Visitor Agreement.
I use the 4x4 mode in my mini-ute often. I use it in winter to get to the mountains and on the logging roads/access roads to get to my favorite fishing spots. The "car based" mini-utes will do just fine for the average person on gravel roads/dirt roads/snow and so on...
-mike
In order for AWD to benefit handling on dry roads, it needs to have some amount of power already going to the rear wheels. For example, Audi/VW uses Quattro that starts at 50:50, BMW's system is 35/65 IIRC and Subaru has a 50:50 for MT and 45/55 for VTD AT.
Ken
That's an interesting point! The largest thermal coefficient for a plastic that I could dig up is about 8×10-5in/in/°F; (for Polyvinylidene Fluoride a PVDF Homopolymer). This means that over, say, a 100°F temperature range, a 60" panel will expand nearly half an inch and is about 10 times as much as steel. (I got the numbers from here.
tidester
SUVs; Aftermarket & Accessories
tidester: interesting bit of trivia, you'll have to share that at one of the chats.
-juice
The benefits of those panels is great so it's worth having the slightly larger gaps.
I've seen that too and it does come in handy. I don't know whether the software we use has that capability but will check into it. However, I'd place getting a better search capability higher on the priority list!
tidester
That invitation should go to michitake who raised the issue. I only confirmed it with some numbers. In any case, I should try harder to make it to the chats!
tidester
I second that!
mich, I think the plastic panels are a great idea. I wish other manufacturers would take a look at this technology. With kids you get dents/dings from bikes, roller blades, balls ect..
http://isuzu-suvs.com/events for info.
-mike
http://www.auto.com/industry/gm14_20020814.htm
I was rear ended by a Saturn, and while my damage wasn't that bad the Saturn crumpled badly. Crash test scores haven't been all that good, so I wonder if they could keep the wonderful ding-free panels but improve on crash protection.
-juice
-Frank P.
Just curious.
BTW, heard a rumor that Honda may supply 50k engines and trannys for the Vue in the future, and it's supposedly the 3.5l V6 and 5 speed from the Odyseey. If so, that would be class-leading power, and maybe ratios for the auto tranny, too. Anyone confirm?
-juice
The 3.5L will be an option for 2004 as far as I know. GM is trading diesel engines for the Honda V6 gas engines.
-juice
-Frank P.
My wife's Legacy, also with a 2.5l engine but with a 1 gallon bigger tank, goes 400 miles routinely.
-juice
Do you have cargo tie-downs? I carry about 8 bungee cords all the time, to secure stuff like that. If you got in an accident, it becomes a projectile that can harm passengers.
Cargo covers at least keep them in the back, but you still get the damage.
Good luck with the fix, maybe share pics?
-juice
here's the link (click on the pics to enlarge){and remember these are Australian pictures which means Right hand drive);
http://www.autoweb.com.au/id_FOR/doc_for0110114/article.html
Odie
Maybe as the next generation Sport Trac, to replace the old Explorer-based one?
-juice
Bob
Bob
Bed is too small to be worthwhile, the rear seat is a joke. I guess if you compare it to a sedan it's not so bad, it's got a bigger trunk, but rear seats are smaller than a sedan.
-mike
-juice
-mike
Bob
But those are 2 seaters, so you're talking about a single-purpose truck. Most people want one vehicle to serve many purposes, and even extended cabs ($14.5k for starters) don't have usable back seats, not on compacts.
-juice
Bob
I think you will see it come to NA.
I haven't looked back, though there are times when I wish I had an old pickup as my hobby car rather than the Lark.
Ed
-mike
Odie
-mike
There is another factor in all this, too. And that is speed. Are manufacturers required to provide equipment that will stand up to excessive (and illegal) speeds? Would this constitute abuse of the vehicle, and therefore not the manufacturers responsibility? For instance, I haven't bought dedicated snow tires for winter driving, because 80 percent of my commute is high speed highway, at warmer temperatures. So I'm concerned about heat, handling characteristics and excessive wear. Where does the manufacturer's responsibility end, and the owner/driver start?
