Visitor Agreement.
Does any body experience the similar problem with his/her Rodeo? I would like to know if there is a known problem and a handy fix before taking the SUV to the dealer. Thanks.
Joel
-mike
link
Short version: Listen to Paisan :-)
-mike
1) Is it very difficult to replace the ABS harness, is it something I can do myself or one needs special tools?
2) What precaustions should I take to drive it while I know that my ABS system may not be working properly?
3) Can I disable the ABS and still drive it safely?
Any help or advise will be greatly appreciated, and many thanks in advance.
Chances are it's not the harness but rather one of the sensors has a bad connection. I'd start with checking out the connections and putting som di-electric grease on em. Then take it from there.
-mike
Joel
slower burning properties of high octane fuel. You will eventually clog your EGR feed tube &
passages if you continuously run high octane fuel in this engine.
I have never heard of this happening. Most modern enignes adjust for the octane level of the gas being used. there are a zillion cars out there using 91 octane that were designed for 87 but run like crap on 87.
jayboreed "Isuzu Trooper" Nov 21, 2001 4:27am
Joel
Like this Rapidfire one:
mcpdjohn "Spark plugs - Your favourite brand and type and why?" Mar 1, 2002 11:59am
Has America totally abandoned Isuzu. I am currently trying to sell my Rodeo, and nobody is calling me to look at it. Too bad, they are good vehicles but are going unrecognized.
BTW, if anyone is looking for a 95.5 Rodeo, extra clean let me know and I'll give you the details.
Joel
Mine is a 97 with 90,000 miles. They seem okay but I was considering having all four of them done when I get the lower ball joints replaced as the grease boot has split open on both sides.
-Ryan
Joel
I am a car guy and can fix, repair and upgrade almost anything.
I checked edmunds service interval for this car states at 40K to change auto trans fluid.
Any other recommendations? How about shocks, does ride a bit bouncy. Also, anywhere i can purchase a strut/shock tower brace? I've read about the ABS shimmy, I think the brace would resolve.
I am a sports car fan, but that cracked me up
There are none available to my knowledge for the rodeo, Offroad trucks are supposed to have flex, not to mention you could stiffen up the body all you want but if you want to stiffen up the chassis you have to do it on the frame level.
Cool to see another NY/NJ person here!
Shocks people like on the Rodeo for on-road are the Monroes IIRC. If you ever want to do some offroading down in the pine barrens check us out http://isuzu-suvs.com it's our home offroad area.
-mike
Joel
Just curious if anyone else has run across this or if it is common on Rodeos?
Joel
-Ryan
There is an Isuzu tech (+20yrs) who has been posting answers to questions on another board for the past few weeks:
. . . and here is his answer to oil useage on +98 . . .
quote:
Most of the complaints of oil usage is on 98 up and I see alot of them. It's in the piston design they changed them in the 98 3.2 run. They only have 4 drain back holes on the oil ring. The new ones will have 10 or 11. Oil is building up and sticking in oil rings. Best way to keep from this doins this is keeping the EGR port clean and the pcv valve replaced. On the 95 3.2 I would say it couldn't hurt to have the egr port cleaned, injectors cleaned and the upper intake decarboned.
-Ryan
Joel
Joel
Joel
-mike
Recently changed tires, did alignment, balanced the tire and checked brackes and resurfaced the rotters.
After this work I noticed that there from passenger side wheel is not setting correctly when I drive and creating bumpi ride. Went back to Firestone for eaglignment and they found nothing.
Do we need to do 30k maintenance work $900 for our warrenty to be valid one?
JohnEagal
-mike
-Ryan (2000 Amigo)
