Thanks for the info about the alignment. I just need to find a dealer that can actually do that right. The one that is next to me can never do alignment right from the first time - I guess they need to take classes from Big-O tires :-)
Another thing that kinda interests me: The dealer who sold me that truck said Isuzu uses some kind of patented brake pads for Rodeo and they are supposed to last about 80K mi. Anybody heard about something like this ?
My 2 cents
As for the pulling, I just took my truck in (11,700 miles) to the dealer to have the alignment done a few days ago. It is covered for 12 months 12,000 miles ... mine pulled to the right ... the steering wheel moved about 2 inches to the right when I would let go ....
As for the Ping .... I think Isuzu needs to issue a computer flash update ... way to many folks here pinging away!
-mike
Good Luck,
Con
DCH
DCH
Now, Isuzu is aware of this pinging problem, because I called them. They say it can be adjusted with a computer adjustment, and they issued a "CD" as they say to dealerships. I took the time, and money, to drive my car to Stevens Isuzu to have this fixed. The Service Manager refused to have a floppy over-nighted to fix the problem while waiting for the CD to come out. He said that what I was hearing was normal, and that all Isuzus make the pinging sound. He could have easily gotten the floppy and put both our minds to rest that he was right or I was right. But he wouldn't do it. He said he would wait for the CD to come out at my next service with the fix. So now, I have to drive this damn $25,000 car around with this pinging sound until my 15,000 mile service, and I don't really even want to take it to Stevens to have the service done.
So, I hope everyone is right about that Chevron stuff. I went to Walmart to buy it and they don't have it. I will check a parts house.
Take my advice, stay away from Steven's Isuzu in Wichita, KS. They are in too big of a rush to properly take care of their customers. You take the car in at 9:00 am, they don't get around to it until 3:00 pm, they spend very little time with it, and then they tell you they can "reproduce" the problem, or there is no problem.
I'm taking mine for alignment next week and they better do it for free! It'll be different dealer than the one I bought the truck from, but I hope they don't start giving me B.S. about hitting a curb or something like that...
Next time you catch something, and it's within 30 minutes of posting, you can click on the Edit button and make any changes or fixes you want to.
Steve
The results show once again you get what you pay for. These types of meters showed pretty good accuracy over the ranges and age didn't seem to slow them down on the lower range.
Part 3 which consist of Digital Gauges will follow soon. One tested so accurate, I went out and bought one and tested it for repeatability and it indicated the same as the first. Which one was it? Stay tuned Until then---by
DCH
Con
The machine that fixes the balancing problems IIRC is the Hunter 9000 machine. You can change tires all day, but it's the rims, not the tires.
-mike
DCH
DCH
I use the digital gauge from Radio Shack and it's been great so far. The measurements are prety accurate, I assumed, since I use my brother's dial gauge to compared it to and they came out very close to each other. I used to have the pen style one but I found it sticky sometimes and not really consistent.
Should we forget this car and look for another rodeo???
-mike
http://www.edmunds.com/chat/isuzuchat.html
-mike
-mike
dch
-mike
Wes
~Wes
-mike
Okay, since I have a tendency to leave my lights on, the project I now have planned is that I am going to buy a kit which automatically turns on my lights when I turn on the vehicle and off 30 seconds after I turn the car off hence eliminating the need for me to manually operate these. With the recent addition of a center protector to the front end of my car I also added an extra pair of auxiliary lighting and fog lights. What I propose to do is rewire the lighting so that when I push the "Parking light" button power comes on to the fog lights and when I push the button which formerly activated the headlights, it activates the new pair of auxiliary lights.
I know this sounds weird but if you know of any wiring kits or have attempted anything similar, your help would be much appreciated. Thanks.
~Wes
Also, another thing that kind of bothers me is when I first start it in the morning, for the first couple of minutes I can hear some excessive noise, which sounds like a wind blowing in the tube (that's the best I can describe this). You can hear that kind of noise from old V8 American trucks. It disappears after couple minutes of driving though. I don't think it has something to do with high RPMs, because the RPM level is pretty much the same as usual. I'm planning to mention this to the dealer when I take it for the oil change, but I know they will not be able to duplicate that (as usual :-)
RS9179 rear
Those are the part #s for the 98-01 Rodeos for the Rancho 9000 shocks. Hope this helps.
-mike
Thanks for the info Mike! Great site, by the way. It's giving me some good ideas on how to make my Rodeo, which I love, more off-road worthy than it is now.
Also, has anyone has any experience with the Calmini lift kits for the Rodeos?
~Todd
I am not a fan of Calmini, very bad customer support, etc. I would go with OME rear springs and a Sway-away front T-bar replacement which should give you about 2" of lift, more than enough for bigger tires.
-mike
I'm going to become a part number pest. I tried to find OME stuff, and came up with little. Any idea on where to get it, and what parts I should get? This information is wonderful!
>I am not a fan of Calmini, very bad customer >support, etc. I would go with OME rear springs >and a Sway-away front T-bar replacement which >should give you about 2" of lift, more than >enough for bigger tires.
-mike
