell it and buy outright. The 2002 Trooper is a really great vehicle. I was able to purchase my new Limited for $12,500 back of list. The dealers that still have Troopers should be more than ready to deal. Something to think about.
If that is out of the question check http://www.wynnsusa.com for Wynn Warranty.
As noted above, first unlatch the clasp. Grab at about the 4 and 8 o'clock positions. Gently pull towards you and up at the same time. The motion you are going for is more like prying off an old fashioned bottle cap one edge at a time. Do not try to pull directly towards you and snap off the cover all at once. You won't have to force anything, the cover will easily slide off.
-mike
I am loving this vehicle. Great ride , power, and it looks nothing like the new assender minivan.
I wonder about the future of Isuzu. The good deals on the trooper were no doubt the result of weak sales for 2002, poor JD Power quality survey scores, and consumer reports safty tests.
Personally I think CR is retarded. All SUVs have rollover potential - they should downgrade acura integra for poor off road handling !?!
Weak sales are another thing. Anyone see this company turning around? The assender can't help.
All in all I think this rig is tops - I'm sure you agree.
-JRR
-mike
Best I've ever done is through the press release links.
I used the JD Powers surveys as leverage when buying my vehicle.
Other model rankings that are interesting:
Ford explorer #193
Isuzu Axiom #219
GMC Envoy #202
The worst vehicle ranking Daewoo Lanos at #224
Worst nameplate Kia #36 of 36
I don't give this survey much credence...Subaru ranked #30 of 36...I have a subaru with 220k orig. miles on it. (Rocky MT miles) THATS QUALITY!
-mike
If "initial quality" includes the dealer rating, then with all the Chrysler commercials about being first in "initial quality" it must be that Chrysler has great dealers, since the quality does not seem to be there in many of the vehicles. They are feature rich though, I don't mean to knock Chrysler, just the notion of "initial quality" including dealer ratings.
