Visitor Agreement.
-mike
-mike
Thanks!!
-mike
-mike
Steve
I had a similar problem with my 2000 LS. After three trips to the dealer where he rotated the tires and did an alignment twice, the mechanics realized the problem came from a misinstalled mud flap. The flap was hitting the front right tire, and causing a drastic pull to the right. It only took them a minute to fix the flap, and i've been good ever since. You might waht to look at your mud flap just to check - the wear was very noticable.
I found that driving style will dramatically impact your milage. Here are the milage stats for my Trooper. All were taken after 10K miles.
1) Highway steady 76-77mph, cruise control, hilly northeast terrain, +4-5psi in tires above stock 15-16mpg
2) Highway steady 60-63mph, cruise control, hilly northeast terrain +4-5psi over stock 19-20mpg
3) City jackrabbit starts, gas-break-gas-break, bumper to bumper traffic, etc, 10-13mpg
4) City gentle driving, no bumper to bumper traffic 12-15mpg
5) Highway steady 75-77mph, cruise control, hilly northeast terrain, 3500lb boat trailer, 11-13mpg
The Trooper is 4500lbs, always has the TOD 4wd system engaged, and has the 3.5l 215hp engine.
-mike
A local dealer is advertising 24 mpg on the Rodeo V-6! I think they can get away with that because that is the Max. MPG on your window sticker (in fine print).
I'm not concerned with the check engine light because I expected it to come on when the speedo stopped.
I'm assuming something is messed up with the electrical system connected to the speedo. Everything else is in excellent working order.
We took it in to the dealer and were told it has been happening with some of the 2001 Rodeo's and that simply changing the speedo does not work. Apparently they are looking for some type of short. I was told "engineers at Isuzu are looking into it right now and that I should hear from them in a couple days." I'm just trying to find out if ANYONE else had had this problem, or has heard of anyone having this problem....
Thanks for any responses....
-mike
Seriously though at around 60-65 you will get significantly better milage.
-mike
The 00 and 01's come with 3year/50k "bumper to bumper" and a 10year/120k "power train" war BTW.
The Major Guard will almost be a bumper to bumper war. as it covers things like powerwindows and sunroof motors, and some major brake parts which might make it worth it if one goes after 5 years.
My buddy did use his on his Pathfinder(Fidelity was the company I think) tranny right at the end of the extended warr. he did get his money back and some but still had to come out of pocket for some non-covered parts.
If it is the Fidelity one, don't get it as it has alot of stuff that is not covered. If you have Geico Ins, they cover the same amount of stuff but only cost 30 bucks a year. Between the factory, extended, and Geico, you should have it all covered.
hope that helps,
Con
-mike
1. The o^2 light stays on on the dashboard all the time, what does that mean, what does it do, and how do I repair it?
2. While driving, we hit the 55mph range and it runs like a dream, but then while slowing down(around the 45mph range) it begins to pull back, no stalling or anything bad just pulls back. Any ideas or solutions?
Thanks for reading this
-RatBreath
Please help.....
Todd
-mike
Depends on what you think is safe? If you were looking at a Ford F-150, The Rodeo and Trooper did much better than it in the 40mph test. But no truck is as safe as a car in the same test(except for the car based Utes like the BMW X5) but for lower speed crashes(which IMHO is more common) a bigger heavier truck will do much better to protect(but cause more damage to the other vehicles as well). So if you are looking for the safest SUV, it is the BMW X5(but it is over $50k) which is car based. Or you could get the Aztek or Escape which are car based as well. But none of them is a Isuzu Product which IMHO is a great value(plus 0% fin too!), cheap on Insurance, and safe enought for most fender benders which is why I just got a 01 Trooper myself.
Good Luck,
Con
-mike
-mike
-mike
http://www.edmunds.com/chat/isuzuchat.html
-mike
-mike
DCH
Con
Luke
