Visitor Agreement.
I own a 2000 Amigo (same as the Rodeo), and I have only had a popping sound come from the doors that was repaired under warrenty.
-Ryan
Hope this helps.
-mike
Basically if you put that Honduh engine in your rodeo it won't last very long, cause it will be overworked.
-mike
The reason for the difference has to do with the whole HP vs. torque an engine produces.
In the extreme, nearly all diesel engines are undersquare, and we are all familiar with the noise levels produced by diesels.
I will also grant that many SUV engines out there are more "carlike" due to the use of them as family grocery getters instead of tow/haul vehicles.
wet plugs after 2 days or 25 starts. To date I have replaced:
fuel filter ($20), spark plug wires ($75), oxygen sensor ($300), fuel injectors x6 ($1100), spark plugs x 1 million.
All of these by an Isuzu dealer in the month of January alone(please add exhorbenant labor costs) and this dealer actually asked me not to bring it back as they have no clue. All fuel system componants are checking out good, ie :pump, pressure reg, mixture valve, etc.
The problem is most evident at a cold start without touching gas pedal....it floods to smell and plugs are wet x6.
The truck is currently at the other Isuzu dealer in town for perusal of current fuel and/or possible spark related problem (and to repair the radiator that "exploded" on the way there to drop off for fuel problem.)
I bought this truck on 01 sept. (5 months ago) The altenator and the head gasket were replaced, as well.
I am currently in a active search for a tall, steep cliff in the San Diego area.
MarisueN@aol.com
I don't understand how the plugs get wet though. That is weird!
-mike
Re: Engine noisy... I too noticed the engine to be very noisy when I just start it in the morning. However, the most noise goes away when the truck warms up. I was told by the dealer that the noise is produced by "clutch fan." I have no clue why the clutch fan (assuming there is such a thing) needs to go off when it's freezing outside, but it seems to be the case.
The thump is not normal. Again I too have. Some folks report that their dealers will do the temp. fix which is to repack the slip joint in the drive shaft with new grease. The word is that it will keep the thump away for about 7k. I find that easing off the brake slow from a stop helps to lessen the thump feeling.
So if you have not tried techron yet run two tanks of gas in a row with it in and take your truck in and have the dealer repack the slip yolk.
-Ryan
I love the Sorento but it all depends on what you are looking for.
Off-road the Rodeo is a better chassis.
More Power
Longer better reputation
Pluses for Sorento:
Available AWD + Low Range
Slightly cheaper
more kia dealers
slightly more refined
Big toss up, but either one would be an excellent choice IMHO.
-mike
The 4L30 tranny in the Rodeo has a very low 1st gear which could hurt off the line acceleration. Also I suspect weight of the rodeo chaissis might be higher.
The Clutch fan is the std. fan for the engine. The electric fan comes on when additional cooling is needed and should always be on when the A/C Compressor is on to suck cool air over the condenser unit.
-mike
If your theory comes true, then Japanese parts may be equally hard to come by.
The other thing is that the Rodeo warranty is now 7/75 not 10/120.
-mike
-mike
willie340: The US bumper to bumper warranty is 3 years/50,000 miles, the 10/120 I'm referring to is powertrain only. All the companies that offer the 10/100 or higher warranties are all only on the powertrain, but those are the most important parts anyway.
-mike
At least on Isuzu built products you know the dealers have been working on them for ~5-10years give or take a few minor changes over time, and they are far more reliable, so the chance that you'll need to visit one of the 400 dealers is less.
Just my opinion on the Ascendor warranty.
-mike
For instance a Trooper that stickered at $33K new in '02 is now selling for $20-22max, maybe even less than $20K and is comparable in size/features/reliability as say a $35-40K Toyota.
-mike
Re the warranty...I had a '95.5 Rodeo that bumper-bumper went to 60,000 miles...can'r remember if that was 60 months or 36 months. Traded it in on the '00 Trooper.
Of course the dealer could not recreate the problem and was not given any more attention.
I have had to replace the battery due the 'stuck horn'.
Me and my neighbors would greatly appreciate a solution to this problem.
Put in an after-markter horn and change the buttons or add a kill switch?
2) Slow wipers? Seems like a very subjective subject, slow to you make not be slow to me. I'd have to see them to see if they are actually slow or not.
3) Engine Noise: Isuzus make loud engine noises in the morning, not ticking per-say but fan noises. If you have ticking it is probably because you let your oil go low.
4) Starter? Doesn't seem right, but again I'd have to hear it to see what you mean by go on forever.
-mike
1. Yes some do use oil, mine new in 2000 used over 0.5qt per 1000 miles, now at 33K I use 0.5 per 3k. So watch it now and it will go down.
2. Wippers slow? no clue
3. ticking, yes they are a little loud on cold start up. Also, if you hear a ticking kocking when accelerating you should try a higher octane gas.
4. Starter. New in 2002 when you turn the key it is like a button, Meaning it will run the starter for a certain length of time based on the temp (I think), BUT it is not like the 98-2001, which is, as long as you have the key turned it will crank the engine. I think BMW and some other high end cars have this too.
-Ryan
I have a '99 Rodeo LS. After about 2 years of ownership I began to have A/C problems. I have been back to the dealership 8 times to have repairs made. The problem is that the compressor cycles on and off at the wrong times, and the car never gets cool enough when the outside air is hot. I live in San Antonio, Texas. The last time I was at the dealership a guy from Isuzu worked on it... same problem. I have written to Isuzu and they want me to go back to the dealer.
What say you all? I wanted them to buy back the thing or give me a new one... they didn't like that idea.
Any and all help appreciated.
Andy Anderson
Unhappy Rodeo Owner
I don't know anything about Isuzus and am wondering how long I could expect one to run before it begins having serious problems/needs serious work. Can anyone give me more info re: the Rodeo's longevity?
Phyllis
The most mileage I have then on a 98 Rodeo is 208K, it sold on ebay a few months ago.
If you buy the 99, get all the normal stuff (flush all the fluids, new belts, filters and the such) done all at once and you will easily see 200k!
-Ryan
-mike
