You said 1998 SLX - is that a typo? I thought Acura stopped selling the SLX after the 1997 model year.
First 2 coil packs, on passenger side, came off no problem. No oil in the well down to the plug or around the plug. All I could see down the well was shiny silver metal and the plug itself. Good sign, I thought.
Problem removing the 3rd coil pack on passenger side, nearest the cabin. Removed connector, unscrewed coil pack. When tugging on the coil pack to get the long tube to release from the plug, the coil pack broke away from the tube. So in my hand I had the coil pack with a little black rubber and a small spring sticking out of the hole in the end. The rubber boot and long tube had stayed down in the well.
I fussed with it for a few minutes but couldn't figure out how to get enough grip on the boot to remove it and the tube. I ended up putting the coil pack back on and drove the truck 3 miles. All seemed fine. It looks like I haven't done any damage, but now I don't know how to get the boot and tube out of that cylinder.
Any suggestions? I was thinking about just taking it to a shop and letting them change the plugs and deal with this when they see it. It's a waste of $80-90, though, since you can do the job yourself for $12-25 depending on which plugs you use. It's frustrating and embarrassing to think that I probably lack the skill to change the plugs on a vehicle, when it's such a simple procedure on this truck.
Can anybody point this novice in the right direction?
-mike
Does that help?
Tom
-mike
To add to serrano's finding hints, go to the front of the vehicle. Bend down so you are staring straight ahead at the engine oil drain plug. Now look a couple of inches to the right. Next come forward of that position about 4". That boxy thing right there on the shaft is the SOTF. The fill plug is also the drain plug as best I could determine. You access it from the back.
Your coil pack problem is a new one on me. I guess your experience is a heads up for all of us to be careful when removing the coil pack.
As to what to do now, you might call the dealer and see if they individually sell the pack AND the boot/tube. If so that might confirm that you haven't done any real damage/give you an idea of the upside dollar cost of this situation.
You sure don't want to make the situation worse, afterall you still seem to run ok. Then again at some point you will have to change the plugs. Do you have enough room to get a good bite with some long needle nose pliers (e.g. one side of the pliers inside the tube the other outside)? If so you might try them and use a gentle but firm twisiting (kind of like you are trying to unscrew it)/pulling motion. I wouldn't twist/pull too hard as you might break the boot tube. If you can inexpensively buy an individual boot tube that might not be such a problem. However if you have to buy the coil pack that could be a rather expensive whoops. Just my well intentioned but totally untested advise. User discretion is highly advised.
I found the best way to get the plug by the brake booster is to use 2 half-the-required-length extensions (I think I read this technique here way back when). Namely, feed in the spark plug socket attached to 1 extension. Then add on the second extension and then wrench loose. Pull out far enough to grab the first extension. Remove the last extension while holding the first extension. Then pull out the first extension attached to the socket holding the plug.
Re: coil pack/spark plug - Did a 50-mile round trip tonight, mostly 70mph freeway cruising, and the truck ran fine. So I'm thinking/hoping that, though the boot/coil pack may not be intended to come apart, it still functions once it has been pieced back together (like I did). Therefore, I have done no damage? A call to St. Charles, as breakor suggested, will probably be enlightening re: whether the parts are sold individually.
There is enough room to play around with a needle-nose pliers. I may try that but was worried about trying it the other day - didn't want to make things any worse than they are.
breakor, what is the 'required length' extension - 10"? 12"? I've seen those lengths at Sears, as well as 6", 3", and 1.5". Don't recall any 5" though.
Again, be careful with the pliers and your removal. You don't want to grip too hard either as that might break the tube boot.
You might want to try and find someone else who is changing plugs and do an install fest. Or, at least some real world experience on how hard to reinstall the plus, tips to not cross thread, etc. before you tackle this job. It just seems that you are cursed when it comes to repair lately and could use such hands-on teaching help.
Sam
With 1500 on the front, it is a good idea to only do 2 and not all 4 because the new ones will catch up very quickly.
Jim
My point is that it could be something simple? The windshield gasket shrinkiing in the cold and causing a whistle? Maybe just a loose belt?
Jim
I bought my Trooper 3 months ago, so I don't know how well they were rotated beforehand.
FYI - Paid $14,500 for a loaded LS with 19k miles. Thought it was a pretty good deal. What do you think?
Usually cupping is caused by a bad shock, wheel imbalance or tire imperfections.
If you have a shimmy or vibration even on smooth roads (rather than bounce) that is likely a tire balance issue.
Actually, there's a different coil pack for cylinder #6. Not sure which one that is, but the price is the same as for #1-5.
The problem is, I'm torn on whether to actually replace the coil pack. It sounds like it's not supposed to come apart like mine did, but it fit back together fine and the truck is running fine. I'm tempted to take it to a shop and see if they even say anything when they pull that one off and it comes apart on them. Do you think they'd just pull the tube/boot out with pliers, change the plugs, put it back together and not say anything - thinking either that there's no problem, or that they broke it and didn't want to fess up to it? Or would they tell me it came apart and advise me it needs to be replaced - at my cost or theirs?
As to what to do with the problem one, I certainly don't have a definitive answer. Certainly the top of the plug must be firmly connected to the wiring in the coil pack. The boot should also be in good enough condition and orientation to seal out dirt and moisture. If you have those conditions you should be fine. If not then get a new assembly. Alternatively you might also check for a used coil pack. If you can pick up a good one for $20 or $30 that might be an acceptable option.
The shop route also offers some benefits. While I doubt they will pay for any existing problem they should be in a position to know if the separated boot/pack is truly a problem. And they should not cross thread the plugs. Again this is a real possibilty that can cost some major dollars.
Thought I would let you know.
My guess would be a decent shop technician would be able to remove the separated boot/tube much more easily and safely than me, so I'm leaning toward just paying a shop to change the plugs. Maybe I can get them to use Champion or Autolite plugs so it doesn't cost as much as going with the ridiculously high Densos.
Tires are expensive and an alignment check is not, maybe even free for the alignment check. The alignment labor for the non shim adjustment is also very low since it is quick to do.
I had my alignment checked for the first time at 135000 miles. It needed minor adjustment and the steering feels better, more solid, after, even though it was not pulling before.
http://www.corbeau.com/brochure/gts2.shtml
On another note, could somebody explain the relationship that GM has developed with Isuzu? Also, I am assuming that the thought process is that the Ascender is supposed to be taking the place of the Trooper. What a joke! It is $4,000 more expensive and a heck of a lot less good looking. Is it the same as the Trailblazer? How does it compare in price with the similar other GM version?
-mike
-mike
-mike
So I am letting them do rotations and oil changes which cost $11 since I provide the 5W30 Valvoline MaxLife or SynPower Oil and Purolator PL24458 extra large filter.
As to what rotation pattern is best, the first thing to remember is that you are primarily trying to account for front to rear wear differences. Namely, the fronts wear more due to scrubbing on turning, increased brake wear, etc. The cross X pattern rotation is designed to also account for side to side differences which should be minimal with a properly aligned vehicle. However almost all vehicles have at least slight alignment issues. Thus, the use of a cross pattern rotation almost always helps to prolong tire life.
Just my $.02.
So, the TOD unit is different than the SOTF unit. Does the gear oil in the front differential also lubricate the SOTF unit? Or does the SOTF unit require a separate lubricant change? If so, I missed it in the manual, and when I changed out all my fluids to synthetics!
Also, I'm sure this has been covered in the past 6500+ posts, but what's the deal on changing the ATF? No fill tube, and no dip stick to check the fluid level??? I had to find a shop with a special machine that does a power flush of the ATF. (I don't trust the dealership.) I did not drop the pan or change the internal filter. Did others do the same when you changed out the ATF?
Front Diffy
Rear Diffy
SOTF Unit
TOD Unit
AT Unit
To fill the AT you need to drain it and then fill it up similar to a diffy where you have to put the cap on properly while it's like overflowing or something, then run it for 5 min and check again. I'm thinking of adding a dispstick tube on mine from <98 models that had it.
-mike
BTW, I like your web site....but I can't get "Paisan's Trooper Page" link to work. Is that an Australian thing?
Thanks for all your comments. What's your tie with Isuzu?
-mike
