Visitor Agreement.
tidester
SUVs
P.S. We're waiving the usual "off topic" clauses of TOU for just a little while! :-)
Happy New Year!?!
To the post about the part number for the updated Sequoia amplifier -- I don't have that but I saw it in the Toyota parts computer, and think the changeover date was 07/01. Check with your dealer to get the facts on that one.
Basically, I got so frustrated with the @#$% thing I said I wanted to order one with my own nickel. That's when the Service Dept. became responsive. It hasn't been shipped yet, so will post my experiences when this is settled.
My next project is getting an updated VSC chip, although that is not as big an annoyance.
He also wired in to my stereo system so they can hear through the stereo, when I'm in a rather generous mood, otherwise they wear the wireless headsets. Came with an antenna for regular TV reception, installs on the inside of the windshield runs against the inside side upward and also across the bottom, non obtrusive. Works well when in a reception area or outside of hilly terrain.
Plug:
The system works great, we went round trip PA to Arizona this year pulling a 3K lbs camper, Sequioa pulls like a champ, hit 85mph on I 40 without even realizing it.
The only problem I have encountered with the Video system is every time the kids get in the car they say the following "Can we watch a Movie." Try looking out the Windows and enjoying the beauty of America, that's your movie!!! Yes, I'm a Dad. :-)
thanx
and happy new year to everyone
Note that this applies to '02 models only. '01 models have to be re-programmed with the dealer's computer.
Hope this helps.
Are the rollover ratings out yet for the Sequoia? I did wonder as I drove around in the lovely Buffalo whiteout, but was pleased that I have side air bags and side air curtains. The numbers on the width vs. height seemed to be more friendly than those for other large SUVs, and I was guessing that the Seq. will come in with a solid three star as compared to the 4Runner's two star. The true clearance for the Sequoia is lower than that which is stated in the literature, from what I can gather, and it is two inches shorter than the Yukon, plus wider. These figures would tend to point to less of a rollover problem, although one always needs to watch. I have a soon-to-be-driving teenage son, so I do worry about these things. I suppose the boy should drive it without four wheel drive engaged if on dry pavement so that the VSC feature cuts the power for him if he gets too speedy behind the wheel? What do you think?
Along those same lines, I suspect that the crash tests for the Tundra were encouraging if they are relevant to the Sequoia, especially since the Sequoia got a beefed up cabin frame and I think they boxed in the rails when they did the conversion to the new design? I was told that beams went into the doors as well, but could not find any documentation of that.
Thank you. Hockey Mom
Given that it weighs about 150lbs more than a Yukon with similar height but a 2" higher clearance it should theoretically have lower resistance to rollover than a Yukon, however I suspect that it will be similar enough to a Yukon a earn a similar rating.
I find it hard to believe that Toyota would be off by 2 inches in determining the clearance of the Sequoia. I do agree with your assessment on longer wheelbases contributing to a reduction in rollover risk, which is why the Suburban and Yukon XL have one of the lowest risks of rollovers and in fact have some of the lowest rates of death and injury on an annual basis for any vehicle on the road.
To me, that indicates that there is a difference of only .6 inches in clearance between the Yukon and the Sequoia in reality- which is relevant as regards the true stability issue. The two inches I am referencing, however, is that the Sequoia is shorter from the ground to the top of the vehicle. I do readily agree with your point that the XL and Suburban vehicles will have a greater stability if the underlying safety contributions from the vehicle stability control feature is not considered due to their longer wheelbases, also the Ford Excursion. The Escalades that I saw were all stickered at the 50K mark, so I didn't consider those very much, even though it has stability in it. Did it have side air bags and side air curtains? X5, Mercedes and Sequoia did, and that was important to me, too. I'm not sure my teenage son should start out learning to drive in this big vehicle, to be truthful, and that was the reason why I had picked the earlier Volvo XC. I'm not sure what I will do when the time comes for him to get behind the wheel!
tidester
SUVs
On the subject of teenage sons learning to drive, I also have a 16 1/2 year son with a driving permit. He drives the Denali XL quite frequently although he prefers driving our Avalon as a new driver. Not sure what we'll get him as a first car, although I doubt it'll be an suv.
BTW, The GM F/S SUVs including the Denali and Escalade have side air bags installed in the front seats as well as the typical front air bags.
seems so familiar....
1)No search engine
2)Message numbers that don't match
3)people who don't realize that the wind resonance
is the sign of a tight car
4)GM trolls throwing turds from the corner
of the room
Oh well... is there a dealer fix for the bass problem? I'd imagine that the 02 don't have this issue. So what got changed and who do I have to yell at to get it fixed?
Jim
> the bass on the stereo sounds like you're sitting in a bass drum in a 4th of July parade;
> the stereo's fader control does just that - the sound fades away out the back window;
> if you open the back window, or ANY back window without using the proper combination of equal window-cracking compensation, the deep resonating buffeting will cause your head to implode;
> when you turn off the vehicle, everyone is imprisoned unless you consult the manual for the deprogramming of the auto-lock feature. That would be the cure except, a few key syllables got dropped in the translation from Japanese to English;
> If you're cold, you shiver until your bones rattle. Same thing with the Sequoia - the valves tick until warm. OK, maybe it's the injectors instead - just wrap little sound-deadening coats around them and all will be better;
> If you go into a skid, you'll die. First you'll be frightened by the skid itself, then your heart will stop when the VSC starts beeping loudly. If that doesn't get you, you'll die from reaching down to turn the VSC off and slide into some permanent, immovable object;
> the dash rattles, the tires wander, the brakes fade faster than my favorite jeans, and that creaking noise up front means I have a lousy weld-job.
Yes, Sequoia fans, THIS is QUALITY! After all, Toyota has a reputation for quality, so we should equate all of these little quirks to "character." As for me, I'm afraid I must admit that I'm becoming a bit disillusioned as these discoveries continue. In the meantime, I'll seek some solace in that smooth silky ride and sweet purring engine (once it's all snuggly & warm).
So, is that all?
iForce engine, smooth and elegant acceleration, well proven in the award winning Tundra with highest reliability documented in the Consumer Reports data for several years. Very nice comments on the Tundra engine anywhere you choose to look- magazines, owners boards, consumer data.
Pretty inside and out. Enormous and has three rows of adult sized seats, all in elegant grey leather.
Safe, large, reliable to 200,000 miles and pretty and pleasing to drive. Sequoia sure beats the competition, Yukon, X5, Escalade, Mercedes, Suburban, Jeep, Jimmy, Explorer, Isuzu, Honda, and whatever else that you might wish to look at. Works for me. I have owned a Yukon, a Mercedes, a Ford Bronco and a Jeep Cherokee- each one of which disintegrated in expensive ways somewhere between 75K and 100K miles. I bet on the Tundra engine and the Toyota reliability reputation. The dealer was a dream to deal with, too, took me far less than 3 hours to purchase and drive away, including test drive and loan and emptying my car out. I was at the GM, Volvo, Mercedes and Jeep dealerships for hours and hours and hours while they screwed around with the paperwork. Then back later to get the things repaired (except the Volvo) over and over and over again at my expense. Hope that straightens out exactly why the Sequoia is a very good choice when the data are compared. Hockeymom
VBG is what comes from reading some of these rather colorful posts...
Thirdsuv: the amplifier changed part numbers around last July. I listened to an 02 in the dealership and the problem seems to be gone. What I told the service person was that I wanted to order the new amp. That's when he said he could probably get it replaced gratis.
Minuteman HA! THAT was pretty funny. You've been watching me drive?
pschreck Actually, I drive a 2002 Sequoia SR5, 2WD. I thought about the MDX, but fell for the SEQ.
Thirdsuv my 2002 has the BOOMING bass.
Hockeymom Yes, all of those attributes are wonderful, BUT... shouldn't we have a quality product for our $$$??? The brakes stop quicker than others, but shouldn't they last awhile? I have 3,700 miles and I can feel that the rotors are warped already. And I BABY this beauty. Gee, how convenient... whenever I drop in for a 3K-mile oil change, I'll just have them throw in a new set of brakes!
And back to minuteman for a second: I bought my SEQ mostly for safety features too, but don't the brakes figure rather prominently in that equation?
My point is... I shopped for quality, I paid for quality, and I want quality. I love the Seq, but I'm very dissatisfied with many of its quirks (shortcomings/defects). Why do we allow ourselves to settle for less than satisfactory?
Seriously, did you not do your research before buying your Sequoia? You sound disappointed with your choice.
You could visit a forum on any vehicle and find individual or even small group problems. Many of them have much more serious problems than the Sequoia.
Haven't heard of warped rotors from anyone yet. Doesn't sound normal for Sequoias.
I had an 01 and now an 02. The stereo sounds exactly the same to me.
The VSC is definitely calibrated differently though (better).
It amazes me that so many folks buy a heavy duty SUV which has more in common with a truck and are disappointed with it because it isn't just like a car. So why didn't they just buy a car?
The Sequoia is the nicest truck I have ever owned. Your complaints are nits, and very subjective. The 6 disk JBL stereo in my '02 is the best sounding stereo I have ever enjoyed in any car, try tweaking the controls a bit. This wind noise thing with the windows down is ridiculous. Who the heck drives around with their windows down? And if they do, why? the HVAC is flawless, and if I need more air, I just open the sunroof. If you want windows down without problems buy a convertible. Are power door locks new to you? Did you notice that front doors will open by pulling on the door handle even if locked? Brakes wearing out? I doubt it. It's a heavy vehicle, don't treat it like a car and the brakes will do fine. Congratulations if you have warped your rotors in 3700 miles. You are the first and I hope you won the road race you were competing in.
Since you have cleverly compiled complaints and issues from many different posters on this board, I think that you are just a ringer and don't really own a Sequoia.
Goodness gracious, even the GM owners don't eat their own young!
ibmindless: You're not alone in some of your quality and rattle concerns you expressed on a "fabled" Toyota. Here's a recent post on one of the GM forums by a current Toyota owner "I've had a Tahoe (96), a Ford Expedition (98) and a I currently own an 01 Toyota Sienna XLE (their high priced minivan that prices out every bit as much as a mid-line Tahoe or Yukon). I bought it for one reason....all the BS hype about what fabulous, state-of-the-art vehicles Toyota makes. If you wanna hear squeaks, rattles, buzzes, and whines, get yourself a Toyota. My 01 Sienna has a rattle in the dash, the sun visors make noise, the rear drums whine, the driver's side window pops when partially lowered, the center chairs hollar when I hit a rough patch of road, the rear seats sound like a box of loose tools, and I've got under 11k miles on it. I only say this because you need not kick yourself for buying a Chevy. At least you have a gutsy workhorse that's a little bit sexy. Both my old Tahoe and Expedition seemed like limos compared to my Toyota. I'm going to loose this thing soon and will probably get a Yukon or Tahoe."
714cut Yup, I did lots of research, and I duly noted some of the glitches - like brakes. I read a couple of complaints that they go out @ 15K. I figured the driver must have thought they were driving a car rather than a 2 1/2 ton truck. But here I am - worried that the brakes are going out.
As for that reverberating wind-thing, tell it to my kid. He opens the 2nd-row window a few inches and the pulsating noise is torturous. I experienced a similar buffeting long ago in a VW bug, and old Ford station wagon, but I figured the industry had streamlined that away. And YES, I know I could find worse problems elsewhere; in fact, I've been there and done that. That's the whole point of my dissatisfaction at the moment. This is a wonderful truck, but these nits are more than nits & quirks --- they're quality issues.
2heeled You're right - I'm busted. I'm so ashamed. I really drive a Kia Sportage. But I put a lift-kit in it, so now I can be at eye-level with Sequoias. And everyone knows the Kia manual doesn't go up to page 26! In fact, I voided the warranty on my little Kia by inserting the ignition key and activating the starter (Paragraph 2, page 1 "Do Not Attempt to Start the Vehicle or the Warranty is Null and Void").
heatwave Since I voided the Kia's warranty, I figured I could hop-up the little beast, so I added a Sienna's fuel injectors (much quieter than a Sequoia's). Now the Tahoe owners cringe when I pass them by, towing my '98 Expedition over hill and dale (I'd be happy to drive the old Ford, but it gave up the ghost even after I bought it new brake shoes & socks).
The Mindless Home & Car
We haven't seen this much action since Heatwave started his musings.
Heatwave: We knew it wouldn't take much to get you out of lurking in the weeds!
