FYI, for those that figure out how to disable trac and vsc, this thing does a hell of a donut.
I noticed that most people who switched to 275/70/16 used the LTX M/S. Will the 275/70/16 Cross Terrain fit as well into the wheel well?
Please share your experiences. Thanks.
SteveK80 On the other hand, if I go with a used 2001 Sub they are all over the place for mid $20's. And I do like the extra space. People say they have some problems....but I think it is a hit and miss deal. Some I know have had zero problems since new other quite few.
I will have the second child in a month. So I need to decide soon and get rid of the Landcruiser.
Thanks for the feedback.
I tested a 2003 Limited with 36K miles. The highway we were on was course at first. I was surprised how trucky the vehicle felt. Delightfully smooth engine and transmission but the ride was not much better than my 01 Land Cruiser. Anyhow, I had the salesman with me and sure enough at 50mph I heard and sensed under my feet on the driver side a mild grinding noise. Kinda like the transaxle was not well lubricated?
It went away at 60 and the salesman had no idea what I was talking about.
I do mostly city driving so my numbers aren't usually as high as robertbick's but I've been keeping track of my fuel consumption since I purchased my Sequoia and have been updating it here:
http://www.istargazer.ca/suv/sequoiafuel.htm
Does anyone care to comment on their experience in the carpool line with a Sequoia?
We are considering an 04 Sequoia SR5. My wife is concerned that our small children and their friends would struggle to get themselves and backpacks past the middle right seat and into the back, and then to pull the seat into upright so the middle passengers can get in.
Have you found that a child standing outside of the vehicle is able to release and fold up the middle seat from, or will my wife need to do it herself before getting into line? For morning drop-off, would a child sitting in the 3rd row be able to release and fold up the seat in order to get out?
Evidently, the carpool line at our school is a high pressure, teeth clenching race to load-em up, move-em out.
She's also concerned about the width of the passenger door (feet scraping against the door as children get out).
Our other choice, the 04 Quest SE, has great entering/seating conveniences but limited towing ability (we'd like to tow a small pop-up camper with the vehicle we eventually purchase).
There really is no way to effectively release the second row while sitting in the third. But, usually if their in the third row then the ones in the second row would fold the seat on their way out.
If you're looking to move alot of small kids around a minivan is a better choice and most should pull a pop-up without much problem depending on its size. However, a Quest is not the greatest choice as the have been riddled with quality problems.
You just bought a 2004 and NOW your asking if it fits into a normal size garage? Don't you think you should have checked first? 8-)
What part of New England do you live? Where did you buy your truck? I'm in Connecticut and I agree.. it's VERY COLD..
I live in MA, it is actually much warmer today ! Just in time for big game tomorrow, yahoo...
Highway driving might present a challenge. Not a horrible one, but one you need to be aware of. I drive up and down Interstate 95 in VA with my rig and do so at 70 to 75 MPH. I do this with the overdrive off. This is CRITICAL! Yes, I'm driving at higher RPMs (about 3000 give or take) but it keeps the transmission from heating up. The only challenge you really have is that your vehicle weighs more than mine to start and your boat/trailer combo is 2300 pounds more. I'm guessing 60 is going to be about the extent of things.
I hope this helps, even if it doesn't answer everything.
I am thinking of purchasing a base SR5 with:
1) steel wheels (upgraded on my own)
2) no running boards ( nerf bars instead )
3) no trailer hitch ( will do myself )
4) no sunroof ( I will live without )
5) other stuff.
Any thoughts on this being a hassle vs. spending the extra $3-4K?
I just picked up my Sequoia SR5 (4x2) two days ago. I special ordered it from a dealer on 12/3/03. Some dealers special order but most don't.
In Southern California all of the SR5's only come with cloth seats. I didn't want the aftermarket so I special ordered mine with leather. It was worth the wait to me. I only had to put $100 down on my credit card. The fleet salesman told me that if the buyer changes their mind it's not a big deal becasue then they will just sell it off their lot.
Be sure and put the Sequoia in low range 4WD before backing down that boat ramp, loading or un. The only time the center diff'l is locked is with the shift in 1st gear position and low range.
Bad timing to start pulling up the ramp and discover the brake apportioned AWD isn't quite up to the task.
As too running with overdrive disabled to prevent transmission overheating I would think it to be the other way around. In overdrive the "locked" torque converter isn't doing any work at all whereas with the extra load and not in overdrive it will be doing LOTS of work.
And I have never heard of a torque converter being locked except in OD when the tranny output shaft is turning faster than the engine.
So you are not alone if you have also experienced it.
Its your front differential. Toyota knows about this. Have your dealer contact its regional office and ask them about it. You'll most likely be given a choice of an arbitration hearing where you'll probably be offered a buy back, or they might want a chance to replace your differential first.
It isn't the tires. Ask me how I know.
With the torque converter locked the converter isn't doing ANY work and unless the bands or clutches in the transmission are slipping it seems unlikely that the tranny would overheat of itself.
Just so you know from where I'm coming I would NEVER run in OD with any indication that the engine is "lugging", even slightly, to get the job done.
Oh, and I did have a T100 at the time and it did come with a transmission oil cooler.
I don't know the mechanics behind it, but I know the results.
