Visitor Agreement.
On a different front, I was in a minor fender bender about a week after buying the truck. Someone tried to do a UTurn in front of me during rush hour traffic. The impact was probably between 5 - 10 mph, but did over $1,300 in damage. Visual external damage was minimal, but some stuff up under the front fender, one of the headlights, and one front quarterpanel had to be replaced.
-mike
I had a vibration problem at 20K miles ('99 Passport) and went with Hunter GSP 9700 for balancing two times and was told it's not the tires (tires were good, Bridgestone duelers).
I manually measured the toe alignement and adjusted it to near zero (spec is with slight toe-in). That solved my vibration problem.
Keep us posted.
My 2000 Rodeo seems to have a problem when I go over any type of bump and coincidentally step on the brakes, I get almost an ABS chatter in the brakes. Happens almost every time I hit a serious bump. Anyone else have that one. Other than that, the Rodeo has been pretty good so far.
-mike
http://www.edmunds.com/chat/isuzuchat.html
-mike
I also am experiencing similar problems. I have a 99 Rodeo LS with the 6-disk in dash changer. Last week, it just stopped working (while in use), with 4 disks stuck inside. I cannot play or eject any of them. I just get a beeping sound and an "Err 3" message on the display. My warranty has expired, so i was hoping that there is a fairly easy fix that I could perform on my own. Right now, I'd be happy just to get my disks out. And the owner's manual is not helpful at all -- it merely says that if you get the "Err 3" message, then eject the disk -- but I can't! Any thoughts out there? Sounds like I'm not the only one with this problem. Thanks for any help...
Luke
Cheers,
Con
P.S. How far out of warr. are you? You might want to call Isuzu and see if they will fix it anyway as it appears to be a common problem with the 6disc. My mom had her power winder motor replaced(Galant) after the warr. as "goodwill" which many manufatures still do today.
Have anyone been having such problems. Right now I am fighting with Isuzu and the dealers because I sure as hell don't want this vehicle any more.
Any advice will be greatly appreciated
-mike
Steve
-mike
At least they admitted to hearing the squeak but they explained that it's due to the new material used on brakes--material without asbestos.
Has anyone ever heard of this? And how come it seems that my Rodeo is the only one doing it?
-mike
email me if you wanna chat.
good luck
Ciao Bello!
-mike
Various sizes and shapes, some new and some very old. Also we tested some digital
gauges some cheap the others expensive. Our test was conducted at our aircraft maintenance shop and against a highly accurate calibrated air pressure standard. I took each gauge and measured three air pressures consisting of 25, 35 and 45 lbs.
All the testing is done and the results in Parts will be published at various times.
Part one consisted of the most popular tire gauge called the pocket or pen type gauge which cost anywhere from $ 1.00 to $ 2.50 range and they have a white plastic dial reading. I tested 5 new ones (Victor, Monkey Grip etc) that were purchased at nationwide chain and auto stores. Each of the new ones read entirely different pressures with the worst being as much as 6 lbs. lower at 25 lbs. While an exact duplicate gauge read 3lbs. lower at 25 lbs. The new ones where mostly 3 lbs lower at 25lbs but improved at the higher pressures of 35 and 45 lbs. There averages where about 2 lbs. at the higher pressures. I tried exercising the dial a few times by pulling it in and out and taking the readings again and some improved by as much as a lb. at the lower reading. I then test older gauges of this type 3 to 10 years and the results were worse in some cases. It seams the older the gauge the lower the accuracy and they are the worst at the lower pressure. Some were off as much as 8 lbs. By the way all of the gauges we tested read low except one and that had an obvious defect. I took the older gauges and sprayed the dial with WD-40 and exercised it about 10 times and then I went back and redid the test and improved the readings to that of a new gauge. One gauge was 7 lbs lower at 35lbs and after my operation the gauge improved to about 2.5 lbs lower. One gauge that was 10 years old had better accuracy than one that was 3 years old, but generally the older the gauge, the lower the accuracy of gauges of this type. You get what you pay for.
In conclusion its best to add 2 or 3 lbs of more air to your tires if you use this kind of gauge. If you want 30 lbs put in the air till your pen type gauge reads 32 or 33 lbs. and don't forget to exercise the dial a few times before checking the tire pressure. On the older ones spray the dial with WD-40 or some silicone lube and exercise the dial about 10 times.
Part 2 deals with more expensive gauges with some surprising results until then-- by
DCH
-mike
I finally had one of my mechanics ride back there and when we stopped the vehicle he looked up under the rear left fender. There he found a metal bracket that supports the rear fender. He bent the bracket so that it was in a more "taut" position.... rattle disappeared.
Do your best to identify exactly where the rattle is coming from. It's usually something simple.
DOES YOUR RODEO LS V6 MAKE PINGING SOUNDS ON ACCELERATION, ESPECIALLY AFTER 30 MPHs AND MORE PREVALENT AS YOU GET FASTER UNTIL YOU STOP THE ACCELERATION?
Over on the subaru site, a lot of people are noticing a similar thing on their cars since the warm weather has started. It could be bad gas roaming around, or ODBII causing problems.
-mike
-mike
DCH
I had the same thing on my 2000 V6 Amigo, at about 10,000 miles. I tried a bottle of Cheveron Techon, (which is suppose to clean the injectors and valves) advice from a member here. And 1500 miles later I have not heard a ping yet! Try it and see if it helps. It's only like 4 bucks at Walmart.
DCH
My 2 cents.
Looking forward to the other parts!
Drew
www.fumotovalve.com
Work great, I have them on four of my engines now!
EVERYBODY WHO RESPONDED: As for the Cheveron fix, that is interesting. Describe to me the "Ping" that you heard so I can feel better about whether or not we are describing the same noise: what it sounds like exactly, when you notice it, etc.
As far as using the Cheveron treatment, doesn't Isuzu frown on additives like that? Do you guys think it would be okay to add something to the motor like SLICK 50? I do not want to void my warranty. I intend to drive this car untilt he 120 miles are up.
Thanks for your responses.
-mike
The knock sounds like tapping a screwdriver to the engine block when accelerating.
My 2 cents
Side Note: I use about 3/4 quart of oil every 2,000 miles, so I would guess that this is where my oil is going (intake and combustion chamber).
As to Techron, one of the best fuel addtives going, I have used it for years on multiple cars. I also use Amsoil PI consistently on several engines including the 3.2 L Rodeo. Injector cleaner etc. similar to Techron.
Oil additves are a different animal and never live up to claims. Use a good synthetic but additves, never. None have ever been proven to work in independent lab tests!!!!!!
In summer heat engines that have never pinged before may do so and usually higher octane solves that issue but Techron is a cheap cure and cannot do any harm, a really good product.
Also, the sticker on the door says that I should put 26psi (cold) which seems rather low for me. What do you think is the normal tire pressure for this truck ? Right now it shows 33psi after about 40 minutes of driving, so I think it'll be about 30-31 psi cold.
Thanks for any feedback...
-mike
http://isuzu-suvs.com
It pings only during acceleration uphill. I looked into the manual yesterday and it said
ping during hard accel is normal! Hmmm, I am going to pour two bottles of Techron
on my next fill up.
