Alan.
This was true of the old engine and the new. Also, have replaced 2 fuel pumps and fuel filters 4 times. Can anyone tell me where to find this beep code?
Thanks, Bruce
Check your oil if it is higher then it should be,ie. above the full mark then this could mean you have a blown head gascket.Allso the oil will look brownish or milky, this indicates water in your oil.
Bob Morin
its alot cheaper compared to the replacement part. and can be done under 20 minutes.
Anyway I got this problem since almost 2 years now !
1. Right bearing as been replaced first, nothing has changed
2. All bearings from the transfer case have been replaced as well, no change again.
I don't think it's worth for me to put any more money on that car but please keep me informed if anyone knows the solution...
Any ideas ??
Help!
Gretchen
Suggestions appreciated.
I got my 2000 Blazer back with a new right front wheel bearing hub yesterday. No charge for the hub or labor to replace it. I have my work done by a local garage and they are mostly less expensive than the Chevy dealer. I was real happy that they replaced the hub at no charge. The mechanic felt the life span of this NAPA part should have been 50000 + miles . Find a good local mechanic and take all your business to them and you'll be amazed at how much money you'll save not to mention much better customer service.
Another situation was a bad injection valve and finally the pump in the gas tank....seems the gas tank must hold preassure to drive gas through the system.
